Re: [cgal-discuss] The Problem in calculate the intersection of two X_monotone_curve_2
- To:
- Subject: Re: [cgal-discuss] The Problem in calculate the intersection of two X_monotone_curve_2
- Date: Sun, 11 Oct 2009 09:45:18 +0200
Please include the relevant code.
Quoting zickphy
Hi all,
I get a problem in programming of compile. Here is my code, please help me
to resovle it, Thanks a lot!!
typedef CGAL::CORE_algebraic_number_traits Nt_traits;
typedef Nt_traits::Rational Rational;
typedef Nt_traits::Algebraic Algebraic;typedef CGAL::Cartesian<Rational>
Rat_kernel;
typedef CGAL::Cartesian<Algebraic> Alg_kernel;
typedef CGAL::Arr_conic_traits_2<Rat_kernel, Alg_kernel,
Nt_traits>Conic_traits_2;
typedef Rat_kernel::Point_2 Point_2;
typedef CGAL::Polygon_2<Rat_kernel> Polygon_2;
typedef CGAL::Gps_traits_2<Conic_traits_2> Gps_traits_2;
typedef Gps_traits_2::Polygon_2 Offset_polygon_2;
typedef Gps_traits_2::Polygon_with_holes_2 Offset_polygon_with_holes_2;
typedef Gps_traits_2::X_monotone_curve_2 X_monotone_curve_2;
typedef Gps_traits_2::Point_2 Query_Point_2;
void main {
Query_Point_2 pt1(0, 0);
Query_Point_2 pt2(0, 10);
Query_Point_2 pt3(10, 0);
Query_Point_2 pt4(0, 10);
std::list<Query_Point_2> pts;
X_monotone_curve_2 is1(pt1, pt2);
X_monotone_curve_2 is2(pt3, pt4);
X_monotone_curve_2 iss[] = {is1, is2};
compute_intersection_points(iss, iss+1, std::back_inserter
(pts));
And I got the compil errors as those:
d:\cgal-3.5-beta1\include\cgal\sweep_line_2_algorithms.h(134) : error C2039:
“Traits”: is not a member of “CGAL::Default_arr_traits<Curve>”
etc.....
Please help me on this problem, thanks!!
View this message in context: http://www.nabble.com/The-Problem-in-calculate-the-intersection-of-two-X_monotone_curve_2-tp25740486p25740486.html
- [cgal-discuss] The Problem in calculate the intersection of two X_monotone_curve_2, zickphy, 10/07/2009
- Re: [cgal-discuss] The Problem in calculate the intersection of two X_monotone_curve_2, efif, 10/11/2009
- Re: [cgal-discuss] The Problem in calculate the intersection of two X_monotone_curve_2, zickphy, 10/11/2009
- Re: [cgal-discuss] The Problem in calculate the intersection of two X_monotone_curve_2, Efraim Fogel, 10/12/2009
- Re: [cgal-discuss] The Problem in calculate the intersection of two X_monotone_curve_2, zickphy, 10/16/2009
