cgal-discuss - Re: [cgal-discuss] squared_distance and to_double producing NaN
  • To:
  • Subject: Re: [cgal-discuss] squared_distance and to_double producing NaN
  • Date: Fri, 2 Oct 2009 06:36:44 -0700 (PDT)
Hi Sebastien,
> > The point is very close to the segment. I am not sure whether
> > producing a NaN is the behaviour one would have to expect given
> > the kernel I use.
> I do not see your point. You are using a floating point number type
> inside your kernel, so the expected behaviour is that you can get NaN.
Ok, basically that's what I wanted to know. Should have been clear
from the beginning anyway... :-)
Thank you for your answer!
Martin
View this message in context:
http://www.nabble.com/squared_distance-and-to_double-producing-NaN-tp25700793p25715981.html
