- To:
- Subject: Re: [cgal-discuss] read_xyz_points works too slow
- Date: Fri, 18 Sep 2009 10:45:26 +0200
杨成林 a écrit :
> Hello,
> The new component "Point Set Processing" seems very useful. I compiled
> examples and found them too slow. For
> example,"read_write_xyz_point_set_example.exe" takes 16.5 seconds to
> process 1435 points. This is not tolerable, I think.
> 杨成林
Hi,
On my Linux box (at 3GHz), read_write_xyz_point_set_example.exe takes 0.037
second
(measured with "time" command).
Please check that you are in release mode, i.e. that you ran cmake with the
option
"-DCMAKE_BUILD_TYPE=release".
What is your platform (OS, compiler)?
Best regards,
Laurent Saboret
INRIA Sophia-Antipolis
- [cgal-discuss] read_xyz_points works too slow, 杨成林, 09/17/2009
- Re: [cgal-discuss] read_xyz_points works too slow, Laurent Saboret, 09/18/2009
