cgal-discuss - Re: [cgal-discuss] Vertex index in a Cell (Delauney 3D)
  • To: <>
  • Subject: Re: [cgal-discuss] Vertex index in a Cell (Delauney 3D)
  • Date: Thu, 8 Oct 2009 00:42:08 +0200
I want to know the original vertex index of each vertex.
For example, if I gave 100 vertices and a cell is made of vertices
30,31,40,49, I want to know these indices, 30,31,40,49.
This information is not stored in the triangulation. You will have to do the conversion from Vertex_handle to original indices yourself.
You have two options for this: either storing the original index in the vertex (check the Vertex_with_info class), or building a std::map<Vertex_handle, size_t> while you insert the points into the triangulation.
Note that if you insert the same point more than once, only one vertex is created...
Camille
