cgal-discuss - Re: [cgal-discuss] QGLVIEWER_INCLUDE_DIR
  • To:
  • Subject: Re: [cgal-discuss] QGLVIEWER_INCLUDE_DIR
  • Date: Tue, 22 Sep 2009 10:54:12 -0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=XIR1Y3OXShO7KA4rv6oy+ZDjM6EFqiUdNTp8J5EGcmu2qupK6/DLo0PPVe3QXUx3tM aNdNDEHEkAyECa+9Nhx45cApKVJqJSaz4PDMGU1pH0/EcVST/Ym8HztxDWlvUl90xTz8 BUtRToOuee3JvaRKZPKyfHq7cvCeKuoKA9KsI=
Hi Marcos,
The Windows installer of QGLViewer does not contains the static
library you are looking for. It only installs the QGLViewer DLL at the
system32 directory. However, you can build the QGLViewer2.lib file
from sources. Download the sources from
http://www.libqglviewer.com/src/libQGLViewer-2.3.4.zip and build it
using MSVC, for example.
Best,
Vicente.
