cgal-discuss - Re: [cgal-discuss] geomview black visualization
  • To:
  • Subject: Re: [cgal-discuss] geomview black visualization
  • Date: Sun, 4 Oct 2009 19:09:13 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=YQijDfUDoBNERiKjx9/2mRZI45VHXjfxa4WCUJrHaF/QTJZ298Sh0emE4nxd0/njg+ oGtiuoBoROVRKG/ktjcMg+funZ4BYPQb31COGF8AyQ9O05ZbPJCizbtP4ES7FJbfK7Av tTX/XP/sTgK4KNxNI+4q/hQbwA/YFlZmuOaBk=
Thank you for your precise and helpful answer, maybe I'll try with Qt. Best regards
2009/10/4 Laurent Rineau (GeometryFactory) <>
Le dimanche 04 octobre 2009 18:14:58, Sterpa a écrit :
> I got an unusual problem with geomview, it shows an entire black screen in
>  the main window. Trying to rotate or zoom on the visualization the image
>  refresh and shows the right content for just a second, and then again the
>  black background. The code is the following:
> void algorithm_2(vector<Line_2> lines, int k) {
> CGAL::Geomview_stream gv(CGAL::Bbox_3(-100, -100, 0, 600, 600, 0));
> gv.set_line_width(2);
> gv.set_bg_color(CGAL::WHITE);
> gv.set_vertex_radius(5);
> for(unsigned j = 0; j < lines.size(); j++) gv << lines[j];
> getchar();
I thing nobody can help. Geomview has bugs, and so have graphics drivers
(OpenGL drivers). Your code looks correct. In my opinion, you have hit a bug
of either Geomview or your graphics driver (or even maybe a bad interaction
between them).  Pray no to have the last version of both of them, and upgrade!
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D
Engineer at GeometryFactory
http://www.geometryfactory.com/
