cgal-discuss - Re: [cgal-discuss] Question on Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Question on Triangulation
  • Date: Thu, 10 Sep 2009 21:11:20 +0200
Hi Rahul,
Remove the * befor fit.
The manual
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Cross_link_anchor_1235
says:
Triangle t.triangle ( Face_handle f) Returns the triangle formed
by the three vertices of f.
Precondition: The face is
finite.
and all the face iterators and circulators are convertible to Face_handle.
best regards,
andreas
Rahul Kavalapara wrote:
Hi,
I am trying to output the vertices of triangles in a Triangulation. I tried to iterate over the faces using the faces iterator, output the triangles vertices to std output.
#include <fstream>
#include <CGAL/Triangulation_2.h>
#include <CGAL/Triangle_2.h>
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_2<K> Triangulation;
typedef Triangulation::Vertex_circulator Vertex_circulator;
typedef Triangulation::Point Point;
typedef Triangulation::Finite_faces_iterator Finite_faces_iterator;
int main()
std::ifstream in("triangulation_prog1.cin");
std::istream_iterator<Point> begin(in);
std::istream_iterator<Point> end;
Triangulation t;
t.insert(begin, end);
Finite_faces_iterator fit;
for(fit = t.finite_faces_begin(); fit != t.finite_faces_end(); ++fit)
K::Triangle_2 tri_2 = t.triangle(*fit); <<-- Error
std::cout << tri_2 << "\n";
return 0;
Error:
triangulation_prog1.cpp: In function ‘int main()’:
triangulation_prog1.cpp:39: error: no matching function for call to ‘CGAL::Triangulation_2<K, CGAL::Tds2<CGAL::Tvb<K, CGAL::Tdsvb<void> >, CGAL::Tfb<K, CGAL::Tdsfb<void> > > >::triangle(CGAL::Tfb<K, CGAL::Tdsfb<CGAL::Tds2<CGAL::Tvb<K, CGAL::Tdsvb<void> >, CGAL::Tfb<K, CGAL::Tdsfb<void> > > > >&)’
/usr/include/CGAL/Triangulation_2.h:798: note: candidates are: typename CGAL::Triangulation_2<Gt, Tds>::Triangle CGAL::Triangulation_2<Gt, Tds>::triangle(typename Tds::Face_handle) const [with Gt = K, Tds = CGAL::Tds2<CGAL::Tvb<K, CGAL::Tdsvb<void> >, CGAL::Tfb<K, CGAL::Tdsfb<void> > >]
Am I missing something for the above code.
Rahul
