- To:
- Subject: Res: [cgal-discuss] compile cgal by cmake
- Date: Sat, 5 Sep 2009 05:33:39 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=2nlwPYLdkkMQqD/6jx1ia8DUXVqoxgo8z8DvBDh9PM/AfIg5Y/NSAz4TNKBqJiXFVuB5Pnh9+aIpH3mzSenyGe4wkYlneD++KvwUR40OolfPQC0dqV/aAfTMKNQsfmpF7QChBM3708+9qab2mP+4FDjUawz/QWPQkx43m5UHePw=;
Sara, you can use cmake to generate the solutions that you will build in Visual Studio.
The link http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows have a good step-by-step to do it.
De: sara_mahdavi <>
Para:
Enviadas: Sábado, 5 de Setembro de 2009 7:38:40
Assunto: [cgal-discuss] compile cgal by cmake
hi
Can I use CMake to compile CGAL file for Visual Studio?
how use cygwin to compile cgal?
View this message in context: http://www.nabble.com/compile-cgal-by-cmake-tp25307025p25307025.html
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
- [cgal-discuss] compile cgal by cmake, sara_mahdavi, 09/05/2009
- Res: [cgal-discuss] compile cgal by cmake, Marcos R. P., 09/05/2009
