- To: CGAL Discuss <>
- Subject: [cgal-discuss] How "exact" are CGAL nearest neighbor searches with kd-trees
- Date: Sat, 12 Sep 2009 16:01:08 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type:content-transfer-encoding; b=BN9AZzxa4ATFrRcEEfxuWcm1RZ7FrO4xGZgYEQKU10L8DQZABRcN+1QuvVYcbKDQb6 ZF+Bwdg5IyNJauRzmkxTjCbCUDNaYAlKeBkSexnT5FAi6Ei+RuTGvYrRYpH4+tD1S6Qt N4psUSMq4ESoDReISm4Yoy/+om+1Gf5QP4g1s=
Hi list,
I try to find an implementation of exact nearest neighbor search using
kd-trees. My questions aim at whether it is easy to change the
existing Orthogonal_k_neighbor_search class so the queries are exact.
Building the kd tree should be "exact" even for
Exact_predicates_inexact_construction_kernel since comparison is only
performed on the coordinates but not on the euclidean distance etc.
I have a question regarding the kd-trees in CGAL: In which sense are
the CGAL kd-trees approximate? I have read the source code and there
seem to be at least two points where they are approximate:
First, you can give a double value Eps that tweaks the slack in
comparison when doing the "unrolling" of the recursion.
Second, after finding k approximate nearest neighbours, the search
stops. This means that for k=1 only the downward part of the search is
execute in the kd-tree.
Is this correct so far?
Now in which part are exact arithmetics used? The
Orthogonal_k_neighbor_search class template is parametrized with the
used kernel through the SearchTraits. Naïvely, I would expect that
passing a Exact_predicates_inexact_construction_kernel through the
SearchTraits, except for the two points above, the query should be
"exact".
For computing the distance, Euclidean_distance<SearchTraits> is used.
Are the comparisons exact when using the
Exact_predicates_inexact_construction_kernel?
Also, there are some arithmetic operations like addition and
subtraction used in the source code of the
Orthogonal_k_neighbor_search. Would they harm exactness.
Bests,
-- Manuel
- [cgal-discuss] How "exact" are CGAL nearest neighbor searches with kd-trees, Manuel Holtgrewe, 09/12/2009
