- To:
- Subject: [cgal-discuss] New to CGAL, problem with simple operations
- Date: Thu, 1 Oct 2009 18:30:20 +0200 (CEST)
Hi,
I'm very new to CGAL and have been trying to get it to work for quite some
time
now. I am trying to implement the Marching Triangle Algorithm and using CGAL
for that.
The first requirement there is that I need to iterate through all the edges
that lie on the boundary of a model. I can't get it to work properly..
This is what I am using:
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
typedef Polyhedron::Vertex_iterator Vertex_iterator;
typedef Polyhedron::Halfedge_iterator Halfedge_iterator;
typedef Polyhedron::Edge_iterator Edge_iterator;
// main() and making a simple polyhedron out of a triangle.
P.make_triangle(p,q,r);
std::cout << "H Edge info:" << std::endl;
for ( Halfedge_iterator hit = P.vertices_begin(); hit != P.vertices_end();
++v)
std::cout << hit->vertex()->point() << std::endl;
This gives me the following error and I can't understand why is it giving that
error:
error C2440: 'initializing' : cannot convert from
'CGAL::CGALi::In_place_list_iterator<T,Alloc>' to
Can someone please tell me what is it that I am doing wrong and how can I fix
it?
I'd really appreciate any help.
Thank you
/Priyank
- [cgal-discuss] New to CGAL, problem with simple operations, fly2priyank, 10/01/2009
- Re: [cgal-discuss] New to CGAL, problem with simple operations, Laurent Rineau (GeometryFactory), 10/01/2009
- Re: [cgal-discuss] New to CGAL, problem with simple operations, Priyank Jain, 10/01/2009
- Re: [cgal-discuss] New to CGAL, problem with simple operations, Priyank Jain, 10/02/2009
