cgal-discuss - RE: [cgal-discuss] A question about 2D mesh generation
  • To: <>
  • Subject: RE: [cgal-discuss] A question about 2D mesh generation
  • Date: Tue, 22 Sep 2009 16:59:15 +0300
Oops, please ignore. Wrong address.
-----Original Message-----
[mailto:]
Sent: Tuesday, September 22, 2009 4:58 PM
To:
...חושב ע"פ שעת תרגול, ל - 40 סטודנטים פלוס תרגול אחראי ותרגילי בית. רק
שתרגילי הבית פרונטליים ואין לזה קריטריון בכלל. כך זה מגיע ל 450 נקודות.
[mailto:]
Sent: Monday, September 21, 2009 7:50 PM
To:
Subject: Re: [cgal-discuss] A question about 2D mesh generation
Le lundi 21 septembre 2009 17:05:18, Amir Vaxman a écrit :
> Do consecutive calls to mesher.refine_mesh() change the mesh, if it is
> already refined and no criteria is added? Suppose that I remove a seed, and
> do refine_mesh() again. Do the triangles of the previsouly-refined domains
> stay the same?
If you change the seeds with mesher.set_seeds(...), then you need to call
mesher.init(), so that the list of bad faces is recomputed. That way, the
next
call to mesher.refine_mesh() will start with the new set of bad faces.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
