cgal-discuss - Re: [cgal-discuss] 2D Triangulation of Shape drawn with mouse
  • To:
  • Subject: Re: [cgal-discuss] 2D Triangulation of Shape drawn with mouse
  • Date: Fri, 25 Sep 2009 19:59:20 -0700
Thank you very much, I will check that out and come back if I dont succeed :)
Thanks!
Am 25.09.2009 um 00:01 schrieb Andreas Fabri:
Hi Matthias,
As I answered Lionel's mail (who also didn't get an answer) : There are
almost no stupid questions, only it is an effort to give a reasonable
answer, this takes time, and people are free to allocate their time
as they want or as it is imposed by constraints.
For the concrete problem, maybe have a look at the Constrained_delaunay_triangulation_2.cpp
demo in demos/Triangulation_2
This demo allows to enter a polygon with the mouse, and then
inserts the edges of the polygon as constraints in a triangulation.
It will still triangulate the area inside the polygon as well as
the outside, so you have to identify the triangles inside by doing
a graph traversal on them.
If your input is not a polyline, but only points then you might
have a look at the Alpha Shape package. This supposed that you
have a rather uniform sampling density for the points on the contour.
hope this helps.
andreas
Matthias Dörfelt wrote:
Is this question too simple, or maybe not accurate enough? If so, please let me know.-
Thanks!
Am 23.09.2009 um 20:28 schrieb <> <>:
Hi,
I am new to cgal and could finally make it work on my mac. I want to use it for
some 2D triangulation tasks and I basically got a simple example to work. Even
though, right now it just traingulates the convex hull (i think thats what its
calles) of all triangles. I want to create concave shapes though, based on the
outlines I draw with my mouse (similar to vector programs, when i click i add a
new point that should connect with the last on and be the outline of the
shape). I figgured, that i would propably have to use constrained triangulation
for that purpose but I could not wrap my head around it. I would be really
thankful if someone could point me into the right direction, or maybe give a
small example!
Thank you!
