[cgal-discuss] Space complexity of the CGAL range search tree: needs large amount of memory
- To:
- Subject: [cgal-discuss] Space complexity of the CGAL range search tree: needs large amount of memory
- Date: Sat, 3 Oct 2009 16:26:12 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=Unn96IZaV6OflBAhq1DvHVifMrd1Kp3mFSTz6hJEUrE1jpS+chpFHnI0HLcUtXRcCuOs1n9PoGaQBIwD6+Opd42n8azyOXtDJS32G7sJVpUULj6/BkymvbmeUKcfZbTOWq28IrHM0rZ0/gQr+CU5518s16oKaYQD/qoPzzhOhwY=;
Dear All, I tried to use the CGAL range search tree as follows. What surprised me is that the more than 2G memory is needed to create a range-search tree with about 36,000 3D integer points. I posed the part of code involving CGAL functions here. Anyway help for reducing the memory requirement is very appreciated. In other words, do I use these CGAL functions in a wrong way? Many thanks! Best, Lincong __________________________________________________ #include <CGAL/basic.h> #include <CGAL/Cartesian.h> #include <CGAL/Range_segment_tree_traits.h> #include <CGAL/Range_tree_k.h> typedef CGAL::Cartesian<int> K; typedef CGAL::Range_tree_map_traits_3<K, int> Traits; typedef Traits::Key Key; typedef Traits::Pure_key Pure_key; typedef Traits::Interval Interval; typedef CGAL::Range_tree_3<Traits> Range_tree_3_type; // The code using CGAL const size_t noOfCube = emptyCube.size(); // the size is 63701 for the example // where the variable "emptyCube" is a "vector<pair<size_t, float> >" std::list<Key> InputList; std::list<Key> OutputList; std::list<Key>::iterator first, last, current; int index, indexX, indexY, indexZ; current = InputList.begin(); for (unsigned int i = 0; i < noOfCube; i++, current++){ index = emptyCube[i].first; indexX = index % noOfStep; // noOfStep == 81 indexY = ( ( index - indexX ) / noOfStep ) % noOfStep; indexZ = ( ( index - indexX ) / noOfStep - indexY ) / noOfStep; InputList.push_back( Key( K::Point_3( indexX, indexY, indexZ ), ( i + 1 ) ) ) ; } first = InputList.begin(); last = InputList.end(); Range_tree_3_type Range_tree_3(first, last); |
- [cgal-discuss] Space complexity of the CGAL range search tree: needs large amount of memory, Tao Go, 10/04/2009
- Re: [cgal-discuss] Space complexity of the CGAL range search tree: needs large amount of memory, Andreas Fabri, 10/05/2009
