cgal-discuss - [cgal-discuss] plz respond and help
  • To:
  • Subject: [cgal-discuss] plz respond and help
  • Date: Sat, 17 Oct 2009 00:06:19 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=bS3LdrKPDmjJXKTclw2k60cAAEYGqOJKLlx0eFcPHBtl07LABDSWMgF5bhUYyU141a53sf2tzoAtCOzZSYCFVkNlXAS4zxcbC5HpyRAlwscOQKlA3CmgWzPGqHr+o9E/Ee05FOB3vExmIoxLBpFTeoJsIEbc67u6GMxMnkBBCKk=;
hi,
m a new user of CGAL2.4. M using it because i have downloaded obstacle mobility model for ns2 which requires CGAL2.4 installed. my system is redhat server 5.2 on which i installed gcc-2.95.3 compiler. however when i try to build CGAL libraries in interactive mode i got this error for shared libraries. i dont know what should i do. plz help me.
Error printed is:
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c aff_transformation_tags.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c assertions.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Bbox_2_intersections.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Bbox_3_intersections.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c cgal_logo.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Color.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c File_header_extended_OFF.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c File_header_OFF.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c File_scanner_OFF.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c File_writer_inventor.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c File_writer_OFF.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c File_writer_VRML_2.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c File_writer_wavefront.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Geomview_stream.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Interval_arithmetic.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c io.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c MP_Float.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c optimisation_basic.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Origin.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Random.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Real_timer.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Timer.C
/usr/local/bin/g++ -fpic -O -Wall -ftemplate-depth-25 '-I/root/CGAL-2.4/include/CGAL/config/i686_Linux-2.6.18-128.el5_g++-2.95' '-I/root/CGAL-2.4/include' -c Triangulation_3.C
/usr/local/bin/g++ -Xlinker -shared -o ''libCGAL.so \
`ls *.o | awk '{for (i=1; i<=NF;++i){printf "";print $i}}'`\
/usr/lib/libc_nonshared.a(elf-init.oS): In function `__libc_csu_init':
(.text+0x2b): undefined reference to `__init_array_end'
(.text+0x34): undefined reference to `__init_array_start'
/usr/bin/ld: libCGAL.so: hidden symbol `__preinit_array_start' isn't defined
/usr/bin/ld: final link failed: Nonrepresentable section on output
collect2: ld returned 1 exit status
make: *** [lib] Error 1
