- To: cgal-discuss <>
- Subject: Re:[cgal-discuss] terrain simplification
- Date: Thu, 24 Sep 2009 11:14:49 +0800 (CST)
hi,
one alternative way is to simplify the 2.5d points set before you build triangulation on it. refer to the manual for details. cgal_manual/Point_set_processing_3/Chapter_main.html
在2009-09-23, 写道: >Hello. > >is it possible to use mesh simplification on a 2d delaunay >triangulation based on 2.5d points. I would like to simplify a terrain based on >Easting,Norhing,Height values e.g. from an DEM. > >The simplification should keep edges e.g. ridges but remove unnecessary >triangles in flat parts. > >Thanks in advance. >-- >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://lists-sop.inria.fr/wws/info/cgal-discuss
"中国制造",讲述中国60年往事
- [cgal-discuss] terrain simplification, matthias.kunz, 09/23/2009
- Re:[cgal-discuss] terrain simplification, sanlington, 09/24/2009
