cgal-discuss - [cgal-discuss] Error on 3D boolean difference operation on Nef Polyhedra
  • To:
  • Subject: [cgal-discuss] Error on 3D boolean difference operation on Nef Polyhedra
  • Date: Mon, 19 Oct 2009 11:03:42 +0200 (CEST)
Hello,
I test to process a 3d boolean difference operation on 2 polyhedrons and an
error occurs.
The 2 polyhedrons are stored in 2 off files, A.off and B1.off, who are joined
to this message.
I'm working with CGAL Release 3.3.1.
I use a kernel of type GAL::Homogeneous<CGAL::Gmpz>.
The polyhedrons are read in the off files ; they are valid and closed.
The polyhedrons are converted into nef_polyhedrons : the nef_polyhedrons are
valid.
When the difference between A nef_polyhedron and B1 nef_polyhedron is process,
an error occurs.
I have to replace the B1 polyhedron by the B2 polyhedron (the off file is
joined to this message).
B2 is the x-translation of B1 of ten units.
In this case the process succeeds.
Could you give me an idea on origin of the error.
Thanks in advance.
Alexandre Carbonel
A.off
OFF
6154 12304 0
7953 102 2867
23631 17267 2211
23099 12881 2318
22951 13643 2409
23701 13227 2481
24054 13301 2552
23807 12425 2251
23571 13034 2457
24854 14081 2795
23449 12621 2276
23311 12789 2298
24846 12873 2668
25074 13190 2719
24003 12188 2231
24413 11933 2190
25195 13238 2682
18131 16237 2585
22612 12541 2329
23846 12728 2360
23735 12263 2125
23276 11629 1930
23525 11983 2030
23257 11687 1932
23264 11756 1988
24115 12141 2220
23536 12315 2147
23693 11769 2081
24890 11781 2146
22351 14457 2410
22442 14228 2364
22243 13279 2322
22809 12959 2343
23181 12775 2306
24126 12054 2218
25109 11661 2120
22081 12759 2412
23526 11884 1986
23404 11761 2041
23367 11713 2026
23179 12626 2218
23318 12587 2246
23576 12142 2067
23876 12084 2159
23395 12003 2106
23756 12031 2154
23469 11621 1930
23506 11771 1972
23939 11035 1888
23387 11367 1864
23599 11317 1945
23421 9624 1800
24421 11522 2021
26624 17562 2065
25874 16688 2497
25951 16903 2384
26324 18800 1651
26164 18747 1655
24774 16985 2188
26268 18574 1652
26125 17891 2002
25910 18338 1693
18445 21345 1825
25766 18876 1727
25978 18867 1690
26153 18865 1664
26434 18620 1637
26407 18763 1640
19778 8644 2633
24956 10909 1857
7232 4600 2970
5410 5452 2868
2592 6082 2723
2369 6235 2627
2186 6200 2672
1884 6040 2647
2203 6588 2703
1955 6554 2684
2155 6426 2670
2397 6073 2700
721 9013 2823
2505 6187 2655
2545 5815 2728
4120 5968 2791
5004 5550 2841
5705 5125 2892
5326 5225 2900
6308 4936 2909
1921 6729 2713
617 9169 2814
12721 19293 2328
494 9981 2843
1870 6725 2710
1759 6185 2673
1310 7860 2749
1734 6572 2736
622 9457 2834
4285 5938 2787
5534 6884 2632
1938 6869 2708
1000 9428 2847
987 9713 2850
3178 6131 2720
2595 6333 2693
6751 3616 3019
7580 2974 2965
7748 3070 2966
7536 3995 2986
7201 4408 2979
9336 5774 2777
9158 5814 2830
10823 5651 2938
6925 4500 2975
6120 4745 2959
6656 4693 2958
8383 7308 2528
9438 5232 2896
5188 6578 2675
6160 6030 2772
6334 6129 2774
9334 5708 2823
7659 4748 2959
7522 4462 2978
7749 10242 2769
7680 10018 2740
7620 10270 2765
6345 7041 2573
6618 7110 2563
5415 7014 2631
6532 6206 2686
19696 8345 2624
10744 7814 2503
12605 10633 2677
10032 7865 2505
8546 9746 2682
8477 9952 2721
8307 10118 2739
7361 7432 2543
7996 9722 2720
8163 7286 2533
6680 7244 2542
6427 7335 2543
7177 10642 2771
5601 6085 2762
8217 10211 2760
8038 10373 2782
8112 10819 2807
1584 9927 2839
1935 9928 2837
2105 9816 2833
8685 10187 2719
6670 11897 2718
7389 4282 2961
10937 4859 2997
7554 4086 2970
7777 4009 2976
14501 6411 2906
7047 4562 2953
6878 4766 2956
16765 17090 2447
17952 16394 2571
17147 16930 2497
17786 16600 2535
17761 16633 2556
22878 18422 2102
17912 16515 2567
17013 16955 2467
17830 16501 2569
17409 16789 2495
17576 16634 2544
17701 15557 2639
16423 15714 2675
16844 17028 2463
18234 15698 2600
23350 18611 1848
25922 16384 2569
17284 16824 2516
16614 17794 2372
16885 18842 2310
17500 20068 2250
17488 19878 2255
17807 19817 2128
15458 16230 2657
17959 13549 2138
23037 17772 2397
22914 18419 2122
22539 18506 2073
22481 18617 2079
22673 18627 2047
23114 18409 2073
22188 17943 2332
22024 17821 2332
21901 18036 2162
23628 17798 2038
22441 18471 2107
22357 18417 2117
22327 18531 2085
22994 18380 2131
22798 18692 2020
22360 18645 2020
22624 18061 2390
22746 18082 2386
22246 19302 2425
20943 20717 1914
22538 19418 2415
22459 19183 2391
22711 19167 2306
22209 19275 2420
21985 19199 2456
22144 19158 2433
21803 19100 2450
21945 19217 2440
21917 18890 2440
21695 19044 2444
21541 18988 2460
21516 18974 2458
22033 18328 2045
21795 19693 1996
20295 9924 2625
19585 8306 2592
19496 8022 2602
19599 8189 2628
18950 9278 2340
19849 8571 2607
19765 8310 2603
20870 8494 2419
21429 8896 2202
21221 8662 2262
15227 9981 2329
18681 7082 2693
19540 7940 2601
19216 7927 2399
19815 11531 2128
19826 11011 2228
18993 8975 2329
18008 10879 2150
17635 10202 2252
16232 10721 2425
17937 9943 2346
17181 10465 2242
18510 10261 2323
18399 9796 2327
17398 10504 2246
19089 9666 2323
19975 11047 2202
20308 10748 2331
18883 11061 2132
19707 11549 2224
19697 11152 2133
15341 10260 2421
15320 10383 2385
14173 9893 2417
14843 10837 2391
14663 11174 2674
14600 11048 2677
14413 9742 2394
14169 9679 2417
14574 11486 2660
14518 11485 2667
13402 9353 2346
13481 9506 2476
13350 9449 2481
13592 9502 2477
12690 13395 2795
11101 13243 2806
13381 9592 2480
12023 8413 2492
17820 10068 2334
18668 10411 2312
18590 9990 2332
18188 10261 2408
18409 10322 2379
18040 10121 2328
18287 10179 2328
18788 10318 2319
15265 10063 2304
15143 10245 2432
16329 12721 2144
16218 12858 2323
15112 10808 2384
16036 10269 2257
16135 12781 2327
16085 12903 2384
14716 12012 2409
17065 13191 2231
17419 13410 2226
15948 12538 2430
17272 13240 2226
16320 13132 2330
16730 13505 2530
17286 14125 2637
16901 13199 2323
16321 13025 2343
16753 13205 2328
16673 13180 2345
16285 13264 2335
16390 13338 2332
16543 13174 2330
18197 13768 2235
17902 13623 2244
17834 13552 2247
18104 13696 2240
18061 13615 2170
18453 7477 2694
14816 10446 2389
15022 10225 2424
14020 10848 2665
14797 10659 2399
14687 10747 2618
14539 10576 2567
15625 10026 2298
16034 11220 2402
14713 11590 2399
15165 11316 2387
14802 11355 2402
14765 11303 2575
14635 11670 2560
14519 11908 2557
14685 11334 2633
16019 11677 2417
14635 11820 2415
14713 11086 2618
15202 12670 2423
15078 12180 2397
14715 12320 2413
14597 12062 2549
14584 11742 2542
14519 11668 2663
14550 12338 2549
14399 11888 2644
15859 12593 2414
15537 12320 2396
15579 12828 2416
14425 12118 2563
14014 12343 2663
15696 13155 2602
15872 13211 2621
14390 12580 2610
22830 13127 2408
22573 12910 2374
18126 15892 2605
18625 13879 2243
15776 13315 2720
16428 13553 2659
17223 14103 2704
17320 13751 2524
17505 13766 2464
17443 14366 2662
17254 13823 2597
17365 14000 2642
17697 14101 2637
18255 14191 2499
17959 14170 2581
18424 14296 2474
18525 14180 2271
22345 18033 2347
18649 16316 2577
17483 16897 2491
17189 17077 2443
14573 10769 2639
12962 10499 2603
14701 11224 2605
14735 11421 2545
14657 10906 2659
14667 11526 2565
14493 11257 2757
14569 11317 2684
14409 11701 2667
14274 11776 2769
14263 11925 2666
14194 12224 2645
14127 12486 2637
14245 12305 2572
14703 10613 2600
13873 12391 2761
14012 12203 2761
14132 12336 2638
13823 12258 2789
13830 14609 2732
14110 12792 2755
13596 15534 2585
13780 15042 2674
14843 12919 2633
14515 13070 2711
14290 13040 2731
15015 13120 2692
15499 12940 2465
15122 14974 2807
16052 13600 2721
16245 13600 2719
16401 13540 2680
15695 14944 2778
16446 15357 2718
14178 12090 2656
14072 12503 2639
14277 12425 2558
14598 12733 2595
14622 12623 2585
17563 14362 2671
17058 13872 2664
16868 13918 2694
16517 13729 2689
16273 13858 2727
15221 13170 2692
14926 12683 2511
14986 12937 2663
21829 17943 2179
21719 17980 2057
19722 15369 2091
20499 16366 2304
19842 15841 2132
19951 15408 2236
21702 13142 2363
18202 14306 2533
19782 15177 2197
18866 15220 2419
18714 15100 2420
18715 15187 2436
21977 13042 2362
19579 14980 2138
21551 18461 2489
22316 17989 2332
21376 18091 2324
22279 18340 2140
21430 17946 2341
21345 17645 2075
21448 17693 2073
21481 16955 2557
22113 18210 2147
22012 18175 2151
21381 17461 2308
22266 17787 2408
21554 17765 2071
20430 15562 2418
21264 17262 2338
20942 16895 2339
21093 17069 2349
21017 17021 2338
20704 16935 2073
20804 16796 2300
20539 16911 2123
20736 16681 2310
20419 16213 2304
20173 16331 2066
19097 16352 2315
20028 16172 2134
20634 16405 2314
20620 16510 2306
20192 15934 2291
20751 16089 2492
19288 16055 2322
20084 15622 2247
20065 15758 2252
20139 15827 2272
20430 16187 2304
20257 15863 2293
20644 15927 2495
20966 17242 2074
21032 17510 2174
21489 17494 2237
21742 18235 2360
20915 17419 2152
19778 15112 2207
20182 13003 2461
20501 15937 2423
21573 13408 2365
21773 14141 2365
21597 13763 2364
21918 17732 2331
22564 14361 2410
23356 15827 2574
23586 15624 2580
22793 17267 2549
22870 13819 2409
22760 14113 2411
22595 13939 2365
22608 13453 2362
22777 12997 2349
22644 13140 2411
22806 11827 2185
22194 12672 2447
22408 12698 2430
22534 12996 2411
22331 12794 2425
22721 12687 2291
22668 12170 2247
19932 10471 2470
20396 10001 2607
19902 10882 2333
19375 9912 2321
19587 10331 2324
20690 9259 2600
20006 9356 2609
19733 9540 2373
20437 10803 2330
20162 11079 2185
20071 11178 2156
20342 10910 2343
20077 10446 2503
19742 11433 2130
20288 11114 2150
21151 10294 2515
20523 10370 2597
20382 10118 2581
19759 10766 2329
19616 10707 2337
19738 10976 2202
19767 10177 2374
19719 10428 2449
19784 9886 2382
20124 9737 2582
19948 9234 2610
19928 20082 1780
19731 20246 1780
18039 16738 2517
20795 9806 2599
21074 10366 2559
20701 10442 2567
21080 8887 2353
22559 12835 2382
26052 16030 2616
22220 10826 2172
21078 10636 2538
18036 6621 2738
14791 11043 2406
15574 10129 2292
16323 10178 2246
16001 6830 2843
16127 6862 2835
16655 6983 2843
16674 7033 2678
14085 5740 2885
14792 9734 2376
13794 9273 2328
18145 10310 2276
18042 10510 2272
18108 10221 2380
17904 10249 2266
17964 10150 2369
17741 10126 2390
17717 10511 2263
17303 9936 2390
17494 10166 2247
17777 10684 2143
18456 10839 2139
17426 13121 2159
17187 13041 2118
23688 17928 1959
22942 17556 2415
17698 13644 2229
17833 13686 2226
17862 13793 2403
17989 13853 2417
15741 13233 2698
16171 13246 2560
16018 13253 2573
16279 13479 2672
16370 13397 2558
16836 13277 2314
16707 13697 2651
16679 13408 2535
17370 13624 2442
18152 13893 2235
18109 13952 2438
18184 14036 2437
18229 14150 2452
20777 10901 2459
16853 10605 2195
17066 10541 2173
17583 9941 2336
17126 7482 2498
11038 7596 2554
11301 6500 2701
10630 6842 2698
11457 6151 2770
11409 7822 2503
17308 10923 2135
17025 10949 2154
17050 13297 2308
17813 12516 2123
17594 13407 2218
13453 4857 2853
13135 4912 2859
20318 15995 2315
20354 16138 2304
20278 16056 2303
20698 16036 2496
20558 15829 2426
20260 15285 2431
20127 15172 2412
20211 14731 2389
19804 15308 2185
18619 14150 2242
18397 14454 2472
18439 14439 2421
18167 13671 2162
19873 13703 2357
20640 12460 2518
20232 13161 2511
20802 11421 2331
20664 11746 2323
20535 12494 2540
21026 11285 2474
20822 11841 2482
20954 11565 2480
20947 11137 2494
20184 13602 2468
19970 13435 2381
20081 13273 2405
20547 12836 2525
20563 13113 2512
21372 12025 2455
20743 11868 2472
20669 12030 2476
20718 12033 2487
20845 11684 2476
21916 11475 2431
20505 10603 2536
20764 11089 2332
20386 11998 2319
20533 11693 2331
20590 11894 2318
20292 12697 2452
18707 13666 2104
18649 13723 2137
19949 13320 2384
19641 13530 2279
19759 12940 2324
19194 13916 2123
19213 14082 2185
19666 13077 2316
19744 13674 2271
19849 13989 2418
19673 13924 2260
18541 14265 2345
17055 18335 2322
16466 17566 2436
16468 17676 2360
16612 17598 2374
18738 17943 2516
17726 16979 2489
18930 17886 2310
18835 17812 2310
19100 17597 2318
16924 18329 2314
16496 18350 2316
18333 16971 2302
17379 18799 2311
15973 17704 2414
16349 17286 2410
16227 17724 2346
15392 18587 2326
16398 17893 2334
15304 17964 2380
15871 17843 2427
16948 19705 2283
17261 20010 2265
14567 18192 2366
14913 18194 2363
12873 14863 2595
14513 17192 2511
12792 19254 2323
14791 23004 2263
15151 22934 2280
14977 23109 2284
15458 23156 2322
15380 18200 2390
14496 19822 2407
16545 19519 2322
12930 19510 2331
15360 18470 2316
14971 18582 2331
15060 18930 2327
16614 20824 2299
15012 18653 2306
15099 18866 2306
15084 18477 2305
15092 18395 2336
15284 19381 2327
15429 18908 2325
15724 18841 2307
15720 19389 2329
16067 18601 2319
15794 17836 2410
15643 18147 2336
15704 18526 2306
15743 18401 2318
14124 18311 2341
14647 19383 2327
13734 19588 2330
15486 17784 2402
15082 18285 2364
20003 21887 2346
20847 21407 2003
22125 18330 2121
21767 17822 2206
22204 17572 2502
22562 17583 2496
22506 17794 2404
21433 17338 2332
21339 17369 2331
18667 13528 2105
19282 13441 2205
19616 13283 2305
16857 12237 2129
16606 13075 2132
14895 10221 2425
15618 10335 2419
14776 10580 2404
16247 10804 2415
16191 10966 2418
15896 10595 2387
15653 10931 2384
16142 11045 2415
16153 10592 2412
16978 11275 2201
16517 11608 2149
15958 11665 2402
14775 11411 2398
16012 11861 2414
16092 13158 2352
14986 11710 2392
16056 11454 2409
15622 11407 2386
16132 11172 2409
16131 10749 2398
15867 10427 2414
15202 10276 2422
14870 10300 2393
19182 14250 2233
19068 14337 2254
18341 14750 2529
18752 13942 2244
14110 5080 2876
19613 8440 2372
19507 8250 2374
19281 7832 2597
19120 7543 2622
18610 7611 2610
18820 7436 2642
19199 7354 2669
13193 5216 2931
13071 5185 2850
10133 4463 2960
13643 4717 2848
15071 9778 2347
19034 7078 2651
19307 7481 2658
21145 8092 2239
19334 7614 2614
19410 7601 2652
18915 7115 2694
17501 7336 2712
17810 7466 2704
17668 7528 2659
17523 7078 2810
13314 9369 2483
13974 9626 2435
16070 6992 2649
15821 6972 2639
14614 9734 2387
14546 9692 2336
14569 9950 2390
15306 6712 2908
15416 6722 2898
15559 6741 2889
15503 6774 2876
15870 6786 2872
16736 9725 2359
17369 7420 2696
17370 7904 2488
17278 8028 2494
17141 10429 2226
16516 10552 2194
15818 9991 2293
14652 9774 2375
15942 6851 2670
14980 6735 2892
12789 9160 2485
14452 6453 2916
12367 9022 2491
12910 7700 2387
14678 6612 2917
12009 8573 2492
11715 8080 2493
13333 7568 2212
13287 7409 2378
14422 6555 2868
14305 6533 2733
14381 6610 2731
22381 17663 2491
23007 17859 2391
22428 17941 2399
22953 17934 2389
22782 17659 2407
23060 17147 2429
22606 17520 2502
21916 17684 2325
23475 17423 2204
22047 17462 2502
23156 17339 2426
23217 17202 2428
23160 16767 2538
23258 14378 2555
15730 12911 2420
15932 12114 2406
16140 12362 2310
15960 12705 2415
15870 12785 2437
18587 13810 2231
18928 14303 2258
18995 14521 2342
19002 14194 2101
20126 14755 2409
19674 14640 2326
19524 14643 2213
19525 14064 2261
19116 14142 2106
18798 13753 2108
18849 14064 2261
18936 14359 2246
18598 14383 2409
18394 14937 2487
18358 14833 2476
18745 14444 2245
18627 14453 2250
18321 15195 2551
18454 14758 2455
18290 15096 2525
18573 14621 2426
18694 14348 2251
18628 14606 2356
18490 15260 2482
18473 15547 2598
18736 16097 2597
18914 16020 2487
19532 15191 2093
19420 15259 2174
18526 15851 2588
18506 16513 2561
18762 16236 2583
17552 14722 2683
18454 15149 2516
18608 15778 2588
18903 15541 2321
18891 15757 2473
18732 15717 2505
19157 7829 2373
18750 8032 2385
18182 7502 2677
18591 7544 2655
18922 7586 2647
19080 7578 2649
18574 7457 2662
19407 8030 2373
18392 7635 2554
17844 7533 2660
18221 7914 2491
17618 7413 2712
17027 7882 2497
17137 7299 2697
17306 7353 2712
17321 7182 2796
17470 7243 2784
18997 7784 2432
18930 7205 2642
18544 7246 2666
18735 7129 2673
18279 7429 2671
18134 7419 2687
17747 7031 2778
16367 6918 2839
16487 6935 2839
16572 6992 2673
17282 7075 2824
17342 6905 2809
16737 6982 2842
16942 7115 2691
16425 6959 2667
16291 6935 2665
16283 6907 2838
16174 6910 2659
16673 9805 2370
15538 5687 2932
15307 5621 2933
16397 7052 2657
16220 7022 2654
15815 6812 2853
17665 6612 2800
16091 6805 2861
16226 6810 2864
16341 6769 2840
16828 7332 2677
14836 6573 2895
14375 6717 2721
14340 6760 2571
12484 6534 2518
11965 8169 2566
15052 6913 2670
15164 7000 2487
18179 6322 2764
15827 5546 2929
15301 5488 2920
16378 6676 2856
16338 5336 2925
16080 6721 2843
14710 6695 2898
15456 6011 2920
12337 6076 2754
14522 5098 2901
14687 5914 2930
12633 6042 2630
15065 6162 2919
14029 6095 2741
13772 4842 2850
13924 5299 2874
14083 4778 2860
13339 5118 2915
15718 6761 2877
15643 6785 2876
15176 6741 2889
15495 6974 2642
15545 6848 2666
15214 6701 2906
15382 6824 2692
16321 8119 2368
15278 6824 2705
15228 6940 2664
15951 6741 2866
18416 7208 2703
18134 7373 2719
17991 7350 2738
17886 7177 2748
17684 7362 2709
17682 7151 2764
17382 7061 2798
17103 7159 2809
17014 7078 2815
17801 7116 2783
17971 7127 2763
13457 4983 2919
13277 5085 2926
13154 5270 2892
14015 5787 2871
13168 5030 2857
13624 4838 2913
13715 4932 2882
13911 5817 2752
13996 5651 2897
13023 5350 2838
12729 5597 2801
11993 5967 2776
11033 7832 2514
12322 8515 2357
12282 8614 2525
14606 6714 2868
14277 6361 2880
14234 5959 2902
13455 5616 2583
13521 5458 2767
13873 5313 2900
13931 5500 2901
13790 5164 2869
13490 5168 2866
14183 6205 2878
14440 6173 2915
14130 5857 2911
16045 6876 2667
16939 7340 2678
15330 6760 2888
14809 6789 2703
14696 6904 2693
14694 6726 2728
14284 6247 2913
12619 5401 2822
12633 5557 2799
12556 5772 2776
12597 5794 2822
12892 5094 2859
15632 6390 2898
14210 5614 2903
14061 5487 2885
12180 6188 2754
11814 7980 2574
11824 8080 2560
12041 8320 2547
12486 8804 2531
14548 6715 2723
12751 9000 2531
12992 9184 2529
13162 9264 2516
14116 8927 2280
13249 9048 2254
11665 6689 2647
10567 6053 2875
9583 4854 2905
9044 5352 2902
11746 6683 2682
12628 4967 2884
22867 13465 2413
7200 3030 3000
7766 3413 2954
7339 3424 3000
7168 1415 2998
7816 369 2900
8077 771 2918
8098 835 2904
7961 952 2929
7510 1043 2964
7918 1352 2944
7904 1473 2921
7361 1694 2997
7155 2449 2999
7762 2934 2942
7835 1581 2947
7721 2383 2928
9521 4961 2920
8082 2829 2937
7926 2817 2927
13235 4363 2883
7880 4102 2976
8771 4224 2981
7735 2087 2939
7814 1709 2935
8366 2733 2903
7880 2304 2918
7975 3185 2949
7395 2145 2979
7168 2247 3000
6620 4330 3000
15540 11861 2392
15013 12568 2421
14748 12485 2537
15130 12712 2498
14768 10871 2593
14764 10477 2537
14785 11145 2410
11695 7992 2546
11780 6769 2636
11314 7742 2558
12232 6353 2701
12131 6498 2678
11867 7608 2280
11575 7375 2392
11648 6800 2673
11675 6881 2637
11523 7192 2587
12515 7544 2278
11507 7380 2556
11551 7608 2566
11509 7734 2564
11742 7922 2564
11603 7758 2547
11571 7195 2477
11993 6419 2712
11354 7407 2584
12292 6161 2718
12829 7857 2390
12095 6598 2661
11932 6620 2658
12088 6695 2472
11944 6724 2473
12037 6878 2464
17124 7242 2696
16510 7294 2655
15736 6861 2662
15012 7344 2487
15101 6835 2685
14854 6903 2676
14562 6842 2709
12313 6326 2707
12336 6333 2599
14100 6025 2866
13974 5876 2746
13750 5746 2582
13565 5500 2586
13583 5167 2838
17119 9894 2388
17137 10123 2226
16938 10083 2217
16784 9798 2389
15675 9367 2391
16504 7166 2658
16466 7070 2659
16226 7356 2465
15935 7452 2525
15702 7652 2394
14811 8401 2359
17142 8273 2345
12708 5714 2828
13918 6070 2571
12463 5936 2796
12570 5874 2793
16694 11839 2211
18345 8414 2457
16921 7630 2496
16934 7758 2498
18326 8330 2468
16948 8580 2349
17894 9400 2344
15975 9637 2267
15965 9641 2277
16461 9514 2351
16744 7763 2368
17385 9888 2353
19091 10822 2218
18863 10653 2336
18443 12361 2248
19271 12332 2131
18619 10977 2105
18559 10616 2303
18672 10859 2135
18229 10585 2285
16972 10739 2163
19155 10919 2158
19327 10659 2335
19783 10577 2330
23524 17584 2105
23587 17764 2038
23842 17911 1912
19319 9243 2330
20004 9735 2562
19913 10055 2526
20491 15773 2421
20380 15670 2406
20201 14863 2450
17874 17227 2516
4350 4518 2963
7202 0 2900
22567 17355 2528
22905 17027 2534
22333 17400 2526
21641 17596 2248
23306 16897 2431
23464 16807 2359
23422 16453 2423
22698 17392 2566
22694 17115 2503
22484 17442 2494
22018 17351 2527
21592 17443 2311
21708 17102 2542
21267 17217 2350
21146 17151 2359
21351 16808 2565
23407 15204 2580
21206 16593 2568
20883 16849 2312
20670 16558 2297
22630 14666 2463
22468 14780 2444
21100 15394 2457
20101 15118 2402
20048 14950 2402
20165 15030 2452
19900 14511 2421
20248 14428 2410
20305 14613 2339
21287 15170 2418
20798 14782 2397
20711 14710 2379
20770 15309 2420
20325 14759 2445
23442 15891 2527
21507 16825 2562
21201 16303 2568
23692 16174 2476
21583 16693 2538
22854 15351 2505
23117 16014 2527
22308 16771 2467
22351 17053 2494
20777 12318 2508
20462 14756 2423
18591 15378 2492
19109 16489 2141
22063 18554 2223
21710 18880 2461
22239 18549 2022
18735 14675 2396
18772 14866 2405
19449 15042 2091
18594 14976 2394
19249 16219 2327
20249 16462 2064
18949 16147 2507
19953 11800 2184
20346 11464 2146
20436 10983 2334
20021 10942 2330
19900 12626 2343
19750 13011 2304
19834 12775 2333
20609 11294 2335
20564 11150 2346
20800 11247 2331
19649 11920 2246
19314 12080 2243
20008 12551 2327
20116 12413 2327
20224 12230 2322
19374 12216 2239
18401 12298 2250
19518 12270 2240
19819 11806 2175
19368 11944 2242
19768 12342 2186
19716 12072 2249
19675 12574 2183
19655 12210 2243
19176 12406 2136
19483 12359 2187
19430 12577 2167
19237 12725 2181
19148 12815 2132
18417 13712 2214
18736 13558 2119
18648 12684 2128
18973 13519 2130
18915 13628 2107
19451 13183 2216
19192 13135 2213
19238 13316 2214
19325 12860 2183
18976 11454 2125
19048 10643 2312
19783 10036 2385
19114 10190 2325
19245 9167 2351
18716 8355 2338
19133 8774 2329
19098 9489 2329
18598 10351 2349
18680 10641 2313
19618 10490 2322
19947 10605 2334
19736 10257 2413
19723 10039 2376
19657 9962 2325
19742 9870 2383
20019 9542 2575
19889 9147 2612
19679 8706 2384
19404 8907 2353
19481 8777 2330
19105 7752 2396
19116 7972 2368
19245 8509 2373
18687 8432 2386
18708 8522 2336
19623 9287 2341
16945 11357 2154
18108 12776 2124
17409 13235 2100
18110 11146 2116
18675 12090 2122
17532 13126 2111
17491 13313 2129
11265 7534 2557
18568 8439 2331
18021 7624 2609
18830 7909 2422
18784 7681 2552
18971 8843 2391
18532 8918 2333
18538 9072 2332
17516 9738 2393
18809 8967 2368
17323 9313 2346
17697 9498 2337
18153 9157 2329
18119 9903 2328
18053 9421 2338
16265 8763 2384
16693 7583 2488
18037 8461 2527
17390 9765 2342
17948 8381 2485
18110 8426 2485
18207 7670 2558
18828 7717 2559
12557 6097 2714
12441 6263 2597
12653 5950 2722
12361 6260 2716
12334 6527 2470
12241 6407 2595
12062 6404 2681
12736 5919 2680
12865 5762 2727
5813 5608 2811
5670 6357 2761
7486 7018 2526
6200 6331 2765
3850 6165 2743
5599 6937 2616
6212 6858 2621
5713 6651 2662
6064 7649 2537
2108 6098 2643
1906 5725 2684
1885 6060 2668
2406 5941 2728
5818 4866 2941
3295 5939 2764
3395 5966 2736
2924 6048 2697
6023 4989 2929
5582 5132 2906
4505 5709 2812
3836 5865 2770
3125 6025 2720
3438 5845 2798
2804 6115 2691
2335 5842 2712
9283 6435 2623
7596 6218 2760
6342 5071 2923
8353 11048 2801
23579 14897 2679
23370 14010 2514
23899 13545 2551
19760 14715 2355
19408 14689 2208
19902 14155 2408
19033 14755 2351
19575 14875 2205
19455 14747 2135
19867 14760 2390
18667 14786 2378
19033 15085 2355
18577 15192 2414
18859 15344 2441
18801 15502 2452
18233 16785 2516
19240 14929 2183
19139 14670 2331
19282 14386 2291
18808 15657 2456
18694 14876 2382
19313 14266 2292
19177 16163 2309
18963 15848 2490
21788 18079 2060
20970 18749 2473
21654 18162 2328
21627 17852 2066
20811 17063 2077
20572 18397 2340
19568 14516 2229
19535 14338 2243
19297 14585 2306
19384 14439 2301
19425 15741 2135
19284 15873 2326
19155 16305 2325
18874 16187 2503
19187 15743 2314
19181 15430 2331
19240 15693 2335
19636 15572 2131
19429 14891 2203
18896 16392 2308
18837 16476 2306
18641 16783 2304
18645 16648 2471
18167 17020 2490
18373 16806 2515
18771 16437 2494
18759 13236 2119
18067 13472 2146
18608 13352 2119
18397 12982 2120
18255 13478 2104
18346 13415 2104
18565 13652 2140
18599 12296 2127
17564 12997 2113
17659 13152 2106
17883 12720 2135
17736 13316 2104
17730 13143 2127
17858 12971 2155
17792 12608 2100
16486 11768 2215
16878 10849 2158
16895 10983 2205
16872 10736 2193
17064 10859 2188
19115 15294 2347
18824 14740 2368
18836 15006 2397
18897 15622 2321
18992 15837 2314
18996 16226 2310
18883 16243 2500
18719 16554 2492
18773 16613 2306
18638 16558 2479
18027 9076 2371
17606 9732 2337
16915 9569 2349
17474 9966 2389
17450 9376 2387
17773 8964 2553
17665 9091 2532
12619 6526 2456
13995 6780 2578
12594 6319 2595
13926 6701 2444
19382 14785 2195
18917 13940 2104
19869 11860 2202
20305 11318 2142
20311 11187 2136
19792 12026 2178
19836 11755 2130
16256 9025 2368
16296 9187 2366
16652 9217 2349
16595 10006 2215
16159 9888 2224
16043 9508 2382
16227 9093 2397
16162 9589 2393
14038 7316 2481
12390 6746 2466
12374 6447 2542
12336 6438 2595
12215 6551 2592
843 8244 2767
587 9986 2843
1421 7015 2781
822 7794 2766
691 8451 2790
1296 7477 2746
1583 6986 2727
6316 5868 2775
6539 5963 2752
6636 6965 2559
6362 6636 2643
5970 6711 2653
5787 6344 2758
5717 6919 2628
5036 6775 2667
4514 5910 2783
4809 6026 2759
5024 5788 2812
5046 6350 2752
16240 9689 2381
16616 10210 2249
16710 10311 2211
16407 10138 2240
20984 18872 2440
21054 18866 2441
20830 18887 2420
20884 18485 2334
21276 18854 2459
21349 18744 2473
21154 18596 2489
21236 17523 2073
20209 17859 2329
20063 18108 2323
19255 15542 2335
19849 15643 2076
19839 16229 2111
19925 16222 2131
20426 16603 2061
18882 16610 2305
19884 16457 2168
19335 15056 2173
19988 15947 2077
19759 15829 2159
19266 16300 2140
19755 15972 2130
20531 16709 2060
19331 17815 2325
19769 16199 2142
20430 16751 2124
20726 17085 2126
20005 16663 2113
21121 17401 2072
19870 17951 2335
19875 17786 2110
20672 17252 2166
18807 16430 2500
19581 16754 2119
18746 16900 2104
18676 17029 2310
18483 16902 2306
18711 16852 2305
19153 17556 2105
20172 16512 2120
18194 17168 2306
18005 18145 2421
18124 17292 2469
18266 17559 2507
18378 17491 2303
18651 17518 2302
18407 17642 2306
19526 17847 2326
19643 17791 2108
19959 17849 2111
18980 17965 2301
18319 17615 2509
19743 17788 2110
19679 17908 2331
19141 17679 2324
19022 18063 2493
19027 18030 2309
20738 17225 2155
20387 17893 2329
20509 17869 2328
20393 17724 2124
20204 18247 2333
19780 17942 2335
20717 17317 2122
20226 18313 2491
20909 17505 2153
21104 18044 2326
20845 17509 2122
20731 18472 2344
21069 17670 2312
20705 17783 2329
20766 17638 2122
20292 17766 2122
20587 17253 2123
20127 17387 2115
19365 16513 2125
19400 16150 2130
19648 16233 2127
19345 16259 2147
19001 16492 2313
19204 16391 2144
19810 16452 2124
20038 16581 2122
19270 17687 2106
19710 15590 2168
19608 15520 2160
19401 15552 2147
19498 15370 2188
19504 15542 2141
19249 15124 2171
19291 17201 2105
18982 16572 2143
18932 16622 2310
19059 16796 2175
18945 16675 2115
18963 16747 2116
19167 17181 2102
19044 16930 2111
18844 16807 2110
19227 17377 2099
19226 16709 2120
19016 17370 2094
18917 17231 2099
19193 17287 2164
19424 17738 2106
19697 17317 2110
18057 17130 2465
18215 17478 2491
18239 17353 2300
17959 17147 2456
18681 17826 2309
18488 17830 2517
18563 17806 2308
18879 18033 2502
18610 17898 2517
19305 18034 2312
19385 18396 2427
19276 18141 2489
19724 18322 2463
19794 18259 2337
19541 18277 2458
19965 18331 2474
20394 18349 2486
20370 18283 2337
21134 18344 2326
21175 18133 2372
21275 18085 2345
17767 17202 2499
17913 17502 2444
17460 18400 2343
17793 17424 2424
19613 18208 2334
19472 17975 2319
19574 18087 2327
19412 18145 2433
19356 18169 2428
21394 18197 2357
20952 17754 2320
21213 18356 2362
20583 18520 2471
20958 18625 2471
18350 18142 2461
19245 18315 2433
19603 18461 2426
19398 18451 2405
19004 18404 2402
17931 17800 2445
18263 17814 2496
21611 18425 2439
21711 18290 2342
22011 16704 2519
22025 14406 2409
19931 13582 2407
19968 13719 2407
19910 13796 2429
20764 13551 2458
20182 14597 2412
19672 14138 2251
20473 14284 2411
20392 14838 2407
19874 14404 2412
20399 14422 2410
19515 13100 2208
19088 13387 2129
19445 13396 2257
19417 13895 2266
19067 13839 2121
19227 13553 2287
19154 13597 2274
19362 13436 2207
18930 13303 2124
19067 13202 2232
19064 13070 2234
19328 13074 2213
19280 12592 2181
18605 12508 2254
18887 12979 2123
18417 13017 2132
18363 12754 2126
18514 12642 2126
18356 12181 2128
18337 12080 2133
18112 11665 2112
18450 12189 2194
18378 12010 2192
18788 12579 2127
18630 13273 2175
17917 13076 2120
18478 13238 2122
17777 13024 2120
17785 12828 2128
17935 12446 2121
18404 12501 2129
18256 13337 2121
17985 12814 2162
17979 12880 2126
19504 11881 2239
18633 11877 2154
18471 12068 2126
18012 12008 2128
18592 11767 2129
17963 11223 2166
18256 11243 2134
17596 10960 2141
17373 10866 2148
17349 10622 2149
14801 9918 2365
16615 10497 2231
16399 10482 2206
16206 10268 2250
18210 11410 2115
17873 11452 2175
18032 11538 2167
17612 11243 2170
17547 12014 2132
17444 11374 2193
17468 11254 2192
17597 11180 2142
18120 11380 2161
18075 11611 2137
16289 12975 2316
17513 13041 2147
17205 12856 2143
17139 12766 2121
17219 12692 2143
17507 12791 2152
16622 12677 2168
16577 12830 2178
16394 12895 2128
16464 12978 2124
17613 11564 2189
17450 12287 2165
16475 12474 2191
16781 12870 2132
16853 12060 2181
16477 12042 2191
16337 11918 2152
17212 11255 2196
17095 11391 2148
17596 12407 2156
17233 12623 2123
16724 12359 2130
16699 12246 2178
16550 12148 2163
16367 12402 2143
16807 13118 2130
16492 12721 2199
16349 12802 2136
16133 12509 2305
16663 12899 2199
16682 13035 2135
17009 13108 2126
16944 12114 2130
17583 12106 2183
17911 11148 2145
17710 12369 2150
17696 12151 2184
17825 12490 2099
17680 12282 2129
17041 11641 2139
18012 11912 2101
17297 11308 2146
17755 11907 2194
17319 11374 2147
17232 11123 2193
17389 11154 2137
17442 11052 2168
17742 11365 2188
17656 11687 2143
16834 11833 2143
16815 10905 2210
16585 10831 2154
16797 11381 2195
16548 10631 2209
17273 11008 2147
17148 11021 2187
16674 11102 2198
16527 11531 2152
16383 11660 2154
17743 11793 2136
17853 11327 2137
16554 11272 2156
16406 11410 2154
16541 11406 2207
16478 11214 2159
16676 10861 2157
18250 12386 2129
17807 12132 2131
18387 8636 2326
18965 8650 2385
19052 8712 2334
18878 8142 2379
18607 8318 2332
19045 8056 2328
18821 8422 2335
18911 8072 2336
19361 8656 2332
19243 8705 2387
19505 8529 2377
18736 9078 2367
18460 8555 2328
18856 8500 2335
18281 9014 2409
18354 8879 2331
18733 8168 2331
18743 9199 2330
18387 9082 2414
18405 8844 2336
18869 8753 2329
18677 8630 2387
18856 8240 2335
18962 8549 2398
18498 8671 2385
18740 8793 2332
18863 8910 2328
18653 8895 2380
18835 9063 2330
19059 8128 2377
19252 8054 2389
19392 8469 2330
17794 8420 2482
17603 9194 2536
17540 9122 2545
17312 9180 2351
17380 9498 2350
18798 7629 2648
18521 8131 2446
18739 7911 2438
18526 7734 2545
18374 7848 2552
18000 7714 2497
18168 7714 2566
17571 8961 2536
18168 8598 2424
17854 8671 2500
18022 8693 2521
17976 9167 2368
17860 8849 2558
17608 9434 2390
17536 9217 2567
17373 9044 2345
17487 8834 2493
17518 7596 2501
17540 8365 2488
17296 8790 2349
17292 8904 2344
17363 8548 2372
16589 8789 2350
16727 8262 2348
17446 8195 2494
17364 8356 2374
17780 8122 2483
17638 7897 2489
16558 7770 2360
17593 7668 2496
17741 7693 2495
18049 7921 2487
14488 6913 2500
14227 6948 2557
14282 7030 2487
14006 6260 2739
14089 6437 2734
14123 6278 2736
14117 6535 2573
13944 6928 2435
13940 6059 2741
14021 6416 2574
13781 6434 2588
13194 6359 2576
13880 5961 2747
15475 7696 2398
15080 9311 2359
15035 9256 2358
15117 7487 2386
16337 7912 2368
16124 7828 2390
16837 7971 2360
16507 7825 2391
15863 8634 2370
16165 9345 2380
13036 6469 2582
12569 6381 2517
12072 6949 2400
12587 6788 2531
11857 7931 2377
16182 7681 2356
16319 7683 2349
16387 7810 2390
16517 7546 2490
14921 7011 2490
15110 7595 2403
15664 7548 2368
15124 7670 2357
16224 7486 2524
16343 8557 2376
16938 8950 2349
15562 7517 2358
15307 7003 2484
15264 7397 2488
15332 7479 2380
14713 7314 2504
14957 7530 2384
15742 7392 2516
15872 7374 2473
15794 7051 2473
16029 7666 2365
15793 7608 2369
16114 7084 2465
16415 7545 2504
16461 7655 2433
16039 7058 2466
16265 7231 2467
16214 7079 2496
16296 7329 2495
16179 7050 2496
13176 9070 2353
14414 6953 2562
13475 9256 2345
13836 9023 2367
14576 7376 2437
14169 7287 2483
12847 6581 2450
12582 6721 2537
14005 7104 2472
13853 7222 2475
14015 6695 2581
14152 6506 2729
13955 6551 2583
14237 6701 2720
12429 6731 2462
13664 6403 2521
12916 5816 2724
13089 5834 2585
13576 6395 2509
13296 6077 2583
13378 6950 2445
12917 6523 2453
12730 6231 2597
12846 6428 2435
12643 6179 2593
12723 6012 2660
12930 6006 2589
13727 6466 2449
13886 6562 2451
13683 6321 2577
13491 6947 2448
13903 7415 2473
13529 6285 2580
13049 6588 2451
12723 7004 2384
12489 6640 2457
12731 6538 2523
13644 5478 2766
13285 5657 2582
13126 5733 2583
13859 5856 2751
13784 5616 2757
13244 5428 2739
13379 5559 2752
13067 5968 2585
13017 5756 2724
14844 7515 2433
14692 7025 2495
14404 7016 2494
14332 7325 2492
14302 7564 2476
14538 7333 2501
14296 8549 2299
14084 9332 2285
13907 9505 2311
14468 9385 2301
13825 9189 2258
13884 8978 2362
13668 9116 2260
13227 9202 2349
12709 8807 2360
13759 8870 2370
13916 8953 2363
12598 8710 2361
13211 7741 2208
13014 7540 2393
13648 7565 2374
13895 7454 2499
13266 8695 2406
13783 8931 2359
13321 8783 2385
13562 8906 2383
14322 8836 2375
14144 9057 2350
14623 9424 2265
14442 9230 2311
15309 9100 2361
14510 8337 2394
15603 9315 2363
14415 7722 2363
14804 8050 2416
14407 8276 2323
14661 7792 2405
14073 8315 2327
14020 8326 2313
12964 8145 2206
13519 7640 2205
13195 6954 2375
13436 7035 2375
12858 6974 2444
13809 7447 2466
13808 7618 2364
13423 7568 2194
12096 8037 2375
12140 8309 2365
12750 6916 2462
12231 6748 2466
12218 6600 2472
11845 7083 2473
11603 7540 2387
11713 6942 2476
13904 8778 2281
13684 8094 2229
13754 8127 2207
13664 7936 2196
14040 8612 2303
14288 8412 2328
14344 8026 2335
14171 8013 2348
13936 8008 2213
14440 7985 2361
14626 7831 2422
14499 8001 2348
14512 7615 2458
14518 7825 2366
14224 7714 2359
14143 7920 2347
13705 7881 2253
14018 7776 2371
13562 7506 2377
13482 8020 2218
13697 7712 2384
13547 7192 2375
13165 7421 2406
13648 7441 2443
13165 7836 2207
12746 8024 2352
12313 8365 2364
13375 7408 2387
12876 7449 2390
12276 8207 2261
12484 8646 2355
12734 7820 2383
12011 8088 2373
12089 7900 2273
12609 7343 2277
12616 7539 2320
12677 7432 2288
12714 7566 2310
13169 7307 2378
12478 7010 2384
12497 6925 2443
12129 7273 2392
12179 7317 2280
12304 6804 2390
11790 7154 2396
11932 7089 2408
12591 8270 2260
12457 8434 2257
12923 8444 2297
12889 8814 2354
12986 9046 2351
13428 9139 2259
13694 9208 2257
13544 9078 2261
13510 9404 2350
13807 9550 2458
14080 9463 2294
14108 9555 2286
12688 7264 2394
13485 8717 2374
13240 8425 2210
13184 8526 2289
13094 8789 2262
13212 8924 2263
13110 8594 2290
13079 8899 2251
12857 8737 2251
12558 8511 2256
12974 8592 2259
12673 8232 2305
12794 7975 2350
12837 8198 2274
12789 8279 2285
13029 8328 2243
13431 8425 2206
13556 8222 2225
13509 8306 2204
13275 8352 2205
13052 7947 2206
13841 8258 2215
13868 8398 2215
13891 8139 2208
13946 7946 2239
13536 7781 2203
13610 7222 2425
13736 6809 2441
13814 7135 2433
13117 7530 2383
12801 7057 2382
13877 6857 2441
15987 9750 2233
15463 9422 2385
14593 9154 2357
14880 9325 2381
14289 8956 2341
14600 8779 2386
14788 7960 2398
14867 7852 2429
14918 7973 2357
14979 7723 2356
16398 7939 2398
15810 7771 2393
14693 8502 2383
14552 8686 2363
14393 9044 2341
14523 9119 2372
14699 9259 2380
15156 9381 2382
15297 9345 2377
15827 9090 2370
15818 9486 2386
15453 8294 2363
15942 9413 2367
16245 10079 2222
15768 9850 2228
15627 9665 2233
14553 8269 2389
14488 7427 2445
13444 6641 2449
13144 6886 2445
11665 7697 2385
11910 7459 2394
15623 7403 2501
15506 7035 2478
15600 7297 2482
16376 7497 2491
14729 7420 2435
15382 18324 2330
16577 17474 2420
16292 17655 2348
16575 17807 2339
16205 17571 2417
16349 17527 2412
16090 17584 2413
16043 18159 2320
16063 17678 2428
16653 17254 2427
19697 11861 2187
19889 12196 2227
19845 12418 2178
20079 11681 2191
20169 11827 2225
20116 11863 2186
9102 12334 2776
8740 10864 2769
8711 10681 2751
7531 10670 2799
7367 10404 2760
12823 11178 2769
8350 9339 2668
7676 9721 2720
7963 10012 2744
7366 10191 2740
11341 12373 2892
8700 9901 2684
8265 9700 2700
7960 9586 2700
8040 9131 2696
8742 9263 2631
8462 7971 2554
8524 9366 2655
8669 9682 2656
8697 8778 2674
7856 7297 2502
8300 7502 2499
8434 8936 2682
8825 9721 2623
10065 8969 2546
9321 9449 2595
10669 13189 2805
8969 9649 2617
11166 8746 2517
18906 7630 2555
14889 5094 2898
15026 5435 2920
14620 5356 2919
15048 4902 2883
15134 5121 2896
15059 4719 2863
15911 5039 2919
15939 4744 2900
15880 4486 2863
16261 5798 2919
16375 4262 2854
16661 4105 2847
16965 3959 2839
17057 3899 2820
17095 3865 2835
17253 3685 2800
15376 4801 2880
16315 4254 2839
17343 3731 2828
11015 3632 2999
13262 3478 2935
12960 3589 2957
13518 4430 2859
13549 4130 2857
12678 2652 2979
13667 3680 2877
11453 4148 3021
11163 4467 3019
11560 4583 3019
10685 4434 3000
10191 4118 2963
10724 4095 3004
11312 3269 3002
11405 3478 3018
11280 3614 3019
15593 4501 2856
15111 4126 2781
14512 4779 2877
15267 4315 2818
14577 4368 2824
11863 3690 3029
9889 3728 2947
8799 3540 2962
8942 3525 2965
8050 1257 2931
12409 20235 2472
12557 18892 2340
12597 18763 2330
13513 18971 2325
13165 19500 2330
12446 19343 2365
12788 19621 2355
12931 18590 2323
10121 13598 2650
10012 13628 2676
12325 19489 2400
12420 19613 2401
12283 19590 2420
12211 20490 2499
12096 20343 2500
12053 20807 2500
12525 19952 2420
12909 15472 2521
12237 19936 2465
9658 14079 2600
12235 20666 2501
10079 14149 2675
9806 13610 2636
9925 13423 2698
9259 13399 2602
9954 13817 2647
10158 13892 2702
10363 13935 2740
10205 14197 2700
14037 18224 2343
13874 16340 2519
13620 16673 2422
13569 16903 2392
13335 16383 2440
13285 15683 2499
13300 16118 2460
13440 15930 2498
13024 15535 2501
12882 15605 2500
13454 15693 2532
13299 16684 2400
13202 16982 2400
13114 17300 2340
13096 17382 2330
13373 16721 2395
13410 17042 2370
13595 17008 2378
13251 16919 2399
13702 17360 2364
13496 17430 2333
13191 17155 2366
13841 17853 2339
13643 17579 2329
12365 15160 2600
12015 14991 2660
13195 17469 2325
13345 18138 2329
13662 18236 2335
14201 17222 2469
13884 16797 2460
13463 16359 2451
14118 16864 2504
13771 16418 2495
14611 17137 2536
14294 16630 2546
13873 16147 2539
13627 15660 2566
13186 15475 2530
14657 16861 2577
12914 15093 2558
14326 16208 2601
13336 15231 2604
15676 15465 2738
16134 16681 2483
16382 16621 2517
14953 16700 2634
15900 16677 2512
15576 16938 2553
15494 16916 2580
15433 16476 2632
14527 16320 2615
14139 15674 2650
13721 15246 2639
12998 14814 2609
13327 14998 2626
12912 14559 2643
12584 15182 2578
12304 14871 2653
15560 15769 2693
15666 15969 2666
15114 16475 2661
14936 16366 2672
14478 15995 2663
15183 15842 2728
14628 15912 2710
14277 15196 2735
13423 14755 2674
12716 14673 2634
12881 14373 2699
12653 14504 2674
14692 16118 2681
14449 15794 2706
14046 13301 2752
15092 13563 2760
14019 14941 2718
13945 14306 2752
14246 14727 2767
13203 14515 2681
12502 14157 2741
11725 14864 2700
12204 14267 2735
11969 14735 2701
15913 14902 2776
15202 15361 2781
15597 15178 2771
14959 15485 2771
15207 13975 2800
14943 14949 2811
14729 14980 2800
15182 16295 2682
14966 16064 2702
14168 15460 2694
13600 14840 2686
13744 14683 2711
12570 14392 2702
15249 15957 2711
10527 13374 2760
10244 13580 2718
10693 13482 2765
10176 13484 2717
10392 13190 2783
10255 13284 2757
11877 14061 2762
10410 14191 2746
11009 14226 2747
10844 13887 2780
11194 14608 2760
11088 14558 2780
9362 13084 2695
10018 13068 2774
10025 13302 2736
10434 13625 2741
11713 13883 2788
10868 14456 2724
10678 14259 2780
10647 14354 2780
11651 14058 2780
12360 13657 2801
10755 14029 2779
11332 14356 2780
11295 14622 2750
11123 14524 2779
10950 12339 2901
11218 13984 2769
11771 13510 2814
10967 13665 2780
9496 13384 2629
9448 13734 2607
9239 13389 2600
9673 13801 2599
9748 13377 2668
8011 12375 2696
21334 20739 1812
20571 19890 1760
21540 21392 1873
21054 20413 1878
21336 21016 1845
22363 19805 2066
21269 19922 1747
21388 19926 1750
22519 19893 2095
23532 20046 2278
21425 21237 1852
21330 21409 1911
21462 21635 1927
21480 21799 1976
21378 21842 2000
20851 21878 2140
19138 21126 1822
20521 21655 2199
21130 21724 2003
20602 21528 2104
20692 21768 2156
20847 21640 2047
20166 21897 2320
21033 20068 1824
20296 20363 1965
20584 20779 1988
20837 21044 1964
21102 21543 1980
21210 21442 1945
23773 18863 1930
20977 20174 1865
20817 20137 1870
20383 20120 1901
20593 21081 2032
20542 21315 2093
21136 21850 2041
20017 20700 2100
20416 21005 2118
20369 21117 2162
20320 21200 2198
17610 22462 2317
20546 21904 2243
19981 20972 2166
20361 21333 2209
20204 21567 2279
20458 21886 2278
20242 21922 2303
19846 21705 2327
15993 15959 2658
15990 15569 2705
16743 15809 2671
16168 16513 2528
15846 16126 2632
16137 17057 2436
17596 16090 2613
16261 16005 2638
16145 16261 2578
15335 16743 2611
15648 16504 2580
15980 17607 2393
15932 17390 2419
16127 17144 2419
18571 6234 2725
18422 4867 2780
18073 5754 2803
17110 5124 2920
17586 5608 2856
18190 4287 2779
20788 6179 2039
17289 3907 2820
18157 4927 2803
17016 4320 2860
18090 4327 2799
20436 4982 1979
21230 6291 1905
20585 5211 1947
20546 4789 1924
20155 6593 2506
21129 5534 1844
19787 5047 2255
20939 4553 1813
20861 4799 1857
21074 4967 1832
21057 5774 1871
20783 6457 2085
20786 5325 1891
21058 6284 1964
19754 5888 2502
20507 4870 1941
20225 4563 1994
19299 5237 2508
20975 6452 2020
21334 7756 2104
21141 7516 2154
20932 7127 2161
20719 7012 2236
20668 5577 1990
20291 5422 2099
20223 4865 2035
19668 6200 2599
19900 4150 2052
19532 5055 2405
18535 4783 2720
18946 4300 2501
18419 4639 2733
19753 4099 2096
21185 7290 2097
20809 6888 2159
21088 7738 2209
19794 4495 2147
15806 1571 2818
21086 11112 2491
21408 9227 2255
20970 8394 2344
21217 8356 2241
20623 7979 2476
20539 6508 2217
20473 6546 2254
20561 7489 2420
20104 6964 2598
20192 6003 2264
19467 4014 2200
19259 4000 2300
20841 7920 2342
20304 6488 2335
19962 6805 2620
19300 6866 2640
18825 6008 2690
19779 5704 2420
18616 5280 2730
16044 1526 2800
19344 4907 2447
19068 3996 2420
18230 4096 2732
18829 3980 2500
19101 3994 2400
19359 5723 2543
19465 5582 2494
19256 5487 2539
18871 5377 2644
19014 4659 2538
18274 4427 2765
18209 3920 2737
18539 3945 2620
18421 3931 2660
18377 3927 2680
21755 6506 1859
21635 6692 1893
20728 4887 1884
21796 6037 1830
20559 4262 1860
20370 4195 1900
20647 4549 1865
21389 5850 1843
20313 4358 1926
20664 5278 1933
20048 4108 2001
20457 5984 2139
20513 5702 2065
20951 6907 2103
20016 4610 2082
19710 4048 2100
20102 5266 2151
19413 4032 2228
21671 8977 2115
19531 4379 2231
20866 7552 2273
19878 5680 2362
19611 5089 2359
19278 4244 2342
20671 7466 2349
20458 6938 2356
20264 6636 2431
19374 4667 2391
19558 5534 2455
20522 7736 2497
20421 7450 2480
20471 7110 2398
19995 6055 2409
19953 6166 2485
19230 4932 2496
20688 9625 2619
20401 7551 2524
20343 7491 2556
20387 7350 2489
19147 4617 2471
20426 8680 2634
19964 7327 2624
19827 6433 2600
19373 5969 2598
19747 6077 2537
19125 5589 2599
18827 4926 2650
18620 4347 2626
18690 3940 2546
19613 6373 2618
19569 7287 2629
18861 5661 2665
19035 5675 2631
19043 5071 2607
18738 4427 2597
18440 4191 2661
19151 4940 2550
19190 6403 2648
19247 6077 2625
18999 6105 2661
19086 5478 2604
18671 4905 2699
18775 4278 2553
15925 1218 2840
19001 4873 2602
19867 6603 2622
18692 4739 2667
18364 4190 2698
18711 5568 2707
18486 5753 2741
17979 6216 2800
17547 6824 2811
17160 6651 2839
18295 5552 2769
18305 6141 2759
18371 5058 2765
18377 4673 2779
16824 4892 2919
18169 4643 2799
17863 4814 2825
16150 3887 2771
16672 3941 2816
16250 4064 2816
15705 4238 2821
16121 3983 2799
16968 5366 2919
17575 4640 2857
16463 4244 2840
17443 4219 2842
17465 5905 2857
16623 4647 2900
17009 3794 2800
18055 5300 2800
17692 5219 2842
18104 3889 2799
17816 4178 2820
17540 3926 2820
17028 6283 2859
17250 4830 2900
17044 4160 2837
16667 6795 2848
16965 6906 2836
17143 5985 2874
17345 5208 2906
17266 4557 2881
16665 4447 2874
16436 4386 2859
17205 5596 2901
17013 4665 2899
15630 4840 2900
23819 15786 2606
25350 15407 2608
23633 15642 2611
23836 15024 2738
24511 14409 2794
24776 15759 2570
25171 14680 2752
25856 16220 2622
25693 15963 2621
26092 16252 2566
25054 14495 2774
25392 15532 2569
23610 14650 2682
24083 14579 2780
24874 14995 2731
24639 14629 2786
23731 15325 2687
24049 15323 2728
23910 15501 2704
25611 14617 2716
24265 14254 2790
25558 14447 2727
24456 13290 2676
24687 13138 2700
24117 13703 2653
24119 14298 2780
23872 14632 2756
23922 14420 2751
24578 15006 2750
25860 15102 2665
24525 13640 2761
25312 13535 2697
26043 14615 2677
25203 13648 2736
24245 13756 2700
25038 12775 2655
24237 13983 2757
23635 15288 2665
23481 14983 2625
25920 14852 2680
25718 14191 2699
24957 13020 2709
23965 13952 2668
24099 12344 2314
24639 11954 2239
25357 11695 2193
25287 11597 2103
23338 14851 2585
22672 14346 2410
22878 13984 2408
23673 14279 2647
23389 14534 2584
25222 13943 2755
24888 13154 2750
24068 14115 2735
24253 14749 2782
24077 15029 2760
23938 14875 2758
25139 14139 2780
24969 13787 2776
24768 13560 2777
24728 13299 2755
24468 13951 2789
24617 14840 2769
26104 15582 2641
25768 15752 2638
25936 15357 2651
26023 14400 2675
25774 15536 2637
26257 15218 2620
26228 14699 2640
26132 15146 2638
26274 14477 2620
26270 14483 2629
26122 14305 2636
26190 14195 2583
25519 13905 2701
25428 13255 2620
24322 13187 2613
26338 15571 2609
26279 14922 2612
26445 15362 2555
26169 14068 2556
25868 14140 2658
25531 13652 2646
25232 12758 2617
24374 12947 2554
24533 12937 2605
24142 13349 2596
23851 13903 2612
26292 15877 2611
26460 15786 2561
26404 15977 2589
26410 15078 2560
25520 13231 2583
25735 13620 2576
24971 12518 2542
25406 12863 2585
25221 12482 2534
24598 12582 2500
24098 13030 2506
25747 13238 2528
24902 12423 2499
24724 12637 2540
24095 12702 2405
24369 12764 2503
23278 13293 2447
23860 13295 2513
23652 13445 2501
23450 13482 2468
23913 13063 2475
24686 12410 2450
25249 12390 2508
25635 12598 2454
25912 13086 2479
26025 13537 2495
23795 12946 2455
25129 11852 2278
25879 12911 2460
25639 12812 2518
25837 12767 2437
23482 12883 2400
23937 12883 2432
24384 12084 2272
22987 13165 2378
24917 12273 2426
24950 11903 2283
25222 12142 2425
23570 12754 2356
23851 12504 2251
24320 12592 2427
25235 12244 2441
25380 12093 2389
22897 13308 2370
23839 12627 2297
24670 12287 2407
25257 11916 2337
25577 12117 2330
25716 12480 2377
22938 13040 2349
23307 12873 2362
22662 12834 2327
23090 11744 2055
22843 12870 2294
25026 12044 2364
25260 11771 2257
25480 11963 2339
24759 11993 2282
25370 11757 2251
23007 12581 2193
22909 12312 2179
23120 12368 2139
23347 12365 2148
23257 11943 2036
23581 12452 2216
23452 12464 2180
24211 11751 2082
23681 11611 2032
24583 11599 2074
24408 11819 2117
23807 11552 2010
23502 11181 1820
23853 10821 1808
23926 10799 1855
23608 11881 2072
23308 11291 1886
23700 11217 1895
23283 11063 1913
23945 10989 1842
23828 10668 1844
23147 8680 1789
23943 10586 1881
23439 10206 1816
23573 10292 1803
23723 9666 1703
23615 9621 1747
25010 11652 2133
24977 11365 1987
23780 10916 1868
25093 11186 1973
22445 11300 2197
21903 10256 2172
22538 9909 1961
22287 9773 2018
22871 10322 1935
22853 9491 1881
23210 9407 1826
23184 8952 1784
23514 8741 1754
21494 9329 2222
22852 9225 1846
21568 7362 2003
21481 7277 2019
23676 8280 1720
23485 8043 1693
23345 8281 1740
23346 8480 1758
23238 9866 1841
23152 10175 1884
22781 10958 2046
22690 11045 2064
22973 11539 2082
23049 11842 2103
21660 9599 2180
21945 9840 2123
21739 9865 2192
21752 9533 2148
21720 10176 2229
22294 10021 2029
22258 11211 2247
22780 11567 2149
22528 11548 2230
22528 12132 2299
22084 12111 2487
22026 11964 2478
22254 11830 2363
21896 11331 2403
21856 10976 2327
22032 11157 2319
22009 10763 2220
21419 10786 2436
21459 9854 2309
21479 10473 2357
20457 8913 2640
20845 9304 2531
21053 9370 2427
21170 9172 2350
22513 12461 2378
22080 11350 2345
22508 12673 2403
22485 11720 2280
22246 11556 2319
21820 10532 2236
21326 9795 2364
23005 12019 2144
23201 12107 2076
23137 11313 1973
23381 10874 1875
23361 10961 1866
23194 10587 1916
22899 10846 2003
23406 10561 1859
23351 10374 1864
22987 8590 1802
23586 10953 1777
23727 9929 1688
23492 9287 1793
23121 8115 1740
22741 8574 1828
22289 8240 1880
22766 8231 1791
25895 16041 2630
25310 18412 1631
25500 18704 1688
25741 16244 2609
25495 15685 2570
25180 15174 2681
25703 14936 2687
25521 14986 2691
25519 15284 2638
24927 15185 2701
24297 15425 2702
24575 15505 2656
23763 15582 2663
23937 15787 2601
23576 15808 2557
23198 15266 2546
23515 15530 2579
25464 17244 2199
25516 17477 2104
24751 17277 2071
24379 18120 1712
24386 18355 1709
24668 17986 1675
24780 18156 1682
25200 18519 1657
25406 18743 1745
25088 18668 1823
26133 18972 1732
25246 20457 2163
25256 20234 2241
23252 19615 2326
23120 18581 1881
23168 20406 2192
22710 20058 2128
22440 19823 2087
22537 19038 2254
22152 21025 1882
23352 20366 2228
22930 19729 2364
22834 19714 2368
23133 19748 2347
22748 19667 2380
26148 19008 1737
23112 20378 2204
21981 20908 1888
23031 20602 2179
23676 20396 2228
23478 20492 2208
24849 20926 2018
22850 20175 2166
22652 19580 2399
23044 19529 2403
22583 19526 2411
22496 19450 2404
22628 19995 2112
24125 17760 1886
24397 17014 2270
25548 16149 2568
25632 16305 2591
25791 16426 2587
25614 16792 2416
25915 16495 2540
25423 17472 2082
26652 17346 2200
25557 17277 2198
26369 17499 2202
26370 16839 2371
26585 18014 1869
24359 17322 2128
24885 16933 2198
25770 18480 1641
26020 17352 2196
26176 17506 2201
26227 18449 1698
26304 17832 2033
26485 18468 1700
26147 17808 2034
25150 18243 1659
24895 18209 1674
25235 17515 1985
24885 17981 1669
22103 19776 2033
22234 19794 2046
22301 19334 2422
21983 19760 2023
22000 19929 2059
21864 19728 2011
21661 19596 1970
22700 20488 2108
22325 20024 2112
21640 19677 1966
22086 19216 2445
22123 9447 2025
22491 8602 1868
21573 8584 2103
21966 8876 2024
21989 8572 1986
22268 8721 1910
21787 7950 1995
22080 8060 1917
21740 7670 1988
22461 8232 1835
21687 6986 1900
22771 7867 1768
21428 6880 1963
21919 6903 1852
21282 6489 1924
22425 6648 1762
22285 6343 1776
21974 5590 1795
22105 5808 1799
21562 5172 1781
21415 5549 1815
21799 21334 1720
21720 21731 1918
23585 20916 2158
24228 20706 2145
23731 21031 2097
23157 20083 2259
22349 11031 2182
22764 11689 2169
21644 9904 2236
21539 9034 2169
22002 9695 2094
22010 10040 2116
22516 10470 2029
22456 10876 2107
22861 11624 2142
23862 12225 2182
24083 12034 2181
23604 11408 1982
22623 10757 2028
22937 11276 2048
23309 12146 2133
24366 11594 2011
24474 11629 2064
24742 11310 1984
24619 11741 2136
24891 11058 1899
22493 11194 2144
22662 11454 2167
23178 12281 2123
23479 12197 2114
23913 11815 2126
24061 11894 2130
22379 9552 1985
22416 10241 2017
22300 9362 1970
22296 10442 2079
22961 10952 1998
24092 11686 2102
24180 11616 2092
23951 11447 2024
23870 11185 1955
24229 11366 1938
24328 11225 2010
24545 10985 2005
24358 11061 2002
24496 11388 2052
24780 11403 1995
24767 11642 2079
25229 11457 2070
25153 11332 2003
22586 9370 1893
22507 10062 1989
22590 10191 1963
22662 10533 2004
22786 10744 1991
23131 11432 2001
24738 10821 1934
22480 9593 1958
22942 10125 1903
22970 10481 1943
23080 11030 1960
24081 10779 1916
23802 10048 1782
24565 10607 1927
24110 10453 1886
24028 11358 1994
24179 11044 1943
24346 10729 1944
24716 10599 1866
24588 10406 1886
23081 9753 1851
22836 9844 1904
23457 10043 1839
23338 11547 1899
23810 11053 1895
23759 10706 1782
23715 10343 1739
23920 10157 1832
24711 10475 1851
24858 10742 1880
23172 10473 1895
23385 10711 1883
23665 10771 1763
24095 11122 1874
24320 10515 1906
24252 9924 1773
24405 10255 1839
23712 10463 1738
23836 10398 1804
24050 10198 1837
23889 9862 1768
24082 9817 1775
23561 9778 1803
23111 9353 1842
23952 10391 1853
23840 8976 1711
23438 9462 1789
23660 9942 1746
23673 10134 1713
23519 10461 1784
24458 10027 1738
24504 10179 1823
24531 10128 1780
23963 9074 1704
23689 8565 1719
23412 9002 1785
23688 8752 1746
23737 9117 1740
23705 9480 1768
23872 9538 1714
23822 9711 1667
23982 9713 1678
24333 9832 1734
24256 9654 1746
23588 8389 1741
23533 8257 1739
23753 9310 1725
23897 9336 1729
24016 9166 1662
24159 9437 1703
24090 9336 1639
24008 9528 1655
22096 6160 1801
21678 6325 1858
22263 7694 1843
21917 5204 1758
21313 5099 1804
21372 4843 1780
21562 5025 1767
22603 6315 1732
22229 5405 1739
22574 6083 1725
22916 6413 1704
22592 5617 1720
23094 7155 1699
22483 5663 1742
23016 7804 1743
22434 7525 1788
22083 7281 1860
22020 6777 1830
22246 7221 1817
22678 7366 1739
22672 6833 1734
22750 7571 1741
23477 7883 1683
22865 7451 1725
23194 7596 1705
22972 6521 1696
22994 6421 1700
22680 5789 1709
22251 7030 1808
21726 8403 2035
21493 8133 2090
21926 7423 1908
21726 7332 1956
22115 8649 1952
22502 7868 1808
22530 9001 1877
22866 8804 1823
25271 18500 1643
25274 18228 1705
26017 18818 1639
26192 18590 1638
24930 18457 1749
24613 18315 1714
25162 18613 1746
24631 18180 1686
24970 18358 1671
23933 18446 1762
24122 18364 1730
24384 18550 1824
24212 18434 1804
25880 18975 1736
25990 19117 1802
24043 18251 1749
23842 18585 1781
24304 18630 1890
24002 18612 1891
24530 18441 1788
24803 18381 1795
25259 18759 1861
25773 19045 1811
26054 19217 1903
26300 19046 1770
23511 18770 1851
24513 18592 1913
24872 18513 1891
23051 18697 1923
24047 18497 1837
23979 18676 1938
24699 18427 1857
25525 18885 1831
23012 18621 1900
22891 18756 1958
25082 18786 1973
24768 18475 1889
25543 19019 1926
22851 18823 1964
23268 18800 1959
23834 18786 1904
22628 18778 2038
22954 18931 2057
23433 18884 1971
23653 19031 2063
24056 18739 1983
24915 18622 1935
25279 18883 1963
26130 19365 1984
25727 19161 1945
25922 19403 2023
23646 18926 1974
22632 18684 1996
23161 18892 2036
23509 18929 2029
24734 19056 2238
24244 18763 2000
24632 18647 1990
26015 19567 2054
26077 19469 2019
26041 19531 2040
22804 18884 2043
23818 19039 2168
24966 19409 2361
24438 20747 2116
25792 19930 2079
25894 19630 2079
25710 19621 2134
25248 19057 2067
25311 20596 2099
25120 20724 2101
25034 20804 2047
24765 20798 2059
24314 20272 2303
24744 19977 2381
24417 19895 2434
23170 18965 2122
24313 18880 2112
24745 18733 2037
25005 18950 2099
22574 18893 2096
22695 19061 2139
23000 19037 2148
23481 19004 2083
23814 19087 2195
25177 19277 2210
25764 19486 2089
23314 19049 2172
24154 18984 2144
24908 18946 2118
24202 19045 2183
25229 19159 2124
25545 19441 2160
23696 19121 2227
23979 19128 2235
25567 19577 2184
24021 18947 2128
24558 18802 2096
25378 19361 2174
22791 19151 2266
23319 19121 2229
24677 19104 2275
25192 19458 2298
25146 19317 2252
23082 19294 2328
22896 19238 2332
23360 19389 2366
23560 19183 2276
25051 19561 2360
25544 19867 2203
22704 19267 2378
23689 19252 2339
24342 19305 2367
24653 19181 2336
24648 19257 2375
25250 19612 2298
25202 19746 2317
23026 19381 2367
23417 19638 2369
24248 19584 2457
24463 19236 2354
24570 19394 2426
23808 19468 2439
23940 19365 2386
24367 20058 2381
24560 19709 2433
24059 19617 2449
24170 19879 2438
23985 19779 2441
23740 19622 2431
23571 19414 2391
23732 19951 2354
23792 20098 2319
24168 20039 2379
24836 20122 2351
24998 19943 2359
23899 19912 2384
24001 20198 2324
23185 19431 2360
24200 19446 2441
24741 19498 2412
25238 20074 2289
25114 20261 2289
24439 20140 2361
25472 19680 2237
25060 20564 2188
24827 20470 2220
23815 20356 2276
23345 19948 2322
24998 20485 2210
24716 20304 2291
25436 20075 2193
24620 20573 2146
24790 20647 2123
23854 20520 2205
23396 20255 2272
23026 20059 2238
23672 20694 2186
22859 20318 2181
24311 20481 2198
24980 20351 2276
25330 19916 2267
25644 19927 2134
22909 20714 2096
22733 20426 2141
22605 20228 2142
23290 20852 2173
24370 20874 2101
23478 21049 2134
23336 21041 2111
23180 21006 2065
22448 20034 2138
22440 19883 2132
23836 20720 2169
23464 21165 2116
22132 19862 2087
25245 20666 2100
25493 20304 2098
24126 21007 2071
24600 20940 2056
23505 21277 2038
22314 20142 2094
23914 21077 2060
23729 21169 2061
23341 21211 2027
22633 20739 1996
22323 20539 1998
22609 20554 2059
22036 20074 2014
21919 19795 2060
24705 21055 2019
24622 21110 2019
24282 21302 2000
23453 21308 1999
22879 20855 2007
22122 20670 1952
21820 19817 2025
21480 19562 1940
21336 19618 1892
21924 20213 1914
22267 20264 2039
21996 20848 1885
21866 20676 1880
22393 21064 1884
23017 21066 1974
22559 21081 1881
22740 21101 1895
23149 21245 1922
23555 21576 1872
24415 21204 2018
22206 20320 2001
23974 21366 1983
23597 21451 1943
22053 20513 1951
21600 19527 1963
21197 19458 1928
21422 18911 2460
21285 19446 1938
23618 21338 2008
22152 20854 1912
22441 20771 1972
23681 21567 1896
23781 21531 1920
21756 19931 1921
23419 21641 1779
23210 21350 1904
21876 20438 1888
21499 19793 1868
21627 20168 1788
21705 20831 1772
21810 20618 1835
21618 21210 1740
21525 20794 1732
21918 20947 1844
22621 21118 1895
22108 21066 1840
23048 21259 1891
23471 21577 1825
21761 20151 1839
21984 21224 1787
22101 21350 1747
22465 21168 1827
22748 21224 1830
21493 19861 1826
22914 21771 1800
22124 21696 1876
21710 21083 1744
21776 21249 1729
21482 20384 1735
22324 21483 1711
22984 21471 1760
23045 21323 1835
23128 21697 1688
22907 21590 1689
21709 21382 1745
21858 21432 1731
21979 21505 1724
22347 21573 1772
21690 21536 1867
22249 21667 1872
22736 21765 1837
21823 21542 1867
22573 21512 1695
25442 18289 1702
26120 18713 1627
25101 18110 1692
25253 17257 2128
25409 17871 1875
25826 18244 1736
24917 17361 2006
24567 17493 1964
24855 17215 2092
25545 17965 1857
25369 18010 1789
25496 17718 1959
26532 17673 2059
26566 18040 1904
25163 17821 1801
26539 18142 1887
24522 17893 1754
24780 17806 1752
25873 18135 1789
24171 17918 1826
24794 17562 1887
24985 17719 1800
25498 18021 1810
26375 18312 1799
26507 18287 1795
24329 17675 1881
25146 17581 1923
25694 15365 2639
24013 15573 2679
25452 16185 2532
24933 15731 2582
24766 15846 2533
25138 15721 2538
25041 15675 2571
25734 16500 2540
26245 16150 2586
26339 16031 2561
25697 16390 2565
25503 16107 2581
25423 15592 2582
24297 15696 2595
24330 15856 2502
25354 15652 2541
26150 16285 2541
26487 15984 2543
26532 15806 2539
24768 16050 2457
25286 16137 2492
25133 15918 2478
26341 16150 2536
26275 16426 2490
26544 16292 2457
26575 16081 2500
26623 16575 2379
24916 16138 2415
25288 16468 2426
25681 16652 2496
24588 16814 2297
24664 16153 2426
25037 16037 2434
25739 17067 2326
26411 16537 2423
24963 16318 2386
26156 16900 2350
26161 16738 2399
25134 16692 2335
25469 16726 2408
26259 17350 2238
25742 16930 2376
26308 16597 2419
24831 16363 2357
24823 16690 2280
25272 16856 2304
25540 17044 2297
24339 16357 2400
24937 16753 2275
25990 17102 2288
25878 17265 2222
26257 17185 2290
26614 16793 2345
23739 16667 2332
24903 16851 2218
25277 17066 2208
26478 17198 2275
24085 16493 2353
23809 16483 2365
24250 17203 2191
26631 17377 2204
24033 16631 2307
24981 17086 2147
25981 17557 2121
23944 17191 2199
25643 17724 1999
25736 17668 2032
26137 17983 1949
26327 17951 1988
26349 18111 1913
21382 7385 2060
23542 18533 1827
13451 14513 2704
14761 15238 2783
15259 14857 2811
16001 5948 2916
16725 3653 2736
13357 4024 2880
13207 3868 2917
14455 4240 2800
13039 2533 2959
12394 2757 2995
16405 3914 2804
16617 3503 2678
18181 7001 2733
22501 9983 1980
23059 13377 2399
23730 13899 2579
24682 18999 2206
5010 5722 2847
4225 6389 2716
2154 8117 2815
4354 6600 2697
2352 8028 2812
4506 6737 2689
2987 9658 2839
5169 6925 2648
5246 6862 2639
6159 7005 2610
2215 10476 2841
1529 9396 2857
1708 10260 2828
5481 11375 2788
2437 10119 2845
1794 9409 2851
4799 6783 2670
5424 10196 2756
2807 9392 2833
2805 9173 2838
2556 9623 2836
7182 10459 2756
5331 11154 2781
5568 10628 2763
5057 10987 2778
3934 10723 2896
4940 11221 2767
4811 11373 2762
5370 10861 2778
6202 11758 2762
6181 11754 2764
1831 7381 2718
1744 7072 2725
917 7858 2763
1561 7848 2751
1767 7594 2729
1966 8449 2842
1558 8693 2840
2363 8593 2848
2343 8816 2866
1314 9583 2848
1036 9042 2839
1638 9009 2863
1322 8236 2793
943 7953 2758
1062 7680 2749
3822 5811 2818
1921 5976 2687
5112 6000 2765
5181 6157 2726
5353 5796 2781
5624 5404 2844
6036 5379 2872
1575 6370 2719
3448 6133 2743
2400 6327 2698
668 8566 2794
447 9804 2838
295 9889 2860
4677 6920 2666
4168 6753 2674
4285 6657 2704
3668 6323 2745
3651 6449 2698
3708 6105 2757
755 8577 2789
572 8039 2779
510 9174 2817
642 8421 2773
464 8321 2780
402 8885 2798
141 8612 2799
767 9989 2852
1196 10215 2840
2239 7463 2734
2694 7574 2751
2091 7194 2687
2220 6826 2681
2320 6592 2650
3785 6696 2670
3975 6592 2699
3268 6422 2658
1901 9084 2864
2040 8656 2859
1313 8907 2846
4883 5549 2865
5484 4790 2954
4518 5643 2844
3065 5191 2837
3866 5697 2840
2908 5665 2761
5846 5230 2892
5630 5974 2742
3028 5967 2737
3413 5563 2836
4216 5415 2876
3727 5315 2871
5062 4915 2934
4754 5462 2880
2852 5035 2820
2764 5127 2799
3155 5764 2783
4925 6254 2723
4380 6236 2735
2129 5722 2703
3530 6611 2658
4770 7101 2630
4467 6869 2659
4981 7031 2660
3978 6956 2632
3402 7142 2631
2974 6618 2619
2678 6854 2641
2649 6654 2650
2912 6408 2607
3233 6561 2596
2354 6742 2675
2336 7068 2672
2646 7343 2719
5094 7160 2636
3379 7420 2705
5366 6867 2649
3652 7283 2600
2659 6446 2621
2957 6944 2652
3607 6774 2622
4693 9169 2786
5910 6879 2619
4423 7524 2564
4686 7731 2577
4559 7253 2602
4104 7428 2575
3187 6993 2644
3618 7042 2584
6492 4582 2973
4573 4810 2940
5010 4670 2961
5971 7301 2570
6014 7220 2594
7467 9460 2690
6804 9199 2690
1776 6439 2697
2371 7886 2799
3037 7849 2777
2922 7475 2736
2084 7723 2764
1547 6396 2740
2578 8244 2831
1784 8088 2788
1647 8252 2806
1841 7890 2778
1707 6806 2757
7141 11809 2741
6609 11616 2741
1110 8137 2769
135 8770 2800
237 8420 2799
943 7405 2793
591 7744 2795
1315 6552 2813
1437 6493 2780
1083 8467 2804
53 8963 2819
320 9789 2860
249 8084 2820
884 7634 2767
495 7628 2825
1467 6838 2795
4661 11199 2779
4266 10890 2861
353 7701 2840
783 7131 2860
943 7221 2829
1191 7031 2809
1036 6838 2840
552 7374 2860
2876 10383 2878
2113 9592 2838
2452 8979 2860
3288 9250 2808
2866 8920 2846
3601 9283 2799
2934 8489 2842
3886 9809 2861
3587 7434 2673
3064 8328 2820
118 9151 2835
451 9621 2846
0 9386 2860
3857 10110 2893
4099 10239 2890
6433 9751 2699
6387 8250 2685
5296 10430 2774
6061 8415 2700
3402 9850 2860
3531 10187 2890
3509 10855 2893
3208 10418 2889
3020 10732 2890
2422 10553 2860
2851 10110 2863
736 7276 2851
7614 3955 2959
10679 7663 2540
10433 7606 2544
9892 7703 2507
9666 7769 2507
9542 7571 2534
9421 7787 2510
8804 7629 2517
8437 7298 2552
7918 7047 2536
7756 7166 2536
7394 7078 2540
5967 6996 2594
7234 7181 2539
10275 7853 2505
11030 7984 2498
9551 4622 2940
9858 4280 2933
9795 4463 2928
9688 4651 2916
11437 5418 2921
8724 7191 2598
9037 7018 2600
9136 7201 2523
11342 5766 2861
11758 6207 2747
9355 5849 2793
11025 7186 2635
9145 5988 2798
9116 7023 2543
9125 7066 2571
9234 7643 2513
6562 7197 2570
11822 9911 2601
11866 9163 2491
12363 9520 2482
12406 9908 2545
12430 9349 2389
11742 9572 2571
11708 9945 2634
11383 8456 2461
11168 8505 2489
11004 8301 2469
10763 8560 2493
9811 8334 2541
9857 9563 2617
10104 8122 2490
9597 9537 2598
9839 9091 2562
9495 9146 2577
9187 9159 2597
8544 8443 2658
8424 8584 2681
7947 8428 2656
6197 8802 2712
7868 8583 2680
7114 9529 2689
7251 10053 2734
6708 8552 2682
6784 10856 2768
6863 10564 2758
5743 10240 2737
5501 9689 2741
5894 10788 2765
6152 11283 2780
12017 13783 2800
11114 13447 2798
10984 12533 2883
10849 11624 2910
12715 11692 2832
8740 12197 2769
10573 12091 2900
9522 12710 2781
11362 11314 2860
11160 11221 2869
11026 11472 2900
9081 12556 2755
9384 12903 2744
8176 11872 2779
8958 12808 2698
8730 11810 2779
8853 12511 2736
8475 11796 2781
8033 11561 2793
7573 11162 2811
7376 11011 2798
7128 11017 2791
7236 11587 2778
6996 11354 2780
7061 10827 2780
6104 11093 2779
6319 10667 2757
6421 10935 2769
5660 11038 2787
5695 11544 2794
10003 10849 2813
10409 9461 2649
9978 9278 2582
9804 8828 2580
6600 11171 2768
6882 11680 2740
6269 11544 2756
6437 11852 2746
13009 4705 2881
6552 4956 2935
6596 5320 2865
6161 5107 2915
7344 3925 2996
6997 4155 3001
6861 3203 3020
6281 4366 3000
12345 10154 2605
12676 9689 2467
12717 9826 2495
12226 9556 2496
11474 8844 2506
6017 9194 2718
6318 8363 2698
7143 8726 2679
13562 14342 2739
11375 12885 2858
8182 11181 2801
8426 10473 2769
7916 10621 2801
7584 11259 2799
7839 11772 2780
7749 11263 2802
7809 12236 2698
7829 11928 2760
7032 12018 2717
7178 12157 2700
12298 5594 2800
11011 4099 3020
7927 4426 2971
8554 3459 2961
9101 4052 2980
8223 4856 2958
9411 4279 2961
9487 5037 2895
9367 5042 2919
7945 4898 2954
7887 5471 2916
8794 4649 2964
7126 5233 2905
8591 3823 2980
6428 4837 2937
12453 5206 2867
12730 4698 2898
11939 5359 2890
12020 6294 2713
10967 6183 2822
11471 5915 2818
10977 6462 2753
10541 6720 2746
10165 6596 2799
9266 6681 2658
9249 6539 2654
10227 6044 2872
9822 6503 2799
9731 6774 2707
9986 6574 2799
9972 6340 2829
9474 6013 2794
9673 5842 2861
10390 5898 2898
9742 5592 2897
9316 6281 2688
9211 6387 2684
9230 5447 2875
8863 6431 2734
7395 5494 2882
8701 5479 2896
8292 5567 2882
8683 6155 2789
7881 5626 2877
7219 6188 2751
6906 5160 2891
6872 5469 2869
6681 5683 2823
6454 5332 2862
6217 5477 2842
10787 6157 2853
11295 6074 2795
11117 7337 2600
10664 7321 2604
10005 7491 2560
9971 6927 2679
9424 6417 2712
9324 6147 2728
7779 6874 2578
8027 6203 2759
7944 6721 2607
7016 6926 2563
6533 6083 2728
10267 6894 2691
9477 7476 2565
9599 7302 2597
9295 7040 2615
8904 7178 2595
8190 7147 2569
7324 6824 2581
6862 6789 2596
6538 7052 2561
6700 7204 2559
9136 7601 2508
9263 7464 2540
9590 6127 2801
9340 5472 2845
8647 6380 2756
8229 6181 2769
7908 5789 2846
6421 5735 2798
12704 9255 2490
12480 9429 2410
12208 8862 2491
12120 9096 2388
11962 9047 2448
12034 8658 2490
11848 8486 2493
11836 8690 2405
11623 8266 2492
11956 8901 2400
11270 8236 2424
10747 8255 2479
10925 8173 2438
10275 8041 2451
9953 8030 2459
9656 7996 2465
11688 9180 2525
11525 9385 2580
12138 9845 2550
12604 10447 2651
12178 10267 2632
10612 11329 2886
11502 9594 2622
11070 11033 2856
11171 10653 2795
11437 9849 2668
8829 8544 2653
9196 8256 2530
8835 8001 2519
8930 7805 2492
7792 8834 2702
8333 7795 2523
7440 8180 2651
8161 7818 2540
7020 8586 2678
6791 8844 2684
6431 9112 2701
7653 7614 2566
7425 7528 2543
5699 7579 2546
7560 8568 2684
6599 8158 2662
5790 8230 2654
5665 8650 2721
5896 8668 2720
4721 7461 2578
5152 10596 2781
5593 9331 2740
5630 8868 2740
7679 11720 2775
8275 12109 2760
9283 12052 2805
9369 12544 2780
10089 11974 2874
10939 10744 2820
9862 11949 2858
9558 11019 2800
10451 11049 2860
9904 12887 2785
10165 12369 2852
10566 12613 2858
9632 12414 2820
11251 11701 2909
11441 11481 2879
11136 12977 2842
11401 13181 2819
12054 13378 2814
11077 12125 2914
11376 11778 2903
11666 11511 2880
11660 11359 2867
12991 11643 2818
10526 11764 2900
12501 13808 2777
6042 11643 2781
5854 11019 2785
8502 12482 2716
7642 12012 2731
6894 11477 2761
6070 10755 2762
17282 20256 2285
18316 21113 1951
18532 20931 2075
18299 20977 2102
18088 21092 1977
18740 21195 1818
18381 21244 1806
17054 22353 2275
16590 22478 2275
18340 20811 2157
18117 20661 2200
17879 19973 2214
17750 19692 2096
17900 19657 2002
17635 19536 2190
18672 19032 2266
18307 18982 2292
17734 20278 2245
18400 20222 2195
17683 19767 2132
17529 20140 2271
18005 19008 2279
17507 19715 2248
17531 19402 2301
17294 19910 2318
17396 19988 2295
17460 19170 2322
16995 19631 2320
17714 19955 2227
16316 18165 2316
16075 17856 2348
17466 15943 2638
17175 15841 2661
17704 15341 2648
17379 14691 2699
16467 13901 2720
17696 15002 2655
16189 15468 2716
16732 14667 2750
16114 15263 2735
15788 14055 2779
16538 15177 2738
16017 15128 2755
16042 14131 2761
15946 13564 2737
15537 13350 2735
15909 14603 2780
15436 15079 2793
15019 14624 2812
14665 13209 2717
14667 13624 2760
14713 14725 2804
14489 14149 2785
13542 12860 2779
13485 13479 2767
14260 13528 2756
15311 13722 2768
13691 12533 2778
13930 12542 2758
13775 13786 2760
13911 14004 2759
13826 13390 2759
13200 14177 2742
13286 13185 2781
13187 13611 2771
13821 13119 2760
16398 15583 2700
16713 15599 2699
17114 16309 2593
17665 16501 2563
17807 16113 2600
17240 16830 2487
17081 16599 2538
16687 16886 2480
13082 13135 2793
12854 14179 2739
12829 10932 2716
13294 11854 2825
13847 11517 2803
12159 12358 2848
17634 15331 2662
17249 15120 2708
17425 15510 2678
13714 11040 2747
13203 11616 2821
13043 12012 2831
13042 11425 2800
14116 11785 2784
11896 13165 2836
13967 12042 2788
13625 12218 2800
13695 12274 2790
13663 11361 2800
14061 11550 2800
13594 12554 2796
13259 12941 2799
12098 13004 2840
12359 13533 2800
14395 11525 2771
13930 11839 2799
17151 17039 2455
16672 17994 2322
18256 6791 2720
18370 6337 2739
18421 6462 2731
15960 16972 2472
16773 16572 2532
18153 16545 2550
17307 16311 2601
18278 16258 2575
18055 15456 2613
17275 15917 2653
17124 15502 2700
17087 14822 2739
16869 15572 2698
16711 13973 2698
16692 14085 2720
16710 15248 2737
17001 14515 2740
16961 15033 2740
16089 13780 2745
16327 14515 2758
16309 14871 2757
17110 14382 2725
16401 14204 2742
16227 15142 2754
15232 13307 2731
14393 13573 2758
14932 13073 2677
14795 13302 2725
14655 12816 2679
13865 12870 2759
13482 13835 2760
12291 14016 2759
12941 13854 2760
12849 13553 2788
16080 14341 2767
15516 14111 2797
14952 13836 2782
15524 14558 2807
14415 14677 2781
15567 13730 2761
14759 14093 2798
14465 13995 2778
13834 11300 2799
13295 11405 2796
12368 11591 2841
12568 10943 2754
13273 11049 2733
14520 10994 2722
14188 10986 2731
13466 10790 2660
13830 10923 2700
12964 10801 2687
14448 10820 2634
14198 10696 2602
12807 10542 2640
13727 10760 2643
12478 10241 2602
13055 10580 2623
13770 10539 2585
13254 10387 2568
13517 10487 2577
12665 10098 2563
14092 10533 2568
14266 10354 2500
13706 10152 2476
13536 10277 2519
13239 10006 2481
14132 10194 2453
13331 9958 2459
14144 10042 2332
13876 10046 2412
13586 9666 2462
13739 9933 2337
13426 9818 2353
13171 9506 2486
13193 9761 2356
12957 9699 2371
12889 12719 2820
13250 12279 2817
13571 11687 2821
12686 11346 2801
12147 12203 2857
11968 12511 2858
13218 12683 2811
12724 11935 2840
12119 11939 2861
19305 7392 2631
18921 6451 2680
19292 6561 2641
19928 6444 2566
18699 6852 2677
17915 6978 2758
17801 6500 2779
17937 6621 2757
18055 6827 2748
17707 6455 2801
17318 6496 2836
15998 6629 2862
16566 6004 2899
16722 6399 2860
15246 6604 2897
14469 5691 2921
14349 4977 2886
13947 4294 2831
23918 15980 2528
23725 15990 2554
23722 16297 2424
24268 16185 2423
24398 15972 2460
24067 16047 2456
24482 16495 2372
24192 16711 2297
24126 17060 2224
23811 16900 2269
24177 17364 2143
22230 18452 2101
22107 18645 2250
22432 18699 2028
23730 17507 2103
23509 17640 2129
23968 17491 2096
23647 17413 2166
23468 17101 2295
22186 19011 2416
21383 19446 1950
21522 19465 1964
21103 19472 1926
20767 18901 2415
20810 19439 1887
20902 19457 1894
21010 19477 1909
20951 19580 1881
20352 18953 2390
20792 19958 1805
20390 19726 1779
20037 19838 1779
20662 19730 1780
20609 19409 1891
21174 19963 1796
22063 19023 2474
21954 18448 2304
21973 18847 2426
22119 18914 2422
22194 18780 2309
22236 18828 2295
22347 18866 2214
21272 19697 1836
21043 19750 1773
20613 19627 1860
21069 19666 1821
21177 19519 1925
20887 19870 1757
20150 19941 1774
20433 20321 1957
19809 21368 2262
19498 21422 2265
19257 21034 1793
18693 21060 1952
19285 20957 1809
19590 20237 1796
19833 19993 1780
19651 20093 1789
19610 20000 1789
19816 20305 1797
18082 20140 2217
19254 20736 1901
18913 21207 1802
19434 21053 1876
19998 19770 1828
19377 20708 1807
18737 21122 1880
19201 20047 2066
19441 20356 1914
19316 20357 1998
19789 20512 1839
19768 20994 2131
19517 20874 1801
15788 22776 2298
18333 21405 1913
20103 20305 1917
20005 20306 1872
20195 20039 1848
20779 20494 1901
19309 21107 1864
18961 21261 1872
18904 20802 2003
18781 20749 2071
18546 20999 2013
18994 20945 1910
19052 21064 1826
19482 20210 1959
19341 20553 1920
18544 21147 1901
19189 20359 2033
18755 20910 2014
20164 7472 2620
20196 7691 2641
20107 7980 2641
19925 7759 2616
20751 9079 2543
20473 9423 2643
20571 9174 2641
20309 9006 2639
20148 8929 2624
20443 8020 2593
20350 7151 2489
22214 12193 2459
21745 11260 2442
21543 11543 2494
21676 10966 2383
21365 10441 2399
21780 11565 2481
21476 11005 2468
20651 8790 2546
20290 7757 2637
20311 7415 2573
20224 7150 2564
20528 9372 2644
20192 8515 2643
20383 8219 2641
20193 9325 2621
20536 10031 2609
19970 9068 2603
20277 8162 2650
19769 8053 2632
19811 7962 2612
20988 10437 2574
20784 10469 2581
20732 10144 2615
20569 8098 2521
21269 10146 2430
21048 9729 2511
20692 8447 2495
20226 6869 2516
19473 7523 2618
18733 7034 2670
19830 8234 2619
19686 8446 2597
19534 8171 2588
19625 7921 2599
19063 10780 2220
19081 11071 2125
19273 10968 2135
19606 11426 2126
19511 11015 2139
18911 10975 2119
18480 10977 2137
18042 10742 2145
19733 11490 2128
19687 11521 2224
19770 11242 2132
19934 11311 2131
20122 11549 2128
11569 8664 2462
12761 9577 2373
14856 10073 2385
16133 10340 2252
16316 10401 2226
11271 8063 2492
12348 8856 2491
12193 8789 2493
12334 8925 2491
12747 9079 2520
12859 9319 2488
13422 9431 2482
19650 11690 2127
16145 12652 2308
16005 12064 2415
17649 13491 2235
14872 10216 2450
17261 14039 2624
17092 13844 2594
16322 13326 2555
16233 13356 2565
17991 14124 2514
17846 13978 2521
14369 12742 2717
14091 12174 2674
17749 13688 2222
18005 13699 2228
18205 13992 2240
18577 13929 2239
17745 13476 2122
15702 13365 2716
18049 14732 2600
15378 13017 2587
17702 14513 2662
15405 13126 2700
15145 13029 2698
14301 12045 2618
17478 14517 2670
16137 13406 2694
14132 12004 2774
18332 19296 2204
18043 18562 2361
18612 18644 2364
17803 18472 2365
17640 18610 2341
17647 18881 2318
17266 18297 2324
17712 18291 2383
17214 18087 2345
17255 17299 2414
17831 17886 2419
17602 18064 2384
17697 18721 2320
17336 18573 2320
17141 17811 2355
16798 17955 2331
18788 19126 2239
18265 19200 2233
17814 18954 2296
17606 19091 2318
18913 19488 2128
17789 19137 2226
17612 19217 2298
17880 19280 2148
18941 20512 2071
18545 19623 2055
18993 19384 2189
17754 19384 2160
18005 20057 2216
18008 19786 2073
18256 19877 2083
18699 19983 2016
18447 19994 2104
19333 19480 2127
19531 19490 2090
17830 19415 2087
17894 19505 2032
18546 19878 1973
18129 19436 2096
18352 19677 2000
18005 19516 1989
18015 19647 1933
18202 19695 1923
18327 19804 1936
17894 18773 2319
17509 13894 2529
17740 14027 2540
15695 13087 2540
15542 13210 2706
15185 12811 2490
15110 12938 2601
16639 13563 2540
16742 13447 2520
15015 12696 2500
16906 13477 2463
15190 12779 2486
15740 13008 2419
17932 13931 2451
17614 13706 2421
17468 13648 2454
17736 13759 2430
17635 13652 2233
15845 13055 2402
14555 10151 2428
14174 10108 2400
11631 8427 2415
11400 8263 2418
12924 9781 2451
14441 10059 2330
13453 9879 2396
14843 9996 2334
19365 10612 2317
22166 12365 2455
22246 12434 2463
21735 11410 2481
21540 11136 2484
21327 10898 2487
20938 10946 2512
21190 10709 2513
20923 10018 2571
20742 9952 2619
20047 9256 2595
19913 8671 2619
20187 10002 2566
20707 10633 2520
20504 18932 2399
20419 18944 2380
20484 19377 1912
20030 8984 2619
20968 10662 2553
20700 10563 2553
20029 10177 2525
19831 9505 2366
20372 10472 2531
19861 10195 2501
20613 10757 2503
21229 11036 2503
21307 11251 2496
22254 11925 2388
21090 11873 2472
21383 11621 2480
23101 17488 2426
23455 17529 2193
21659 14263 2409
19477 18974 2298
19221 19179 2241
19370 19355 2205
18757 19268 2216
20223 19305 1972
20179 19249 2011
19877 19799 1859
18768 19772 1961
19057 19732 2007
18555 19411 2146
20043 19512 1912
19503 19800 1896
18777 19837 1919
18976 19900 1870
19363 20120 2018
22000 18520 2287
21999 18652 2303
22015 18796 2393
22092 18446 2038
21822 18319 2350
21657 18733 2464
20134 18991 2300
20339 18946 2370
19716 18725 2385
19112 18791 2337
18558 18777 2324
20092 19055 2199
19583 19126 2240
19869 19018 2251
19071 19107 2259
19978 19199 2119
19871 19145 2179
19707 19302 2142
19924 19463 1992
19272 19676 2028
18788 19590 2068
20090 19150 2103
19570 19661 2003
20369 19362 1936
20307 19421 1940
19958 19692 1871
19396 19923 1820
20162 19382 1964
19214 19812 1941
18986 20033 1986
18780 19894 1927
19185 19982 2004
19536 20100 1907
18668 20304 2154
18780 20222 2134
18490 20126 2149
19008 20194 2108
19160 20141 2090
18367 20437 2192
18596 20595 2143
18020 14198 2559
17915 14555 2613
17337 14400 2700
17042 14029 2688
16624 13878 2672
16451 13779 2686
23573 16118 2496
20269 19638 1897
20242 19699 1799
19939 15459 2236
18201 13625 2169
18092 13831 2236
17450 13580 2237
17331 13541 2244
16858 13382 2307
16704 13351 2317
12366 11151 2803
10096 11554 2878
11517 12046 2898
11739 12213 2879
10915 7492 2581
10422 7299 2596
9658 7161 2636
9130 7311 2530
9461 6914 2673
9130 6829 2598
8898 6834 2661
8243 6825 2620
8635 6761 2678
8110 6806 2601
8019 6818 2577
7673 6306 2732
7316 6497 2665
7451 6732 2600
6606 6811 2576
6538 6562 2632
9191 6912 2618
9473 6728 2693
9713 6364 2801
8679 6982 2644
8429 7063 2602
8351 6712 2668
8459 6425 2739
8138 6600 2634
7603 6604 2645
7739 6421 2701
7615 6506 2667
6783 6160 2738
6957 6503 2669
11734 5858 2801
12240 5538 2823
10483 6535 2800
10382 6374 2834
10206 6345 2840
9763 5952 2852
9420 5650 2856
8958 6074 2798
8186 5900 2827
7767 6044 2804
6898 5798 2813
13130 4337 2900
12222 4360 2999
11359 4862 3001
10889 5062 2979
10042 5808 2900
9387 4684 2941
8645 5223 2924
8412 5365 2918
7877 5250 2939
7420 5022 2942
7215 5198 2917
6854 4961 2924
6611 5021 2913
11860 4648 3000
11635 4787 3000
10522 5701 2924
10199 5618 2919
10089 5020 2939
5532 5660 2808
5618 5855 2775
5574 7873 2576
4943 7514 2557
3434 8416 2799
5571 8422 2685
5122 8856 2759
4224 7272 2597
4396 7455 2581
3369 6680 2591
23725 17595 2009
22775 15053 2494
22319 14675 2420
22930 14741 2516
17429 13537 2238
17229 13391 2263
20617 10930 2326
20172 10821 2335
20033 10679 2333
11182 7878 2497
23043 14136 2480
22819 14435 2456
18356 13603 2135
20850 11467 2395
20582 12239 2478
22022 14588 2405
21563 14795 2411
16333 19391 2318
16763 19218 2312
17089 19416 2312
18444 16592 2560
17472 17035 2468
16886 19712 2312
16807 19607 2315
16742 20012 2357
17762 20806 2208
16930 20253 2327
17464 20499 2255
16970 20649 2299
16720 20629 2324
14865 20232 2520
16357 21161 2250
16105 22699 2290
15491 20109 2478
16704 19794 2349
16745 20161 2347
15821 19648 2392
16121 21056 2321
15471 20505 2480
16285 20603 2378
16523 20358 2373
16123 20934 2346
16150 20138 2414
15712 18882 2320
16112 19922 2420
16181 19903 2406
16767 20258 2349
15979 20802 2386
17344 22342 2279
17046 20733 2256
16722 20967 2215
15813 21491 2259
17271 20828 2182
16303 22604 2274
17498 20665 2235
16243 21381 2194
15145 20335 2514
14718 20524 2563
20638 20152 1895
16220 22968 2339
16568 22908 2337
16460 22791 2307
18357 22162 2315
17212 22833 2331
18065 21966 2255
18437 21957 2286
19094 21699 2263
18727 22115 2335
19567 22015 2357
19419 21751 2311
16926 22847 2340
19059 21912 2312
17443 22711 2343
16782 23011 2361
17513 22871 2379
18209 22520 2376
17326 23060 2380
17271 23022 2363
17796 22519 2342
18199 22422 2352
17035 23038 2360
18873 22506 2421
18683 22319 2377
19257 22200 2384
17956 22820 2426
15963 23074 2343
17451 23035 2400
17963 22561 2373
18598 22591 2422
18223 22666 2419
17713 22948 2420
16149 21549 2161
17008 22101 2236
17783 22113 2269
17779 21908 2224
18762 21936 2297
18222 21872 2242
20043 21532 2289
16727 22349 2269
18050 21387 1933
18487 21829 2200
16119 22276 2051
16093 22611 2253
17211 22105 2236
16806 22195 2252
16722 21180 2129
16936 21742 2010
17751 20972 2119
16881 20970 2171
15915 21970 2048
16233 22471 2194
16362 22395 2203
16602 22269 2173
17371 21920 2216
18776 21803 2232
20119 21220 2219
18161 20994 2102
17037 21843 2110
16573 21366 2080
16404 21552 2082
17108 21599 2023
16084 21831 2078
16598 21443 2027
16478 22233 2119
15992 22539 2174
16784 22071 2200
16696 22032 2102
16614 21998 2041
16896 21787 2066
16912 21877 2157
18016 21485 2003
18673 21717 2142
18192 21690 2110
18735 21542 2049
18944 21662 2230
19917 20887 2120
15869 22298 2006
18973 21532 2144
18845 21443 2002
19124 21441 2098
19139 21333 2063
20150 20617 2075
15268 22677 2239
16049 22197 1878
16769 21306 2029
17499 21337 1936
18617 21561 2035
19119 21224 1972
19369 21120 2057
19582 21019 1968
19798 20859 1999
19994 20592 1992
20330 20505 2018
16892 21630 1960
20685 20770 1957
20507 20449 1973
16030 22269 1996
16403 22140 2031
16430 21681 2007
16750 21839 2017
17274 21318 1909
17391 21449 2017
17569 21471 2033
19566 21067 2071
19288 21279 2067
19249 21158 1968
16470 21971 1956
18690 21371 1903
19714 20795 1914
19988 20526 1976
20792 20642 1922
17492 20953 2117
17703 21421 1993
16482 21901 1861
16563 21861 1905
17096 21081 2049
15908 22161 1880
16313 21820 1988
16765 21702 1920
15935 22092 1944
17215 20973 2096
15806 21867 2119
17798 21088 1996
17297 21108 1943
17435 21104 1927
18016 21202 1792
17223 21271 1837
16919 21229 2015
17145 21159 1946
16611 21561 1921
16219 21941 1944
16737 21523 1833
16112 22127 1867
15756 22198 1889
18297 21243 1796
16703 21614 1840
16580 21685 1848
16392 21891 1862
17664 21216 1799
16877 21514 1857
17134 21261 1825
17631 21165 1834
17368 21193 1814
16090 22456 2136
17446 21704 2156
17751 21718 2150
18077 21826 2195
19391 21200 2128
19694 21277 2238
20066 21067 2192
20308 20697 2068
20256 20883 2137
16210 22280 2064
16214 22367 2143
16337 22253 2136
17136 22052 2213
19268 21645 2275
19512 21235 2189
20132 20862 2145
17143 21780 2160
18813 21659 2192
19333 21427 2211
16885 22010 2191
19478 21320 2198
16500 16405 2555
16677 16405 2565
16712 16178 2611
16556 16120 2624
15957 17754 2438
15429 18075 2376
15237 17709 2431
17165 19983 2294
15769 18761 2323
16080 19383 2320
14423 18099 2360
13982 17647 2379
14335 18462 2350
13082 18177 2327
13424 19532 2325
14199 17835 2382
13990 17425 2413
14864 18047 2375
14604 17722 2423
15729 17518 2433
14834 17767 2423
15239 17474 2487
14983 17268 2538
14302 17493 2442
15704 17281 2482
15407 17135 2550
14913 17101 2570
15245 16981 2595
13538 19708 2372
14365 19189 2327
14062 19604 2329
14054 19439 2325
13839 21482 2481
14566 19539 2329
14319 21307 2505
15000 19441 2330
14661 19679 2380
15177 19559 2363
15535 19527 2367
16260 19533 2351
15304 23136 2300
14897 21293 2455
15533 20726 2458
13437 20733 2539
15682 20528 2457
15822 20642 2428
15002 20595 2533
14818 20879 2538
14532 20447 2559
14385 21472 2453
13629 21521 2471
13921 20605 2569
14117 21560 2454
14086 21208 2535
13166 21130 2495
13545 21297 2497
13411 20926 2536
13281 20510 2514
12689 20727 2487
13319 21044 2523
13916 20518 2563
13642 20338 2520
14307 21139 2541
14324 20595 2573
14084 20981 2559
13803 20807 2560
14496 20851 2561
15448 22856 2290
15764 23200 2339
15333 22938 2302
15909 22669 2281
14933 22786 2248
15873 22571 2233
15113 21479 2377
15573 20948 2422
15310 21211 2413
14912 21012 2498
14333 22296 1917
14593 22231 1917
14992 22522 2153
15645 22537 2167
15654 22585 2236
14796 20011 2467
14070 19730 2376
13075 19953 2427
12693 20094 2431
15296 19907 2443
15117 19735 2400
14758 19813 2419
14480 20204 2512
13906 19831 2397
13289 20118 2463
12792 20434 2479
12585 20384 2467
13185 20296 2485
15072 20085 2479
15614 20223 2481
15100 20749 2508
15336 20375 2500
14700 21132 2507
14698 21481 2430
14365 21724 2351
13317 21564 2447
13057 20832 2513
12689 20970 2479
12471 20938 2474
13091 20751 2516
12961 20178 2461
15788 19760 2415
15145 21044 2468
12942 21195 2476
12736 21382 2434
13384 19782 2393
13690 20065 2459
15910 20143 2450
16082 20510 2404
14105 21751 2391
12988 21428 2437
12771 21550 2413
12797 19883 2401
15802 21055 2374
14737 21667 2354
14283 21654 2402
13700 21733 2421
12963 21784 2399
13503 21947 2373
13056 22049 2356
15149 22740 2249
14817 22642 2181
14250 22786 2222
13968 22962 2212
14195 23001 2240
14461 23048 2260
14128 22661 2194
15444 22680 2226
14776 22822 2211
14560 22951 2253
13557 22902 2044
15765 22368 2079
14612 22585 2139
14409 22689 2206
13778 22704 2086
13974 22750 2190
13763 22917 2152
15354 22499 2132
14432 22511 2118
14733 22750 2142
14639 22798 2215
14235 22586 2162
15685 21356 2322
13879 21840 2365
13289 21868 2396
15178 21635 2303
14113 21920 2297
13419 22049 2338
14665 21868 2273
14571 21793 2309
14112 21946 2252
13156 22301 2289
15421 21688 2261
13907 21936 2291
13403 22262 2263
15235 21819 2209
15021 21709 2288
14261 21835 2305
13201 22414 2257
15759 21627 2225
14713 21936 2207
13875 22123 2189
13786 22424 2041
15368 22199 1891
15558 22278 1940
15102 22367 2066
15203 22267 1964
14656 22359 1987
14756 22298 2024
14562 22346 2052
13888 22543 1977
13678 22840 2064
14762 22459 2115
14260 22478 2078
14239 22468 2040
15414 22392 2056
14065 22465 1995
13873 22617 2079
14711 22656 2126
14008 22542 2099
13515 22896 1999
15489 21853 2165
14410 21932 2184
14598 21997 2114
13647 22262 2189
13571 22653 1976
13259 22548 2197
13332 22716 2099
14459 22230 1909
15251 21975 2093
14849 22157 1904
13429 22820 1955
13453 22895 1948
15635 22029 2066
14889 22055 2015
14127 22309 1941
15146 22144 1923
13989 22411 1934
14133 22256 2005
13747 22547 1920
13468 22599 2090
15444 22007 2083
14787 21986 2078
14051 22221 2060
13457 22688 2059
14411 22061 2094
14372 22360 2005
15361 22128 1975
14694 22099 1994
13667 22671 1940
15362 18703 2307
15929 17951 2346
15547 18696 2305
14432 18633 2329
14653 18446 2335
13907 18608 2329
14969 21859 2177
14930 21981 2067
13565 22422 2151
18578 21832 2256
23458 17467 2186
23397 16184 2467
21834 11975 2484
14494 12533 2550
17419 14124 2669
17752 14750 2651
17816 14987 2643
8697 5752 2863
7220 5927 2815
11435 6354 2732
8130 6464 2677
6975 6356 2700
6890 6013 2766
11596 6573 2680
11472 6856 2642
11245 6636 2689
11567 6870 2628
10274 7183 2634
9196 7211 2574
8842 6665 2691
8451 6933 2641
6613 6273 2689
6648 6550 2649
6053 6369 2765
10048 7179 2639
8906 6931 2635
9341 6524 2675
9798 7643 2528
9107 7254 2561
8915 7419 2541
14266 5354 2901
14051 4465 2834
19206 7480 2620
18482 10388 2289
14070 9707 2425
15525 9871 2313
22844 18039 2389
18231 15253 2588
16763 17422 2399
17067 17545 2372
16849 17284 2420
17372 17505 2380
17165 13493 2269
18271 14029 2245
18355 14047 2248
18658 14242 2247
14569 12469 2542
18212 14800 2562
18204 15139 2597
18212 14956 2547
21230 13244 2424
20946 13582 2458
21370 13529 2412
21460 13099 2409
21818 12326 2438
21673 12854 2411
21031 14948 2411
21201 15107 2411
20986 14720 2399
13781 4681 2848
13050 5401 2874
12882 5539 2853
12893 5649 2717
12498 5988 2716
23138 13651 2435
23503 14267 2586
21550 15408 2434
22529 16038 2467
22172 16323 2468
21121 9708 2475
20891 9124 2482
21158 9987 2494
22286 18999 2320
11021 12845 2860
10729 12991 2822
10483 13022 2802
10257 12665 2830
10350 12235 2876
9259 12268 2779
9829 11453 2845
9709 11201 2820
10255 11372 2879
10542 9082 2567
11265 9087 2563
9936 12485 2831
11515 12852 2860
11727 12895 2857
12348 12731 2840
12783 12869 2814
12169 11270 2821
11901 11826 2874
11892 10154 2633
10515 10713 2820
10759 10946 2856
10205 11170 2861
12106 11455 2847
11516 11184 2819
11407 10887 2800
11646 10557 2712
11605 10943 2796
10975 10520 2787
12362 10750 2719
11786 11185 2818
12064 10357 2647
10570 10182 2761
11458 10453 2712
10107 10036 2727
10289 9018 2547
10937 9085 2580
9270 9621 2597
9594 9708 2618
8989 9350 2602
9255 8733 2625
10464 9766 2704
9048 10169 2656
10751 9354 2641
10144 9492 2640
11775 10731 2746
12034 10600 2702
11003 9444 2656
11306 9954 2701
10889 9748 2702
12213 10873 2762
11223 10542 2765
11234 10162 2723
11269 9592 2656
11041 10269 2757
10649 9685 2699
10760 10057 2744
10304 10748 2820
8583 11088 2789
9821 11625 2859
8557 10898 2777
9035 11936 2779
9387 11325 2799
8888 11589 2793
9222 11754 2800
10002 11816 2878
9507 11841 2823
12742 12304 2835
12476 4349 2968
11252 5027 2974
10803 4717 2998
10455 4457 2980
10534 4753 2978
10385 5319 2939
9756 4578 2935
12271 5062 2907
12093 4744 2959
11689 5157 2940
11430 5120 2961
11058 5360 2958
9690 5074 2921
8163 5173 2940
7162 4939 2931
9920 4777 2939
7702 3552 2974
7913 3216 2960
7825 2228 2942
7907 1710 2933
8173 850 2915
7865 3584 2964
8072 237 2886
11648 3180 3014
7667 1808 2959
7335 2643 2979
8014 371 2883
7946 7 2876
8021 3 2876
8070 3611 2961
9378 3595 2960
8989 3831 2980
10389 3415 2955
9600 3892 2960
9882 3835 2939
10270 3821 2960
12210 2656 2999
12152 3832 3020
11778 3998 3023
11900 3497 3032
11952 3800 3034
12259 3375 3024
12049 3018 3015
12079 3379 3023
12479 3380 2999
12917 3089 2970
12817 2791 2978
13037 2237 2964
10864 2064 2891
8944 2810 2899
13527 1585 2937
13500 1734 2939
11433 2518 2960
10570 3148 2960
11010 3106 2981
10806 3107 2962
10723 3408 2983
10791 2938 2940
11175 2900 2964
8470 2486 2878
9947 3463 2951
9509 3452 2940
10256 2983 2922
9187 3092 2920
8850 3169 2935
8600 3074 2931
8266 1475 2899
8254 2916 2920
8493 1797 2876
7894 1879 2923
8938 1505 2859
4632 4644 2960
4147 5191 2897
5209 4328 2995
6586 3880 3019
4951 2576 3081
7507 3198 2982
5092 3361 3060
6873 2057 3020
6763 2435 3019
7277 1906 2998
6898 1333 2996
6763 1900 3020
7422 1440 2990
4796 4267 2991
6748 1203 3000
7013 825 2963
7441 2373 2958
7730 1332 2965
6905 1269 2989
2061 1858 3099
7222 840 2958
7317 707 2940
7391 310 2912
7602 772 2938
4577 4079 3000
2482 2446 3071
5079 3779 3042
4962 4053 3021
6275 4065 3020
5507 4115 3019
5880 4108 3020
6791 2740 3019
5263 1791 3100
9494 2895 2902
9682 3197 2919
9051 1061 2859
9432 1671 2840
8643 863 2896
8432 568 2902
8562 1061 2897
8085 2609 2912
8577 2751 2897
10837 3410 2985
10323 3169 2940
10873 2375 2900
11633 2118 2956
12457 2444 3000
8865 1993 2858
8804 2513 2879
10633 2524 2901
12616 2281 2986
8247 3385 2952
11359 2884 2975
11797 2688 2991
12002 1916 2960
9573 4107 2959
11866 2203 2973
13028 1935 2958
10140 2232 2879
8300 2189 2881
8121 2171 2899
8794 1723 2860
10615 2061 2880
11050 1951 2904
9653 1744 2839
9544 2622 2887
11410 1542 2900
9995 2017 2863
11074 1630 2884
9650 2126 2856
9156 2268 2865
9426 1451 2839
10514 1771 2856
9975 1286 2845
10788 1510 2855
10476 1453 2840
9470 1117 2840
10028 1575 2840
1971 5495 2720
2590 5395 2760
1960 5288 2752
1862 5384 2739
2135 4897 2797
2256 4681 2820
2418 4334 2856
2430 4101 2884
2458 3809 2926
2386 3709 2943
2269 3293 2990
2399 2730 3046
2356 2139 3094
1956 1755 3099
1911 1672 3098
2185 1989 3099
4883 1616 3100
4905 1679 3100
1843 1599 3095
1885 1684 3097
1681 1467 3089
1700 1450 3088
4940 1542 3101
5215 805 3045
2045 1821 3098
3247 2363 3057
2310 3116 3007
2308 3310 2991
2378 3126 2994
2402 3493 2961
2466 3673 2940
3226 2350 3056
2438 2881 3020
5159 1822 3099
5278 2309 3079
3275 2468 3050
3290 2474 3048
2992 2307 3060
3337 2400 3051
2722 2410 3058
2441 2985 3007
3420 4371 2900
3163 4639 2860
3416 4849 2883
4208 3927 2999
3963 4233 2957
2988 5407 2801
2624 5670 2739
4019 3692 2999
3996 4829 2924
4332 3457 3037
4238 4358 2967
5212 1398 3082
4671 2613 3079
5366 1711 3080
5258 1567 3103
5037 1715 3100
4689 3151 3060
4382 3575 3038
3868 3445 3000
4937 865 3060
5040 1257 3087
3006 4857 2838
3390 5272 2858
3804 5116 2900
3622 5006 2899
3488 4557 2904
3755 4430 2936
3837 3935 2960
3840 4615 2934
3706 4174 2933
4401 3836 3020
5558 2596 3064
5540 3080 3060
5547 3655 3039
5417 1979 3079
5649 2807 3059
6410 1305 3019
5656 1677 3059
5375 1144 3066
5858 3403 3040
6046 2979 3039
6053 2328 3039
5642 2164 3061
6024 2035 3039
6574 888 2998
5904 1452 3041
6239 1058 3020
4906 267 3000
5790 1174 3039
5464 865 3039
5865 690 3019
6151 380 2976
5740 198 2974
5018 476 3023
5610 3 2960
6432 1706 3021
6280 699 3000
5458 475 3018
6633 314 2939
6117 53 2940
5271 119 2980
7167 595 2935
6758 13 2914
7684 280 2900
12537 3639 2994
12429 3084 2997
13129 3245 2947
14927 3907 2749
12054 4232 3020
12197 3539 3018
12369 4071 2998
12968 4077 2935
15746 4086 2795
16301 3669 2700
15611 3835 2702
15613 3408 2703
15078 3683 2733
15561 3712 2681
13230 2985 2941
13745 3295 2898
13246 2579 2936
14233 3101 2840
13963 2937 2881
13310 2069 2940
13714 3026 2907
14118 1624 2919
13723 2409 2899
13672 2497 2899
14608 1513 2920
14971 3317 2779
14162 2114 2866
15170 3178 2778
15128 1241 2922
15247 1725 2861
13803 1808 2920
13996 3965 2830
14008 3360 2860
14383 4123 2796
14370 3647 2807
15559 3924 2741
14582 3889 2778
14970 4024 2758
14775 3626 2771
14710 1706 2898
14021 1904 2899
13724 2124 2905
14036 2304 2862
14205 2572 2836
14440 2423 2809
14959 2795 2777
14570 2196 2830
14770 1946 2863
15380 1015 2920
15036 1535 2899
15938 1871 2763
15465 1444 2878
15763 1290 2854
15838 1008 2860
14488 3194 2814
15387 2009 2802
16286 2280 2599
16184 1953 2699
15410 3787 2700
15343 3565 2720
15386 2609 2707
14799 2350 2785
15553 2141 2755
15877 2089 2730
15836 1707 2801
16135 1797 2740
15620 2593 2671
15580 2949 2711
15748 3250 2690
16116 2070 2687
16570 3348 2639
16480 3044 2548
15811 2720 2631
15769 2853 2658
15294 2469 2719
15903 2504 2615
15642 2460 2674
16059 3138 2619
15965 3565 2638
16259 3387 2618
15791 3537 2657
16419 3027 2544
16444 2919 2516
15699 2271 2697
16294 2623 2525
16100 2937 2597
16342 2545 2520
15986 2998 2635
16247 3204 2585
16174 2499 2547
15093 2973 2780
15030 2497 2748
14806 2509 2772
16082 1631 2780
15526 937 2900
14036 2599 2863
15678 868 2880
12688 5782 2717
13111 5662 2730
13396 5342 2751
13621 5236 2754
13715 5385 2757
13725 5632 2766
13750 5633 2763
14229 6506 2729
23704 18664 1794
24729 18382 1813
24343 18441 1779
23860 18317 1758
23793 18174 1842
23986 17634 1968
23639 17827 1999
22894 18515 2033
19807 13420 2289
20194 12348 2316
20453 12204 2313
22011 12298 2464
21461 12251 2458
22141 12585 2431
22636 13799 2365
22323 13097 2373
21643 13980 2364
22134 14314 2365
17731 17066 2455
17478 17652 2378
18908 18374 2419
18617 18388 2417
18234 18250 2423
19952 18666 2420
19696 18877 2345
19362 18678 2379
19074 18594 2375
20117 18848 2398
14561 2724 2800
21085 14243 2440
23596 13747 2516
23000 14889 2539
23139 15721 2513
20275 15258 2425
22642 16893 2468
22853 16720 2470
22877 16357 2465
22553 15497 2461
22766 15641 2478
22365 15839 2458
22102 16128 2460
23208 16170 2566
22928 15904 2480
23338 15628 2550
23415 15381 2557
22392 15235 2454
23281 14134 2533
23041 15537 2535
20324 12882 2520
21068 13191 2457
20430 12718 2543
21597 12165 2448
21202 12748 2465
20880 13080 2502
20926 13324 2469
21140 13922 2440
20402 14041 2420
20291 13699 2448
20445 13549 2464
20228 13538 2462
21826 12520 2425
21596 12270 2462
21397 12803 2440
21645 12663 2409
21140 13802 2449
21188 14284 2420
21473 13966 2409
20743 13867 2451
20101 13775 2421
21202 12363 2472
20953 12254 2498
21032 12613 2499
20690 13278 2497
21011 11716 2464
21999 12613 2414
21483 12647 2431
21226 13937 2421
22985 15725 2499
23269 15998 2581
23016 16781 2508
17958 15058 2619
18142 18044 2461
18765 18193 2478
17841 17679 2439
20608 11476 2332
20485 11782 2339
19138 12094 2128
19237 11870 2129
19687 11613 2127
19512 11735 2128
20564 11627 2342
20287 11617 2184
20271 11776 2185
19361 11146 2130
16771 10410 2203
17492 10377 2251
18813 10917 2127
18692 11887 2129
19377 11774 2131
18530 9236 2332
18649 9759 2322
18872 9959 2320
19562 9287 2327
19133 10398 2321
19802 9252 2366
19817 9347 2360
19777 9094 2373
19630 8998 2382
19658 8581 2377
19161 8100 2335
19778 8732 2605
4756 6400 2715
5882 5957 2765
4855 6520 2698
6489 6396 2666
5989 5741 2784
12300 5953 2757
2569 5754 2708
4526 11208 2800
3903 10995 2880
4555 10653 2837
4281 10612 2868
4635 9987 2825
4936 9099 2774
5363 9997 2760
4812 8817 2759
5220 9426 2763
5209 9068 2760
5890 7158 2598
5546 7381 2577
5324 7761 2562
4868 8291 2677
3761 9183 2778
3871 9477 2818
4284 10249 2867
4129 11075 2854
4713 11022 2799
4489 10931 2826
4481 10308 2854
4343 9539 2824
4018 9608 2842
3128 10043 2869
2646 10613 2880
4130 9915 2862
4360 10026 2851
3286 9570 2829
4739 10477 2821
4282 9318 2803
3215 8713 2819
3266 8189 2801
4384 8688 2739
3445 8949 2797
3585 8443 2783
3583 8150 2761
3364 7916 2765
2829 7960 2799
5053 9730 2780
4691 9499 2803
4055 9089 2767
3672 9008 2776
3843 8483 2732
4965 8636 2739
4526 8900 2765
4136 8556 2718
4615 8412 2698
3992 8730 2738
4081 7895 2645
3165 7501 2730
5331 8724 2740
3830 8739 2746
3695 7992 2724
4267 8337 2680
4796 8119 2639
4632 7994 2616
4354 8436 2690
3832 7742 2683
3805 7863 2703
4358 7930 2621
5080 8187 2659
5559 8352 2669
5060 8049 2627
4580 8306 2660
5921 8030 2620
4024 7638 2600
4472 8196 2640
5458 8035 2620
5354 7583 2554
5118 7863 2581
4337 7845 2604
3838 7183 2600
5185 7484 2579
4952 10404 2802
6400 11198 2769
6697 9828 2704
7316 9889 2720
6043 10005 2715
6698 9394 2690
7343 9738 2705
9946 12240 2851
10045 10603 2786
10145 9712 2673
8659 9068 2659
8180 8924 2701
8122 8745 2700
7819 9067 2700
7418 9227 2689
7384 8907 2701
7105 9052 2690
9211 7896 2474
7503 7259 2514
7735 7504 2539
8103 7401 2493
7285 7229 2515
7067 7286 2519
6242 7753 2563
6546 7538 2531
10039 8482 2564
9673 8602 2612
9625 8233 2516
10501 8756 2516
10705 8445 2498
10837 8809 2527
10247 8741 2538
8395 7558 2493
8744 8186 2575
10209 8377 2538
10293 8494 2545
10131 8616 2563
7137 8020 2636
5796 7808 2562
9621 8458 2588
7781 8145 2619
7706 7762 2585
7682 8366 2660
6842 7740 2613
9409 8627 2621
9094 8447 2609
7293 8029 2639
6993 7943 2637
7092 7650 2605
6472 7885 2620
9250 8563 2618
8075 8118 2592
6709 7934 2642
20808 15201 2405
20366 15078 2405
22284 15374 2441
20366 15227 2424
21215 14489 2400
21377 16521 2556
21952 15924 2479
21834 16402 2540
22102 15704 2429
22442 14524 2409
19323 15405 2163
19167 14418 2314
18996 14940 2356
18910 15094 2351
18468 13418 2120
16919 10677 2163
18670 15298 2416
18102 9052 2373
18168 8859 2399
18201 8602 2421
18411 9525 2329
19304 8311 2332
19148 8213 2330
18310 9214 2331
16212 9609 2359
16512 8043 2364
12426 6361 2586
11854 6780 2473
1473 7548 2732
1328 7253 2738
5538 6656 2658
5471 6650 2653
14938 9526 2253
14709 9629 2260
14421 9473 2277
14131 9247 2353
16634 10131 2211
16661 10056 2213
17351 10354 2233
17028 10148 2223
16998 10263 2214
16766 10045 2213
17224 10173 2234
20679 18658 2454
20072 18572 2437
21668 18382 2430
21552 18545 2472
18987 15388 2334
19029 16049 2311
19587 15323 2147
19268 16671 2140
18792 17111 2101
18809 16806 2307
18885 16711 2308
18812 17247 2311
18715 17019 2101
18960 17490 2313
19038 17449 2097
20087 17792 2111
20044 17958 2334
20588 17657 2123
21465 18391 2489
21537 18045 2342
21167 17771 2321
19234 18077 2312
19210 17766 2322
18395 17554 2301
19039 15912 2310
19030 15197 2343
17990 17423 2453
17598 17267 2426
20691 18521 2466
18584 18333 2437
19006 18305 2445
18646 16449 2589
18773 16396 2493
18894 16285 2490
21934 18296 2045
21918 18194 2037
21872 18180 2015
21771 18510 2425
21912 18638 2405
18778 16761 2305
18945 16509 2309
20119 16207 2068
21692 16543 2546
21429 16109 2562
21734 15658 2453
21398 15968 2561
20864 16026 2558
20768 15848 2539
21241 15381 2452
21782 16095 2536
21338 14503 2402
22105 15402 2418
20901 15685 2512
20521 15500 2493
22361 15582 2441
22159 15950 2460
21801 15952 2510
21456 15710 2504
21199 15736 2532
21792 16932 2527
22122 16896 2519
21974 17162 2519
22020 16388 2505
20689 15754 2533
20972 16201 2563
20064 13486 2391
20076 12981 2326
20025 12818 2309
20188 13493 2475
21672 12518 2443
20798 14468 2405
20118 14014 2414
21682 15150 2420
21878 16504 2537
22317 12672 2413
20704 14567 2404
19634 14354 2238
19245 13709 2275
19192 12525 2131
18846 12390 2128
19566 12905 2197
19589 12696 2179
19540 12485 2176
19080 12889 2133
19192 12971 2124
19391 13574 2273
18232 12256 2129
18319 11943 2133
18738 12402 2143
18503 13179 2135
18461 11935 2128
15854 10176 2287
16689 10725 2163
17167 11981 2130
16760 11493 2152
16739 11859 2177
16708 11389 2156
16522 11128 2157
16551 11004 2159
17821 11491 2144
17862 11856 2135
17758 12057 2129
17886 12183 2130
17642 11955 2131
17594 12467 2126
17331 12325 2127
17489 12136 2130
17592 12707 2123
16634 12312 2133
16357 12179 2144
17438 12188 2127
16645 11642 2149
16371 11736 2146
16361 12031 2143
16322 12570 2143
18031 11726 2132
17965 11016 2144
17627 11069 2132
18141 11725 2133
19545 13447 2260
19413 8875 2331
19665 9563 2326
18746 8623 2339
18320 8760 2334
18405 8753 2394
18587 8670 2334
18556 8532 2375
18750 8257 2379
18953 8183 2336
19114 8326 2336
19041 8453 2335
19176 8640 2333
19191 8323 2380
19185 8417 2337
18101 8840 2394
18648 7665 2551
18633 7801 2541
18456 8024 2515
18410 7979 2512
18262 8171 2482
17929 8604 2529
17526 8918 2489
17665 7796 2534
17885 7731 2491
17099 8132 2355
16353 8714 2362
11576 7227 2393
12492 8535 2359
12716 8695 2359
14495 6869 2565
14122 6876 2559
13337 6378 2449
13471 6364 2447
13449 6307 2573
13263 6413 2449
12903 6307 2592
13277 6055 2588
13428 6215 2579
13699 5639 2583
13628 5523 2582
13845 5891 2578
14215 6737 2572
14116 7462 2469
14571 7578 2433
14830 7630 2405
14918 7241 2489
12699 6375 2437
12727 6820 2446
12789 8685 2252
12713 8623 2253
12039 7458 2283
12626 7634 2270
12462 7314 2280
12004 7400 2395
11778 7614 2386
13531 7926 2203
13686 8548 2205
13679 7048 2445
14697 8694 2360
15649 7790 2361
15288 9611 2237
14911 9643 2251
15418 9715 2227
14885 7700 2401
13849 7119 2461
13707 7241 2456
14402 8638 2367
14455 9629 2267
16155 7414 2500
16697 17948 2334
19856 12086 2190
20016 12231 2179
19747 12262 2186
20223 11898 2185
8997 11494 2779
9110 11379 2778
9344 11052 2775
8935 10339 2696
9245 10001 2627
8838 9444 2612
8995 8665 2648
8981 9019 2619
8673 10511 2738
8976 10996 2754
9366 10811 2751
9009 10407 2700
8809 10000 2685
8907 9881 2639
8679 11460 2780
9628 10542 2740
8905 10785 2738
9045 10797 2738
10129 9834 2697
9739 10192 2720
9158 10493 2705
9640 10120 2700
9496 10098 2671
9208 10233 2659
9794 9892 2660
9792 9943 2672
9035 9795 2615
17983 10555 2272
20200 12658 2308
12579 7862 2268
12378 7256 2387
16286 22015 1856
18784 21312 1856
18469 19786 1918
19172 19881 1858
26585 18014 0
26485 18468 0
26407 18763 0
26300 19046 0
26077 19469 0
26041 19531 0
25792 19930 0
25311 20596 0
25245 20666 0
24705 21055 0
24622 21110 0
24282 21302 0
23781 21531 0
23681 21567 0
23419 21641 0
22914 21771 0
17451 23035 0
17326 23060 0
15764 23200 0
14977 23109 0
14461 23048 0
13515 22896 0
13453 22895 0
295 9889 0
0 9386 0
53 8963 0
1681 1467 0
1700 1450 0
5271 119 0
5610 3 0
7202 0 0
8021 3 0
15678 868 0
22592 5617 0
22680 5789 0
22994 6421 0
25577 12117 0
25837 12767 0
25879 12911 0
26274 14477 0
26410 15078 0
26532 15806 0
26575 16081 0
26623 16575 0
26652 17346 0
3 5261 0 5487
3 0 1003 5487
3 0 5256 1003
3 5256 0 5261
3 5261 5487 5327
3 5487 5328 5327
3 5487 1003 5328
3 5262 5256 5261
3 5262 5261 1127
3 5261 5327 1127
3 5260 1004 1003
3 5256 5260 1003
3 5328 1003 1007
3 1003 1004 1007
3 5343 5256 5262
3 5256 5254 5260
3 5343 5254 5256
3 1127 5327 5485
3 5327 5325 5485
3 5327 5326 5325
3 5327 5328 5326
3 5326 5328 5325
3 5328 1007 5325
3 6141 5584 6140
3 6140 5584 5262
3 6140 5262 6139
3 6139 5262 1127
3 5381 5343 5262
3 5378 5381 5262
3 5371 5378 5262
3 5582 5371 5262
3 5584 5582 5262
3 6139 1127 6138
3 6138 1127 5478
3 1127 5486 5478
3 1127 5485 5486
3 1004 1006 1007
3 1004 1005 1006
3 1005 1004 5260
3 5254 1005 5260
3 5325 1007 5323
3 1007 1002 5323
3 1007 5317 1002
3 1007 1006 5317
3 5381 5342 5343
3 5343 5342 5254
3 1005 5254 2185
3 5254 5344 2185
3 5342 5344 5254
3 5486 5485 5482
3 5485 5320 5482
3 5485 5325 5320
3 5320 5325 5323
3 6131 6133 6132
3 6131 6130 6133
3 6130 6129 6133
3 6129 6128 6133
3 6128 6127 6133
3 6127 6126 6133
3 6126 6125 6133
3 6125 6124 6133
3 6124 6123 6133
3 6123 6122 6133
3 6122 6121 6133
3 6121 6120 6133
3 6120 6119 6133
3 6119 6118 6133
3 6118 6117 6133
3 6117 6116 6133
3 6116 6115 6133
3 6115 6114 6133
3 6114 6113 6133
3 6113 6112 6133
3 6112 6111 6133
3 6111 6110 6133
3 6110 6109 6133
3 6109 6153 6133
3 6153 6152 6133
3 6152 6151 6133
3 6151 6150 6133
3 6150 6149 6133
3 6149 6148 6133
3 6148 6147 6133
3 6147 6146 6133
3 6146 6145 6133
3 6145 6144 6133
3 6144 6143 6133
3 6143 6142 6133
3 6142 6141 6133
3 6141 6140 6133
3 6140 6139 6133
3 6139 6138 6133
3 6138 6137 6133
3 6137 6136 6133
3 6136 6135 6133
3 6135 6134 6133
3 6142 3101 6141
3 6141 3101 5584
3 5584 5540 5582
3 5541 5540 5584
3 2498 5541 5584
3 3101 2498 5584
3 5381 5340 5342
3 5381 5376 5340
3 5381 5378 5376
3 5378 5382 5376
3 5380 5382 5378
3 5379 5380 5378
3 5371 5379 5378
3 5582 5536 5371
3 5371 5373 5379
3 5371 5350 5373
3 5359 5350 5371
3 5284 5359 5371
3 5536 5284 5371
3 5582 5540 5536
3 6138 5478 6137
3 6137 5478 5484
3 5478 5476 5484
3 5483 5476 5478
3 5486 5483 5478
3 5486 5482 5483
3 1006 5322 5317
3 1006 1008 5322
3 1006 1005 1008
3 1008 1005 1009
3 1005 2185 1009
3 5323 5479 5460
3 5323 5315 5479
3 5323 1002 5315
3 5320 5323 5468
3 5323 5319 5468
3 5319 5323 5460
3 5315 1002 5316
3 1002 5312 5316
3 1002 1010 5312
3 5317 1010 1002
3 5317 1013 1010
3 5322 1013 5317
3 5342 5340 5344
3 2185 5300 5253
3 5344 5300 2185
3 1009 2185 1022
3 2185 5253 1022
3 5344 5366 5302
3 5304 5366 5344
3 5340 5304 5344
3 5344 5302 5300
3 5482 5475 5483
3 5482 5468 5475
3 5482 5320 5468
3 3564 6133 3694
3 3564 6132 6133
3 3668 6133 6134
3 3668 3694 6133
3 5403 6134 6135
3 5403 3668 6134
3 6136 5404 6135
3 6135 5404 5403
3 6137 5484 6136
3 6136 5484 5404
3 6143 3117 6142
3 6142 3117 3101
3 6144 3116 6143
3 6143 3116 3117
3 6145 2741 6144
3 6144 2741 3116
3 6146 2724 6145
3 6145 2724 2741
3 6147 2722 6146
3 6146 2722 2724
3 6148 2676 6147
3 6147 2676 2722
3 6149 2697 6148
3 6148 2697 2676
3 6150 3435 6149
3 6149 3435 2697
3 6151 3442 6150
3 6150 3442 3435
3 6152 3443 6151
3 6151 3443 3442
3 6153 2918 6152
3 6152 2918 3443
3 2922 2918 6109
3 6109 2918 6153
3 2930 2922 6110
3 6110 2922 6109
3 66 2930 6111
3 6111 2930 6110
3 3151 66 6112
3 6112 66 6111
3 3186 3151 6113
3 6113 3151 6112
3 3187 3186 6114
3 6114 3186 6113
3 3192 3187 6115
3 6115 3187 6114
3 3196 3192 6116
3 6116 3192 6115
3 3303 3196 6117
3 6117 3196 6116
3 3303 6118 3317
3 3303 6117 6118
3 3317 6119 3318
3 3317 6118 6119
3 3318 6120 3319
3 3318 6119 6120
3 3319 6121 3349
3 3319 6120 6121
3 3349 6122 3348
3 3349 6121 6122
3 3348 6123 3351
3 3348 6122 6123
3 3351 6124 3371
3 3351 6123 6124
3 3371 6125 4729
3 3371 6124 6125
3 4729 6126 4719
3 4729 6125 6126
3 4719 6127 4935
3 4719 6126 6127
3 4935 6128 663
3 4935 6127 6128
3 663 6129 4999
3 663 6128 6129
3 4999 6130 5054
3 4999 6129 6130
3 5054 6131 5066
3 5054 6130 6131
3 5066 6132 3564
3 5066 6131 6132
3 3101 3095 2498
3 3101 3093 3095
3 3101 3098 3093
3 3101 3103 3098
3 3101 3117 3103
3 5540 5539 5536
3 5540 2458 5539
3 2557 2458 5540
3 5541 2557 5540
3 2509 2557 5541
3 2504 2509 5541
3 2499 2504 5541
3 2498 2499 5541
3 2499 2498 2502
3 2498 2500 2502
3 2428 2500 2498
3 3095 2428 2498
3 5340 5376 5304
3 5376 5341 5304
3 5369 5341 5376
3 5382 5369 5376
3 5380 5377 5382
3 5382 5372 5369
3 5382 5377 5372
3 5379 5377 5380
3 5379 5282 5377
3 5373 5282 5379
3 5536 5516 5284
3 5516 5536 5537
3 5536 5539 5537
3 5373 5368 5282
3 5373 5350 5368
3 5368 5350 5282
3 5350 5349 5282
3 5350 5286 5349
3 5350 5358 5286
3 5361 5358 5350
3 5359 5361 5350
3 5359 5351 5361
3 5355 5351 5359
3 5362 5355 5359
3 5284 5362 5359
3 5284 5285 5362
3 5284 5518 5285
3 5509 5518 5284
3 5516 5509 5284
3 5484 5471 5404
3 5484 5477 5471
3 5484 5481 5477
3 5476 5481 5484
3 5476 5475 5481
3 5483 5475 5476
3 1009 1013 5322
3 1008 1009 5322
3 1013 1009 1022
3 5468 5319 5460
3 5468 5460 5470
3 5470 5460 5469
3 5460 5479 5469
3 5479 5312 5467
3 5316 5312 5479
3 5315 5316 5479
3 5479 5467 5469
3 5468 5480 5475
3 5480 5468 5470
3 5312 5465 5467
3 5312 5313 5465
3 5312 1011 5313
3 1027 1011 5312
3 5314 1027 5312
3 1010 5314 5312
3 1010 5258 5314
3 1013 5258 1010
3 1013 1022 5258
3 5253 5300 5303
3 5253 5303 1022
3 5302 5364 5300
3 5300 5364 5303
3 5303 5252 1022
3 1022 1021 5258
3 1022 5252 1021
3 5302 5352 5364
3 5366 5352 5302
3 5304 5352 5366
3 5304 5341 5352
3 5475 5474 5481
3 5475 5480 5474
3 5061 5066 3564
3 2201 5061 3564
3 90 2201 3564
3 3669 90 3564
3 3669 3564 3694
3 3693 3669 3694
3 3692 3693 3694
3 3668 3692 3694
3 3661 3692 3668
3 3577 3661 3668
3 3670 3577 3668
3 5403 3670 3668
3 5403 3676 3670
3 5403 3681 3676
3 5403 3677 3681
3 5403 3680 3677
3 5403 5386 3680
3 5393 5386 5403
3 5410 5393 5403
3 5402 5410 5403
3 5401 5402 5403
3 5471 5401 5403
3 5404 5471 5403
3 3117 3099 3103
3 3117 3100 3099
3 3116 3100 3117
3 3116 3115 3100
3 3116 3112 3115
3 2797 3112 3116
3 68 2797 3116
3 2649 68 3116
3 2741 2649 3116
3 2741 2750 2649
3 2750 2741 2736
3 2741 2742 2736
3 2724 2742 2741
3 2742 2724 2717
3 2724 2723 2717
3 2724 2718 2723
3 2722 2718 2724
3 2719 2718 2722
3 2686 2719 2722
3 2676 2686 2722
3 2676 2679 2686
3 2676 2677 2679
3 2676 2697 2677
3 2697 2684 2677
3 2684 2697 2673
3 2697 2685 2673
3 3435 2685 2697
3 2685 3435 2683
3 3435 2695 2683
3 3435 3434 2695
3 3435 3442 3434
3 3442 3441 3434
3 3442 3443 3441
3 3441 3443 3451
3 3443 3469 3451
3 3443 2918 3469
3 2918 3477 3469
3 3477 2918 52
3 52 2918 2922
3 52 2922 3403
3 3403 2922 3405
3 3405 2922 3414
3 3414 2922 2930
3 3414 2930 3413
3 3413 2930 2928
3 2930 65 2928
3 65 2930 66
3 65 66 55
3 55 66 3151
3 55 3151 2882
3 3151 2897 2882
3 2897 3151 3150
3 3151 3175 3150
3 3175 3151 3186
3 3175 3186 3185
3 3186 3187 3185
3 3185 3187 3192
3 3193 3185 3192
3 3193 3192 3194
3 3194 3192 3289
3 3289 3192 3304
3 3304 3192 3196
3 3304 3196 2883
3 2883 3196 3272
3 3196 3303 3272
3 3303 3197 3272
3 3197 3303 3198
3 3198 3303 3317
3 2903 3198 3317
3 2903 3317 3306
3 3317 3318 3306
3 3306 3318 3336
3 3336 3318 3319
3 3336 3319 3305
3 3305 3319 3309
3 3319 3338 3309
3 3338 3319 3349
3 3338 3349 3348
3 3338 3348 3339
3 3339 3348 3335
3 3335 3348 3351
3 3364 3335 3351
3 3364 3351 3378
3 3351 3379 3378
3 3379 3351 3371
3 3379 3371 3387
3 3387 3371 4724
3 4724 3371 4733
3 4733 3371 4729
3 4717 4733 4729
3 4717 4729 4719
3 4717 4719 4720
3 4720 4719 4723
3 4723 4719 4935
3 4716 4723 4935
3 4728 4716 4935
3 4728 4935 4934
3 4935 664 4934
3 664 4935 663
3 4907 664 663
3 662 4907 663
3 662 663 4938
3 4938 663 661
3 661 663 5003
3 5003 663 4999
3 5003 4999 4998
3 4998 4999 5054
3 5004 4998 5054
3 5004 5054 5066
3 5083 5004 5066
3 5083 5066 5065
3 5065 5066 5061
3 3095 2430 2428
3 3095 3094 2430
3 3095 3096 3094
3 3093 3096 3095
3 3093 2966 3096
3 3093 2964 2966
3 3098 2964 3093
3 3098 3103 2964
3 3103 2965 2964
3 2965 3103 3090
3 3103 3099 3090
3 5539 5517 5537
3 5539 2458 5517
3 2478 5552 2458
3 2557 2478 2458
3 2458 5552 5517
3 2469 2478 2557
3 2509 2469 2557
3 2509 2453 2511
3 2504 2453 2509
3 2469 2509 2511
3 2504 2448 2453
3 2504 2446 2448
3 2437 2446 2504
3 2502 2437 2504
3 2499 2502 2504
3 2502 2436 2437
3 2424 2436 2502
3 2500 2424 2502
3 2500 2496 2424
3 2429 2496 2500
3 2428 2429 2500
3 2428 2430 2429
3 5341 5375 5352
3 5341 5369 5375
3 5369 5372 5374
3 5369 5374 5375
3 5377 5363 5372
3 5377 5367 5363
3 5282 5367 5377
3 5372 5363 5374
3 5282 5349 5367
3 5516 5512 5509
3 5516 5537 5512
3 5537 5527 5512
3 5537 5517 5527
3 5349 5292 5291
3 5286 5292 5349
3 5349 5354 5367
3 5349 5291 5354
3 5286 5357 5292
3 5286 5358 5357
3 5357 5358 2173
3 5358 5257 2173
3 5358 5276 5257
3 5361 5276 5358
3 5270 5276 5361
3 5351 5270 5361
3 5351 3498 5270
3 5351 2165 3498
3 5280 2165 5351
3 3497 5280 5351
3 5355 3497 5351
3 5362 5281 5355
3 5281 3497 5355
3 5285 5507 5362
3 5507 5281 5362
3 5518 5529 5285
3 5285 5529 5507
3 5518 5528 5529
3 5509 5528 5518
3 5509 5527 5528
3 5512 5527 5509
3 5471 5397 5401
3 5471 5396 5397
3 5471 5443 5396
3 5477 5443 5471
3 5477 5406 5443
3 5481 5406 5477
3 5481 5473 5406
3 5474 5473 5481
3 5470 5469 5472
3 5480 5470 5474
3 5474 5470 5472
3 5472 5469 5462
3 5469 5461 5462
3 5469 5467 5461
3 5461 5467 5466
3 5467 5465 5466
3 5466 5465 5417
3 5465 5455 5417
3 5465 5459 5455
3 5465 5464 5459
3 5465 5336 5464
3 5313 5336 5465
3 999 5336 5313
3 1011 999 5313
3 5259 999 1011
3 5321 5259 1011
3 1027 5321 1011
3 1026 5321 1027
3 5314 1026 1027
3 5258 1014 5314
3 1014 1026 5314
3 1021 1014 5258
3 5303 1024 5252
3 5303 5365 1024
3 5364 5365 5303
3 5365 5364 5345
3 5364 5293 5345
3 5352 5293 5364
3 5252 5251 1021
3 1024 5251 5252
3 1021 1012 1014
3 1000 1012 1021
3 5251 1000 1021
3 5352 5375 5353
3 5352 5353 5293
3 5474 5472 5473
3 5078 5065 5061
3 5078 5061 5060
3 5060 5061 2201
3 5032 5060 2201
3 4993 5032 2201
3 4985 4993 2201
3 4978 4985 2201
3 4972 4978 2201
3 2206 4972 2201
3 2199 2206 2201
3 2200 2199 2201
3 2200 2201 2205
3 2205 2201 3533
3 3533 2201 3705
3 3705 2201 3706
3 3706 2201 3579
3 3579 2201 90
3 1430 3579 90
3 1430 90 3563
3 3563 90 3669
3 3693 3563 3669
3 3693 3573 3563
3 3573 3693 3692
3 3576 3573 3692
3 3661 3576 3692
3 3577 3576 3661
3 3670 3662 3577
3 3574 3576 3577
3 3662 3574 3577
3 3670 3664 3662
3 3672 3664 3670
3 3676 3672 3670
3 3708 3672 3676
3 3681 3708 3676
3 3677 3708 3681
3 3677 3678 3708
3 3679 3678 3677
3 3680 3679 3677
3 3673 3679 3680
3 3665 3673 3680
3 5386 3665 3680
3 5386 3666 3665
3 5386 3652 3666
3 5386 3559 3652
3 5386 1299 3559
3 5385 1299 5386
3 5393 5385 5386
3 5393 5410 5385
3 5410 5387 5385
3 5410 5388 5387
3 5410 5392 5388
3 5412 5392 5410
3 5411 5412 5410
3 5409 5411 5410
3 5409 5410 5402
3 5396 5409 5402
3 5397 5396 5402
3 5397 5402 5401
3 3099 3097 3090
3 3100 3097 3099
3 3097 3100 2962
3 3100 3115 2962
3 3115 3110 2962
3 3115 3102 3110
3 3112 3102 3115
3 3112 3114 3102
3 3114 3112 2851
3 3112 2799 2851
3 3112 2798 2799
3 2797 2798 3112
3 2797 3083 2798
3 2797 3072 3083
3 3071 3072 2797
3 3086 3071 2797
3 3087 3086 2797
3 3070 3087 2797
3 68 3070 2797
3 68 3046 3070
3 68 3047 3046
3 3047 68 3024
3 68 2993 3024
3 68 2783 2993
3 2649 2783 68
3 2649 3016 2783
3 2649 2650 3016
3 2649 2752 2650
3 2750 2752 2649
3 2752 2750 2740
3 2750 2736 2740
3 2740 2736 2731
3 2736 2735 2731
3 2736 2742 2735
3 2742 2716 2735
3 2742 2717 2716
3 2716 2717 2702
3 2717 2701 2702
3 2717 2723 2701
3 2723 2705 2701
3 2719 2705 2723
3 2718 2719 2723
3 2705 2719 2699
3 2719 2686 2699
3 2699 2686 2680
3 2686 2687 2680
3 2686 2679 2687
3 2679 2677 2678
3 2679 2671 2687
3 2679 2678 2671
3 2678 2677 2671
3 2677 2636 2671
3 2677 2674 2636
3 2677 2684 2674
3 2674 2684 2675
3 2684 2673 2675
3 2675 2673 2668
3 2673 2683 2668
3 2685 2683 2673
3 2683 2694 2668
3 2683 2695 2694
3 2695 2696 3426
3 2695 3434 2696
3 2695 3426 2694
3 3434 3441 3439
3 2696 3434 3439
3 3439 3441 3433
3 3441 3440 3433
3 3441 3451 3440
3 3451 3459 3440
3 3451 3469 3459
3 3469 3477 3473
3 3469 2921 3459
3 3469 3473 2921
3 2920 3477 2929
3 3477 3402 2929
3 3477 52 3402
3 3473 3477 2920
3 52 3403 3402
3 3403 3405 3486
3 3402 3403 3485
3 3403 3486 3485
3 3405 3413 3486
3 3405 3414 3413
3 3486 3413 3408
3 3413 2928 3408
3 3408 2928 3395
3 2928 60 3395
3 60 2928 2925
3 2928 3130 2925
3 2928 58 3130
3 65 58 2928
3 65 55 58
3 58 55 3130
3 3130 55 3391
3 55 56 3391
3 56 55 64
3 64 55 2882
3 64 2882 3129
3 3129 2882 63
3 63 2882 3140
3 2882 2897 3140
3 2897 3141 3140
3 2897 3150 3141
3 3150 3175 3176
3 3141 3150 3176
3 3175 3177 3176
3 3175 3185 3177
3 3177 3185 3213
3 3185 3193 3213
3 3213 3193 3194
3 3194 3289 3236
3 3213 3194 3222
3 3222 3194 3271
3 3194 3236 3271
3 3236 3289 3278
3 3289 3304 3278
3 3278 3304 2884
3 2884 3304 2883
3 2883 3272 3276
3 2884 2883 3269
3 3269 2883 3276
3 3272 3197 3280
3 3276 3272 3279
3 3272 3280 3279
3 3197 3198 3280
3 3280 3198 3199
3 3199 3198 3306
3 3198 2903 3306
3 3199 3306 3191
3 3191 3306 2971
3 3306 3294 2971
3 3294 3306 3305
3 3306 3336 3305
3 3294 3305 2972
3 3305 3309 2972
3 3310 3309 3345
3 3309 3338 3345
3 2972 3309 3310
3 3345 3338 3339
3 3345 3339 3320
3 3339 3335 3320
3 3320 3335 3334
3 3335 3352 3334
3 3335 3364 3352
3 3352 3364 3378
3 3363 3352 3378
3 3363 3378 3369
3 3378 3377 3369
3 3378 3379 3377
3 3380 3379 3387
3 3377 3379 3380
3 3380 3387 3389
3 3389 3387 3376
3 3387 3384 3376
3 3384 3387 3386
3 3386 3387 3372
3 3372 3387 2362
3 2362 3387 4724
3 4726 4724 4725
3 4725 4724 4731
3 4731 4724 4727
3 4727 4724 4733
3 2363 2362 4724
3 2389 2363 4724
3 2394 2389 4724
3 4726 2394 4724
3 4727 4733 4717
3 4730 4727 4717
3 4730 4717 4715
3 4715 4717 4720
3 4715 4720 4706
3 4706 4720 4723
3 4706 4723 4716
3 4713 4706 4716
3 4713 4716 4741
3 4741 4716 4009
3 4009 4716 4703
3 4703 4716 4728
3 4702 4703 4728
3 4675 4702 4728
3 4675 4728 4280
3 4280 4728 4934
3 4948 4934 5001
3 5001 4934 4785
3 4785 4934 4994
3 4934 4936 4994
3 4936 4934 4907
3 4934 664 4907
3 4937 4280 4934
3 4948 4937 4934
3 4936 4907 662
3 4936 662 4938
3 4938 661 5002
3 4994 4936 4938
3 4946 4994 4938
3 4946 4938 4995
3 4995 4938 5002
3 5002 661 5003
3 5007 5003 4996
3 4996 5003 4998
3 5014 5002 5003
3 5014 5003 5007
3 4997 4998 5004
3 4996 4998 4997
3 5083 5045 5004
3 5010 4997 5004
3 5045 5010 5004
3 5008 5045 5083
3 5073 5008 5083
3 5073 5083 5059
3 5059 5083 5065
3 5078 5059 5065
3 2429 2430 2496
3 2430 2433 2496
3 2430 2426 2433
3 3094 2426 2430
3 3094 2966 2426
3 3096 2966 3094
3 2966 2967 2426
3 2966 2497 2967
3 2964 2497 2966
3 2964 2965 2497
3 2965 3090 2497
3 2497 3090 3091
3 3090 2494 3091
3 3090 2963 2494
3 3097 2963 3090
3 5517 5543 5535
3 5552 5543 5517
3 5517 5535 5527
3 2478 5581 5552
3 5552 5538 5543
3 5581 5538 5552
3 2470 5581 2478
3 2469 2470 2478
3 2469 2517 2470
3 2469 2511 2517
3 2511 2513 2517
3 2453 2513 2511
3 2453 2457 2513
3 2508 2457 2453
3 2448 2508 2453
3 2446 2508 2448
3 2416 2506 2446
3 2444 2416 2446
3 2421 2444 2446
3 2437 2421 2446
3 2446 2445 2508
3 2506 2445 2446
3 2436 2421 2437
3 2424 2423 2436
3 2436 2423 2421
3 2503 2423 2424
3 2433 2503 2424
3 2496 2433 2424
3 5375 5283 5353
3 5375 5338 5283
3 5370 5338 5375
3 5374 5370 5375
3 5374 5363 5370
3 5363 5296 5370
3 5354 5296 5363
3 5367 5354 5363
3 5527 5535 5514
3 5527 5514 5528
3 5354 5291 5296
3 5291 5348 5296
3 5291 5287 5348
3 5291 5289 5287
3 5292 5289 5291
3 5292 5288 5289
3 5292 5357 5288
3 5357 2173 5288
3 5288 2173 5347
3 2173 2160 5347
3 2173 2175 2160
3 2173 2174 2175
3 5257 2174 2173
3 5276 5273 5257
3 5257 5273 2174
3 3498 5489 5276
3 5270 3498 5276
3 5276 5277 5273
3 5489 5277 5276
3 5280 5489 3498
3 2165 5280 3498
3 5280 5279 5489
3 3497 5279 5280
3 3497 5504 5279
3 5504 3497 5281
3 5511 5504 5281
3 5507 5511 5281
3 5529 5511 5507
3 5529 5530 5510
3 5528 5530 5529
3 5529 5510 5511
3 5514 5530 5528
3 5324 5409 5396
3 5407 5324 5396
3 5443 5407 5396
3 5443 5414 5407
3 5443 5405 5414
3 5444 5405 5443
3 5406 5444 5443
3 5406 5462 5444
3 5473 5462 5406
3 5473 5472 5462
3 5462 5435 5444
3 5462 5461 5435
3 5461 5437 5435
3 5461 5458 5437
3 5461 5466 5458
3 5458 5466 5416
3 5466 5417 5416
3 5416 5417 5439
3 5417 5455 5439
3 5439 5455 5309
3 5455 5459 5309
3 5459 5456 5309
3 5459 5464 5456
3 5464 5463 5456
3 5464 3818 5463
3 5336 3818 5464
3 999 3818 5336
3 999 1001 3818
3 5310 1001 999
3 104 5310 999
3 5259 104 999
3 1014 104 5259
3 5321 1014 5259
3 1014 5321 1026
3 1014 1012 104
3 1017 5251 1024
3 5345 1017 1024
3 5365 5345 1024
3 5345 1016 1017
3 5345 5301 1016
3 1023 5301 5345
3 5293 1023 5345
3 5293 5346 1023
3 5353 5346 5293
3 5251 5263 5255
3 1025 5263 5251
3 1017 1025 5251
3 5251 5255 1000
3 1012 105 104
3 1012 1000 105
3 105 1000 5250
3 5250 1000 3709
3 1000 154 3709
3 5255 154 1000
3 5353 5283 5346
3 5074 5059 5078
3 5074 5078 5060
3 5028 5060 5032
3 5092 5074 5060
3 5028 5092 5060
3 5028 5032 5025
3 5025 5032 4993
3 5021 5025 4993
3 5018 5021 4993
3 5018 4993 4991
3 4991 4993 4985
3 4984 4991 4985
3 4984 4985 4978
3 4977 4984 4978
3 4977 4978 4971
3 4971 4978 4972
3 4925 4971 4972
3 4925 4972 2206
3 4960 4925 2206
3 4960 2206 2199
3 2204 2186 2199
3 2204 2199 2200
3 2186 4960 2199
3 2198 2204 2200
3 2198 2200 2205
3 3839 2205 3811
3 3811 2205 3536
3 3536 2205 3533
3 2196 2198 2205
3 2187 2196 2205
3 2188 2187 2205
3 2214 2188 2205
3 2207 2214 2205
3 2345 2207 2205
3 2345 2205 2343
3 2343 2205 3839
3 5712 3533 3705
3 3803 3536 3533
3 3519 3803 3533
3 3532 3519 3533
3 3532 3533 3674
3 3674 3533 5711
3 5711 3533 5728
3 5728 3533 5712
3 5735 3705 3706
3 3703 5712 3705
3 3704 3703 3705
3 3704 3705 3682
3 3682 3705 5735
3 5735 3706 3516
3 3516 3706 3579
3 3518 3516 3579
3 146 3518 3579
3 146 3579 100
3 100 3579 3578
3 3578 3579 1430
3 95 3578 1430
3 88 95 1430
3 88 1430 3573
3 3573 1430 3563
3 3562 88 3573
3 3574 3562 3573
3 3574 3573 3576
3 3664 3575 3662
3 3575 3574 3662
3 3571 3562 3574
3 1433 3571 3574
3 1432 1433 3574
3 1432 3574 3572
3 3572 3574 3575
3 3663 3664 3672
3 3664 3572 3575
3 3664 1432 3572
3 3671 1432 3664
3 3663 3671 3664
3 3708 3678 3672
3 3678 3663 3672
3 3679 3663 3678
3 3663 3679 3671
3 3679 1431 3671
3 3673 1431 3679
3 3673 1435 1431
3 3657 1435 3673
3 3657 3673 3665
3 94 3657 3665
3 3652 94 3665
3 3666 3652 3665
3 3559 94 3652
3 1299 92 3559
3 3647 94 3559
3 92 3647 3559
3 5383 3610 1299
3 5385 5383 1299
3 1299 74 92
3 1299 3553 74
3 3610 3553 1299
3 5387 5384 5385
3 5384 5383 5385
3 3606 5384 5387
3 5388 3606 5387
3 5445 3605 5388
3 5389 5445 5388
3 5391 5389 5388
3 5392 5391 5388
3 3605 3606 5388
3 5412 5413 5392
3 5413 5391 5392
3 5442 5413 5412
3 5442 5412 5411
3 5415 5423 5411
3 5415 5411 5409
3 5423 5442 5411
3 5394 5415 5409
3 5394 5409 5324
3 3097 2962 2963
3 2962 3110 3118
3 2963 2962 3107
3 2962 3118 3107
3 3102 3113 3110
3 3118 3110 3108
3 3110 3105 3108
3 3110 3109 3105
3 3111 3109 3110
3 3113 3111 3110
3 3102 3114 3113
3 3114 3104 3113
3 3114 2851 3104
3 3104 2851 2958
3 2958 2851 2854
3 2851 2847 2854
3 2851 2774 2847
3 2800 2774 2851
3 2799 2800 2851
3 3082 2800 2799
3 3083 3082 2799
3 2798 3083 2799
3 3072 3082 3083
3 3072 3063 3074
3 3071 3063 3072
3 3082 3072 2800
3 3072 2792 2800
3 3072 3074 2792
3 3063 3071 3075
3 3071 3084 3075
3 3071 3086 3084
3 3086 3088 3085
3 3087 3088 3086
3 3086 3085 3084
3 3070 3080 3087
3 3088 3087 3089
3 3087 3059 3089
3 3087 3081 3059
3 3080 3081 3087
3 3070 3068 3080
3 3070 3069 3068
3 3070 3046 3069
3 3046 3037 3069
3 3046 3036 3037
3 3047 3036 3046
3 3047 3024 3036
3 3036 3024 3031
3 3031 3024 3011
3 3024 2991 3011
3 2993 2991 3024
3 2993 3014 2991
3 2993 2781 3014
3 2783 2781 2993
3 2783 3017 2781
3 3016 3017 2783
3 3017 3016 2781
3 2781 3016 3015
3 3016 2780 3015
3 3016 2650 2780
3 2650 34 2780
3 2650 2749 34
3 2650 2752 2749
3 2749 2752 2740
3 2749 2740 2721
3 2721 2740 2748
3 2740 2731 2748
3 2748 2731 2729
3 2731 2735 2729
3 2735 2716 2729
3 2729 2716 2706
3 2716 2700 2706
3 2716 2702 2700
3 2702 2639 2700
3 2702 2689 2639
3 2701 2689 2702
3 2701 2681 2689
3 2698 2681 2701
3 2705 2698 2701
3 2705 2699 2698
3 2699 2688 2698
3 2688 2699 2680
3 2688 2680 2635
3 2635 2680 2637
3 2680 2656 2637
3 2680 2644 2656
3 2687 2644 2680
3 2687 2671 2644
3 2644 2671 2625
3 2671 2636 2625
3 2636 2623 2625
3 2636 2643 2623
3 2636 2674 2643
3 2674 2675 2643
3 2675 2668 2670
3 2643 2675 2633
3 2675 2670 2633
3 2668 2694 519
3 2670 2668 2672
3 2672 2668 2669
3 2668 519 2669
3 2694 2613 519
3 2694 3426 2613
3 3426 3425 2613
3 3426 3439 3425
3 2696 3439 3426
3 3425 3439 3433
3 3425 3433 2613
3 2613 3433 174
3 174 3433 2916
3 2916 3433 53
3 3433 3440 53
3 3440 3454 53
3 3440 3459 3454
3 3459 2921 3454
3 2921 3473 3468
3 3473 3457 3468
3 3473 2920 3457
3 3454 2921 3453
3 3453 2921 3466
3 2921 3468 3466
3 2920 2929 2927
3 2927 2929 2931
3 2929 3485 2931
3 3402 3485 2929
3 3457 2920 2927
3 3485 3486 3484
3 3484 3486 3408
3 2931 3485 59
3 3485 3484 59
3 3484 3408 3399
3 3399 3408 3412
3 3412 3408 3390
3 3408 3395 3390
3 3395 60 3390
3 60 2925 3390
3 2925 3130 2856
3 3390 2925 2856
3 3130 3391 2856
3 3391 3129 2856
3 3391 64 3129
3 56 64 3391
3 2856 3129 3127
3 3129 63 3127
3 63 3140 62
3 63 62 3127
3 3140 3149 3159
3 3140 3141 3149
3 62 3140 3159
3 3149 3141 3176
3 3176 3213 3164
3 3177 3213 3176
3 3149 3176 3164
3 3213 3222 3219
3 3164 3213 3195
3 3195 3213 3218
3 3213 3219 3218
3 3236 3278 3288
3 3271 3236 3288
3 3219 3222 3225
3 3225 3222 3229
3 3222 3271 3229
3 3271 3242 3229
3 3271 3288 3242
3 3288 3278 2884
3 3288 2884 3268
3 3268 2884 3269
3 3287 3276 3273
3 3273 3276 3279
3 3269 3276 3287
3 3268 3269 3262
3 3262 3269 3261
3 3269 3287 3261
3 3279 3280 3191
3 3280 3199 3191
3 3277 3273 3279
3 3277 3279 3286
3 3286 3279 3300
3 3279 2971 3300
3 3279 3191 2971
3 2971 3294 2972
3 3300 2971 2972
3 3300 2972 3295
3 2972 3310 3295
3 3310 3345 3307
3 3307 3345 3320
3 3295 3310 3301
3 3310 3307 3301
3 3307 3320 3311
3 3311 3320 3334
3 3334 3352 3363
3 3311 3334 3331
3 3331 3334 3333
3 3334 3363 3333
3 3333 3363 3361
3 3363 3369 3361
3 3369 3377 3389
3 3361 3369 3368
3 3369 3389 3368
3 3377 3380 3389
3 3368 3389 3376
3 3376 3384 3383
3 3368 3376 3367
3 3367 3376 2968
3 3376 3382 2968
3 3376 3383 3382
3 3384 3372 3383
3 3384 3386 3372
3 3383 3372 3388
3 3388 3372 2969
3 2969 3372 2362
3 2361 2969 2362
3 2361 2362 2383
3 2383 2362 2363
3 4710 4726 4725
3 4710 4725 4705
3 4705 4725 4722
3 4725 4718 4722
3 4725 4731 4718
3 2370 2394 4726
3 4711 2370 4726
3 4711 4726 4714
3 4714 4726 4710
3 4732 4731 4727
3 4731 4732 4718
3 4718 4732 4727
3 4730 4718 4727
3 2383 2363 2389
3 2368 2383 2389
3 2368 2389 2393
3 2393 2389 2394
3 2393 2394 2392
3 2392 2394 691
3 2394 2370 691
3 4722 4718 4730
3 4722 4730 4721
3 4721 4730 4715
3 2388 4721 4715
3 2388 4715 4706
3 4691 2388 4706
3 4691 4706 4008
3 4008 4706 4747
3 4706 4713 4747
3 4747 4713 4741
3 4747 4741 4755
3 4755 4741 4009
3 4755 4009 4754
3 4754 4009 4696
3 4009 4704 4696
3 4009 4703 4704
3 4704 4703 4702
3 4696 4704 4702
3 4696 4702 4675
3 4696 4675 4745
3 4745 4675 4939
3 4675 4937 4939
3 4937 4675 4280
3 4947 4948 5001
3 4947 5001 5011
3 5011 5001 4785
3 4939 4937 4948
3 4939 4948 4947
3 5011 4785 4994
3 5011 4994 4946
3 4995 5002 5013
3 5013 5002 5014
3 5039 5011 4946
3 5039 4946 5046
3 4946 4995 5046
3 5046 4995 5052
3 4995 5013 5052
3 5000 4996 4997
3 5007 4996 5015
3 5015 4996 5000
3 5006 5014 5007
3 5012 5006 5007
3 5012 5007 5015
3 5052 5013 5014
3 5052 5014 5006
3 5009 4997 5010
3 5009 5000 4997
3 5008 5010 5045
3 5008 5009 5010
3 5051 5009 5008
3 5051 5008 5073
3 5036 5073 5059
3 5044 5051 5073
3 5071 5044 5073
3 5036 5071 5073
3 5036 5059 5074
3 2433 2431 2503
3 2426 2431 2433
3 2426 2501 2431
3 2967 2501 2426
3 2967 2497 2501
3 2497 3091 2501
3 2501 3091 2422
3 3091 2961 2422
3 3091 2494 2961
3 2963 3107 2494
3 2494 2495 2961
3 2494 3107 2495
3 5543 5549 5535
3 5535 5534 5514
3 5535 5549 5534
3 5543 5538 5579
3 5543 5579 5549
3 5581 5553 5538
3 2483 5553 5581
3 2470 2483 5581
3 5538 5550 5579
3 5538 5551 5550
3 5538 5557 5551
3 5545 5557 5538
3 5553 5545 5538
3 2470 2517 2483
3 2483 2517 2480
3 2517 2521 2480
3 2427 2521 2517
3 2513 2427 2517
3 2457 2427 2513
3 2457 2510 2427
3 2445 2510 2457
3 2508 2445 2457
3 2506 2505 2445
3 2506 2416 2505
3 2416 2432 2505
3 2416 2439 2432
3 2439 2416 2444
3 2439 2444 2503
3 2503 2444 2423
3 2423 2444 2421
3 2445 2505 2510
3 2434 2439 2503
3 2431 2434 2503
3 5283 5298 5299
3 5283 5297 5298
3 5338 5297 5283
3 5283 5299 5346
3 5370 5339 5338
3 5338 5339 5297
3 5296 5339 5370
3 5296 5294 5339
3 5296 5348 5294
3 5534 5532 5514
3 5514 5532 5530
3 5290 5266 5348
3 5287 5290 5348
3 5348 5266 5294
3 5289 5290 5287
3 5288 5347 5289
3 5289 5347 5290
3 5290 5347 5266
3 5347 2160 5266
3 5266 2160 5269
3 2160 2172 5269
3 2160 3841 2172
3 2160 2175 3841
3 2181 2167 2175
3 2174 2181 2175
3 2175 2167 3841
3 5273 5274 2174
3 5274 2181 2174
3 5493 5274 5273
3 5277 5493 5273
3 5489 5275 5277
3 5489 5278 5275
3 5279 5278 5489
3 5275 5493 5277
3 5504 5502 5279
3 5279 2162 5278
3 2161 2162 5279
3 5490 2161 5279
3 5502 5490 5279
3 5504 5511 5502
3 5511 5508 5502
3 5583 5508 5511
3 5510 5583 5511
3 5530 5583 5510
3 5531 5583 5530
3 5532 5531 5530
3 5421 5324 5407
3 5398 5394 5324
3 5420 5398 5324
3 5421 5420 5324
3 5414 5421 5407
3 5405 5399 5414
3 5408 5421 5414
3 5399 5408 5414
3 5405 5439 5399
3 5435 5439 5405
3 5444 5435 5405
3 5435 5438 5439
3 5437 5438 5435
3 5437 5337 5438
3 5437 5458 5337
3 5337 5458 5416
3 5337 5416 5439
3 5438 5337 5439
3 5439 5400 5399
3 5400 5439 5436
3 5439 5309 5436
3 5309 5440 5436
3 5309 5311 5440
3 5456 5311 5309
3 5456 5457 5311
3 5463 5457 5456
3 5463 5335 5457
3 5333 5335 5463
3 5308 5333 5463
3 103 5308 5463
3 3818 103 5463
3 3818 3816 103
3 1001 3816 3818
3 5250 3816 1001
3 5310 5250 1001
3 104 105 5310
3 105 5250 5310
3 1016 1025 1017
3 1016 5301 1025
3 5301 1023 1025
3 1023 5356 1025
3 1023 5299 5356
3 5346 5299 1023
3 5255 5263 154
3 5356 2183 5263
3 5356 5263 1025
3 5263 1019 154
3 5263 3853 1019
3 2183 3853 5263
3 5250 106 3816
3 5250 3709 106
3 3709 153 151
3 3709 154 153
3 106 3709 151
3 154 1019 153
3 5092 5036 5074
3 5058 5092 5028
3 5027 5058 5028
3 5021 5027 5028
3 5021 5028 5025
3 5058 5036 5092
3 5017 5027 5021
3 4992 5017 5021
3 4992 5021 5018
3 4990 4992 5018
3 4917 4990 5018
3 4969 4917 5018
3 4969 5018 4991
3 4984 4969 4991
3 4969 4984 4977
3 4921 4969 4977
3 4970 4921 4977
3 4973 4970 4977
3 4973 4977 4971
3 4973 4971 4925
3 4973 4925 4960
3 4959 4973 4960
3 4952 4959 4960
3 4952 4960 2186
3 2202 4952 2186
3 2202 2186 2204
3 2197 2202 2204
3 2198 2197 2204
3 2196 2197 2198
3 3659 150 3811
3 3659 3811 3810
3 3810 3811 3535
3 3535 3811 3536
3 150 3839 3811
3 3836 2347 3839
3 3836 3839 3838
3 3838 3839 150
3 2344 2343 3839
3 2347 2344 3839
3 3535 3536 3803
3 2191 2197 2196
3 2187 2191 2196
3 2187 89 2191
3 2188 89 2187
3 4880 2193 2188
3 2229 4880 2188
3 2229 2188 2295
3 2295 2188 2322
3 2322 2188 2323
3 2323 2188 2329
3 2329 2188 2331
3 2331 2188 2214
3 2193 89 2188
3 2319 2214 2207
3 2319 2331 2214
3 2213 2319 2207
3 2212 2213 2207
3 2212 2207 2211
3 2211 2207 2345
3 2210 2345 2344
3 2345 2343 2344
3 2208 2211 2345
3 2208 2345 2342
3 2342 2345 2210
3 3531 5712 3703
3 3531 5728 5712
3 3995 3535 3803
3 3773 3995 3803
3 3799 3773 3803
3 3996 3799 3803
3 3996 3803 3519
3 3802 3996 3519
3 3802 3519 3534
3 3534 3519 3528
3 3528 3519 3532
3 3530 3528 3532
3 3530 3532 3674
3 5729 3530 3674
3 5729 3674 5711
3 5730 5711 5728
3 5729 5711 5730
3 3675 5730 5728
3 3675 5728 3531
3 3682 5735 3520
3 3520 5735 3516
3 3702 3531 3703
3 3702 3703 3704
3 3702 3704 5734
3 5734 3704 3682
3 5734 3682 3707
3 3707 3682 3520
3 3520 3516 148
3 148 3516 147
3 147 3516 3518
3 147 3518 146
3 148 147 146
3 3521 148 146
3 3521 146 3546
3 3546 146 100
3 99 3546 100
3 99 100 95
3 100 3578 95
3 3547 99 95
3 79 3547 95
3 79 95 88
3 3562 3571 88
3 3571 79 88
3 3571 3667 79
3 3660 3667 3571
3 1429 3660 3571
3 3539 1429 3571
3 1432 3539 3571
3 1432 3571 1433
3 3671 3539 1432
3 1431 5866 3671
3 1434 3539 3671
3 5866 1434 3671
3 1431 1435 5866
3 1435 3538 5866
3 87 3538 1435
3 91 87 1435
3 3657 91 1435
3 94 91 3657
3 3647 91 94
3 91 3647 92
3 87 91 92
3 76 87 92
3 77 76 92
3 1300 77 92
3 74 1300 92
3 3610 78 3553
3 1313 78 3610
3 5710 1313 3610
3 5384 5710 3610
3 5384 3610 5383
3 1298 1300 74
3 3553 1298 74
3 78 1298 3553
3 5384 5430 5710
3 3596 5430 5384
3 5429 3596 5384
3 3606 5429 5384
3 3594 5429 3606
3 3605 3594 3606
3 5426 3594 3605
3 5445 5426 3605
3 5425 5426 5445
3 5425 5445 5389
3 5390 5425 5389
3 5391 5390 5389
3 5413 5451 5391
3 5391 5424 5390
3 5453 5424 5391
3 5451 5453 5391
3 5442 5451 5413
3 5442 5431 5451
3 5433 5431 5442
3 5436 5433 5442
3 5436 5442 5419
3 5419 5442 5418
3 5418 5442 5423
3 5418 5423 5415
3 5330 5420 5415
3 5330 5415 5394
3 5421 5418 5415
3 5420 5421 5415
3 5330 5394 5398
3 3118 3108 3106
3 3118 3106 3107
3 3107 2957 2495
3 3107 2960 2957
3 3107 3106 2960
3 3113 2958 3111
3 3113 3104 2958
3 3108 3092 3106
3 3105 3092 3108
3 3105 3124 3092
3 3111 3124 3105
3 3109 3111 3105
3 3111 2958 3124
3 3124 2958 2956
3 2958 2854 2956
3 2854 2948 2956
3 2854 2852 2948
3 2854 3126 2852
3 2847 3126 2854
3 2847 2774 3126
3 2774 2791 3126
3 2792 2791 2774
3 2800 2792 2774
3 2792 3074 3073
3 3074 3063 3073
3 3063 3075 3073
3 2792 3073 2791
3 3075 2850 3073
3 3075 3084 2850
3 2850 3084 3064
3 3084 3076 3064
3 3084 3085 3076
3 3085 3077 3076
3 3085 3089 3077
3 3088 3089 3085
3 3081 3080 3053
3 3080 3054 3053
3 3068 3054 3080
3 3089 3059 3079
3 3077 3089 3078
3 3089 3079 3078
3 3079 3059 3058
3 3059 3057 3058
3 3059 3053 3057
3 3081 3053 3059
3 3068 3069 3054
3 3069 3037 3054
3 3054 3037 3052
3 3037 3031 3052
3 3037 3036 3031
3 3031 3035 3052
3 3031 3011 3035
3 3011 3012 3035
3 3011 3013 3012
3 3011 2991 3013
3 2991 2762 3013
3 2991 3014 2762
3 3014 2781 3015
3 3014 3015 2762
3 3015 2992 2762
3 3015 2780 2992
3 2992 2780 14
3 2780 27 14
3 2780 34 27
3 34 2721 27
3 2749 2721 34
3 2721 2730 27
3 2721 2748 2730
3 2730 2748 2751
3 2751 2748 2739
3 2748 2729 2739
3 2729 2715 2739
3 2729 2706 2715
3 2706 2700 2715
3 2715 2700 2703
3 2700 2707 2703
3 2700 11 2707
3 2700 2639 11
3 2639 2645 11
3 2639 2689 2645
3 2689 12 2645
3 2689 15 12
3 2689 2681 15
3 2698 2688 2681
3 2681 2688 15
3 2688 2635 15
3 15 2635 12
3 2635 2637 12
3 12 2637 2657
3 2637 2663 2657
3 2637 2656 2663
3 2656 2662 2663
3 2656 2644 2662
3 2644 2625 2662
3 2625 2623 2662
3 2662 2623 2614
3 2623 2862 2614
3 2623 2861 2862
3 2643 2861 2623
3 2643 2633 2861
3 2633 2670 3417
3 2670 2672 3417
3 2861 2633 3417
3 519 2613 2611
3 519 2855 2669
3 2855 519 2611
3 3417 2672 2615
3 2672 2859 2615
3 2672 2669 2859
3 2669 2612 2859
3 2669 2855 2612
3 2613 174 2611
3 2611 174 2858
3 2858 174 3427
3 174 2914 3427
3 174 2916 2914
3 2914 2916 3424
3 2916 53 3424
3 3454 54 53
3 3424 53 3446
3 53 3458 3446
3 53 54 3458
3 3454 3453 54
3 3468 2926 3466
3 3468 3457 2926
3 3457 2927 2926
3 3453 3466 54
3 3466 2926 3467
3 54 3466 3450
3 3466 3467 3450
3 2926 2927 3480
3 2927 2931 3480
3 2931 59 3483
3 3480 2931 3483
3 3482 3484 3399
3 59 3484 3482
3 3483 59 3482
3 3482 3399 3401
3 3401 3399 3394
3 3399 3412 3394
3 3394 3412 3400
3 3412 3390 3400
3 3400 3390 3128
3 3390 2856 3128
3 3128 2856 2932
3 2856 3127 2932
3 2932 3127 2933
3 3127 2879 2933
3 3127 2857 2879
3 62 2857 3127
3 62 3159 2857
3 3159 3174 3148
3 3159 3164 3174
3 3149 3164 3159
3 2857 3159 2880
3 2880 3159 3148
3 3174 3164 3195
3 3219 3225 3218
3 3195 3218 3206
3 3174 3195 3162
3 3162 3195 3206
3 3218 3225 3212
3 3206 3218 3216
3 3218 3212 3216
3 3242 3288 3243
3 3288 3268 3243
3 3225 3229 3212
3 3229 3190 3240
3 3229 3235 3190
3 3229 3242 3235
3 3212 3229 3230
3 3230 3229 3240
3 3242 3243 3235
3 3243 3268 3262
3 3287 3273 3277
3 3261 3287 3277
3 3235 3243 3262
3 3235 3262 3267
3 3267 3262 3252
3 3262 3201 3252
3 3262 3261 3201
3 3201 3261 3270
3 3270 3261 3200
3 3261 3277 3200
3 3200 3277 3286
3 3200 3286 3281
3 3281 3286 3300
3 3281 3300 3284
3 3284 3300 2970
3 2970 3300 3295
3 2970 3295 3293
3 3295 3296 3293
3 3295 3301 3296
3 3301 3307 3311
3 3301 3311 3296
3 3296 3311 3331
3 3312 3331 3347
3 3331 3333 3347
3 3297 3296 3331
3 3297 3331 3321
3 3321 3331 3312
3 3333 3361 3332
3 3347 3333 3346
3 3333 3332 3346
3 3332 3361 3330
3 3361 3368 3330
3 3330 3368 2891
3 2891 3368 3362
3 3362 3368 3366
3 3368 3367 3366
3 3382 3383 3388
3 3367 2968 3374
3 3366 3367 3374
3 3374 2968 3381
3 2968 3382 3381
3 3381 3382 3385
3 3382 3388 3385
3 3388 2969 3385
3 3385 2969 2350
3 2350 2969 2360
3 2969 2361 2360
3 2360 2361 2376
3 2376 2361 2375
3 2361 2366 2375
3 2361 2383 2366
3 2366 2383 2369
3 2369 2383 2368
3 4738 4714 4710
3 4738 4710 4708
3 4708 4710 4705
3 4705 4722 2388
3 4708 4705 4736
3 4736 4705 2388
3 4722 4721 2388
3 691 2370 4711
3 2395 691 4711
3 2395 4711 4712
3 4712 4711 4714
3 4709 4714 4738
3 4709 4712 4714
3 2369 2368 2367
3 2367 2368 2365
3 2365 2368 2393
3 2365 2393 2392
3 2391 2365 2392
3 2391 2392 4740
3 4740 2392 691
3 4740 691 2395
3 4736 2388 4691
3 4746 4691 4008
3 4736 4691 4746
3 4858 4746 4008
3 4858 4008 4735
3 4735 4008 4747
3 4865 4735 4747
3 4865 4747 4768
3 4768 4747 4755
3 4769 4768 4755
3 4769 4755 4766
3 4766 4755 4754
3 4754 4856 4855
3 4754 4753 4856
3 4754 4696 4753
3 4766 4754 4857
3 4857 4754 4855
3 4753 4696 4745
3 4753 4745 4767
3 4767 4745 4939
3 5005 4939 4947
3 4767 4939 5005
3 5005 4947 5049
3 5049 4947 5011
3 5049 5011 5039
3 5064 5039 5042
3 5039 5046 5042
3 5040 5049 5039
3 5040 5039 5064
3 5042 5046 5041
3 5046 5052 5041
3 5041 5052 5006
3 5053 5000 5009
3 5047 5015 5000
3 5047 5000 5053
3 5047 5012 5015
3 5041 5006 5043
3 5043 5006 5012
3 5043 5012 5080
3 5080 5012 5047
3 5053 5009 5051
3 5044 5053 5051
3 5077 5071 5036
3 5077 5036 5058
3 5050 5053 5044
3 5071 5050 5044
3 5048 5050 5071
3 4944 5048 5071
3 5069 4944 5071
3 5072 5069 5071
3 5077 5072 5071
3 2961 2434 2431
3 2422 2961 2431
3 2501 2422 2431
3 2957 2959 2961
3 2495 2957 2961
3 2961 2959 2434
3 5534 5549 5532
3 5549 5580 5532
3 5579 5580 5549
3 5579 5548 5580
3 5562 5548 5579
3 5550 5562 5579
3 2491 5545 5553
3 2482 2491 5553
3 2483 2482 5553
3 2483 2480 2482
3 5550 5571 5562
3 5551 5571 5550
3 5551 5563 5571
3 5557 5563 5551
3 5544 5577 5557
3 5545 5544 5557
3 5557 5577 5563
3 2492 5544 5545
3 2491 2492 5545
3 2480 2533 2482
3 2521 2533 2480
3 2521 2449 2533
3 2516 2449 2521
3 2427 2516 2521
3 2427 2515 2476
3 2468 2515 2427
3 2510 2468 2427
3 2427 2476 2516
3 2505 2464 2510
3 2464 2468 2510
3 2432 2464 2505
3 2507 2455 2432
3 3487 2507 2432
3 2439 3487 2432
3 2432 2455 2464
3 2796 3487 2439
3 2795 2796 2439
3 2434 2795 2439
3 2959 2795 2434
3 5299 3843 5356
3 5299 5298 3843
3 5298 2183 3843
3 5298 2184 2183
3 5295 2184 5298
3 5297 5295 5298
3 5339 5295 5297
3 5339 5294 5295
3 5295 5294 5264
3 5294 5267 5264
3 5294 2182 5267
3 5294 5269 2182
3 5266 5269 5294
3 5532 5542 5531
3 5621 5542 5532
3 5580 5621 5532
3 2182 5269 5268
3 5269 2171 5268
3 5269 2172 2171
3 2172 5237 2171
3 2172 2170 5237
3 2172 3841 2170
3 3841 5236 2170
3 3841 2168 5236
3 2167 2168 3841
3 5272 5492 2167
3 2181 5272 2167
3 2167 2169 2168
3 5492 2169 2167
3 2181 5274 5272
3 5274 5271 5272
3 5493 5271 5274
3 5493 5488 5271
3 5275 5488 5493
3 5278 5488 5275
3 2162 5488 5278
3 5502 5508 5490
3 2162 5495 5488
3 3495 5495 2162
3 2161 3495 2162
3 2161 5503 3495
3 5503 2161 5490
3 5508 5503 5490
3 5583 5506 5508
3 5506 5503 5508
3 5583 5505 5506
3 5531 5505 5583
3 5542 5505 5531
3 5421 5419 5418
3 5419 5421 5408
3 5395 5330 5398
3 5420 5395 5398
3 5420 5422 5395
3 5422 5420 5330
3 5399 5419 5408
3 5399 5400 5419
3 5400 5436 5419
3 5436 5440 5433
3 5440 5441 5433
3 5440 5311 5441
3 5311 5457 5331
3 5311 5331 5441
3 5457 5334 5331
3 5457 5335 5334
3 5335 3819 5334
3 5333 3819 5335
3 1028 3819 5333
3 5308 1028 5333
3 3817 1028 5308
3 103 3817 5308
3 3816 3817 103
3 3816 106 3817
3 3843 2183 5356
3 2184 5264 2183
3 2183 5265 3853
3 5264 5265 2183
3 153 1019 121
3 1019 3842 121
3 1020 3842 1019
3 3853 1020 1019
3 3844 1020 3853
3 5265 3844 3853
3 106 107 3817
3 106 151 107
3 107 151 156
3 151 69 156
3 151 121 69
3 153 121 151
3 5035 5077 5058
3 5027 5035 5058
3 5027 5024 5035
3 5020 5024 5027
3 5020 5027 5017
3 4983 5020 5017
3 4983 5017 4990
3 4990 5017 4992
3 4919 4983 4990
3 4919 4990 4917
3 4899 4919 4917
3 4899 4917 4922
3 4922 4917 4969
3 4922 4969 4921
3 4926 4922 4921
3 4926 4921 4970
3 4923 4926 4970
3 4973 4923 4970
3 4910 4923 4973
3 4910 4973 4959
3 4924 4910 4959
3 4974 4924 4959
3 4974 4959 4952
3 4986 4952 2202
3 4986 4974 4952
3 2192 4986 2202
3 2192 2202 2197
3 89 2192 2197
3 2191 89 2197
3 3809 3838 150
3 3809 150 3659
3 3999 3809 3659
3 3999 3659 3808
3 3808 3659 3810
3 3810 3535 3995
3 5785 3808 3810
3 5785 3810 3773
3 3773 3810 3995
3 3997 2344 2347
3 3997 2347 3836
3 3971 3997 3836
3 3971 3836 3998
3 3998 3836 3838
3 3658 3998 3838
3 3658 3838 3809
3 2210 2344 3788
3 3788 2344 3997
3 668 2192 89
3 660 668 89
3 2193 660 89
3 2193 2189 660
3 5089 2189 2193
3 2243 5089 2193
3 2242 2243 2193
3 4880 2242 2193
3 2241 2242 4880
3 2229 2241 4880
3 2236 2241 2229
3 2227 2236 2229
3 2228 2227 2229
3 2228 2229 2295
3 2336 2295 2322
3 2240 2228 2295
3 2297 2240 2295
3 2297 2295 2336
3 2336 2322 2337
3 2337 2322 2323
3 2337 2323 2329
3 2320 2337 2329
3 2320 2329 2330
3 2330 2329 2331
3 2330 2331 2319
3 2334 2330 2319
3 2334 2319 2213
3 2327 2334 2213
3 2327 2213 2212
3 2327 2212 2195
3 2195 2212 2211
3 2195 2211 2208
3 2324 2342 2210
3 2324 2210 3788
3 2346 2208 2342
3 2195 2208 2346
3 2346 2342 2324
3 5714 3675 3531
3 3696 5714 3531
3 3696 3531 3695
3 3695 3531 3702
3 5785 3773 3799
3 3801 5785 3799
3 3801 3799 4000
3 4000 3799 3996
3 3772 4000 3996
3 3772 3996 3529
3 3996 3802 3529
3 3529 3802 3534
3 3529 3534 3967
3 3967 3534 3530
3 3534 3528 3530
3 3967 3530 5729
3 5739 5784 5729
3 5739 5729 5730
3 5784 3967 5729
3 5713 5739 5730
3 5713 5730 5714
3 5714 5730 3675
3 3526 3707 3520
3 3526 3520 148
3 3701 3702 5734
3 3695 3702 3701
3 5738 3701 5734
3 5738 5734 3512
3 3512 5734 3707
3 3512 3707 3526
3 3683 3526 148
3 3683 148 3521
3 3588 3521 3517
3 3517 3521 3546
3 3684 3683 3521
3 3588 3684 3521
3 3517 3546 99
3 3547 3517 99
3 3667 3590 3547
3 3667 3547 79
3 3548 3517 3547
3 3590 3548 3547
3 3543 3590 3667
3 3655 3543 3667
3 3549 3655 3667
3 3660 3549 3667
3 93 3549 3660
3 93 3660 3550
3 3550 3660 1429
3 3539 3550 1429
3 1434 3551 3539
3 3551 3550 3539
3 5866 3538 1434
3 1434 5865 3551
3 3538 5865 1434
3 75 98 3538
3 87 75 3538
3 3538 3537 5865
3 3582 3537 3538
3 98 3582 3538
3 3561 75 87
3 77 3561 87
3 76 77 87
3 73 77 1300
3 72 3561 77
3 73 72 77
3 1298 73 1300
3 78 72 1298
3 78 80 72
3 71 80 78
3 1301 71 78
3 1301 78 1313
3 81 1301 1313
3 5710 81 1313
3 5710 3599 81
3 5430 3599 5710
3 72 73 1298
3 3596 3599 5430
3 1303 3599 3596
3 3607 1303 3596
3 5429 3607 3596
3 3594 3607 5429
3 3600 3607 3594
3 5446 3600 3594
3 5448 5446 3594
3 5426 5448 3594
3 5449 5448 5426
3 5424 5449 5426
3 5424 5426 5425
3 5424 5425 5390
3 5451 5431 5453
3 5453 5449 5424
3 5431 5427 5453
3 5453 5450 5449
3 5428 5450 5453
3 5427 5428 5453
3 5433 5427 5431
3 5433 5441 5427
3 5422 5330 5395
3 2960 3106 2957
3 3106 3121 2957
3 3106 2853 3121
3 3092 2853 3106
3 2957 3122 2959
3 3121 3122 2957
3 2956 2853 3092
3 3124 2956 3092
3 2956 2948 2853
3 2853 2948 2952
3 2948 3125 2952
3 2852 3125 2948
3 3126 2794 2852
3 2852 2794 3125
3 3126 2791 2794
3 2791 3061 2794
3 2791 3073 3061
3 3073 2850 3061
3 2850 3064 3061
3 3064 2790 3061
3 3064 50 2790
3 3064 2779 50
3 3076 2779 3064
3 3076 3077 2779
3 3077 2778 2779
3 3077 3078 2778
3 3053 3052 3057
3 3054 3052 3053
3 3079 3058 3078
3 3078 2849 2778
3 3078 3058 2849
3 3058 3030 2849
3 3058 3045 3030
3 3057 3045 3058
3 3057 3032 3045
3 3052 3032 3057
3 3052 3035 3032
3 3032 3035 2775
3 3035 3029 2775
3 3035 3012 3029
3 3012 3034 3029
3 3012 3010 3034
3 3012 3013 3010
3 3013 51 3010
3 3013 2990 51
3 3013 2762 2990
3 2990 2762 2763
3 2762 2992 2763
3 2992 14 2763
3 2763 14 2999
3 14 2984 2999
3 14 33 2984
3 33 14 24
3 14 27 24
3 27 2751 2648
3 27 2730 2751
3 27 2648 24
3 2751 2739 2727
3 2648 2751 2727
3 2727 2739 2647
3 2739 2715 2647
3 2715 2734 2647
3 2715 2703 2734
3 2703 2709 2734
3 2703 2707 2709
3 2707 2690 2709
3 2707 2691 2690
3 2707 11 2691
3 11 2627 2691
3 11 2657 2627
3 2645 2657 11
3 2645 12 2657
3 2657 2665 2627
3 2657 2664 2665
3 2657 2663 2664
3 2663 8 2664
3 2663 2662 8
3 2662 2614 8
3 8 2614 2619
3 2614 2610 2619
3 2862 2610 2614
3 2862 2861 2863
3 2862 2860 2610
3 2862 2605 2860
3 2862 2863 2605
3 2861 3417 2863
3 2863 3417 2615
3 2855 2611 2612
3 2611 2858 2612
3 2615 3429 3423
3 2859 3429 2615
3 2863 2615 2605
3 2605 2615 2860
3 2860 2615 3423
3 2859 2912 3429
3 2612 2912 2859
3 2612 2858 2912
3 2858 3427 2912
3 3427 2913 2912
3 3427 3424 2913
3 2914 3424 3427
3 2913 3424 3419
3 3424 3446 3419
3 3458 54 3450
3 3446 3445 3437
3 3446 2915 3445
3 3446 3458 2915
3 3419 3446 3437
3 3458 3450 3463
3 2915 3458 3456
3 3458 3463 3456
3 3467 2926 2919
3 2919 2926 2873
3 2926 3480 2873
3 3450 3467 2919
3 3463 3450 2872
3 3450 2873 2872
3 3450 2919 2873
3 3480 3483 2873
3 2873 3483 2917
3 3483 3482 2917
3 3482 3401 2917
3 2917 3401 2934
3 2934 3401 3416
3 3401 3394 3416
3 3394 3404 3416
3 3394 3400 3404
3 3400 3128 3404
3 3404 3128 3392
3 3128 2932 3392
3 3392 2932 2933
3 2933 3131 3147
3 3135 3131 2933
3 2879 3135 2933
3 3392 2933 2935
3 2935 2933 2877
3 2933 2878 2877
3 2878 2933 5594
3 2933 3147 5594
3 3135 2879 3131
3 2879 3133 3131
3 2879 2857 3133
3 2857 2880 3133
3 3148 3174 3162
3 2880 3148 3133
3 3133 3148 2881
3 2881 3148 3162
3 3162 3206 3205
3 3206 3216 3205
3 2881 3162 3173
3 3173 3162 3205
3 3182 3212 3228
3 3212 3230 3228
3 3216 3212 3505
3 3212 3182 3505
3 3205 3216 3224
3 3216 3505 3224
3 3228 3230 3240
3 3228 3240 3247
3 3240 3248 3247
3 3240 3241 3248
3 3240 3190 3241
3 3241 3190 3248
3 3190 3267 3248
3 3190 3235 3267
3 3248 3267 3252
3 3248 3252 3246
3 3252 3202 3246
3 3252 3201 3202
3 3202 3201 3251
3 3201 3270 3251
3 3270 3200 3264
3 3251 3270 3264
3 3264 3200 3274
3 3200 3281 3274
3 3274 3281 2901
3 2901 3281 3284
3 3284 2970 3293
3 2901 3284 2902
3 2902 3284 3293
3 3293 3296 3297
3 2902 3293 2898
3 2898 3293 2900
3 3293 3297 2900
3 3312 3347 3313
3 3313 3347 3322
3 3347 3346 3322
3 3290 3321 3312
3 3290 3312 3314
3 3314 3312 3313
3 2900 3297 3290
3 3290 3297 3321
3 3332 3330 3346
3 3322 3346 3328
3 3346 3330 3328
3 3328 3330 2899
3 3330 2891 2899
3 2899 2891 3360
3 2891 3362 3360
3 3362 3366 3360
3 3360 3366 3374
3 3360 3374 3373
3 3373 3374 3359
3 3374 3358 3359
3 3374 3381 3358
3 3381 3385 2350
3 3358 3381 2350
3 3358 2350 2358
3 2358 2350 2359
3 2350 2360 2359
3 2359 2360 2376
3 2359 2376 202
3 202 2376 2374
3 2376 2375 2374
3 2375 692 2374
3 2375 2366 692
3 2366 2369 692
3 692 2369 2382
3 2369 2367 2382
3 4757 4738 4774
3 4774 4738 5093
3 5093 4738 4708
3 4777 4709 4738
3 4757 4777 4738
3 4743 4708 4775
3 4708 4739 4775
3 4739 4708 4736
3 4743 5093 4708
3 4737 4736 4746
3 4707 4739 4736
3 4707 4736 4737
3 4740 2395 4257
3 4257 2395 4258
3 4258 2395 4712
3 4859 4712 4709
3 4258 4712 4859
3 4782 4859 4709
3 4782 4709 4780
3 4780 4709 4777
3 2382 2367 2391
3 2367 2365 2391
3 2382 2391 2387
3 2387 2391 4740
3 4758 2387 4740
3 4758 4740 4257
3 4756 4746 4862
3 4862 4746 4858
3 4756 4737 4746
3 4858 4735 4772
3 4862 4858 4760
3 4760 4858 4772
3 4772 4735 4865
3 4772 4865 4802
3 4802 4865 4770
3 4865 4769 4770
3 4865 4768 4769
3 4770 4769 4766
3 4770 4766 4800
3 4800 4766 4857
3 4800 4857 4855
3 6105 4800 4855
3 6105 4855 4744
3 4744 4855 4846
3 4855 4856 4846
3 4856 4753 4846
3 4846 4753 4767
3 4799 4846 4767
3 4799 4767 4779
3 4779 4767 5005
3 4779 5005 4836
3 4836 5005 5038
3 5038 5005 5049
3 5038 5049 5040
3 5042 5041 4945
3 5064 5042 4945
3 5082 5064 5062
3 5064 4945 5062
3 5070 5040 5064
3 5068 5070 5064
3 5068 5064 5082
3 5037 5038 5040
3 5037 5040 5070
3 4945 5041 5043
3 5050 5047 5053
3 5048 5047 5050
3 4944 5080 5047
3 4944 5047 5048
3 4945 5043 5062
3 5062 5043 4944
3 5043 5080 4944
3 5079 5072 5077
3 5079 5077 5035
3 5072 4944 5069
3 5062 4944 5072
3 5082 5062 5072
3 5079 5082 5072
3 3122 2795 2959
3 5580 5533 5621
3 5548 5533 5580
3 5554 5548 5562
3 5548 5578 5533
3 5548 5554 5578
3 5564 5554 5562
3 5571 5564 5562
3 2491 2549 2492
3 2491 2541 2549
3 2542 2541 2491
3 2482 2542 2491
3 2482 2451 2542
3 2533 2451 2482
3 5571 5563 5564
3 5564 5563 5554
3 5563 5560 5554
3 5563 5577 5560
3 5574 5572 5577
3 5544 5574 5577
3 5577 5572 5560
3 2588 5574 5544
3 2493 2588 5544
3 2492 2493 5544
3 2493 2492 2561
3 2492 2549 2561
3 2533 2488 2451
3 2533 2550 2488
3 2528 2550 2533
3 2479 2528 2533
3 2449 2479 2533
3 2449 2522 2479
3 2476 2522 2449
3 2516 2476 2449
3 2476 2435 2485
3 2476 2515 2435
3 2522 2476 2485
3 2515 2526 2435
3 2472 2526 2515
3 2468 2472 2515
3 2464 2465 2468
3 2465 2472 2468
3 2464 2443 2465
3 2442 2443 2464
3 2455 2442 2464
3 2507 2442 2455
3 2507 2454 2442
3 3487 2454 2507
3 2795 3120 3487
3 2796 2795 3487
3 3487 2440 2454
3 3487 3120 2440
3 2795 2953 3120
3 2955 2953 2795
3 3122 2955 2795
3 5295 5264 2184
3 5264 3844 5265
3 5264 5267 3844
3 5267 5360 3844
3 5267 5268 5360
3 2182 5268 5267
3 5621 5533 5542
3 5505 5542 5520
3 5542 5522 5520
3 5542 5526 5522
3 5513 5526 5542
3 5515 5513 5542
3 5533 5515 5542
3 5268 2171 3726
3 5268 3726 5360
3 3726 2171 3727
3 2171 742 3727
3 2171 5237 742
3 2170 5236 5237
3 5237 5238 742
3 5236 5238 5237
3 5236 4630 5239
3 5236 4618 4630
3 152 4618 5236
3 2168 152 5236
3 5238 5236 5239
3 2168 4617 152
3 2169 4617 2168
3 5494 4616 5492
3 5271 5494 5492
3 5271 5492 5272
3 5492 4628 2169
3 5492 4616 4628
3 2169 4629 4617
3 4628 4629 2169
3 5488 5494 5271
3 5488 5495 5494
3 5495 4615 5494
3 1018 4615 5495
3 3494 1018 5495
3 3495 3494 5495
3 2166 3494 3495
3 5503 2166 3495
3 2166 5503 2164
3 5503 5520 2164
3 5506 5520 5503
3 5505 5520 5506
3 5441 5454 5427
3 5332 5454 5441
3 5331 5332 5441
3 5331 5334 5332
3 5334 5307 5332
3 5334 3819 5307
3 3819 3640 5307
3 1028 3640 3819
3 1028 111 3640
3 3817 111 1028
3 3817 107 111
3 3842 120 121
3 121 120 69
3 3845 3849 3842
3 1020 3845 3842
3 3842 3849 120
3 1020 3851 3845
3 3844 3851 1020
3 3844 3846 3851
3 5360 3846 3844
3 107 156 111
3 113 156 86
3 156 157 86
3 156 69 157
3 111 156 113
3 69 5248 157
3 69 4624 5248
3 120 4624 69
3 5056 5079 5035
3 5024 5056 5035
3 5031 5056 5024
3 5020 5031 5024
3 5031 5020 4983
3 4989 5031 4983
3 4919 4989 4983
3 4916 4989 4919
3 4901 4916 4919
3 4901 4919 4920
3 4920 4919 4899
3 4920 4899 4922
3 4920 4922 4926
3 4931 4920 4926
3 4932 4931 4926
3 4923 4932 4926
3 4910 4932 4923
3 4918 4932 4910
3 4918 4910 4924
3 4927 4918 4924
3 4927 4924 4961
3 4961 4924 4974
3 4951 4961 4974
3 4951 4974 4986
3 4979 4951 4986
3 4979 4986 2192
3 2190 4979 2192
3 668 2190 2192
3 3796 3658 3809
3 3797 3796 3809
3 3999 3797 3809
3 3797 3999 3808
3 3768 3808 3801
3 3801 3808 5785
3 3798 3797 3808
3 3768 3798 3808
3 3790 3788 3997
3 3790 3997 3971
3 3779 3790 3971
3 3779 3971 3787
3 3787 3971 3837
3 3837 3971 3998
3 3970 3998 3796
3 3796 3998 3658
3 3970 3837 3998
3 2326 2324 3788
3 3786 2326 3788
3 3786 3788 3790
3 2190 668 660
3 2189 2190 660
3 5089 4896 2189
3 2189 4881 2190
3 2189 688 4881
3 4898 688 2189
3 4896 4898 2189
3 5087 4896 5089
3 5088 5087 5089
3 4879 5088 5089
3 686 4879 5089
3 2215 686 5089
3 2215 5089 2243
3 2237 2215 2243
3 2237 2243 2242
3 2238 2237 2242
3 2238 2242 2241
3 2235 2238 2241
3 2235 2241 2236
3 2231 2235 2236
3 2233 2231 2236
3 2227 2233 2236
3 2224 2227 2239
3 2227 2228 2239
3 2233 2227 2224
3 2239 2228 2240
3 2296 2297 2336
3 2318 2296 2336
3 2332 2318 2336
3 2335 2332 2336
3 2335 2336 2337
3 2273 2239 2240
3 2285 2273 2240
3 2285 2240 2297
3 2310 2285 2297
3 2296 2310 2297
3 2335 2337 2320
3 2334 2320 2330
3 2339 2335 2320
3 2339 2320 2321
3 2321 2320 2334
3 2321 2334 2327
3 2341 2321 2327
3 3775 2341 2327
3 2314 3775 2327
3 2312 2314 2327
3 2312 2327 2317
3 2317 2327 2326
3 2327 2315 2326
3 2327 2313 2315
3 2313 2327 2195
3 2194 2313 2195
3 2315 2194 2195
3 2315 2195 2209
3 2209 2195 2346
3 2209 2346 2324
3 2326 2209 2324
3 5727 5731 5714
3 5727 5714 3696
3 5731 5713 5714
3 5736 5737 3696
3 5736 3696 3695
3 5737 5727 3696
3 3689 5736 3695
3 3689 3695 3701
3 3768 3801 3800
3 3800 3801 4000
3 3800 4000 5788
3 5788 4000 3770
3 4000 3772 3770
3 3770 3772 3529
3 3770 3529 3523
3 3523 3529 3699
3 3699 3529 3967
3 3699 3967 5784
3 5717 5784 5739
3 5717 3699 5784
3 5749 5717 5739
3 5749 5739 5715
3 5715 5739 5731
3 5739 5713 5731
3 3524 3512 3526
3 3525 3524 3526
3 3525 3526 3683
3 3689 3701 5738
3 5726 5733 5738
3 3687 5726 5738
3 5752 3687 5738
3 3685 5752 5738
3 3685 5738 3512
3 5733 3689 5738
3 3685 3512 3524
3 3684 3525 3683
3 3548 3588 3517
3 3589 3588 3548
3 3545 3684 3588
3 3589 3545 3588
3 3686 3525 3684
3 3686 3684 3545
3 3543 3548 3590
3 3589 3548 3543
3 3542 3589 3543
3 3655 3542 3543
3 3654 3542 3655
3 3656 3654 3655
3 3656 3655 3540
3 3540 3655 3549
3 3540 3549 93
3 5865 3540 93
3 5865 93 3551
3 3551 93 3550
3 3541 3540 5865
3 3537 3541 5865
3 3584 3583 98
3 75 3584 98
3 3583 3582 98
3 102 3584 75
3 3561 102 75
3 3537 3651 3541
3 3582 3651 3537
3 3624 3580 3582
3 3623 3624 3582
3 3583 3623 3582
3 3582 3580 3651
3 80 1310 3561
3 80 3561 72
3 1310 102 3561
3 1312 1310 80
3 71 1312 80
3 3599 1305 71
3 3599 71 1301
3 1305 1312 71
3 81 3599 1301
3 3599 1310 1305
3 1303 1310 3599
3 1311 1304 1303
3 1311 1303 3607
3 1303 1304 1310
3 3600 1311 3607
3 3595 1311 3600
3 3602 3595 3600
3 3602 3600 5446
3 5448 3602 5446
3 5447 3602 5448
3 5452 5447 5448
3 5452 5448 5449
3 5450 5452 5449
3 5427 5434 5428
3 5329 5434 5427
3 5454 5329 5427
3 5434 5452 5450
3 5428 5434 5450
3 3121 2954 3122
3 2853 2954 3121
3 2853 2952 2954
3 2954 2955 3122
3 2952 3018 3123
3 3125 3018 2952
3 2952 3123 2954
3 2794 3018 3125
3 2794 2789 3018
3 3061 2789 2794
3 3061 2790 2789
3 2790 3038 2789
3 2790 2801 3038
3 50 2801 2790
3 50 3060 2801
3 2779 3060 50
3 2779 2778 3060
3 2778 3065 3060
3 2778 2849 3065
3 2849 3066 3065
3 2849 3030 3066
3 3030 3044 3066
3 3030 3056 3044
3 3062 3056 3030
3 3045 3062 3030
3 3032 3062 3045
3 3062 3032 2775
3 3062 2775 2773
3 2775 3029 2773
3 3029 2767 2773
3 3029 3034 2767
3 3034 3009 3051
3 3010 3009 3034
3 3034 3051 2767
3 3010 51 3009
3 51 2989 3009
3 51 2990 2989
3 2990 2763 2989
3 2989 2763 2760
3 2760 2763 2999
3 2760 2999 2998
3 2998 2999 42
3 2999 2984 42
3 42 2984 2983
3 2984 13 2983
3 2984 24 13
3 33 24 2984
3 24 2727 2647
3 2648 2727 24
3 13 24 6
3 24 2733 6
3 24 2647 2733
3 2733 2647 2738
3 2647 2708 2738
3 2647 2734 2708
3 2734 2709 2708
3 2709 2704 2708
3 2709 2690 2704
3 2704 2690 5
3 2690 2692 5
3 2690 2682 2692
3 2690 2691 2682
3 2691 2626 2682
3 2691 2627 2626
3 2627 2634 2638
3 2627 2665 2634
3 2626 2627 2638
3 2665 2664 2634
3 2634 2664 2666
3 2664 8 2666
3 8 2608 2666
3 8 2619 2608
3 2619 2610 2667
3 2608 2619 2659
3 2619 2667 2659
3 2610 2618 2667
3 2610 2860 2618
3 2860 2864 2618
3 2860 3423 2864
3 2864 3423 2609
3 3423 3420 2609
3 3423 3422 3420
3 3432 3422 3423
3 3429 3432 3423
3 3429 3428 3432
3 2912 3428 3429
3 3428 2912 3419
3 2912 2913 3419
3 3432 3419 3438
3 3419 3437 3438
3 3428 3419 3432
3 3438 3437 3449
3 3437 3445 3449
3 3449 3445 3452
3 3445 3456 3452
3 2915 3456 3445
3 3463 3472 3462
3 3472 3463 3393
3 3463 2872 3393
3 3456 3463 3462
3 3456 3455 3452
3 3456 3462 3455
3 2872 2873 3393
3 2873 2917 3393
3 3393 2917 2934
3 3393 2934 3396
3 2934 3416 3396
3 3416 3411 3396
3 3416 3404 3411
3 3411 3404 2935
3 3404 3392 2935
3 3147 3131 3163
3 3147 3163 5594
3 3131 3173 3154
3 3131 2881 3173
3 3133 2881 3131
3 3131 3154 3163
3 3411 2935 3407
3 3407 2935 2877
3 3407 2877 3406
3 3406 2877 2875
3 2877 3134 2875
3 2877 2878 3134
3 3134 2878 3132
3 2878 5594 3132
3 3132 5594 3146
3 5594 3158 3146
3 5594 3163 3158
3 3173 3205 3184
3 3184 3205 3224
3 3154 3173 3163
3 3163 3173 3184
3 3505 3182 3228
3 3505 3228 3217
3 3228 3247 3217
3 3224 3505 3217
3 3184 3224 3183
3 3224 3204 3183
3 3204 3224 3217
3 3247 3248 3239
3 3247 3239 3217
3 3239 3248 3266
3 3248 3246 3266
3 3266 3246 3253
3 3246 3254 3253
3 3246 3202 3254
3 3202 3251 3254
3 3254 3251 3260
3 3260 3251 3264
3 3264 3274 3259
3 3260 3264 3263
3 3263 3264 3259
3 3259 3274 2357
3 3274 2901 2357
3 2901 3282 3275
3 3282 2901 2892
3 2901 2902 2892
3 2357 2901 3275
3 2892 2902 2887
3 2887 2902 2898
3 2887 2898 2904
3 2898 3285 2904
3 2898 2900 3285
3 3285 2900 3291
3 2900 3290 3291
3 3314 3313 3327
3 3327 3313 3337
3 3337 3313 3340
3 3313 3322 3340
3 3340 3322 3329
3 3322 3328 3329
3 3291 3290 2943
3 2943 3290 3314
3 2943 3314 3308
3 3308 3314 3327
3 3328 2899 3329
3 2899 3360 3329
3 3329 3360 3357
3 3357 3360 3356
3 3360 3373 3356
3 3356 3373 3375
3 3373 3359 3375
3 3375 3359 2354
3 3359 2348 2354
3 3359 2352 2348
3 3359 3358 2352
3 3358 2358 2352
3 2352 2358 202
3 2358 2359 202
3 2351 2352 202
3 2351 202 4813
3 4813 202 4797
3 202 2374 4797
3 4797 2374 2373
3 2374 692 2373
3 692 2381 2373
3 2381 692 2382
3 2381 2382 2386
3 2386 2382 2387
3 4774 5093 4743
3 4776 4757 4774
3 4776 4774 4789
3 4789 4774 4743
3 4863 4777 4757
3 4863 4757 4776
3 4780 4777 4781
3 4781 4777 4776
3 4777 4863 4776
3 4775 4739 4849
3 4789 4743 4775
3 4789 4775 4773
3 4773 4775 4848
3 4775 4849 4848
3 4849 4739 4707
3 4849 4707 4737
3 4849 4737 4848
3 4848 4737 4847
3 4847 4737 4756
3 4758 4257 4851
3 4851 4257 4258
3 4860 4258 4866
3 4866 4258 4864
3 4864 4258 4859
3 4860 4851 4258
3 4864 4859 4782
3 4866 4864 4782
3 4807 4866 4782
3 4783 4807 4782
3 4783 4782 4790
3 4790 4782 4287
3 4782 4780 4287
3 4287 4780 4781
3 2386 2387 4852
3 2387 4758 4852
3 4852 4758 4851
3 4847 4756 4862
3 4804 4847 4862
3 4803 4804 4862
3 4803 4862 4763
3 4763 4862 4749
3 4862 4760 4749
3 4749 4760 4772
3 4749 4772 4771
3 4771 4772 4802
3 4821 4802 4817
3 4802 4770 4817
3 4796 4771 4802
3 4821 4796 4802
3 4817 4770 4809
3 4809 4770 4800
3 4809 4800 6105
3 4840 4809 6105
3 4840 6105 4833
3 4833 6105 4835
3 6105 4744 4835
3 4835 4744 4799
3 4744 4846 4799
3 4819 4799 4836
3 4799 4779 4836
3 4786 4835 4799
3 4786 4799 4819
3 5067 4836 5081
3 4836 5037 5081
3 4836 5038 5037
3 4822 4819 4836
3 4752 4822 4836
3 4752 4836 5067
3 5076 5068 5082
3 5076 5082 5057
3 5057 5082 5079
3 5081 5070 5068
3 5081 5037 5070
3 5063 5081 5068
3 5091 5063 5068
3 5091 5068 5076
3 5057 5079 5056
3 5578 5515 5533
3 5554 5555 5578
3 5554 5561 5555
3 5560 5561 5554
3 5555 5515 5578
3 2549 2555 2561
3 2560 2555 2549
3 2541 2560 2549
3 2556 2548 2541
3 2542 2556 2541
3 2548 2560 2541
3 2451 2556 2542
3 2451 2488 2556
3 5560 5575 5561
3 5573 5575 5560
3 5572 5573 5560
3 5572 5570 5573
3 2156 5570 5572
3 5574 2156 5572
3 2588 2156 5574
3 2588 2159 2156
3 2588 2590 2159
3 2590 2588 2582
3 2588 2589 2582
3 2588 2420 2589
3 2588 2415 2420
3 2481 2415 2588
3 2490 2481 2588
3 2493 2490 2588
3 2493 2561 2490
3 2481 2561 2415
3 2561 2489 2415
3 2561 2452 2489
3 2450 2452 2561
3 2555 2450 2561
3 2561 2481 2490
3 2488 2558 2548
3 2488 2550 2558
3 2556 2488 2548
3 2550 2438 2547
3 2528 2438 2550
3 2550 2547 2558
3 2479 2522 2528
3 2522 2438 2528
3 2522 2485 2438
3 2438 2485 2486
3 2485 2484 2486
3 2485 2435 2484
3 2435 2538 2484
3 2435 2527 2538
3 2526 2527 2435
3 2526 2520 2527
3 2472 2520 2526
3 2472 2519 2520
3 2465 2519 2472
3 2465 2443 2519
3 2441 2456 2443
3 2442 2441 2443
3 2443 2514 2519
3 2456 2514 2443
3 2454 2441 2442
3 2454 2440 2441
3 3120 2949 2440
3 3119 2949 3120
3 2953 3119 3120
3 2441 2440 2456
3 2440 747 2456
3 2440 2462 747
3 2440 225 2462
3 2949 225 2440
3 2953 2951 3119
3 3123 2951 2953
3 2954 3123 2953
3 2954 2953 2955
3 5360 3726 3846
3 5520 5519 2164
3 5520 5522 5519
3 5522 5521 5519
3 5524 5521 5522
3 5526 5524 5522
3 5526 5491 5524
3 5500 5491 5526
3 5513 5500 5526
3 5547 5500 5513
3 5515 5547 5513
3 5555 5556 5515
3 5499 5547 5515
3 5556 5499 5515
3 3726 3727 3846
3 3727 5240 3846
3 3727 742 5240
3 742 5238 5240
3 5238 4632 5249
3 5238 5239 4632
3 5238 5249 5240
3 5239 4631 4632
3 5239 4630 4631
3 4618 110 4630
3 4630 3873 4631
3 4630 110 3873
3 4618 5245 110
3 5235 5245 4618
3 152 5235 4618
3 4617 5235 152
3 4617 4629 5235
3 5494 5234 4616
3 4616 5234 4628
3 4615 5234 5494
3 4628 5242 5244
3 5234 5242 4628
3 4629 4628 5244
3 4629 5244 5235
3 4615 3856 5234
3 4615 3812 3856
3 4615 1018 3812
3 1018 2163 3812
3 2164 2163 1018
3 3494 2164 1018
3 2166 2164 3494
3 2164 4206 2163
3 5519 4206 2164
3 5332 5329 5454
3 5332 5318 5329
3 5332 5307 5318
3 5307 3642 5318
3 5307 3592 3642
3 112 3592 5307
3 3640 112 5307
3 3640 113 112
3 111 113 3640
3 120 3849 4624
3 3849 4623 4624
3 3849 5247 4623
3 3845 5247 3849
3 3845 3851 5247
3 3851 4621 5247
3 3851 4620 4621
3 3846 4620 3851
3 3846 3725 4620
3 5240 3725 3846
3 3854 113 86
3 3854 86 1306
3 1306 86 84
3 86 3815 84
3 86 1316 3815
3 157 1316 86
3 113 3854 112
3 157 4626 3813
3 157 5248 4626
3 157 3813 1316
3 5248 3885 4626
3 5248 4625 3885
3 4624 4625 5248
3 4623 3850 4624
3 4624 3850 4625
3 5022 5057 5056
3 5023 5022 5056
3 5023 5056 5031
3 4968 5023 5031
3 4989 4968 5031
3 4988 4968 4989
3 4967 4988 4989
3 4916 4967 4989
3 4908 4967 4916
3 4908 4916 4901
3 4966 4908 4901
3 4966 4901 4929
3 4929 4901 4920
3 4929 4920 4931
3 4918 4931 4932
3 4933 4929 4931
3 4930 4933 4931
3 4930 4931 4918
3 4915 4930 4918
3 4915 4918 4927
3 4956 4915 4927
3 4956 4927 4928
3 4928 4927 4961
3 4958 4961 4951
3 4958 4928 4961
3 4980 4958 4951
3 4979 4980 4951
3 4957 4980 4979
3 4895 4957 4979
3 4895 4979 2190
3 4881 4895 2190
3 3833 3970 3796
3 3833 3796 3797
3 3798 3795 3797
3 3794 3833 3797
3 3795 3794 3797
3 3769 3798 3768
3 3769 3768 3800
3 3794 3795 3798
3 3794 3798 3769
3 3785 3786 3790
3 3785 3790 3779
3 3789 3779 3791
3 3791 3779 3787
3 2111 3785 3779
3 5227 2111 3779
3 5227 3779 3789
3 3834 3787 3837
3 3791 3787 3792
3 3792 3787 3834
3 3834 3837 3970
3 3792 3834 3970
3 3835 3792 3970
3 3835 3970 3833
3 2317 2326 2325
3 2325 2326 3786
3 2326 2315 2209
3 3781 2325 3786
3 3781 3786 3785
3 4896 4897 4898
3 4896 4900 4897
3 687 4900 4896
3 5088 687 4896
3 5087 5088 4896
3 688 4895 4881
3 688 4950 4895
3 4897 4950 688
3 4898 4897 688
3 5088 671 687
3 670 671 5088
3 676 670 5088
3 690 676 5088
3 690 5088 4879
3 690 4879 686
3 656 657 686
3 656 686 2215
3 657 690 686
3 4882 2215 2237
3 4877 656 2215
3 4882 4877 2215
3 4878 4882 2237
3 4878 2237 2238
3 4883 4878 2238
3 2234 4883 2238
3 2234 2238 2235
3 2232 2234 2235
3 2232 2235 2231
3 2218 2232 2231
3 2218 2231 2230
3 2230 2231 2233
3 2226 2230 2233
3 2226 2233 2224
3 2203 2224 2239
3 2272 2203 2239
3 2272 2239 2273
3 2219 2226 2224
3 2221 2219 2224
3 2223 2221 2224
3 2203 2223 2224
3 2294 2310 2296
3 4134 2294 2296
3 4134 2296 2318
3 4134 2318 2328
3 2328 2318 2332
3 2340 2328 2332
3 2340 2332 2339
3 2332 2335 2339
3 2285 2283 2273
3 658 2272 2273
3 2283 658 2273
3 2271 2283 2285
3 2284 2271 2285
3 2284 2285 2310
3 2284 2310 2294
3 2340 2339 3775
3 3775 2339 2341
3 2341 2339 2321
3 3986 3775 263
3 263 3775 2137
3 3775 2314 2137
3 3986 2340 3775
3 2137 2314 2312
3 2137 2312 2316
3 2316 2312 2317
3 2316 2317 2325
3 2315 2313 2194
3 5715 5731 5727
3 5737 5715 5727
3 5750 5749 5737
3 5750 5737 5736
3 5749 5715 5737
3 5732 5750 5736
3 5732 5736 5733
3 5733 5736 3689
3 5786 3769 3800
3 5786 3800 5788
3 3697 5786 5788
3 3697 5788 3771
3 5788 3770 3771
3 3771 3770 5717
3 3770 3523 5717
3 5717 3523 3699
3 3771 5717 5719
3 5719 5717 5749
3 5719 5749 5750
3 3685 3524 3525
3 5741 5744 3525
3 3686 5741 3525
3 5744 3685 3525
3 5732 5733 5726
3 5725 5726 3687
3 5740 5732 5726
3 5751 5740 5726
3 5751 5726 5725
3 5752 5725 3687
3 5762 5758 5752
3 5762 5752 5745
3 5745 5752 5741
3 5752 5744 5741
3 5744 5752 3685
3 5758 5725 5752
3 3544 3545 3589
3 3544 3589 3542
3 3653 3688 3545
3 3544 3653 3545
3 3688 3686 3545
3 3688 5741 3686
3 3653 3544 3542
3 3510 3653 3542
3 3508 3510 3542
3 3508 3542 3654
3 3656 3508 3654
3 3508 3656 3541
3 3541 3656 3540
3 3510 3508 3541
3 3651 3510 3541
3 3622 3623 3583
3 3584 3622 3583
3 3619 3622 3584
3 3629 3619 3584
3 102 3629 3584
3 3620 3629 102
3 101 3620 102
3 1310 101 102
3 3580 3648 3651
3 3648 3510 3651
3 3581 3648 3580
3 3624 3581 3580
3 3649 3581 3624
3 3650 3649 3624
3 3630 3650 3624
3 3630 3624 3623
3 3618 3630 3623
3 3622 3618 3623
3 1305 1310 1312
3 1304 101 1310
3 1309 3570 1304
3 1311 1309 1304
3 1304 3560 101
3 3570 3560 1304
3 3552 1309 1311
3 3595 3552 1311
3 3601 3595 3602
3 3595 3593 3552
3 3601 3593 3595
3 5306 3601 3602
3 5447 5306 3602
3 5432 5306 5447
3 5452 5432 5447
3 5434 5432 5452
3 5434 1126 5432
3 5329 1126 5434
3 5329 5318 1126
3 3018 3002 3123
3 3123 3002 2951
3 3018 3025 3002
3 3018 2789 3025
3 2789 3038 3039
3 2789 2786 3025
3 2789 3039 2786
3 3038 2801 3039
3 2801 3040 2802
3 3060 3040 2801
3 2801 3026 3039
3 2801 2802 3026
3 3060 3065 3040
3 3065 3066 3040
3 3066 2777 2776
3 3066 3044 2777
3 3040 3066 2776
3 2777 3044 3067
3 3044 3055 3067
3 3044 3056 3055
3 3056 2773 3055
3 3056 3062 2773
3 2773 3043 3055
3 2773 2767 3043
3 2767 2766 3043
3 2767 2772 2766
3 3051 2772 2767
3 2772 3051 47
3 3051 3033 47
3 3051 3009 3033
3 3009 3006 3033
3 3009 2989 3006
3 2989 2760 3006
3 3006 2760 3005
3 3005 2760 2998
3 3005 2998 2764
3 2764 2998 2761
3 2998 26 2761
3 2998 44 26
3 2998 42 44
3 44 42 19
3 42 2983 19
3 2983 6 19
3 2983 13 6
3 19 6 2758
3 2758 6 9
3 9 6 10
3 6 2733 10
3 2733 18 2732
3 18 2733 2738
3 2733 2732 10
3 2708 18 2738
3 2708 2726 18
3 2726 2708 2714
3 2708 2704 2714
3 2714 2704 2711
3 2704 5 2711
3 5 1320 2711
3 5 2692 1320
3 2692 2628 1320
3 2692 2682 2628
3 2682 2626 2628
3 2626 2638 2628
3 2628 2638 2646
3 2638 2658 2646
3 2638 2640 2658
3 2638 2634 2640
3 2634 2666 2640
3 2666 2624 2640
3 2666 2608 2624
3 2624 2608 2659
3 2667 2632 2659
3 2667 2618 2632
3 2617 2659 2661
3 2659 2660 2661
3 2659 2632 2660
3 2624 2659 2629
3 2629 2659 2617
3 2632 2618 2621
3 2618 2864 2621
3 2864 2866 2865
3 2864 2609 2866
3 2864 2865 2621
3 2609 3431 3430
3 2609 3421 3431
3 2609 3420 3421
3 2866 2609 3430
3 3420 3422 3421
3 3422 3432 3438
3 3422 3449 3421
3 3422 3438 3449
3 3449 3436 3421
3 3449 3444 3436
3 3449 3452 3444
3 3452 3465 3444
3 3452 3455 3465
3 3455 3462 3465
3 3465 3462 3471
3 3462 3472 3471
3 3471 3472 2924
3 3472 3479 2924
3 3472 3393 3479
3 3393 3396 3398
3 3479 3393 3398
3 3398 3396 2874
3 3396 3410 2874
3 3396 3411 3410
3 3410 3411 3407
3 3158 3163 3184
3 3410 3407 3415
3 3407 3406 3415
3 3409 3406 5596
3 3406 2875 5596
3 3415 3406 3409
3 2875 3142 5596
3 2875 2876 3142
3 3134 2876 2875
3 3134 3132 2876
3 3132 3146 2876
3 3146 3158 3153
3 2876 3146 5595
3 3146 3138 5595
3 3146 3153 3138
3 3158 3184 3153
3 3153 3184 3144
3 3144 3184 3183
3 3215 3217 3221
3 3217 3239 3221
3 3204 3217 3215
3 3183 3204 3223
3 3144 3183 3145
3 3183 3172 3145
3 3172 3183 3223
3 3204 3215 3223
3 3239 3266 3221
3 3221 3266 3250
3 3250 3266 3249
3 3266 3253 3249
3 3253 3254 3255
3 3253 3255 3249
3 3254 3260 3263
3 3255 3254 3263
3 3263 3259 3258
3 3258 3259 2357
3 3255 3263 3256
3 3256 3263 3245
3 3263 3258 3245
3 3245 2357 2885
3 2357 3275 2885
3 3258 2357 3245
3 3275 3282 2973
3 2885 3275 2895
3 3275 2973 2895
3 3282 2892 2973
3 2973 2892 2904
3 2892 2887 2904
3 3283 2973 2904
3 3283 2904 2888
3 2904 3285 2888
3 2888 3285 3292
3 3285 3291 3292
3 3291 2943 3292
3 3308 3327 3337
3 3337 3326 3350
3 3326 3337 3353
3 3337 3340 3353
3 3308 3337 3315
3 3315 3337 3350
3 3353 3340 3329
3 3353 3329 3357
3 3292 2943 2944
3 2944 2943 3308
3 2944 3308 2940
3 3308 3315 2940
3 3353 3357 3365
3 3365 3357 3356
3 3365 3356 3355
3 3355 3356 2355
3 3356 3375 2355
3 2355 3375 2354
3 2355 2354 4250
3 4250 2354 4254
3 2354 4241 4254
3 2354 2348 4241
3 2371 2348 2378
3 2348 2351 2378
3 2348 2352 2351
3 4241 2348 2371
3 2378 2351 4285
3 2351 4813 4285
3 4813 4797 4798
3 4285 4813 4701
3 4701 4813 4798
3 4797 2373 4798
3 4798 2373 4795
3 4795 2373 4853
3 2373 2381 4853
3 2381 2385 4853
3 2385 2381 2386
3 4861 2386 4852
3 2385 2386 4854
3 4854 2386 4861
3 4781 4776 4810
3 4810 4776 4789
3 4742 4789 4773
3 4810 4789 4281
3 4281 4789 4742
3 6106 4781 4810
3 4287 4781 6106
3 4742 4773 4815
3 4773 4848 4815
3 4815 4848 4847
3 4805 4815 4847
3 4805 4847 4804
3 4778 2390 4851
3 4278 4778 4851
3 4278 4851 4806
3 4806 4851 4860
3 2390 4852 4851
3 4860 4866 4850
3 4850 4866 4807
3 4806 4860 4850
3 4850 4807 4808
3 4808 4807 4790
3 4807 4783 4790
3 2364 4808 4790
3 2364 4790 4287
3 2364 4287 4269
3 4269 4287 6106
3 4861 4852 2390
3 4788 4805 4804
3 4788 4804 4803
3 4841 4803 4829
3 4829 4803 4796
3 4803 4763 4796
3 4841 4788 4803
3 4763 4749 4796
3 4749 4771 4796
3 4839 4817 4816
3 4816 4817 4809
3 4839 4821 4817
3 4842 4821 4838
3 4838 4821 4839
3 4842 4796 4821
3 4829 4796 4842
3 4816 4809 4840
3 4839 4816 4840
3 4839 4840 4820
3 4820 4840 4833
3 4820 4833 4764
3 4833 4835 4764
3 4764 4835 4822
3 4822 4835 4819
3 4835 4786 4819
3 5075 5067 5081
3 5075 5081 5063
3 4824 5067 5075
3 4824 4752 5067
3 4764 4822 4752
3 4764 4752 4824
3 5090 5091 5076
3 5090 5076 5034
3 5034 5076 5057
3 5022 5034 5057
3 5055 5075 5063
3 5055 5063 5029
3 5029 5063 5090
3 5090 5063 5091
3 5561 5556 5555
3 5561 5575 5556
3 2555 2477 2450
3 2555 2540 2477
3 2560 2540 2555
3 2558 2540 2560
3 2548 2558 2560
3 5573 5565 5575
3 5575 5565 5556
3 5573 5570 5565
3 5570 5576 5565
3 5570 5569 5576
3 5570 5559 5569
3 2156 5559 5570
3 5559 2156 5569
3 2156 5558 5569
3 2156 3493 5558
3 2156 2585 3493
3 2156 2159 2585
3 2159 2590 2417
3 2159 2155 2585
3 2159 2417 2155
3 2590 2582 2417
3 2582 2598 2419
3 2582 2589 2598
3 2417 2582 2154
3 2154 2582 2593
3 2593 2582 2419
3 2589 2573 2580
3 2420 2573 2589
3 2589 2580 2598
3 2420 2572 2573
3 2489 2572 2420
3 2415 2489 2420
3 2489 2570 2572
3 2452 2570 2489
3 2452 2411 2570
3 2450 2411 2452
3 2450 2477 2411
3 2558 2547 2540
3 2547 2554 2540
3 2438 2554 2547
3 2438 2486 2554
3 2486 2484 2554
3 2484 2539 2554
3 2484 2537 2539
3 2538 2537 2484
3 2538 2447 2537
3 2538 4192 2447
3 2527 4192 2538
3 2527 2425 4192
3 2520 2425 2527
3 2520 4308 4336
3 2525 4308 2520
3 2519 2525 2520
3 2520 4336 2425
3 2518 2525 2519
3 2514 2518 2519
3 2456 747 2514
3 2514 2471 2518
3 2514 747 2471
3 3119 2512 2949
3 2949 2512 225
3 3119 2950 2512
3 2951 2950 3119
3 747 2461 2471
3 747 2462 2461
3 2462 226 2461
3 225 226 2462
3 2512 2977 225
3 225 2460 226
3 225 2793 2460
3 2977 2793 225
3 2951 2947 2950
3 3002 2947 2951
3 5519 5521 4206
3 5521 5125 4206
3 5521 3496 5125
3 5491 3496 5521
3 5524 5491 5521
3 5491 5525 3496
3 5546 5525 5491
3 5500 5546 5491
3 5547 5546 5500
3 5501 5546 5547
3 5499 5501 5547
3 5556 5568 5499
3 5565 5568 5556
3 5499 5568 5501
3 5240 5249 3728
3 5240 3728 3725
3 5249 4632 5246
3 3728 5249 994
3 5249 5246 994
3 4632 4631 5246
3 4631 3874 5246
3 4631 4619 3874
3 4631 3873 4619
3 110 993 3873
3 110 3890 993
3 110 3733 3890
3 3729 3733 110
3 5244 3729 110
3 5245 5244 110
3 3873 3866 4619
3 3873 993 3866
3 5235 5244 5245
3 5234 5241 5242
3 5234 3856 5241
3 5243 3729 5244
3 5242 5243 5244
3 5242 5241 5243
3 3856 997 5241
3 3856 977 997
3 581 977 3856
3 3812 581 3856
3 2163 581 3812
3 2163 580 581
3 2163 743 580
3 5153 743 2163
3 4206 5153 2163
3 4206 915 5153
3 5125 915 4206
3 5318 5305 1126
3 5318 3642 5305
3 3642 3603 3641
3 3592 3603 3642
3 5305 3642 3641
3 3592 85 3603
3 3592 1307 85
3 1302 1307 3592
3 112 1302 3592
3 112 3854 1302
3 4622 3850 4623
3 5247 4622 4623
3 4621 4622 5247
3 4621 3880 4622
3 995 3880 4621
3 3848 995 4621
3 4620 3848 4621
3 4620 1015 3848
3 994 1015 4620
3 3725 994 4620
3 3728 994 3725
3 3854 1306 1302
3 1302 1306 1307
3 1306 84 1307
3 1307 84 85
3 85 84 3591
3 84 83 3591
3 84 70 83
3 84 3597 70
3 3815 3597 84
3 3815 3888 3558
3 1316 3888 3815
3 3815 3558 3597
3 3813 3888 1316
3 3813 3814 3888
3 4627 3814 3813
3 4626 4627 3813
3 4626 3885 4627
3 4627 3885 3814
3 3885 3886 3814
3 3885 3852 3886
3 4625 3852 3885
3 4625 3850 3852
3 3850 3879 3852
3 3850 3883 3879
3 3850 3881 3883
3 3880 3881 3850
3 4622 3880 3850
3 5090 5034 5022
3 5030 5090 5022
3 4988 5030 5022
3 4988 5022 5023
3 4988 5023 4968
3 4940 5030 4988
3 4940 4988 4967
3 4942 4940 4967
3 4908 4942 4967
3 4976 4942 4908
3 4943 4976 4908
3 4943 4908 4966
3 4914 4943 4966
3 4914 4966 4929
3 4933 4914 4929
3 4700 4914 4933
3 4700 4933 4930
3 4915 4700 4930
3 4700 4915 4956
3 4980 4956 4928
3 4673 4700 4956
3 4962 4673 4956
3 4949 4962 4956
3 4949 4956 4950
3 4950 4956 4957
3 4957 4956 4980
3 4980 4928 4958
3 4950 4957 4895
3 3835 3833 3793
3 3793 3833 3794
3 2114 3793 3794
3 2114 3794 141
3 141 3794 3769
3 141 3769 5786
3 3973 3781 3785
3 2111 3973 3785
3 5224 3791 3830
3 3830 3791 3792
3 5224 3789 3791
3 6088 3789 5224
3 5229 5227 3789
3 5229 3789 6088
3 5172 3973 2111
3 5172 2111 5227
3 3972 5172 5227
3 5230 3972 5227
3 5230 5227 5229
3 3830 3792 3835
3 145 3830 3835
3 145 3835 3793
3 5169 2316 2325
3 5169 2325 3979
3 3979 2325 3781
3 3979 3781 3973
3 4900 4903 4897
3 4903 4950 4897
3 4902 4903 4900
3 687 4902 4900
3 671 4902 687
3 666 4949 4950
3 4903 666 4950
3 671 677 4902
3 678 677 671
3 674 678 671
3 674 671 670
3 673 674 670
3 675 673 670
3 676 675 670
3 676 669 675
3 2095 669 676
3 665 2095 676
3 665 676 690
3 665 690 657
3 665 657 4884
3 4884 657 4877
3 657 656 4877
3 4883 4882 4878
3 4890 4877 4882
3 4890 4882 4883
3 4885 4884 4877
3 4885 4877 4890
3 2244 4890 4883
3 2244 4883 2245
3 2245 4883 2217
3 2217 4883 2218
3 4883 2234 2218
3 2234 2232 2218
3 2217 2218 2230
3 2246 2217 2230
3 2246 2230 2219
3 2219 2230 2226
3 2253 2223 2203
3 2255 2253 2203
3 2255 2203 2272
3 658 2255 2272
3 2246 2219 2221
3 2222 2246 2221
3 2222 2221 2220
3 2220 2221 2223
3 2253 2220 2223
3 4063 2284 2294
3 4076 4063 2294
3 4076 2294 4134
3 3994 4135 4134
3 2333 3994 4134
3 2333 4134 3774
3 3774 4134 2328
3 4135 4076 4134
3 2340 3774 2328
3 3987 3774 2340
3 3987 2340 3986
3 2271 658 2283
3 2269 2255 658
3 2271 2269 658
3 2293 2271 2284
3 2293 2269 2271
3 4063 2293 2284
3 3985 3986 263
3 3985 263 5168
3 5168 263 2137
3 4089 3987 3986
3 4089 3986 3985
3 5168 2137 5169
3 5169 2137 2316
3 5716 5719 5750
3 3632 5716 5750
3 3632 5750 5732
3 3632 5732 5740
3 5789 5786 3697
3 3527 141 5786
3 3766 3527 5786
3 3765 3766 5786
3 5789 3765 5786
3 5789 3697 3957
3 3957 3697 3825
3 3825 3697 3968
3 3968 3697 3771
3 3968 3771 5719
3 3969 3968 5719
3 3969 5719 5720
3 5720 5719 5716
3 4637 5745 5741
3 4637 5741 3691
3 3691 5741 3688
3 5758 5751 5725
3 5755 5740 5751
3 5755 3632 5740
3 5743 5751 5758
3 5743 5755 5751
3 5756 5743 5758
3 5756 5758 5762
3 5753 5756 5762
3 5753 5762 5745
3 5753 5745 5746
3 5746 5745 5747
3 5747 5745 5742
3 5745 4637 5742
3 5742 3688 5748
3 5748 3688 3653
3 5742 3691 3688
3 5748 3653 3648
3 3648 3653 3510
3 3619 3618 3622
3 3617 3618 3619
3 3620 3617 3619
3 3629 3620 3619
3 3621 3617 3620
3 3587 3621 3620
3 101 3587 3620
3 3569 3587 101
3 3560 3569 101
3 3649 5748 3648
3 3581 3649 3648
3 3649 5742 5748
3 5747 5742 3649
3 3626 5747 3649
3 5760 3626 3649
3 5760 3649 3650
3 3630 5760 3650
3 3638 5760 3630
3 3617 3638 3630
3 3617 3630 3618
3 3570 3568 3560
3 3570 1293 3568
3 82 1293 3570
3 1309 82 3570
3 1308 82 1309
3 3593 1308 1309
3 3593 1309 3552
3 3568 3569 3560
3 3604 3601 5306
3 3604 3593 3601
3 3604 3591 3593
3 3593 3591 1308
3 3641 3604 5306
3 3641 5306 5432
3 1126 3641 5432
3 5305 3641 1126
3 3002 2787 2947
3 3002 3000 2787
3 3025 3000 3002
3 3025 2786 3000
3 2786 3039 3019
3 3039 3026 3019
3 2786 3019 3502
3 2786 3502 3000
3 3026 2802 2788
3 2802 3027 2788
3 2802 2846 3027
3 2776 2846 2802
3 3040 2776 2802
3 3026 3020 3019
3 3020 3026 2980
3 3026 3021 2980
3 3026 2788 3021
3 2776 2777 2846
3 2777 3067 2846
3 2846 3067 3048
3 3067 2845 3048
3 3067 3055 2845
3 3055 3043 3050
3 2845 3055 3049
3 3055 3050 3049
3 3043 2766 3050
3 2766 2782 3050
3 2766 3042 2782
3 2766 2772 3042
3 2772 47 3042
3 47 3008 3042
3 47 3033 3008
3 3033 3007 3008
3 3033 3006 3007
3 3006 3005 3007
3 3007 3005 2764
3 3008 3007 2764
3 3008 2764 2770
3 2770 2764 2985
3 2764 2761 2985
3 2985 2761 45
3 2761 46 45
3 2761 26 46
3 26 2768 46
3 26 44 2768
3 2768 44 21
3 44 41 21
3 44 19 41
3 41 19 2997
3 19 25 2997
3 19 2758 25
3 25 2758 2759
3 2759 2758 9
3 40 9 32
3 9 10 32
3 2759 9 40
3 2732 2725 10
3 32 10 2
3 10 2744 2
3 10 2725 2744
3 2732 2720 2725
3 2726 2720 2732
3 18 2726 2732
3 2726 2714 2720
3 2720 2714 7
3 2714 4 7
3 2714 2711 4
3 4 2711 2712
3 2712 2711 5623
3 2711 1320 5623
3 1320 3504 5623
3 1320 2693 3504
3 1320 2628 2693
3 2628 2646 2693
3 2646 2658 2693
3 2693 2658 3504
3 3504 2658 2654
3 2658 2631 2654
3 2658 2629 2631
3 2624 2629 2658
3 2640 2624 2658
3 2660 2632 2621
3 2617 2661 2630
3 2630 2661 2607
3 2661 2660 2607
3 2629 2617 2631
3 2631 2617 2630
3 2660 2622 2607
3 2660 2621 2622
3 2621 2865 2622
3 2865 3418 2622
3 2865 2866 3418
3 2866 3430 3418
3 3418 3430 2604
3 3430 2868 2604
3 3430 3431 2868
3 3431 4211 4212
3 3436 4211 3431
3 3421 3436 3431
3 2868 3431 4207
3 3431 4212 4207
3 3436 3444 3448
3 3436 3448 4211
3 3444 3465 3460
3 3444 3460 3448
3 3465 3471 3461
3 3460 3465 3461
3 3471 2924 3461
3 3461 2924 57
3 2924 3398 57
3 2924 3479 3398
3 57 3398 2874
3 57 2874 2911
3 2911 2874 2923
3 2874 3397 2923
3 2874 3410 3397
3 3397 3410 3415
3 3415 3409 2910
3 3397 3415 5598
3 3415 2910 5598
3 5596 3136 3488
3 3142 3136 5596
3 3409 5596 5597
3 5597 5596 3488
3 2910 3409 1118
3 1118 3409 5597
3 3142 3137 3136
3 2876 3137 3142
3 2876 3139 3137
3 2876 5595 3139
3 3138 3153 3144
3 3139 5595 3156
3 5595 3138 3156
3 3138 3144 3156
3 3156 3144 3145
3 3215 3221 3211
3 3211 3221 3220
3 3221 3250 3220
3 3223 3215 3211
3 3172 3223 2377
3 3223 3189 2377
3 3189 3223 3211
3 3156 3145 3136
3 3136 3145 3143
3 3143 3145 3167
3 3145 3157 3167
3 3145 3172 3157
3 3157 3172 3167
3 3167 3172 2377
3 3250 3249 3238
3 3220 3250 3238
3 3238 3249 3257
3 3249 3256 3257
3 3249 3255 3256
3 3256 3245 3265
3 3257 3256 3233
3 3233 3256 3265
3 3245 2885 3265
3 3265 2885 2906
3 2885 2895 2906
3 2895 2973 3283
3 2906 2895 2893
3 2895 3283 2893
3 2893 3283 2888
3 2894 2893 2888
3 2894 2888 2909
3 2909 2888 3292
3 2909 3292 3298
3 3298 3292 2944
3 2945 3350 3354
3 3350 3365 3354
3 3326 3365 3350
3 3323 3315 3350
3 3323 3350 2945
3 3326 3353 3365
3 2940 3315 3323
3 3299 3298 2944
3 3299 2944 3302
3 3302 2944 2940
3 3302 2940 2939
3 2939 2940 3316
3 3316 2940 3323
3 3354 3365 3370
3 3365 3355 3370
3 3370 3355 2355
3 3370 2355 4249
3 4249 2355 4250
3 4234 4250 4239
3 4250 4254 4239
3 4252 4249 4250
3 4252 4250 4234
3 4254 4236 2380
3 4254 4241 4236
3 4239 4254 2349
3 2349 4254 4255
3 4254 4284 4255
3 4254 2380 4284
3 4241 2371 4236
3 2379 2378 4285
3 2371 2378 4236
3 2378 2379 4236
3 2379 4285 4701
3 4701 4798 4256
3 4256 4798 4795
3 4236 2379 4701
3 4236 4701 2380
3 4701 4256 2380
3 4256 4795 2372
3 2372 4795 4784
3 4795 4853 4784
3 4853 4854 4784
3 4853 2385 4854
3 4854 4861 2384
3 2384 4861 2390
3 4784 4854 2384
3 61 4810 4281
3 6106 4810 61
3 4281 4742 4828
3 4828 4742 4815
3 61 4281 4828
3 4269 6106 61
3 4841 4815 4788
3 4815 4805 4788
3 4828 4815 4841
3 2384 2390 4778
3 4794 2384 4778
3 4794 4778 4793
3 4793 4778 4278
3 4793 4278 4792
3 4792 4278 4806
3 4792 4806 4270
3 4270 4806 4791
3 4806 4850 4791
3 4791 4850 4808
3 4286 4791 4808
3 4286 4808 2364
3 4259 4286 2364
3 4259 2364 4292
3 4292 2364 4269
3 4292 4269 4006
3 4006 4269 4007
3 4269 61 4007
3 4845 4841 4829
3 4845 4829 4843
3 4843 4829 4834
3 4829 4842 4834
3 4844 4841 4845
3 4828 4841 4844
3 4832 4838 4839
3 4832 4839 4820
3 4834 4842 4838
3 4834 4838 4832
3 4801 4832 4820
3 4762 4801 4820
3 4762 4820 4764
3 4734 4762 4764
3 4734 4764 4824
3 5055 4824 5075
3 4734 4824 5033
3 5033 4824 5055
3 5030 5029 5090
3 5033 5055 5026
3 5026 5055 5029
3 5026 5029 5019
3 5019 5029 5030
3 2477 2567 2586
3 2477 2563 2567
3 2477 2562 2563
3 2487 2562 2477
3 2540 2487 2477
3 2411 2477 2569
3 2569 2477 2418
3 2418 2477 2586
3 2554 2487 2540
3 5565 5576 5568
3 5569 5567 5576
3 5576 5566 5568
3 5576 5567 5566
3 5569 5558 5567
3 5558 3500 5566
3 3493 3500 5558
3 5567 5558 5566
3 3500 3493 5497
3 5497 3493 5523
3 3493 2574 5523
3 3493 3499 2574
3 3493 2575 3499
3 3493 2585 2575
3 2585 2154 2575
3 2155 2154 2585
3 2155 2417 2154
3 2593 2419 2599
3 2419 2598 2599
3 2598 2592 2602
3 2598 2580 2592
3 2598 2602 2599
3 2154 2153 2575
3 2154 2593 2153
3 2153 2593 2152
3 2152 2593 2581
3 2593 2599 2581
3 2580 2597 2592
3 2580 2587 2597
3 2586 2587 2580
3 2573 2586 2580
3 2418 2586 2573
3 2572 2418 2573
3 2572 2570 2418
3 2570 2411 2418
3 2411 2569 2418
3 2554 2546 2545
3 2554 2539 2546
3 2487 2554 2545
3 2539 2537 2546
3 2537 2552 2546
3 2537 2447 2552
3 2447 2543 2552
3 2447 2536 2543
3 4192 2536 2447
3 4192 2467 2559
3 4336 2467 4192
3 2425 4336 4192
3 4192 2559 2536
3 4336 4319 2467
3 4336 4308 4319
3 4308 2532 4318
3 2525 2532 4308
3 4308 4318 4319
3 2525 2466 2532
3 2518 2466 2525
3 2518 2471 2466
3 2461 224 2471
3 2471 2463 2466
3 2471 224 2463
3 2950 2947 2512
3 2512 2810 2977
3 2808 2810 2512
3 2978 2808 2512
3 2947 2978 2512
3 2461 517 224
3 2460 517 2461
3 226 2460 2461
3 2977 2807 2793
3 2810 2807 2977
3 2460 2830 517
3 2460 2825 2830
3 2976 2825 2460
3 2793 2976 2460
3 2809 2976 2793
3 2807 2809 2793
3 2947 2787 2978
3 2178 915 5125
3 2180 2178 5125
3 3496 2180 5125
3 2179 2180 3496
3 2177 2179 3496
3 5525 2177 3496
3 5546 2177 5525
3 5546 5523 2177
3 5498 5523 5546
3 5501 5498 5546
3 5566 5498 5501
3 5568 5566 5501
3 994 5246 1015
3 1015 5246 3847
3 3847 5246 115
3 5246 3874 115
3 3874 4619 3872
3 115 3874 4610
3 3874 3872 4610
3 4619 3866 3872
3 993 4607 3866
3 993 3890 4607
3 3890 4606 4607
3 3890 3859 4606
3 3733 3859 3890
3 3733 3860 3859
3 4605 3860 3733
3 3857 4605 3733
3 3729 3857 3733
3 5243 5241 3729
3 5241 3857 3729
3 3866 3870 4609
3 3866 4608 3870
3 3866 4607 4608
3 3866 4609 3872
3 5241 3855 3857
3 997 3855 5241
3 997 977 3855
3 977 973 3855
3 977 741 973
3 943 741 977
3 581 943 977
3 580 943 581
3 944 939 580
3 743 944 580
3 580 939 943
3 743 913 944
3 5153 913 743
3 5153 915 913
3 915 4205 913
3 2178 4205 915
3 3603 3604 3641
3 3603 85 3604
3 85 3591 3604
3 3880 5101 3881
3 3880 109 5101
3 995 109 3880
3 3848 115 995
3 3877 109 995
3 115 3877 995
3 3847 115 3848
3 1015 3847 3848
3 3591 83 1308
3 70 3506 83
3 83 3506 1308
3 70 1446 3506
3 70 3557 1446
3 3597 3557 70
3 3597 5708 1289
3 3558 5708 3597
3 3597 1289 3557
3 3558 3889 5708
3 3888 3889 3558
3 3888 3887 3920
3 3814 3887 3888
3 3888 3920 3889
3 3886 3887 3814
3 3919 5102 3886
3 3879 3919 3886
3 3852 3879 3886
3 3886 4614 3887
3 5102 4614 3886
3 3883 3919 3879
3 3881 3919 3883
3 3881 5101 4612
3 3881 4612 3919
3 4940 5019 5030
3 5016 5019 4940
3 4942 5016 4940
3 4987 5016 4942
3 4941 4987 4942
3 4941 4942 4976
3 4909 4941 4976
3 4909 4976 4964
3 4964 4976 4943
3 4964 4943 4914
3 4913 4964 4914
3 4913 4914 4700
3 4699 4913 4700
3 4673 4699 4700
3 4962 4699 4673
3 4676 4699 4962
3 4953 4676 4962
3 4953 4962 4955
3 4962 4949 4955
3 4955 4949 666
3 145 3793 2114
3 124 3832 2114
3 124 2114 2115
3 2115 2114 3527
3 3527 2114 141
3 3832 145 2114
3 3982 3979 3973
3 3982 3973 5172
3 1317 5224 3830
3 1317 3830 145
3 2112 6083 5224
3 2112 5224 5226
3 5226 5224 1317
3 6083 6088 5224
3 6075 6074 6088
3 6083 6075 6088
3 6074 5229 6088
3 6074 5230 5229
3 3972 3982 5172
3 5232 3976 3972
3 5232 3972 5230
3 3976 3982 3972
3 5232 5230 6075
3 6075 5230 6074
3 5226 1317 145
3 3831 5226 145
3 3831 145 3832
3 3981 5168 5169
3 3981 5169 5170
3 5170 5169 3979
3 3980 5170 3979
3 5791 3980 3979
3 5178 5791 3979
3 5178 3979 3982
3 4903 4904 666
3 4902 4904 4903
3 677 4904 4902
3 4954 4955 666
3 4904 4954 666
3 678 680 677
3 677 680 4904
3 679 4686 678
3 679 678 674
3 4686 680 678
3 5084 679 674
3 5084 674 673
3 675 5084 673
3 669 5084 675
3 685 684 669
3 2095 685 669
3 650 5084 669
3 5086 650 669
3 684 5086 669
3 683 685 2095
3 683 2095 665
3 682 683 665
3 4872 682 665
3 4872 665 4884
3 4873 4884 4887
3 4887 4884 4885
3 652 4872 4884
3 4873 652 4884
3 659 4885 4890
3 659 4890 2244
3 4889 4885 659
3 4889 4887 4885
3 659 2244 2247
3 2247 2244 2245
3 2247 2245 2248
3 2248 2245 2217
3 2248 2217 2246
3 2216 2248 2246
3 2216 2246 2222
3 2252 2253 2255
3 2225 2220 2253
3 2252 2225 2253
3 2269 2257 2255
3 379 2252 2255
3 2257 379 2255
3 2225 2216 2222
3 2225 2222 2220
3 4133 3828 4063
3 4133 4063 4135
3 4135 4063 4076
3 3489 2293 4063
3 3828 3489 4063
3 4136 4135 3994
3 4065 4133 4135
3 4065 4135 4136
3 262 3994 2333
3 262 4136 3994
3 262 2333 4098
3 4098 2333 3774
3 3987 4098 3774
3 4097 3987 4089
3 4097 4098 3987
3 3489 2282 2269
3 2293 3489 2269
3 2270 2257 2269
3 2282 2270 2269
3 5167 3985 5168
3 5179 4089 3985
3 3829 5179 3985
3 3829 3985 5167
3 5167 5168 3981
3 5180 4089 5179
3 4097 4089 5180
3 4639 5720 5716
3 4639 5716 5718
3 5718 5716 3632
3 5718 3632 5755
3 3646 3765 5789
3 3646 5789 3957
3 5787 2115 3527
3 3766 5787 3527
3 5787 3766 3765
3 5790 5787 3765
3 3645 5790 3765
3 5798 3645 3765
3 5798 3765 5800
3 5800 3765 3646
3 3956 3957 3763
3 3763 3957 3825
3 3956 3646 3957
3 3965 3825 3969
3 3969 3825 3968
3 3763 3825 3965
3 3964 3969 5761
3 5761 3969 5720
3 3964 3965 3969
3 5761 5720 4639
3 5742 4637 3691
3 5718 5755 5743
3 5757 5743 5767
3 5767 5743 5756
3 5754 5718 5743
3 5757 5754 5743
3 5764 5767 5756
3 5764 5756 5753
3 5764 5753 5769
3 5769 5753 5763
3 5763 5753 5746
3 5763 5746 5747
3 3626 5763 5747
3 3621 4642 3617
3 4642 3638 3617
3 3611 4642 3621
3 3587 3611 3621
3 3585 3611 3587
3 3569 3585 3587
3 3586 3585 3569
3 3568 3586 3569
3 5768 5769 3626
3 3690 5768 3626
3 3616 3690 3626
3 3616 3626 3638
3 3638 3626 5760
3 5769 5763 3626
3 3639 3616 3638
3 4642 3639 3638
3 3567 3586 3568
3 3507 3567 3568
3 1293 3507 3568
3 3609 3507 1293
3 96 3609 1293
3 82 96 1293
3 3506 96 82
3 1308 3506 82
3 2787 2979 2978
3 2787 2812 2979
3 3502 2812 2787
3 3000 3502 2787
3 3502 3019 2812
3 3019 3001 2812
3 3019 3020 3001
3 2788 3027 3021
3 3027 3048 3022
3 2846 3048 3027
3 3027 3022 3021
3 3020 2980 3001
3 3001 2980 3003
3 3003 2980 520
3 2980 2981 520
3 2980 3021 2981
3 3021 2986 2981
3 3021 3022 2986
3 3048 2843 2844
3 2845 2843 3048
3 3048 2844 3022
3 2845 3049 2843
3 3049 3050 2841
3 3050 2848 2841
3 3050 2782 2848
3 2843 3049 2844
3 3049 3004 2844
3 3049 2841 3004
3 2782 3042 2848
3 3042 3008 2848
3 3008 2770 2848
3 2848 2770 2765
3 2770 49 2765
3 2770 2985 49
3 48 2985 3041
3 2985 45 3041
3 49 2985 2765
3 2765 2985 48
3 45 46 38
3 45 38 3041
3 46 37 38
3 46 36 37
3 2768 36 46
3 36 2768 21
3 36 21 43
3 21 41 43
3 41 2997 43
3 43 2997 2988
3 2997 2756 2988
3 2997 2759 2756
3 2997 25 2759
3 2756 2759 40
3 39 32 2747
3 2747 32 31
3 32 2 31
3 40 32 39
3 2756 40 2755
3 40 39 2755
3 2744 2725 2728
3 2725 2710 2728
3 2725 7 2710
3 2720 7 2725
3 31 2 476
3 2 2743 476
3 2 2744 2743
3 2744 2728 2743
3 7 4 2710
3 4 2713 2710
3 4 2712 2713
3 2712 5623 2713
3 5623 3504 1319
3 2713 5623 1319
3 3504 5159 1319
3 3504 2654 5159
3 5159 2654 2655
3 2654 2616 2655
3 2654 2631 2616
3 2631 2630 2616
3 2616 2630 1318
3 2630 2607 1318
3 2607 2620 1318
3 2607 2622 2620
3 2622 3418 2867
3 2620 2622 2641
3 2622 2867 2641
3 3418 2604 2867
3 2867 2604 2606
3 2604 4208 2606
3 2604 2868 4208
3 2868 4207 4208
3 4212 3475 4209
3 4212 3474 3475
3 4210 3474 4212
3 4211 4210 4212
3 4207 4212 4209
3 4211 3448 4210
3 4208 4207 1165
3 4207 4209 1165
3 3448 4213 4210
3 3448 3460 4213
3 3460 3447 4213
3 3460 3461 3447
3 3461 57 2911
3 3447 3461 2911
3 4214 2911 4215
3 2911 3476 4215
3 2911 2923 3476
3 3447 2911 4214
3 3476 2923 4217
3 4217 2923 4223
3 2923 3397 4223
3 3397 5598 4223
3 5598 2910 1118
3 5598 1118 4643
3 4223 5598 4643
3 3143 5593 3488
3 3136 3143 3488
3 1118 5597 3488
3 1118 3488 188
3 3488 173 188
3 3488 5593 173
3 3137 3156 3136
3 4643 1118 546
3 546 1118 188
3 3137 3139 3156
3 3189 3211 3171
3 3211 3220 3171
3 3171 3220 3210
3 3210 3220 3214
3 3220 3234 3214
3 3220 3238 3234
3 3167 2377 5593
3 5593 2377 3178
3 2377 3171 3178
3 2377 3189 3171
3 3143 3167 5593
3 3238 3257 3234
3 3234 3257 3233
3 3233 3265 3244
3 3265 2906 3244
3 3234 3233 3227
3 3227 3233 3231
3 3231 3233 3244
3 3244 2906 3237
3 3237 2906 204
3 2906 203 204
3 2906 2905 203
3 2906 2896 2905
3 2906 2894 2896
3 2906 2893 2894
3 2896 2894 2909
3 2896 2909 2356
3 2356 2909 3298
3 2356 3298 3299
3 3325 3354 4249
3 3354 3370 4249
3 2945 3354 3324
3 3324 3354 3325
3 4228 2945 3324
3 2942 3323 2945
3 2942 2945 3341
3 3341 2945 4228
3 2941 3316 3323
3 2941 3323 216
3 216 3323 2942
3 2937 3299 3302
3 2356 3299 2889
3 2889 3299 2353
3 2353 3299 2937
3 2936 3302 2939
3 2937 3302 2936
3 201 2936 2939
3 206 201 2939
3 2946 206 2939
3 207 2946 2939
3 207 2939 2941
3 2939 3316 2941
3 3325 4249 4253
3 4253 4249 4234
3 4249 4252 4234
3 4234 4239 4251
3 4251 4239 4237
3 4239 2349 4237
3 4253 4234 4232
3 4232 4234 4231
3 4231 4234 4240
3 4234 4251 4240
3 2380 2372 4282
3 2380 4256 2372
3 4284 2380 4282
3 4237 2349 4255
3 4255 4284 511
3 4237 4255 4238
3 4238 4255 511
3 4284 4283 511
3 4284 4282 4283
3 2372 4784 4282
3 4282 4784 4812
3 4784 4794 4812
3 4784 2384 4794
3 4837 61 4828
3 4007 61 4837
3 4005 4837 4828
3 4005 4828 4825
3 4825 4828 4844
3 4811 4794 4792
3 4794 4793 4792
3 4812 4794 4811
3 4811 4792 4279
3 4279 4792 4270
3 4270 4791 4286
3 4279 4270 4286
3 4279 4286 4259
3 4261 4279 4259
3 4261 4259 4292
3 4292 4273 4260
3 4292 4006 4273
3 4261 4292 4291
3 4291 4292 4288
3 4288 4292 4297
3 4297 4292 4260
3 4273 4006 4007
3 4295 4273 4007
3 4295 4007 4837
3 4827 4845 4831
3 4831 4845 4843
3 4827 4844 4845
3 4830 4843 4834
3 4831 4843 4830
3 4787 4830 4834
3 4787 4834 4765
3 4834 4832 4765
3 4825 4844 4827
3 4765 4832 4801
3 4761 4765 4801
3 4761 4801 4762
3 4761 4762 4698
3 4698 4762 4734
3 4698 4734 5033
3 4674 4698 5033
3 4694 4674 5033
3 4694 5033 5026
3 5016 4694 5026
3 5016 5026 5019
3 2587 2586 2414
3 2586 2412 2414
3 2567 2412 2586
3 2567 2568 2412
3 2563 2568 2567
3 2563 2410 2568
3 2475 2410 2563
3 2562 2475 2563
3 2545 2475 2562
3 2487 2545 2562
3 5566 5497 5498
3 3500 5497 5566
3 5498 5497 5523
3 5523 5496 2177
3 2574 5496 5523
3 2574 2578 5496
3 2574 2576 2578
3 3499 2576 2574
3 3499 2151 2576
3 3499 2152 2151
3 2575 2152 3499
3 2575 2153 2152
3 2581 2599 2600
3 2600 2599 2149
3 2599 2148 2149
3 2599 2584 2148
3 2599 2602 2584
3 2602 2592 2571
3 2602 2571 2584
3 2592 2413 2571
3 2592 2597 2413
3 2152 2581 2151
3 2581 2600 2151
3 2597 2583 2601
3 2414 2583 2597
3 2587 2414 2597
3 2413 2597 2579
3 2597 2601 2579
3 2545 2546 2475
3 2546 2553 2475
3 2546 2551 2553
3 2552 2551 2546
3 2552 2543 2551
3 2543 4191 2551
3 2543 2559 4191
3 2536 2559 2543
3 2559 2474 4191
3 2559 2473 2474
3 2467 2473 2559
3 2467 4298 2473
3 4319 4298 2467
3 4319 4318 4298
3 4318 2531 4298
3 2524 2531 4318
3 2532 2524 4318
3 2466 2524 2532
3 2466 2523 2524
3 2466 2463 2523
3 224 5164 4335
3 517 5164 224
3 224 4335 2463
3 2463 4335 4332
3 2463 4332 2523
3 2810 2809 2807
3 2810 2808 2809
3 2808 2979 2785
3 2978 2979 2808
3 2808 2785 2809
3 517 2830 5164
3 2830 2829 5164
3 2830 2837 2829
3 2825 2837 2830
3 2825 2826 2837
3 2811 2826 2825
3 2976 2811 2825
3 2809 2785 2976
3 2785 2811 2976
3 2180 2146 2178
3 2178 2144 4205
3 2146 2144 2178
3 2179 2146 2180
3 2179 2176 2146
3 2577 2176 2179
3 5496 2577 2179
3 5496 2179 2177
3 115 3916 3877
3 115 4610 3916
3 3872 3871 4610
3 3872 3915 3871
3 3872 4609 3915
3 3916 4610 119
3 4610 108 119
3 4610 3735 108
3 4610 3871 3735
3 4608 4607 3863
3 4607 4606 3863
3 4606 3862 3863
3 3861 3862 4606
3 3891 3861 4606
3 3859 3891 4606
3 3860 3891 3859
3 3860 4604 3891
3 4605 4604 3860
3 4605 3840 4604
3 973 3840 4605
3 3855 973 4605
3 3855 4605 3857
3 4609 3870 3915
3 4608 3863 3870
3 3870 4593 3915
3 3870 3867 4593
3 3870 3869 3867
3 3863 3869 3870
3 973 974 3840
3 949 974 973
3 948 949 973
3 741 948 973
3 741 941 948
3 740 941 741
3 943 740 741
3 940 740 943
3 939 940 943
3 945 1075 939
3 944 945 939
3 939 916 940
3 939 962 916
3 1075 962 939
3 913 945 944
3 913 914 945
3 732 914 913
3 4205 732 913
3 4205 908 732
3 2141 908 4205
3 2144 2141 4205
3 109 4611 5101
3 5101 3882 4612
3 5101 4611 3882
3 109 3737 4611
3 109 3735 3737
3 108 3735 109
3 119 108 109
3 3877 119 109
3 3916 119 3877
3 3506 1444 96
3 3506 1446 1444
3 1446 3554 1445
3 3556 3554 1446
3 4633 3556 1446
3 3557 4633 1446
3 1446 1445 1444
3 3557 1289 4633
3 1289 5708 4634
3 1289 4634 4633
3 5708 3598 4634
3 5708 5705 3598
3 5708 117 5705
3 1436 117 5708
3 3920 1436 5708
3 3889 3920 5708
3 3887 1437 3920
3 3920 1437 1436
3 3887 4614 1437
3 4614 5102 5106
3 5102 3884 5106
3 5102 1315 3884
3 4613 1315 5102
3 3919 4613 5102
3 3919 4612 4613
3 4614 5106 1437
3 4612 3899 4613
3 4612 3918 3899
3 3882 3918 4612
3 4680 4694 5016
3 4684 4680 5016
3 4987 4684 5016
3 4912 4684 4987
3 4912 4987 4941
3 4911 4912 4941
3 4911 4941 4909
3 4911 4909 4681
3 4681 4909 4913
3 4909 4964 4913
3 4699 4965 4913
3 4965 4681 4913
3 4963 4965 4699
3 4676 4963 4699
3 4975 4676 4953
3 4687 4963 4676
3 4975 4687 4676
3 4904 4953 4954
3 4954 4953 4955
3 4975 4953 4904
3 144 3831 3832
3 144 3832 122
3 122 3832 124
3 123 122 124
3 123 124 2120
3 124 2115 2120
3 2120 2115 5787
3 5791 5178 3982
3 3976 5791 3982
3 6076 6075 6083
3 6091 6076 6083
3 6091 6083 2112
3 6090 6091 2112
3 6090 2112 2113
3 2113 2112 5226
3 2113 5226 3831
3 5174 5232 6075
3 5228 5174 6075
3 6076 5228 6075
3 5231 5791 3976
3 5231 3976 5232
3 5225 5231 5232
3 5173 5225 5232
3 5174 5173 5232
3 6082 2113 3831
3 6082 3831 135
3 135 3831 143
3 143 3831 144
3 3776 5167 3981
3 3776 3981 5171
3 5171 3981 5170
3 5171 5170 3980
3 3974 3980 5791
3 5171 3980 3974
3 5231 3974 5791
3 4905 4975 4904
3 680 4905 4904
3 680 4679 4905
3 4906 4679 680
3 4876 4906 680
3 4876 680 4686
3 679 4875 4686
3 681 4876 4686
3 4875 681 4686
3 685 4875 679
3 685 679 684
3 684 679 5086
3 5086 679 5084
3 650 5086 5084
3 2102 685 683
3 681 4875 685
3 2102 681 685
3 5085 2102 683
3 682 5085 683
3 653 5085 682
3 2407 653 682
3 2407 682 4872
3 689 2407 4872
3 689 4872 652
3 4888 4873 4887
3 4889 4888 4887
3 689 652 4873
3 4888 689 4873
3 2249 4893 659
3 2249 659 2247
3 4893 4889 659
3 4894 4888 4889
3 4894 4889 4893
3 2250 2254 2247
3 2250 2247 2216
3 2216 2247 2248
3 2254 2249 2247
3 2250 2216 2251
3 2251 2216 2225
3 2252 2251 2225
3 2256 2251 2252
3 2256 2252 379
3 2268 379 2257
3 2268 2257 2270
3 2267 2256 379
3 2268 2267 379
3 3828 2309 3489
3 377 2309 3828
3 377 3828 4133
3 4055 4060 4133
3 4055 4133 4065
3 2291 377 4133
3 4060 2291 4133
3 3489 2309 2282
3 4065 4136 262
3 4075 4065 262
3 4064 4055 4065
3 4064 4065 4075
3 5181 262 4097
3 262 4098 4097
3 4096 4075 262
3 5182 4096 262
3 5182 262 5181
3 4185 4097 5180
3 5181 4097 4185
3 2282 2308 2270
3 2309 2308 2282
3 380 2268 2270
3 2308 380 2270
3 3829 5167 3776
3 4185 5180 5179
3 4185 5179 2121
3 5179 3829 2121
3 2121 3829 3988
3 3988 3829 3776
3 5761 4639 5754
3 5754 4639 5718
3 5800 3646 3956
3 123 2120 5787
3 2118 123 5787
3 5790 2118 5787
3 3645 2118 5790
3 137 2118 3645
3 2124 137 3645
3 5797 2124 3645
3 5797 3645 5798
3 5799 5798 5800
3 5797 5798 5799
3 3827 5799 5800
3 3827 5800 3956
3 3826 3956 3763
3 3826 3763 3700
3 3700 3763 3965
3 3955 3956 3767
3 3767 3956 3826
3 3955 3827 3956
3 3700 3965 3964
3 3964 5761 5754
3 3700 3964 4638
3 4638 3964 5754
3 5774 5767 5764
3 5774 5757 5767
3 5724 5754 5757
3 5724 5757 5774
3 5772 5754 5724
3 5772 4638 5754
3 5777 5774 5764
3 5777 5764 5759
3 5759 5764 5768
3 5768 5764 5769
3 3631 3639 4642
3 3611 3631 4642
3 3585 3631 3611
3 3585 3615 3631
3 3566 3615 3585
3 3586 3566 3585
3 3567 3566 3586
3 5776 5759 5768
3 5776 5768 3690
3 3628 5776 3690
3 3628 3690 3616
3 3639 3628 3616
3 5776 3628 3639
3 3637 5776 3639
3 5782 3637 3639
3 5782 3639 3631
3 3567 3511 3566
3 3509 3511 3567
3 3509 3567 3507
3 5704 3509 3507
3 3608 5704 3507
3 3609 3608 3507
3 1445 3608 3609
3 1444 1445 3609
3 1444 3609 96
3 2812 3003 2979
3 2979 3003 2785
3 3001 3003 2812
3 3022 2803 2986
3 3022 2844 2803
3 2785 3003 2836
3 3003 2823 2836
3 3003 520 2823
3 520 2813 2823
3 2974 2813 520
3 2981 2974 520
3 2986 2994 2981
3 2981 2994 2974
3 2986 2804 2994
3 2803 2804 2986
3 2844 3004 2803
3 2841 2842 3004
3 2841 2848 2842
3 2848 2765 2842
3 3004 2987 2803
3 3004 3028 2987
3 2842 3028 3004
3 2765 48 2771
3 2842 2765 2771
3 48 3041 2769
3 2769 3041 3023
3 3041 20 3023
3 3041 38 20
3 48 2769 2771
3 23 38 2757
3 38 43 2757
3 37 43 38
3 20 38 22
3 38 23 22
3 37 36 43
3 2757 43 2839
3 43 2988 2839
3 2839 2988 2996
3 2988 2756 2996
3 2996 2756 2755
3 2753 39 2747
3 2753 2747 2745
3 2747 31 2745
3 2755 39 2753
3 2745 31 518
3 31 476 518
3 2996 2755 2754
3 2755 2753 2754
3 2743 2728 2737
3 2728 3503 2737
3 2710 3503 2728
3 2710 5158 3
3 2710 2713 5158
3 3503 2710 3
3 476 338 518
3 476 337 338
3 2743 337 476
3 2743 2737 337
3 2713 1319 5158
3 5158 1319 2653
3 1319 4653 2653
3 1319 5639 4653
3 1319 5159 5639
3 5639 5159 802
3 5159 2655 802
3 802 2655 5624
3 2655 2651 5624
3 2655 2616 2651
3 2616 1318 2651
3 1318 2642 2651
3 1318 2620 2642
3 2620 2641 2642
3 2641 2867 2606
3 2641 2606 2642
3 2606 2871 2642
3 2606 470 2871
3 470 2606 2869
3 2606 4208 2869
3 2869 4208 1162
3 4208 4561 1162
3 4208 1165 4561
3 4209 3475 1134
3 1165 4209 1134
3 3475 1133 1134
3 3475 3470 1133
3 3475 3474 3470
3 3474 3478 3470
3 3474 4213 3478
3 3464 4213 3474
3 4210 3464 3474
3 4213 3464 4210
3 4561 1165 5095
3 1165 1134 5095
3 4213 4214 3478
3 4213 3447 4214
3 4214 4215 3478
3 3478 4215 3481
3 4215 3476 3481
3 3476 4217 3481
3 3481 4217 4224
3 4217 4223 4224
3 4223 4221 4224
3 4221 4223 4643
3 4643 546 1117
3 4221 4643 4222
3 4643 1117 4222
3 5593 3152 173
3 5593 3178 3152
3 173 2886 188
3 546 188 790
3 790 188 792
3 188 196 792
3 188 3160 196
3 188 2886 3160
3 173 3152 3160
3 2886 173 3160
3 546 5599 1117
3 5599 546 790
3 3178 3171 3181
3 3181 3171 3210
3 3181 3210 3170
3 3170 3210 3180
3 3210 3203 3180
3 3210 3214 3203
3 3214 3227 3203
3 3234 3227 3214
3 3152 3178 3170
3 3178 3181 3170
3 3232 3244 3237
3 3231 3244 3232
3 3203 3227 3209
3 3209 3227 3226
3 3227 3231 3226
3 3231 3232 3226
3 3226 3232 3237
3 205 3226 3237
3 205 3237 204
3 5166 204 4226
3 204 203 4226
3 2890 205 204
3 2890 204 5166
3 4226 203 208
3 203 206 208
3 203 2938 206
3 203 2908 2938
3 203 2907 2908
3 2905 2907 203
3 2905 2896 2356
3 2907 2905 2889
3 2905 2356 2889
3 3324 3325 4253
3 4228 3324 4227
3 4227 3324 4253
3 209 3341 4228
3 212 209 4228
3 213 212 4228
3 213 4228 4227
3 210 216 2942
3 210 2942 3341
3 209 210 3341
3 207 2941 216
3 210 207 216
3 2908 2353 2937
3 2938 2908 2937
3 2938 2937 2936
3 2907 2889 2353
3 2908 2907 2353
3 201 2938 2936
3 2938 201 206
3 208 206 2946
3 208 2946 4242
3 4242 2946 207
3 4242 207 209
3 207 210 209
3 3344 4227 4253
3 3342 3344 4253
3 3342 4253 4229
3 4229 4253 4233
3 4233 4253 4232
3 4562 4251 4563
3 4251 4237 4563
3 4240 4251 4483
3 4483 4251 4539
3 4539 4251 4562
3 4563 4237 4238
3 1452 4233 4232
3 1452 4232 1454
3 1454 4232 4231
3 4230 4231 4240
3 1454 4231 4230
3 4230 4240 4481
3 4481 4240 4483
3 4282 4812 4811
3 4283 4282 4277
3 4277 4282 4811
3 4238 511 4263
3 4263 511 4264
3 511 512 4264
3 511 4266 512
3 511 4283 4266
3 4563 4238 4271
3 4271 4238 4506
3 4506 4238 4263
3 4266 4283 4277
3 4002 4295 4837
3 4002 4837 4005
3 4004 4002 4005
3 4759 4004 4005
3 4759 4005 4825
3 4759 4825 4750
3 4750 4825 4814
3 4814 4825 4827
3 4277 4811 4279
3 4266 4277 4279
3 4262 4266 4279
3 4262 4279 4272
3 4272 4279 4261
3 4272 4261 4268
3 4268 4261 4291
3 4290 4260 4295
3 4260 4273 4295
3 4297 4260 4290
3 4294 4291 4288
3 4294 4268 4291
3 4296 4276 4288
3 4296 4288 4297
3 4276 4294 4288
3 4297 4290 4003
3 4420 4296 4297
3 4289 4420 4297
3 4289 4297 4003
3 4290 4295 4002
3 4826 4827 4831
3 4826 4831 4818
3 4818 4831 4830
3 4814 4827 4823
3 4827 4826 4823
3 4692 4818 4830
3 4692 4830 4751
3 4751 4830 4748
3 4830 4787 4748
3 4748 4787 4761
3 4787 4765 4761
3 4748 4761 4698
3 4674 4748 4698
3 4693 4748 4674
3 672 4693 4674
3 672 4674 4680
3 4680 4674 4694
3 2414 2412 2583
3 2412 2564 2583
3 2412 2568 2564
3 2568 899 2564
3 2568 4104 899
3 2410 4104 2568
3 2410 4190 4105
3 2475 4190 2410
3 2410 4105 4104
3 2553 4190 2475
3 5496 2578 2577
3 2578 2576 2577
3 2576 2158 2577
3 2151 2158 2576
3 2158 2151 2149
3 2151 2600 2149
3 2158 2149 2176
3 2176 2149 2157
3 2149 2603 2157
3 2149 2148 2603
3 2148 2147 2603
3 2148 2584 2147
3 2584 2571 2147
3 2571 903 2147
3 2571 2413 903
3 2413 2579 903
3 2601 2583 2596
3 2579 2601 4201
3 2601 2596 4201
3 2583 4199 2596
3 2583 4198 4199
3 2564 4198 2583
3 2579 4201 2150
3 903 2579 2150
3 2553 2551 4190
3 2551 4191 4190
3 4191 2474 4190
3 2474 745 4190
3 2474 2544 745
3 2473 2544 2474
3 2473 4298 2544
3 4298 2535 2544
3 4298 4299 2535
3 4317 4299 4298
3 2531 4317 4298
3 2531 2530 4317
3 2524 2530 2531
3 2524 2523 2530
3 2523 4332 2530
3 5164 2828 4335
3 4335 4316 4332
3 4335 2828 4316
3 5163 4334 5164
3 2829 5163 5164
3 5164 4334 2828
3 4332 4307 2530
3 4307 4332 4322
3 4332 2534 4322
3 4332 2827 2534
3 4332 4316 2827
3 2785 2836 2811
3 2837 5163 2829
3 2837 5165 5163
3 5165 2837 500
3 2837 4333 500
3 2837 2826 4333
3 4313 2826 4474
3 2826 4472 4474
3 2826 2824 4472
3 2826 2836 2824
3 2811 2836 2826
3 2826 4313 4333
3 2144 2146 2141
3 2146 2145 2141
3 2157 2145 2146
3 2176 2157 2146
3 2577 2158 2176
3 3735 3871 3897
3 3871 3915 3897
3 3897 3915 3875
3 3915 4593 3875
3 3735 3897 3737
3 3863 3903 3869
3 3862 3903 3863
3 3862 572 3903
3 571 572 3862
3 3861 571 3862
3 5103 571 3861
3 573 5103 3861
3 3891 573 3861
3 4604 573 3891
3 3840 950 4604
3 4604 950 573
3 3840 975 950
3 974 975 3840
3 4593 3896 3875
3 4593 3867 3896
3 3867 4592 3896
3 3867 3868 4592
3 3867 3869 3868
3 3869 3903 3868
3 974 1088 975
3 949 1088 974
3 948 5154 949
3 949 5155 1088
3 5154 5155 949
3 941 5154 948
3 941 1909 5154
3 740 1909 941
3 5587 1909 740
3 916 5587 740
3 940 916 740
3 961 5588 1075
3 945 961 1075
3 1075 5588 962
3 914 961 945
3 962 5587 916
3 962 5588 5587
3 914 959 961
3 914 960 959
3 980 960 914
3 732 980 914
3 908 5124 732
3 732 5124 980
3 908 2143 5124
3 2141 2143 908
3 2141 2142 2143
3 2145 2142 2141
3 4611 3878 3882
3 4611 3897 3878
3 3737 3897 4611
3 3882 3917 3918
3 3882 3878 3917
3 3554 3608 1445
3 3554 3555 3608
3 3556 3555 3554
3 3556 3598 3555
3 4633 3598 3556
3 4634 3598 4633
3 3555 3598 1447
3 3598 142 1447
3 3598 5705 142
3 5705 5117 142
3 117 5117 5705
3 117 1292 5117
3 118 1292 117
3 1436 118 117
3 1437 118 1436
3 1437 3902 118
3 1437 5106 3902
3 5106 4602 3902
3 5106 3884 4602
3 3884 5105 4602
3 3884 4586 5105
3 1315 4586 3884
3 3899 4586 1315
3 4613 3899 1315
3 3899 5104 4586
3 3918 5104 3899
3 3918 4597 5104
3 3917 4597 3918
3 4672 672 4680
3 4684 4672 4680
3 4682 4672 4684
3 4682 4684 4690
3 4690 4684 4912
3 4982 4690 4912
3 4981 4982 4912
3 4981 4912 4963
3 4912 4911 4963
3 4963 4911 4965
3 4911 4681 4965
3 4687 4981 4963
3 4679 4687 4975
3 4679 4975 4905
3 4687 4685 4981
3 4688 4685 4687
3 4688 4687 4679
3 143 144 2119
3 2119 144 122
3 2119 122 123
3 2119 123 2118
3 3977 5228 6076
3 6084 3977 6076
3 6084 6076 6091
3 6094 6084 6091
3 6094 6091 6090
3 6085 6094 6090
3 6085 6090 2113
3 6085 2113 6082
3 3977 5174 5228
3 5188 5173 5174
3 3804 5188 5174
3 3804 5174 3977
3 4572 3974 5231
3 4572 5231 5225
3 5173 4572 5225
3 5188 4572 5173
3 6077 6085 6082
3 149 6077 6082
3 149 6082 135
3 134 149 135
3 134 135 2119
3 135 143 2119
3 3988 3776 2338
3 2338 3776 5171
3 3780 2338 5171
3 3780 5171 3974
3 3993 3780 3974
3 4572 3993 3974
3 4906 4688 4679
3 4906 4677 4688
3 667 4677 4906
3 4660 667 4906
3 4660 4906 4876
3 4660 4876 681
3 4661 4660 681
3 177 4661 681
3 644 177 681
3 644 681 2102
3 4030 644 2102
3 4031 4030 2102
3 4031 2102 5085
3 4031 5085 653
3 4871 4031 653
3 647 4871 653
3 2407 647 653
3 4886 2407 689
3 2407 2103 647
3 2101 2103 2407
3 648 2101 2407
3 648 2407 2408
3 2408 2407 4886
3 4886 689 4888
3 4892 4886 4888
3 4894 4892 4888
3 2261 4894 4893
3 2261 4893 2254
3 2254 4893 2249
3 2264 4892 4894
3 2405 2264 4894
3 2405 4894 2261
3 2261 2254 2266
3 2266 2254 2256
3 2256 2254 2250
3 2256 2250 2251
3 2266 2256 2267
3 380 2267 2268
3 2307 2267 380
3 2278 2266 2267
3 2307 2278 2267
3 2309 380 2308
3 2290 380 2309
3 377 2290 2309
3 2281 2290 377
3 2292 2281 377
3 2291 2292 377
3 4061 2291 4060
3 4128 4061 4060
3 2288 4128 4060
3 4062 2288 4060
3 4062 4060 4055
3 4054 4062 4055
3 4054 4055 4064
3 4053 4141 2291
3 4053 2291 4061
3 4141 2292 2291
3 4096 4064 4075
3 4054 4064 4096
3 5233 5181 4080
3 4080 5181 4185
3 5233 5182 5181
3 4095 4096 4186
3 4186 4096 4180
3 4180 4096 5182
3 4095 4054 4096
3 4180 5182 5233
3 4184 4080 4185
3 4184 4185 4574
3 4574 4185 2121
3 2281 2307 380
3 2290 2281 380
3 4573 4574 2121
3 4573 2121 3988
3 3983 4573 3988
3 3983 3988 3777
3 3777 3988 3780
3 3988 2338 3780
3 137 2119 2118
3 137 134 2119
3 2123 134 137
3 2123 137 2124
3 2125 2124 5797
3 2117 2123 2124
3 2125 2117 2124
3 5795 2125 5797
3 5795 5797 3951
3 3951 5797 5799
3 3961 3951 5799
3 3961 5799 3827
3 3961 3827 5821
3 5821 3827 3955
3 3698 3767 3826
3 3698 3826 3700
3 3698 3700 4638
3 5836 5831 3767
3 5836 3767 3962
3 3962 3767 3698
3 5831 3955 3767
3 5821 3955 5831
3 3963 4638 5772
3 3963 3698 4638
3 5765 5724 5774
3 5765 5774 5777
3 5771 5772 5724
3 5771 5724 5765
3 3963 5772 5778
3 5778 5772 5773
3 5772 5771 5773
3 5766 5765 5777
3 5766 5777 5770
3 5770 5777 5759
3 5781 5759 5776
3 5781 5770 5759
3 3615 5782 3631
3 3615 3637 5782
3 4640 3637 3615
3 3566 4640 3615
3 3636 4640 3566
3 3613 3636 3566
3 3565 3613 3566
3 3511 3565 3566
3 3637 5781 5776
3 3634 5781 3637
3 4641 3634 3637
3 4640 4641 3637
3 3522 3565 3511
3 3522 3511 3509
3 5704 3522 3509
3 1447 5706 5704
3 3555 1447 5704
3 3608 3555 5704
3 5706 3522 5704
3 2803 2814 2804
3 2803 2805 2814
3 2987 2805 2803
3 2836 4312 2824
3 2836 2821 4312
3 2823 2821 2836
3 2823 2813 2821
3 2813 2822 2821
3 2813 2835 2822
3 2813 2815 2835
3 2784 2815 2813
3 2974 2784 2813
3 2994 2784 2974
3 2994 2995 2784
3 2804 2995 2994
3 2804 2814 2995
3 2842 2771 3028
3 2771 2840 2987
3 3028 2771 2987
3 3023 2805 2987
3 2840 3023 2987
3 2771 2769 2840
3 2840 2769 3023
3 3023 20 2805
3 20 2746 2805
3 20 22 2746
3 23 2757 2806
3 2757 2839 2806
3 22 23 2746
3 2746 23 2806
3 2806 2839 2838
3 2839 2996 2838
3 2838 2996 2754
3 2754 2753 483
3 483 2753 2745
3 483 2745 17
3 17 2745 2833
3 2745 518 2833
3 480 518 5954
3 518 338 5954
3 2833 518 480
3 2838 2754 478
3 478 2754 484
3 2754 483 484
3 2737 3 998
3 3503 3 2737
3 2737 998 337
3 3 472 998
3 3 2653 472
3 3 5158 2653
3 338 482 5954
3 338 481 482
3 338 337 481
3 337 477 481
3 337 998 477
3 472 2653 473
3 473 2653 2652
3 2653 4654 2652
3 2653 4653 4654
3 4653 802 4654
3 5639 802 4653
3 802 4646 4654
3 802 5624 4646
3 4646 5624 1149
3 5624 4644 1149
3 5624 2870 4644
3 2651 2870 5624
3 2651 1144 2870
3 2642 1144 2651
3 2642 5637 1144
3 2642 2871 5637
3 5637 2871 5636
3 2871 470 5636
3 470 469 5636
3 470 2869 469
3 2869 1162 469
3 469 1162 5671
3 1162 5095 5671
3 1162 4561 5095
3 5095 1134 801
3 1134 1133 801
3 4216 4225 1133
3 3470 4216 1133
3 1133 1132 801
3 1132 1133 800
3 1133 4225 800
3 3478 4216 3470
3 3478 3481 4216
3 5671 5095 5634
3 5634 5095 801
3 3481 4224 1
3 4216 3481 1
3 1 4224 4222
3 4224 4221 4222
3 4222 1117 183
3 1117 192 183
3 5599 192 1117
3 4222 1116 4498
3 1116 4222 183
3 1 4222 4498
3 3152 3155 3160
3 3152 3166 3155
3 3152 3170 3166
3 192 5599 790
3 183 192 790
3 183 790 793
3 790 792 793
3 792 5130 200
3 792 196 5130
3 793 792 697
3 697 792 791
3 792 199 791
3 792 200 199
3 196 184 5130
3 184 196 5600
3 196 3160 5600
3 5600 3160 3161
3 3160 3155 3161
3 3166 3170 3180
3 3166 3180 3155
3 3155 3180 3169
3 3180 3209 3169
3 3180 3203 3209
3 3169 3209 3208
3 3209 3226 3208
3 3226 205 3208
3 3208 205 2890
3 4247 5166 4226
3 4247 4226 4245
3 4245 4226 4244
3 4226 4242 4244
3 4226 208 4242
3 4248 2890 5166
3 4248 5166 4247
3 3207 3208 2890
3 3207 2890 4248
3 214 213 4227
3 214 4227 3344
3 4242 209 212
3 211 4242 212
3 1176 211 212
3 1176 212 213
3 4520 1176 213
3 4520 213 214
3 4244 4242 211
3 3343 214 3344
3 3343 3344 1456
3 1456 3344 3342
3 1456 3342 1453
3 3342 4229 1453
3 4229 4233 1452
3 1453 4229 1452
3 4562 4563 4271
3 4539 4562 4540
3 4562 4271 4540
3 4538 4483 4539
3 4481 4483 4482
3 4482 4483 4538
3 4542 4539 4510
3 4510 4539 4540
3 4538 4539 4504
3 4504 4539 4542
3 1453 1452 5880
3 1452 1454 5880
3 1454 4230 5880
3 5880 4230 4481
3 5880 4481 5620
3 4481 4482 5620
3 4506 4263 4511
3 4263 4265 4511
3 4263 4264 4265
3 4265 4264 4547
3 4547 4264 4275
3 4264 4262 4275
3 4264 512 4262
3 512 4266 4262
3 4540 4271 4506
3 4540 4506 4511
3 4290 4002 4004
3 4010 4004 4668
3 4004 4759 4668
3 4003 4290 4004
3 4010 4003 4004
3 4668 4759 4750
3 4668 4750 4695
3 4750 4814 4695
3 4695 4814 4823
3 4275 4262 4272
3 4294 4272 4268
3 4275 4272 4294
3 4275 4294 4276
3 4514 4276 4296
3 4293 4275 4276
3 4514 4293 4276
3 4552 4296 4420
3 4514 4296 4552
3 4289 4003 4010
3 4551 4552 4420
3 4551 4420 4289
3 4551 4289 4554
3 4554 4289 4010
3 4823 4826 4818
3 4695 4823 4818
3 4695 4818 4692
3 4697 4695 4692
3 4670 4697 4692
3 4670 4692 4671
3 4671 4692 672
3 4692 4693 672
3 4692 4751 4693
3 4751 4748 4693
3 4672 4671 672
3 2564 4195 4198
3 2564 899 4195
3 899 522 4196
3 899 4104 522
3 899 4196 4195
3 4104 4105 522
3 4105 4190 4103
3 4105 4103 522
3 4190 4193 4103
3 4190 745 4193
3 2157 2603 2145
3 2603 901 2145
3 2603 2147 901
3 2147 900 901
3 2147 903 900
3 903 2150 900
3 2596 2591 4201
3 2596 4199 2591
3 4201 4202 902
3 2591 4202 4201
3 2150 4201 3492
3 3492 4201 4200
3 4201 902 4200
3 4198 2565 4199
3 4199 2566 2591
3 4199 2565 2566
3 4198 887 2565
3 4198 4195 887
3 2150 3492 900
3 4337 4189 745
3 2544 4337 745
3 745 4338 4193
3 745 750 4338
3 745 739 750
3 4189 739 745
3 2544 2535 4337
3 2535 4301 4337
3 2535 4299 4301
3 4299 4300 4301
3 4299 4317 4300
3 4317 4326 4300
3 4317 4322 4326
3 4307 4322 4317
3 2530 4307 4317
3 2828 4302 4316
3 2828 4334 4302
3 4316 4302 2827
3 5163 5165 4334
3 4334 4475 4302
3 4334 500 4475
3 5165 500 4334
3 4322 2534 4321
3 4326 4322 4321
3 2534 2827 4321
3 2827 4305 4306
3 2827 4304 4305
3 4302 4304 2827
3 4321 2827 4306
3 500 515 4475
3 500 521 515
3 500 4474 521
3 4333 4474 500
3 4333 4313 4474
3 521 4474 4485
3 4474 4472 4485
3 4472 4315 4492
3 2824 4315 4472
3 4472 4492 4485
3 4310 4315 2824
3 4312 4310 2824
3 2145 901 2142
3 3897 3876 3878
3 3897 3875 3876
3 3875 1314 3876
3 3875 5120 1314
3 3896 5120 3875
3 3903 3895 3868
3 3903 5111 3895
3 572 5111 3903
3 572 3736 5111
3 5109 3736 572
3 571 5109 572
3 3858 5107 571
3 5103 3858 571
3 571 5107 5109
3 3734 3858 5103
3 573 3734 5103
3 950 3734 573
3 950 3858 3734
3 5709 3858 950
3 975 5709 950
3 975 1090 5709
3 975 1091 1090
3 976 1091 975
3 1088 976 975
3 3896 4592 5120
3 5120 4592 3864
3 4592 4579 3864
3 4592 3868 4579
3 3868 3895 4579
3 1088 5585 976
3 1088 5156 5585
3 5155 5156 1088
3 5154 1909 5156
3 5154 5156 5155
3 1909 1910 5586
3 958 1910 1909
3 5587 958 1909
3 1909 5586 5156
3 5588 958 5587
3 5588 1904 958
3 5591 1904 5588
3 1908 5591 5588
3 5589 1908 5588
3 959 5589 5588
3 961 959 5588
3 959 960 5589
3 960 1908 5589
3 960 947 1908
3 980 947 960
3 5124 979 980
3 980 530 947
3 979 530 980
3 5124 2143 979
3 2143 4204 979
3 2143 909 4204
3 2142 909 2143
3 901 883 2142
3 2142 883 909
3 3878 5113 3917
3 3878 3876 5113
3 3917 4583 4597
3 3917 5113 4583
3 1447 116 5706
3 5868 116 1447
3 1290 5868 1447
3 142 1290 1447
3 1441 1290 142
3 5117 1441 142
3 5117 1440 1441
3 5117 1439 1440
3 1292 1439 5117
3 5707 1439 1292
3 118 5707 1292
3 3902 128 118
3 128 5707 118
3 3902 4602 128
3 4602 5115 128
3 4602 5105 5115
3 5105 4603 5115
3 5105 4587 4603
3 4586 4587 5105
3 4586 4600 4587
3 5104 4600 4586
3 4596 4598 5104
3 4597 4596 5104
3 4600 5104 4601
3 5104 4598 4601
3 4597 4583 4596
3 4683 4672 4682
3 4689 4671 4672
3 4689 4672 4683
3 4982 4682 4690
3 4683 4682 4982
3 4685 4683 4982
3 4685 4982 4981
3 4689 4683 4685
3 4678 4689 4685
3 4667 4678 4685
3 4677 4667 4685
3 4688 4677 4685
3 5792 3804 3977
3 5792 3977 6084
3 6089 5792 6084
3 6089 6084 6094
3 6097 6094 6085
3 6093 6089 6094
3 6095 6093 6094
3 6097 6095 6094
3 5208 6085 6077
3 5208 6097 6085
3 3942 5175 5188
3 3978 3942 5188
3 3978 5188 3804
3 5188 5175 4572
3 5223 3978 3804
3 5792 5223 3804
3 5175 3993 4572
3 5208 6077 149
3 6086 5208 149
3 2122 6086 149
3 2122 149 134
3 133 2122 134
3 133 134 2123
3 3777 3780 3993
3 3777 3993 5175
3 4874 4667 4677
3 4665 4874 4677
3 4666 4665 4677
3 4666 4677 667
3 4661 4666 667
3 4661 667 4660
3 4662 4666 4661
3 646 4662 4661
3 177 646 4661
3 643 646 177
3 643 177 644
3 4102 644 4030
3 4102 643 644
3 651 4102 4030
3 651 4030 649
3 649 4030 4031
3 649 4031 2103
3 2103 4031 647
3 647 4031 4871
3 2408 4886 4891
3 4891 4886 4892
3 2101 649 2103
3 2104 2100 2101
3 158 2104 2101
3 648 158 2101
3 2099 649 2101
3 2100 2099 2101
3 2409 648 2408
3 158 648 2401
3 2401 648 2409
3 2409 2408 4891
3 2263 4891 4892
3 2264 2263 4892
3 2305 2261 2277
3 2277 2261 2266
3 2276 2405 2261
3 2305 2276 2261
3 2406 2263 2264
3 2406 2264 2405
3 2265 2406 2405
3 2265 2405 2276
3 2277 2266 2278
3 2287 2278 2307
3 2281 2287 2307
3 2286 2277 2278
3 2280 2286 2278
3 2280 2278 2287
3 3490 2287 2281
3 4141 3490 2281
3 4141 2281 2292
3 4144 4053 4061
3 4128 4144 4061
3 4051 4144 4128
3 4050 4051 4128
3 4050 4128 4056
3 4056 4128 2288
3 2288 4062 4066
3 382 4056 2288
3 383 382 2288
3 383 2288 4066
3 4066 4062 4054
3 4095 4058 4054
3 383 4066 4054
3 4132 383 4054
3 4058 4132 4054
3 2304 3490 4141
3 4052 2304 4141
3 4053 4052 4141
3 4143 4052 4053
3 4143 4053 4144
3 5233 4080 4184
3 4186 4180 5233
3 4181 4186 5233
3 4086 4181 5233
3 4086 5233 4187
3 4187 5233 4188
3 5233 4184 4188
3 4181 4095 4186
3 376 4058 4095
3 4092 376 4095
3 4091 4092 4095
3 4091 4095 4181
3 4188 4184 4574
3 5184 4188 4574
3 5184 4574 3990
3 3990 4574 4573
3 3990 4573 3989
3 3989 4573 3983
3 3782 3983 3784
3 3784 3983 3777
3 3984 3989 3983
3 3782 3984 3983
3 3784 3777 3942
3 3942 3777 5175
3 2117 133 2123
3 5795 2117 2125
3 2128 133 2117
3 2133 2128 2117
3 2133 2117 5795
3 2133 5795 5796
3 5796 5795 3951
3 3764 5796 3951
3 3764 3951 3961
3 5826 3764 3961
3 5826 3961 3953
3 3953 3961 5830
3 5830 3961 5821
3 3959 5830 5821
3 3959 5821 5832
3 5832 5821 5831
3 3962 3698 3963
3 5832 5831 5827
3 5827 5831 5836
3 5827 5836 5833
3 5836 3962 5833
3 5833 3962 5775
3 5775 3962 3963
3 5775 3963 5778
3 5773 5771 5765
3 5773 5765 3635
3 3635 5765 5766
3 4635 5775 5778
3 4635 5778 5780
3 5780 5778 5773
3 5780 5773 3635
3 5766 5770 5781
3 3635 5766 5781
3 3634 3635 5781
3 3636 4641 4640
3 3612 3966 3636
3 3565 3612 3636
3 3565 3636 3613
3 3636 3966 4641
3 3614 3612 3565
3 3522 3614 3565
3 3966 4636 3634
3 3966 3634 4641
3 4636 3635 3634
3 3513 3614 3522
3 3514 3513 3522
3 1443 3514 3522
3 116 1443 3522
3 5706 116 3522
3 2995 2814 2784
3 2814 2815 2784
3 2814 2975 2815
3 2814 2982 2975
3 2805 2982 2814
3 2805 2746 2982
3 615 4310 4312
3 2821 615 4312
3 2820 615 2821
3 2832 2820 2821
3 2822 2832 2821
3 2835 2832 2822
3 2835 2819 2832
3 2834 2819 2835
3 2815 2834 2835
3 2815 2975 2834
3 2746 2806 2982
3 2982 2806 478
3 2806 2838 478
3 484 483 17
3 484 17 2816
3 2816 17 2831
3 2831 17 2833
3 2833 4469 4309
3 2833 480 4469
3 2831 2833 4309
3 480 5954 4469
3 4469 5954 5606
3 5954 479 5606
3 5954 482 479
3 2975 478 484
3 2982 478 2975
3 2975 484 2816
3 477 998 475
3 998 5607 475
3 998 472 5607
3 472 473 5607
3 35 482 417
3 482 5608 417
3 482 481 5608
3 479 482 35
3 481 477 5608
3 5608 477 30
3 477 475 30
3 474 473 29
3 473 468 29
3 473 2652 468
3 5607 473 474
3 468 2652 28
3 2652 5846 28
3 2652 4654 5846
3 4654 1148 5846
3 4654 4646 1148
3 1148 4646 1149
3 1148 1149 5846
3 5846 1149 4645
3 1149 5638 4645
3 1149 4644 5638
3 2870 1167 4644
3 4644 1167 5638
3 1144 5637 2870
3 2870 5640 1167
3 2870 5636 5640
3 5637 5636 2870
3 5636 5625 5640
3 5636 5671 5625
3 5636 469 5671
3 5625 5671 1168
3 5671 5634 1168
3 5634 801 5672
3 5672 801 1129
3 801 794 1129
3 801 1132 794
3 4225 797 800
3 4216 797 4225
3 4216 1 797
3 1132 800 794
3 800 799 794
3 800 797 799
3 1168 5634 5672
3 797 1 4498
3 547 183 793
3 4497 1116 183
3 4497 183 547
3 5094 797 4498
3 5094 4498 4497
3 4498 1116 4497
3 3161 3155 3165
3 3155 3169 3165
3 1135 793 795
3 795 793 696
3 696 793 697
3 547 793 1135
3 199 200 185
3 200 163 185
3 184 163 200
3 5130 184 200
3 697 791 430
3 696 697 789
3 789 697 430
3 791 199 354
3 791 420 430
3 791 354 420
3 199 194 354
3 199 185 194
3 184 5600 163
3 5600 3161 197
3 163 5600 187
3 5600 197 187
3 197 3161 3179
3 3161 3165 3179
3 3165 3169 3188
3 3188 3169 3208
3 3188 3208 3207
3 198 4247 4246
3 4246 4247 4517
3 4247 4245 4517
3 4220 4248 4247
3 198 4220 4247
3 4517 4245 4244
3 4244 1176 4520
3 4244 211 1176
3 4517 4244 5918
3 5918 4244 5917
3 5917 4244 4520
3 4220 3207 4248
3 3188 3207 4220
3 4520 214 3343
3 5917 4520 5883
3 5883 4520 1457
3 4520 3343 1457
3 1457 3343 1456
3 1457 1456 1343
3 1456 1453 1343
3 1343 1453 5880
3 4510 4540 4511
3 4482 4538 4235
3 4235 4538 4522
3 4522 4538 4504
3 4482 4235 4522
3 4482 4522 5620
3 4537 4510 4511
3 4542 4510 4533
3 4533 4510 4537
3 4505 4542 4533
3 4505 4504 4542
3 4522 4504 4505
3 1457 1343 5880
3 1458 1457 5880
3 1592 1458 5880
3 5908 1592 5880
3 5908 5880 1591
3 1591 5880 1574
3 1574 5880 1516
3 1516 5880 5881
3 5881 5880 5616
3 5880 5620 5616
3 5620 4528 5617
3 5620 4521 4528
3 4522 4521 5620
3 5616 5620 5617
3 4537 4511 4543
3 4511 4541 4543
3 4511 4265 4541
3 4265 4547 4541
3 4547 4514 4274
3 4547 4293 4514
3 4293 4547 4275
3 4541 4547 4546
3 4547 4274 4546
3 4011 4010 4668
3 4011 4668 4670
3 4668 4697 4670
3 4697 4668 4695
3 4553 4554 4010
3 4553 4010 4011
3 4274 4514 4552
3 4274 4552 4551
3 4549 4551 4548
3 4548 4551 4554
3 4546 4274 4551
3 4546 4551 4544
3 4544 4551 4549
3 4548 4554 4553
3 4553 4011 4670
3 4018 4553 4670
3 4021 4018 4670
3 4021 4670 4001
3 4001 4670 4669
3 4670 4671 4669
3 4669 4671 4689
3 4195 4196 887
3 4196 4197 887
3 522 4197 4196
3 4197 522 4194
3 522 3501 4194
3 4103 3501 522
3 4103 4193 3501
3 4193 4338 3501
3 882 883 901
3 900 882 901
3 900 3492 882
3 2591 2566 4202
3 902 904 4200
3 902 890 904
3 902 2594 890
3 4202 2594 902
3 4202 2595 2594
3 2566 2595 4202
3 3492 4200 978
3 882 3492 906
3 3492 978 906
3 4200 904 4203
3 978 4200 4203
3 2565 4194 874
3 4197 4194 2565
3 887 4197 2565
3 2565 874 2566
3 2566 874 2595
3 4189 5126 739
3 4189 746 5126
3 4337 746 4189
3 4337 748 746
3 4337 749 748
3 4337 4327 749
3 4328 4327 4337
3 4301 4328 4337
3 4338 866 228
3 750 866 4338
3 4338 228 3501
3 750 864 866
3 739 864 750
3 739 5126 864
3 4301 4300 4328
3 4300 4339 4328
3 4300 4321 4339
3 4326 4321 4300
3 4302 490 4304
3 4302 514 490
3 4475 514 4302
3 4476 4475 4331
3 4475 515 4331
3 514 4475 4476
3 4321 4306 4478
3 4321 4478 4339
3 4306 4484 4478
3 4306 4477 4484
3 4306 4323 4477
3 4303 4323 4306
3 4305 4303 4306
3 4320 4303 4305
3 4304 4320 4305
3 4304 490 4320
3 515 4329 4331
3 515 521 4329
3 4329 521 4485
3 4485 2459 516
3 4492 2459 4485
3 4329 4485 4330
3 4330 4485 516
3 4492 4493 2459
3 4471 4493 4492
3 4315 4471 4492
3 4310 4471 4315
3 4310 4470 4471
3 4310 4314 4470
3 615 4314 4310
3 3876 3865 5113
3 1314 3865 3876
3 1314 5120 3865
3 5120 3864 3865
3 3895 5118 4577
3 5111 5118 3895
3 3895 4577 4579
3 5118 5111 3905
3 5111 4576 3905
3 3893 4576 5111
3 3736 3893 5111
3 3736 3892 3893
3 5110 3892 3736
3 5108 5110 3736
3 5109 5108 3736
3 5107 5108 5109
3 5107 5110 5108
3 5107 992 5110
3 3858 992 5107
3 3858 1053 992
3 3858 981 1053
3 907 981 3858
3 5709 907 3858
3 1090 907 5709
3 1090 5157 907
3 1091 5157 1090
3 1091 5585 5157
3 976 5585 1091
3 3865 3864 4591
3 3864 4579 4591
3 4579 3906 4591
3 4579 3905 3906
3 4577 3905 4579
3 5585 1282 5157
3 5585 1288 1282
3 5156 1288 5585
3 5156 1912 1288
3 5586 1912 5156
3 1905 1906 5586
3 1910 1905 5586
3 5586 1906 1912
3 1910 957 1905
3 958 957 1910
3 958 1074 957
3 1904 1074 958
3 1904 5591 6039
3 1904 6039 1074
3 5591 6038 6039
3 5591 5590 6038
3 5591 1073 5590
3 1907 1073 5591
3 946 1907 5591
3 1908 946 5591
3 947 946 1908
3 530 965 947
3 947 942 946
3 965 942 947
3 979 4204 530
3 956 965 530
3 4204 956 530
3 4204 909 964
3 4204 964 956
3 909 911 964
3 883 911 909
3 883 906 911
3 882 906 883
3 3865 4581 5113
3 5113 4594 4583
3 5113 4581 4594
3 4583 5114 4596
3 4583 4594 5114
3 97 3627 116
3 5868 97 116
3 116 3514 1443
3 3627 3514 116
3 5867 97 5868
3 1290 5867 5868
3 1290 1296 5867
3 1441 1296 1290
3 1441 1440 1296
3 1439 1295 1440
3 1440 3633 1296
3 1440 1295 3633
3 1439 4590 1295
3 5707 4590 1439
3 5115 4590 5707
3 128 5115 5707
3 4603 5116 5115
3 5115 5116 4590
3 4603 3910 5116
3 4603 4587 3910
3 4587 4599 3910
3 4601 4599 4587
3 4600 4601 4587
3 4601 4598 4599
3 4598 3900 4599
3 4598 4584 3900
3 4598 4582 4584
3 4596 4582 4598
3 4596 5114 4582
3 4669 4689 4667
3 4689 4678 4667
3 4874 4669 4667
3 5200 5792 6089
3 5198 5223 5792
3 5200 5198 5792
3 6093 5200 6089
3 6078 6097 5208
3 6096 6095 6097
3 6078 6096 6097
3 5200 6093 6095
3 6099 6095 6096
3 6092 5200 6095
3 6099 6092 6095
3 6078 5208 6100
3 6100 5208 6087
3 6087 5208 6086
3 3783 3784 3942
3 5187 3783 3942
3 5187 3942 3978
3 5186 5187 3978
3 5186 3978 5223
3 5198 5186 5223
3 2138 6087 6086
3 2134 2138 6086
3 2134 6086 2122
3 2134 2122 2129
3 2129 2122 133
3 2129 133 2128
3 4874 178 4669
3 655 178 4874
3 655 4874 4665
3 654 655 4665
3 4028 654 4665
3 4028 4665 4666
3 4027 4028 4666
3 4662 4027 4666
3 646 4027 4662
3 4027 646 4409
3 4409 646 634
3 634 646 6069
3 646 643 6069
3 6069 643 4102
3 6069 4102 176
3 176 4102 2098
3 2098 4102 651
3 637 2098 651
3 636 637 651
3 636 651 2097
3 2097 651 649
3 2097 649 2099
3 4106 2409 4891
3 4106 4891 2263
3 2104 2096 2100
3 2100 2097 2099
3 2100 635 2097
3 2096 635 2100
3 2104 5132 2096
3 5134 5132 2104
3 357 5134 2104
3 4101 357 2104
3 171 4101 2104
3 158 171 2104
3 171 158 2401
3 2401 2409 4106
3 2259 2401 4106
3 4074 171 2401
3 4074 2401 2259
3 2262 4106 2263
3 2406 2262 2263
3 2306 2305 2277
3 2306 2277 2286
3 2305 181 2276
3 2311 181 2305
3 2311 2305 2306
3 181 2265 2276
3 2400 2262 2406
3 2400 2406 2265
3 181 2400 2265
3 2301 2280 2287
3 3490 2301 2287
3 2306 2286 2280
3 2279 2306 2280
3 2301 2279 2280
3 2303 3490 2304
3 2303 2301 3490
3 4139 4143 4144
3 4051 4139 4144
3 2289 4139 4051
3 4127 2289 4051
3 4130 4127 4051
3 4130 4051 4050
3 4131 4050 382
3 382 4050 4056
3 384 4130 4050
3 4129 384 4050
3 4129 4050 4131
3 4131 382 383
3 4131 383 378
3 378 383 4132
3 4059 4132 4058
3 373 4059 4058
3 376 373 4058
3 4059 378 4132
3 4049 2304 4052
3 4049 2303 2304
3 4143 4049 4052
3 2302 4049 4143
3 4139 2302 4143
3 4092 4091 4181
3 4182 4092 4181
3 4078 4182 4181
3 4078 4181 4086
3 3992 4086 4187
3 4078 4086 3992
3 3992 4187 3778
3 3778 4187 4147
3 4147 4187 4188
3 4147 4188 5184
3 4090 376 4182
3 376 4092 4182
3 374 373 376
3 4090 374 376
3 5189 4147 5184
3 5189 5184 3990
3 5189 3990 3991
3 3991 3990 3984
3 3984 3990 3989
3 3783 3782 3784
3 5190 3782 3783
3 3991 3984 3782
3 5190 3991 3782
3 5794 2126 2128
3 5794 2128 2133
3 2126 2129 2128
3 2130 5794 2133
3 2130 2133 3761
3 3761 2133 5796
3 3761 5796 3764
3 3760 3761 3764
3 3762 3760 3764
3 3762 3764 5826
3 5824 5826 3953
3 5835 3762 5826
3 5824 5835 5826
3 5825 5824 3953
3 5825 3953 5830
3 3958 5825 5830
3 3959 3958 5830
3 5803 3958 3959
3 5802 5803 3959
3 5802 3959 136
3 136 3959 5832
3 5805 136 5832
3 5805 5832 5806
3 5806 5832 5827
3 5827 5833 5807
3 5806 5827 5807
3 5807 5833 5822
3 5833 5775 5822
3 5822 5775 4635
3 4636 5780 3635
3 5822 4635 5779
3 5779 4635 5723
3 5723 4635 5780
3 5779 5723 5780
3 5779 5780 4636
3 5783 4636 3966
3 3625 5783 3966
3 3612 3625 3966
3 3614 3625 3612
3 3513 3625 3614
3 5783 5779 4636
3 3514 127 3513
3 3513 127 3625
3 1294 127 3514
3 3627 1294 3514
3 2975 2816 2834
3 4494 615 2820
3 615 2818 4314
3 4309 2818 615
3 4494 4309 615
3 2832 4494 2820
3 2819 4494 2832
3 2831 4494 2819
3 2816 2831 2819
3 2834 2816 2819
3 4494 2831 4309
3 4309 2817 2818
3 2817 4309 5604
3 4309 4469 5604
3 4469 4468 5604
3 4468 4469 5606
3 5604 5606 5148
3 5606 5667 5148
3 5606 479 5667
3 4468 5606 5604
3 479 35 5667
3 475 5607 30
3 5607 474 30
3 35 417 5149
3 417 411 5149
3 417 30 411
3 5608 30 417
3 35 5149 5656
3 5667 35 5656
3 411 30 464
3 30 466 464
3 30 465 466
3 30 474 465
3 474 29 5610
3 29 28 5610
3 29 468 28
3 474 5610 465
3 28 5846 4658
3 5610 28 1603
3 1603 28 4658
3 5846 4645 4658
3 4645 5931 4658
3 4645 5839 5931
3 4645 5638 5839
3 5638 5630 5839
3 1167 5630 5638
3 1167 5670 5631
3 5640 5670 1167
3 1167 5631 5630
3 5640 5625 5670
3 5670 5625 5635
3 5625 1168 5635
3 1168 5672 5629
3 5635 1168 5629
3 5672 1129 1136
3 5629 5672 5628
3 5628 5672 1136
3 1129 471 1136
3 1129 794 471
3 794 547 471
3 794 799 547
3 797 5094 799
3 799 4497 547
3 799 5094 4497
3 471 547 1135
3 3179 3165 3168
3 3165 3188 3168
3 1135 795 1128
3 1128 795 1137
3 795 696 1137
3 471 1135 1136
3 1136 1135 1128
3 1137 696 789
3 185 193 194
3 185 186 193
3 185 187 186
3 163 187 185
3 789 430 695
3 695 430 796
3 430 420 796
3 1137 789 695
3 420 354 189
3 189 354 427
3 354 422 427
3 354 194 422
3 420 189 796
3 194 195 422
3 194 193 195
3 187 197 3179
3 186 187 4220
3 187 3179 4220
3 3179 3168 4220
3 3168 3188 4220
3 4246 4517 4516
3 198 4246 4219
3 4219 4246 4516
3 186 4220 198
3 193 186 198
3 193 198 195
3 195 198 1177
3 1177 198 4219
3 4516 4517 5918
3 4515 4516 5918
3 4515 5918 5917
3 4519 4243 5917
3 4519 5917 459
3 459 5917 5882
3 5882 5917 1600
3 1600 5917 5883
3 4243 4515 5917
3 1600 5883 419
3 419 5883 1457
3 5898 419 1457
3 5898 1457 1458
3 4522 4505 4521
3 4534 4537 4543
3 4530 4533 4537
3 4532 4530 4537
3 4532 4537 4430
3 4430 4537 4429
3 4429 4537 4534
3 4536 4505 4533
3 4530 4536 4533
3 4521 4505 4536
3 5898 1458 1576
3 1576 1458 1592
3 1455 1592 5908
3 1576 1592 1455
3 1520 1455 5908
3 1520 5908 1347
3 5908 1591 1347
3 1347 1591 1574
3 1575 1574 1516
3 1347 1574 1575
3 1575 1516 1513
3 1513 1516 1573
3 1516 5881 1573
3 5881 5616 1595
3 1573 5881 1595
3 5616 4523 1595
3 4523 5616 5617
3 4523 5617 5618
3 5618 5617 4524
3 5617 4500 4524
3 5617 4528 4500
3 4528 4527 4500
3 4528 4531 4527
3 4526 4531 4528
3 4521 4526 4528
3 4526 4521 4536
3 4508 4543 4507
3 4543 4513 4507
3 4543 6108 4513
3 4543 4541 6108
3 4534 4543 4508
3 4541 4546 6108
3 6108 4546 4544
3 4019 4548 4553
3 4019 4553 4267
3 4267 4553 4018
3 4549 4548 4550
3 4550 4548 4019
3 4544 4549 4427
3 4427 4549 4550
3 6108 4544 4513
3 4513 4544 4427
3 4424 4267 4018
3 4424 4018 4021
3 4029 4021 178
3 178 4021 4001
3 4012 4424 4021
3 4029 4012 4021
3 178 4001 4669
3 4194 869 874
3 4194 937 869
3 4194 931 937
3 4194 938 931
3 228 938 4194
3 3501 228 4194
3 904 917 4203
3 904 927 917
3 904 888 927
3 889 888 904
3 890 889 904
3 890 879 889
3 890 870 879
3 2594 870 890
3 2594 871 870
3 2594 528 871
3 2594 2595 528
3 874 873 2595
3 2595 875 528
3 2595 873 875
3 906 978 911
3 978 4203 911
3 911 4203 892
3 4203 922 892
3 4203 762 922
3 763 762 4203
3 764 763 4203
3 917 764 4203
3 874 934 873
3 754 934 874
3 869 754 874
3 5126 736 864
3 5126 748 736
3 746 748 5126
3 748 4342 736
3 749 4342 748
3 4327 4342 749
3 4327 223 4342
3 4327 4339 223
3 4328 4339 4327
3 938 228 931
3 228 866 931
3 866 928 931
3 866 865 928
3 866 864 865
3 864 738 865
3 864 736 738
3 4339 222 223
3 4478 222 4339
3 490 514 4320
3 514 2529 4320
3 514 4476 2529
3 4476 4331 4303
3 4331 4324 4303
3 4331 516 4324
3 4331 4330 516
3 4329 4330 4331
3 2529 4476 4303
3 4484 4325 4478
3 222 4478 5703
3 4478 4325 5703
3 4484 4477 4325
3 4477 486 491
3 4324 486 4477
3 4323 4324 4477
3 4325 4477 510
3 4477 491 510
3 4303 4324 4323
3 4320 2529 4303
3 2459 4473 516
3 4324 516 486
3 516 501 486
3 501 516 616
3 516 4486 616
3 516 4473 4486
3 2459 601 4473
3 2459 4493 601
3 4493 4311 601
3 4470 4311 4493
3 4471 4470 4493
3 4470 4314 4311
3 4314 5096 4311
3 2818 5096 4314
3 3865 5119 4581
3 3865 4580 5119
3 3865 4591 4580
3 4577 5118 3905
3 3905 3894 3904
3 4576 3894 3905
3 3906 3905 5112
3 3905 3904 5112
3 4576 3711 3894
3 3893 3711 4576
3 3893 4575 3711
3 3892 4575 3893
3 3892 1257 4575
3 5110 1257 3892
3 5110 1054 1257
3 5110 1044 1054
3 1043 1044 5110
3 992 1043 5110
3 992 1037 1043
3 996 1037 992
3 1053 996 992
3 1055 1286 1053
3 981 1055 1053
3 1053 1037 996
3 1053 1058 1037
3 1053 1286 1058
3 907 1055 981
3 907 5157 1055
3 5157 1283 1055
3 5157 1280 1283
3 1282 1280 5157
3 4580 4591 3738
3 4591 3739 3738
3 4591 3906 3739
3 3906 5112 3739
3 1282 910 1280
3 1282 1892 910
3 1287 1892 1282
3 1288 1287 1282
3 1288 1883 1287
3 1912 1883 1288
3 1912 1884 1883
3 1906 1884 1912
3 1906 6036 1884
3 1905 6036 1906
3 1905 957 6036
3 6039 6038 957
3 1074 6039 957
3 957 6038 6036
3 6038 1089 6036
3 6040 1089 6038
3 1073 6040 6038
3 5590 1073 6038
3 1907 6040 1073
3 1907 1821 6040
3 912 1821 1907
3 1072 912 1907
3 946 1072 1907
3 942 1072 946
3 965 972 1071
3 956 972 965
3 965 1071 942
3 942 1071 1072
3 778 972 956
3 964 778 956
3 155 778 964
3 911 155 964
3 911 892 155
3 4581 5119 4594
3 4594 3730 5114
3 3907 3730 4594
3 5119 3907 4594
3 5114 4595 4582
3 5114 3730 4595
3 97 1294 3627
3 5867 1294 97
3 1442 1294 5867
3 3633 1442 5867
3 1296 3633 5867
3 1295 3515 3633
3 1295 125 3515
3 3911 125 1295
3 4589 3911 1295
3 4590 4589 1295
3 3633 3721 1442
3 3515 3721 3633
3 3910 4589 4590
3 5116 3910 4590
3 3910 1438 4589
3 3910 3901 1438
3 3909 3901 3910
3 4588 3909 3910
3 4599 4588 3910
3 4599 3900 4588
3 3900 3898 4588
3 3900 3718 3898
3 3900 4585 3718
3 4584 4585 3900
3 4584 4582 4585
3 4582 3908 4585
3 4582 4595 3908
3 5207 5198 5200
3 6092 5207 5200
3 5198 3975 5186
3 5194 3975 5198
3 5220 5194 5198
3 5222 5220 5198
3 5222 5198 5207
3 5203 6078 6100
3 6099 6096 6078
3 5204 6099 6078
3 5203 5204 6078
3 5793 6092 6099
3 6098 5793 6099
3 6098 6099 5204
3 5793 5207 6092
3 5203 6100 2138
3 2138 6100 6087
3 5190 3783 3944
3 3944 3783 5187
3 3975 5187 5186
3 3975 3944 5187
3 5203 2138 6079
3 6079 2138 2134
3 6079 2134 2129
3 2126 6079 2129
3 4029 178 4026
3 4026 178 655
3 4028 655 654
3 4025 4026 655
3 4025 655 4028
3 4027 4025 4028
3 4027 4024 4025
3 4418 4024 4027
3 4415 4418 4027
3 4401 4415 4027
3 4401 4027 4409
3 4402 4409 634
3 4400 4401 4409
3 1581 4400 4409
3 1581 4409 4402
3 4411 634 6069
3 4404 4402 634
3 4410 4404 634
3 4410 634 4411
3 5133 4411 6069
3 5132 5133 6069
3 5132 6069 637
3 6069 176 637
3 637 176 2098
3 5132 637 2096
3 2096 637 635
3 637 636 635
3 635 636 2097
3 2259 4106 2262
3 5134 5133 5132
3 4405 5133 5134
3 4664 4405 5134
3 357 4664 5134
3 513 4664 357
3 162 513 357
3 356 162 357
3 356 357 4101
3 175 356 4101
3 4072 175 4101
3 4072 4101 160
3 160 4101 165
3 165 4101 171
3 165 171 4074
3 2260 4074 2259
3 2399 2260 2259
3 2399 2259 2262
3 4107 4074 4868
3 4868 4074 2260
3 4073 165 4074
3 4107 4073 4074
3 2404 2399 2262
3 2404 2262 2400
3 2279 2311 2306
3 2275 2400 181
3 2275 181 2311
3 2274 2275 2311
3 2258 2274 2311
3 2258 2311 2299
3 2299 2311 2279
3 2396 2400 2275
3 2396 2404 2400
3 2299 2279 2301
3 386 2299 2301
3 386 2301 2303
3 4049 386 2303
3 4057 2302 4139
3 2289 4057 4139
3 4127 4057 2289
3 4046 4127 402
3 402 4127 384
3 384 4127 4130
3 4046 4057 4127
3 381 4131 395
3 395 4131 4379
3 4379 4131 378
3 381 4129 4131
3 402 384 4129
3 402 4129 381
3 4379 378 4059
3 393 4379 4059
3 393 4059 373
3 333 393 373
3 374 333 373
3 3491 386 4049
3 4140 3491 4049
3 2302 4140 4049
3 4138 4140 2302
3 4142 4138 2302
3 4057 4142 2302
3 4093 4182 4146
3 4146 4182 4085
3 4182 4078 4085
3 4100 4090 4182
3 4079 4100 4182
3 4093 4079 4182
3 4085 4078 3992
3 4087 4085 3992
3 4087 3992 3778
3 4087 3778 4183
3 4183 3778 4571
3 3778 4147 4571
3 4571 4147 5189
3 392 4380 4090
3 4395 392 4090
3 4088 4395 4090
3 4088 4090 4100
3 4380 374 4090
3 4380 333 374
3 5183 4571 5189
3 5183 5189 3991
3 5196 5183 3991
3 5196 3991 5190
3 5193 5190 5191
3 5191 5190 3944
3 5193 5196 5190
3 5205 6079 2126
3 5205 2126 5794
3 6080 6081 5794
3 2130 6080 5794
3 6081 5205 5794
3 3947 6080 2130
3 3947 2130 3761
3 3760 3947 3761
3 3947 3760 2127
3 2127 3760 5835
3 5835 3760 3762
3 3954 5835 5824
3 3954 5824 5825
3 3952 2127 5835
3 3954 3952 5835
3 3954 5825 3958
3 5804 3954 3958
3 5803 5804 3958
3 2131 5803 5802
3 2131 5804 5803
3 5802 5805 3722
3 5802 136 5805
3 3719 2131 5802
3 3719 5802 3720
3 3720 5802 3722
3 3722 5805 5806
3 3722 5806 139
3 139 5806 5808
3 5808 5806 5807
3 5808 5807 1297
3 1297 5807 5822
3 1297 5822 3960
3 3960 5822 5779
3 5722 3960 5779
3 5722 5779 3625
3 5779 5783 3625
3 127 5722 3625
3 5721 5722 127
3 3644 5721 127
3 3741 3644 127
3 3911 3741 127
3 125 3911 127
3 3721 125 127
3 1294 3721 127
3 1442 3721 1294
3 2818 2817 5096
3 2817 5604 5096
3 5096 5604 5644
3 5604 5148 5644
3 5148 5653 5949
3 5667 5653 5148
3 5644 5148 5654
3 5148 5949 5654
3 5653 5667 5656
3 5656 5149 5147
3 5149 411 5147
3 411 464 5147
3 5949 5653 5656
3 5949 5656 5668
3 5668 5656 5144
3 5656 5147 5144
3 5147 464 5146
3 464 466 5146
3 466 5659 5146
3 466 5609 5659
3 465 5609 466
3 465 4499 5609
3 465 5610 4499
3 5610 1603 4499
3 1603 4658 4499
3 4499 4658 5930
3 4658 4659 5930
3 4658 5952 4659
3 4658 5931 5952
3 5839 5630 5931
3 5952 5931 5160
3 5931 5845 5160
3 5931 5934 5845
3 5630 5934 5931
3 5630 5632 5934
3 5630 5631 5632
3 5670 5635 5631
3 5631 5161 5632
3 5631 5635 5161
3 5635 5629 5161
3 5161 5629 5162
3 5629 5628 5162
3 5628 1136 5627
3 5627 1136 1128
3 5628 5627 5162
3 5627 1128 1170
3 1170 1128 1130
3 1128 1137 1130
3 1130 1137 798
3 1137 695 798
3 798 695 796
3 798 796 1131
3 796 694 1131
3 796 467 694
3 190 467 796
3 189 190 796
3 190 189 191
3 189 428 191
3 189 427 428
3 427 693 215
3 422 693 427
3 427 215 428
3 422 4218 693
3 422 1177 4218
3 422 195 1177
3 1175 4219 4516
3 4515 1175 4516
3 1177 4219 1175
3 4218 1177 693
3 693 1177 4518
3 4518 1177 1175
3 4518 1175 4515
3 4518 4515 4243
3 4518 4243 5914
3 5914 4243 4519
3 5915 5914 4519
3 5916 5915 4519
3 5916 4519 459
3 1342 5916 459
3 1342 459 1344
3 459 1601 1344
3 1601 459 5882
3 1601 5882 1600
3 1344 1601 1600
3 1344 1600 5898
3 1600 419 5898
3 1344 5898 1588
3 1588 5898 1590
3 1590 5898 1576
3 4429 4534 4416
3 4534 4508 4416
3 4526 4536 4530
3 4526 4530 4531
3 4531 4530 4532
3 4531 4532 4527
3 4527 4532 4502
3 4532 4430 4502
3 4502 4430 4429
3 4502 4429 4422
3 4422 4429 4416
3 1577 1590 1576
3 1577 1576 1518
3 1518 1576 1455
3 1518 1455 1520
3 1518 1520 1347
3 1522 1518 1347
3 1522 1347 1511
3 1511 1347 1510
3 1510 1347 1575
3 1510 1575 1513
3 1513 1573 1571
3 1460 1510 1513
3 1460 1513 1461
3 1461 1513 1571
3 1571 1573 1570
3 1570 1573 1595
3 1570 1595 1572
3 1572 1595 1568
3 1595 1596 1568
3 1596 1595 5618
3 1595 4523 5618
3 1596 5618 5619
3 5618 4524 5619
3 5619 4524 4398
3 4398 4524 4525
3 4524 4016 4525
3 4524 4529 4016
3 4524 4500 4529
3 4500 4527 4529
3 4527 4501 4529
3 4527 4502 4501
3 4535 4508 4507
3 4535 4507 4421
3 4421 4507 4435
3 4507 4512 4435
3 4513 4512 4507
3 4416 4508 4535
3 4513 4545 4512
3 4545 4513 4427
3 4019 4267 4424
3 4428 4550 4019
3 4428 4019 4424
3 4427 4550 4428
3 4545 4427 4433
3 4433 4427 4426
3 4427 4428 4426
3 4426 4428 4424
3 4425 4426 4424
3 4425 4424 4012
3 180 4012 4029
3 180 4029 4020
3 4020 4029 179
3 179 4029 4026
3 4425 4012 180
3 869 933 754
3 869 937 933
3 937 931 933
3 931 930 933
3 929 930 931
3 928 929 931
3 917 1064 918
3 886 1064 917
3 766 886 917
3 927 766 917
3 917 918 764
3 927 775 766
3 927 526 775
3 888 526 927
3 888 966 526
3 888 527 966
3 889 527 888
3 889 880 527
3 889 879 880
3 879 878 880
3 870 878 879
3 870 884 878
3 877 884 870
3 871 877 870
3 871 1082 877
3 871 872 1082
3 528 872 871
3 528 529 872
3 875 529 528
3 873 936 875
3 873 934 936
3 936 876 875
3 875 876 529
3 892 781 155
3 892 922 781
3 922 905 781
3 922 776 905
3 922 919 776
3 922 925 919
3 762 925 922
3 763 968 762
3 762 968 925
3 763 923 968
3 763 765 923
3 764 765 763
3 764 921 765
3 764 918 921
3 934 861 936
3 934 862 861
3 933 862 934
3 754 933 934
3 736 851 850
3 736 229 851
3 4342 229 736
3 736 850 738
3 4342 223 229
3 223 220 229
3 220 223 218
3 223 129 218
3 129 223 4340
3 223 67 4340
3 222 67 223
3 928 868 929
3 928 865 868
3 865 867 868
3 865 852 867
3 738 852 865
3 738 850 737
3 738 849 852
3 738 737 849
3 222 5703 67
3 4325 1240 5703
3 4325 510 1240
3 67 5703 1241
3 5703 5699 1241
3 5703 1240 5699
3 510 491 5698
3 491 4488 5698
3 491 1239 4488
3 509 1239 491
3 217 509 491
3 486 217 491
3 486 502 217
3 486 501 502
3 1240 510 5697
3 510 5698 5697
3 4473 565 4486
3 565 4473 617
3 4473 604 617
3 601 604 4473
3 501 616 502
3 616 493 244
3 616 4491 493
3 4480 4491 616
3 4486 4480 616
3 502 616 4489
3 4489 616 244
3 565 4480 4486
3 604 601 4656
3 601 603 4656
3 601 5666 603
3 601 4496 5666
3 4311 4496 601
3 4496 4311 610
3 4311 5096 610
3 5096 5644 610
3 5119 3731 3907
3 4580 3731 5119
3 4580 3738 3731
3 5112 3904 5122
3 3904 3914 5122
3 3904 3714 3914
3 3894 3714 3904
3 3894 5121 3714
3 3894 3711 5121
3 5112 3732 3739
3 3732 5112 5122
3 4575 3710 3711
3 3711 3712 5121
3 3711 130 3712
3 3710 130 3711
3 4575 570 3710
3 1257 570 4575
3 570 1257 951
3 1257 4652 951
3 1257 1054 4652
3 1054 1038 4652
3 1054 1048 1038
3 1047 1048 1054
3 1045 1047 1054
3 1044 1045 1054
3 1044 1052 1045
3 1044 1967 1052
3 1037 1967 1044
3 1037 1044 1043
3 1037 5864 1967
3 1060 5864 1037
3 1058 1060 1037
3 1286 1057 1058
3 1040 1057 1286
3 1039 1040 1286
3 1055 1039 1286
3 1055 1069 1039
3 1283 1069 1055
3 1057 1060 1058
3 1283 1070 1069
3 1283 5863 1070
3 1281 5863 1283
3 1280 1281 1283
3 1280 910 1281
3 3738 3739 3731
3 3731 3739 3907
3 3739 3732 3907
3 910 1891 1281
3 1892 1891 910
3 1883 1893 1892
3 1287 1883 1892
3 1892 1893 1891
3 1911 1893 1883
3 1884 1911 1883
3 1884 6036 1911
3 6036 1886 1911
3 6037 1886 6036
3 1089 6037 6036
3 1817 1812 1089
3 1817 1089 1821
3 1821 1089 6040
3 1089 1896 6037
3 1089 1819 1896
3 1089 1818 1819
3 1812 1818 1089
3 912 1817 1821
3 912 1814 1817
3 1071 1814 912
3 1071 912 1072
3 963 1814 1071
3 972 963 1071
3 972 955 963
3 972 778 955
3 778 786 955
3 778 781 786
3 155 781 778
3 4595 3730 3908
3 3730 3717 3908
3 3730 5123 3717
3 3907 5123 3730
3 5122 5123 3907
3 3732 5122 3907
3 3515 125 3721
3 126 3741 3911
3 1291 126 3911
3 3901 1291 3911
3 1438 3901 3911
3 4589 1438 3911
3 3909 1291 3901
3 3898 1291 3909
3 4588 3898 3909
3 3898 3718 1291
3 4585 3908 3718
3 1291 3718 3720
3 3718 3719 3720
3 3718 138 3719
3 114 138 3718
3 3908 114 3718
3 3717 114 3908
3 5221 5222 5207
3 5209 5221 5207
3 5209 5207 3805
3 3805 5207 5793
3 3945 3944 3975
3 5194 3945 3975
3 5220 5217 5194
3 5217 3945 5194
3 5218 5217 5220
3 5214 5218 5220
3 5219 5214 5220
3 5219 5220 5222
3 5215 5219 5222
3 5215 5222 5221
3 3756 5204 5203
3 2136 3756 5203
3 2136 5203 5205
3 5205 5203 6079
3 5793 6098 5204
3 3754 5793 5204
3 3756 3754 5204
3 3805 5793 5210
3 5210 5793 3754
3 3945 5191 3944
3 4024 4023 4026
3 4024 4026 4025
3 4023 179 4026
3 4423 4015 4024
3 4418 4423 4024
3 4024 4015 4023
3 4414 4418 4415
3 4419 4423 4418
3 4417 4419 4418
3 4414 4417 4418
3 4401 4414 4415
3 4440 4414 4401
3 4408 4440 4401
3 4408 4401 4400
3 1581 4402 4404
3 4440 4408 4400
3 4397 4440 4400
3 4399 4397 4400
3 4399 4400 1581
3 4403 4399 1581
3 4403 1581 4404
3 5133 4410 4411
3 4407 4403 4404
3 4407 4404 4410
3 5612 4407 4410
3 5135 5612 4410
3 5135 4410 5133
3 4405 5135 5133
3 5907 5135 4405
3 5611 5907 4405
3 4664 5611 4405
3 639 5611 4664
3 513 639 4664
3 4108 838 513
3 4108 513 164
3 164 513 162
3 513 838 639
3 161 164 162
3 161 162 167
3 162 356 167
3 167 356 175
3 167 175 4072
3 168 167 4072
3 168 4072 4073
3 4073 4072 165
3 4072 160 165
3 4867 4868 2260
3 4867 2260 2399
3 4867 2399 2404
3 4869 4868 4870
3 4870 4868 2404
3 4868 4867 2404
3 4869 4107 4868
3 4073 4107 4869
3 4069 4109 4073
3 4069 4073 4869
3 4070 168 4073
3 4109 4070 4073
3 2403 4870 2404
3 2403 2404 2396
3 2397 2396 2275
3 2397 2275 2274
3 2258 2397 2274
3 2300 2258 2299
3 2397 2258 2300
3 4048 2300 2299
3 4048 2299 386
3 170 2403 2396
3 4038 170 2396
3 4038 2396 2397
3 3491 4048 386
3 4046 4142 4057
3 4391 402 381
3 4386 4046 402
3 4390 4386 402
3 4390 402 4391
3 4041 4142 4046
3 4045 4041 4046
3 4386 4045 4046
3 381 395 5097
3 5097 395 336
3 336 395 393
3 395 4379 393
3 404 4391 381
3 404 381 396
3 396 381 5097
3 370 336 393
3 375 370 393
3 375 393 333
3 4380 375 333
3 4140 4048 3491
3 4041 4047 4140
3 4041 4140 4138
3 4140 390 4048
3 4047 390 4140
3 4142 4041 4138
3 4146 4085 4087
3 4145 4093 4146
3 4084 4145 4146
3 4084 4146 4149
3 4149 4146 2116
3 4146 4087 2116
3 4145 4079 4093
3 4094 4088 4100
3 4094 4100 4079
3 4094 4079 4145
3 2116 4087 4183
3 2116 4183 4571
3 4148 4571 5216
3 5216 4571 5193
3 4571 5196 5193
3 4571 5183 5196
3 4148 2116 4571
3 369 375 4380
3 392 369 4380
3 4392 369 392
3 368 4392 392
3 368 392 4395
3 368 4395 4088
3 367 368 4088
3 4099 367 4088
3 4099 4088 4094
3 5199 5191 3945
3 5199 5193 5191
3 5211 5216 5193
3 5211 5193 5199
3 3759 2136 5205
3 3759 5205 6081
3 6080 3759 6081
3 5829 5834 6080
3 5829 6080 3947
3 5206 3759 6080
3 5834 5206 6080
3 5817 3947 2127
3 5829 3947 5817
3 3948 5817 2127
3 3949 3948 2127
3 3949 2127 3952
3 5816 3952 3954
3 2132 5816 3954
3 2132 3954 5804
3 3950 3949 3952
3 5816 3950 3952
3 138 2132 5804
3 138 5804 2131
3 138 2131 3719
3 3720 3722 126
3 3722 3912 126
3 3912 3722 139
3 1291 3720 126
3 3912 139 126
3 126 139 3741
3 3741 139 140
3 139 5808 140
3 140 5808 1297
3 140 1297 3643
3 3643 1297 3960
3 3643 3960 5722
3 5721 3643 5722
3 3644 3643 5721
3 3644 140 3643
3 3741 140 3644
3 5644 5654 5605
3 5644 5605 610
3 5654 5949 5668
3 5654 5668 5605
3 5147 5146 5144
3 5605 5668 5662
3 5668 5645 5662
3 5668 5655 5645
3 5655 5668 5144
3 5655 5144 5642
3 5642 5144 5647
3 5144 5145 5647
3 5144 5657 5145
3 5144 5146 5657
3 5146 5659 5669
3 5146 5669 5657
3 5659 5930 5669
3 5659 4499 5930
3 5609 4499 5659
3 5930 5841 5658
3 5930 4659 5841
3 5669 5930 5658
3 5841 4659 5151
3 4659 1157 5151
3 4659 5952 1157
3 5952 5160 1157
3 5160 5924 5928
3 5845 5924 5160
3 1157 5160 5928
3 5934 5632 5845
3 5845 5843 5924
3 5845 5935 5843
3 5632 5935 5845
3 5632 5161 5935
3 5935 5161 5633
3 5161 5162 5633
3 5633 5162 5942
3 5162 1169 5942
3 5627 1169 5162
3 5627 1170 1169
3 1169 1170 5940
3 5940 1170 5941
3 1170 1138 5941
3 1170 1130 1138
3 1130 798 1138
3 1138 798 1131
3 1138 1131 1139
3 1139 1131 425
3 1131 431 425
3 1131 1345 431
3 1131 694 1345
3 694 406 1345
3 694 405 406
3 467 405 694
3 467 190 405
3 405 190 1342
3 190 191 1342
3 191 5916 1342
3 191 428 5916
3 428 5915 5916
3 428 215 5915
3 215 4518 5914
3 693 4518 215
3 215 5914 5915
3 405 1342 406
3 406 1342 1344
3 406 1344 5899
3 5899 1344 5900
3 1344 421 5900
3 1344 1588 421
3 421 1588 1578
3 1578 1588 1590
3 1578 1590 1577
3 4422 4416 4509
3 4416 4535 4509
3 4501 4502 4503
3 4502 4422 4503
3 4503 4422 4396
3 4422 4509 4396
3 1578 1577 1518
3 421 1578 1518
3 5900 421 1518
3 5900 1518 1521
3 1521 1518 1589
3 1589 1518 1522
3 5897 1522 1511
3 1523 1589 1522
3 1523 1522 5897
3 5897 1511 1512
3 1512 1511 1510
3 1512 1510 1524
3 1524 1510 1460
3 1481 1461 1571
3 1481 1571 1514
3 1514 1571 1585
3 1571 1583 1585
3 1571 1570 1583
3 1460 1461 5896
3 1524 1460 5895
3 5895 1460 5896
3 5896 1461 1481
3 1583 1570 1572
3 1586 1572 1587
3 1587 1572 1569
3 1572 1568 1569
3 1583 1572 1586
3 1569 1568 1594
3 1594 1568 5910
3 1568 1596 5910
3 5910 1596 1597
3 1596 5619 1597
3 1597 5619 5613
3 5613 5619 4398
3 5614 5613 4398
3 5614 4398 5615
3 5615 4398 4397
3 4398 4525 4397
3 4525 4017 4397
3 4525 4016 4017
3 4017 4016 4413
3 4016 4412 4413
3 4529 4412 4016
3 4529 4501 4412
3 4412 4501 4503
3 4509 4535 4421
3 4509 4421 4434
3 4421 4435 4434
3 4435 6107 4438
3 4512 6107 4435
3 4435 4438 4434
3 4512 4545 6107
3 4545 4433 6107
3 6107 4433 4439
3 4439 4433 4426
3 4439 4426 4438
3 4438 4426 4437
3 4437 4426 4425
3 4437 4425 4014
3 4014 4425 180
3 4014 180 4013
3 4013 180 4020
3 4023 4020 179
3 4013 4020 4015
3 4015 4020 4023
3 933 930 862
3 930 932 862
3 930 868 932
3 929 868 930
3 918 1064 921
3 921 1064 920
3 1064 758 920
3 775 758 1064
3 766 775 1064
3 886 766 1064
3 775 757 758
3 966 757 775
3 526 966 775
3 880 757 966
3 527 880 966
3 880 885 757
3 878 885 880
3 878 884 885
3 885 884 1864
3 884 1863 1864
3 884 1081 1863
3 1082 1081 884
3 877 1082 884
3 529 1081 1082
3 872 529 1082
3 529 1063 1081
3 529 891 1063
3 876 891 529
3 936 1062 876
3 935 1062 936
3 861 935 936
3 876 967 891
3 876 1062 967
3 781 954 786
3 781 905 954
3 905 969 971
3 776 969 905
3 905 971 954
3 776 1066 969
3 919 1066 776
3 919 925 1066
3 925 926 1066
3 925 920 926
3 923 920 925
3 968 923 925
3 921 920 923
3 765 921 923
3 861 1062 935
3 861 862 1062
3 862 751 1062
3 932 751 862
3 850 1777 737
3 1777 850 1261
3 850 2140 1261
3 850 1244 2140
3 851 1244 850
3 735 1244 851
3 229 735 851
3 229 219 735
3 229 4341 219
3 229 220 4341
3 4341 220 734
3 220 218 734
3 218 733 734
3 4340 733 218
3 129 4340 218
3 4340 67 5701
3 4340 5701 733
3 67 1241 5701
3 868 752 932
3 868 848 752
3 867 848 868
3 867 302 848
3 852 302 867
3 852 849 302
3 849 737 1780
3 737 6015 1780
3 1261 6015 737
3 1777 1261 737
3 849 1780 854
3 302 849 848
3 849 854 848
3 1240 5697 5699
3 5701 1241 1750
3 1241 5700 1750
3 1241 5699 5700
3 5699 5697 1249
3 5700 5699 1249
3 5697 5698 1249
3 5698 492 1249
3 5698 4488 492
3 4488 508 492
3 4488 1120 508
3 1239 1120 4488
3 1239 509 1120
3 509 4487 1121
3 509 4479 4487
3 217 4479 509
3 1120 509 1121
3 217 502 4479
3 502 4489 497
3 4479 502 497
3 4480 565 4491
3 565 4649 4491
3 565 617 4649
3 617 1194 1187
3 604 1194 617
3 4649 617 493
3 493 617 1187
3 604 4656 1194
3 4489 244 497
3 497 244 4651
3 244 4650 4651
3 244 493 4650
3 493 1187 4650
3 4491 4649 493
3 4656 598 1194
3 598 4656 599
3 4656 614 599
3 4656 603 614
3 603 5666 614
3 614 5666 602
3 602 5666 613
3 5666 5663 613
3 5666 4495 5663
3 4496 4495 5666
3 4496 610 4495
3 4495 610 5663
3 610 5662 5663
3 610 5605 5662
3 3914 4578 5122
3 5122 3913 5123
3 4578 3913 5122
3 3914 3913 4578
3 3914 3740 3913
3 3914 3714 3740
3 3714 3712 3740
3 5121 3712 3714
3 951 130 3710
3 570 951 3710
3 3712 3715 3740
3 3712 3713 3715
3 3712 132 3713
3 3723 132 3712
3 130 3723 3712
3 130 3724 3723
3 4652 3724 130
3 951 4652 130
3 4652 4361 3724
3 574 4361 4652
3 1038 574 4652
3 1049 574 1038
3 1048 1049 1038
3 1042 1048 1047
3 1048 1051 1049
3 2088 1051 1048
3 1966 2088 1048
3 1042 1966 1048
3 1045 1042 1047
3 6026 1042 1045
3 1052 6026 1045
3 1965 2012 1052
3 1967 1965 1052
3 2012 6026 1052
3 5864 1965 1967
3 5864 1061 1965
3 1060 1061 5864
3 1059 1061 1060
3 1057 1059 1060
3 1040 1964 1057
3 1057 1964 1059
3 1428 1964 1040
3 1285 1428 1040
3 1039 1285 1040
3 1427 1285 1039
3 1069 1427 1039
3 1070 1427 1069
3 1426 1427 1070
3 5863 1426 1070
3 1281 1407 5863
3 5863 1833 1426
3 1407 1833 5863
3 1891 1407 1281
3 1891 1889 1407
3 1893 1889 1891
3 1893 1911 6035
3 1893 6035 1889
3 1911 1886 6035
3 1886 1820 6035
3 1886 6037 1820
3 6037 6031 1820
3 6037 6033 6031
3 1899 6033 6037
3 1896 1899 6037
3 1813 1818 1812
3 1814 1813 1812
3 1814 1812 1817
3 1896 1885 1899
3 1896 1882 1885
3 1896 1819 1882
3 1819 1895 1894
3 1879 1895 1819
3 1818 1879 1819
3 1819 1894 1882
3 1818 1815 1879
3 1813 1815 1818
3 1814 1878 1813
3 5592 1878 1814
3 955 5592 1814
3 963 955 1814
3 955 787 5592
3 786 787 955
3 954 986 786
3 786 788 787
3 786 986 788
3 5123 3913 3717
3 3717 3913 114
3 5816 2132 138
3 3716 5816 138
3 114 3716 138
3 3913 3716 114
3 5209 5215 5221
3 5213 5215 5209
3 5202 5213 5209
3 5202 5209 5176
3 5176 5209 3805
3 5201 3805 5210
3 5176 3805 5201
3 5217 5199 3945
3 5218 5199 5217
3 5214 5199 5218
3 3946 5199 5214
3 3946 5214 5219
3 3943 3946 5219
3 3938 3943 5219
3 3938 5219 5177
3 5177 5219 5213
3 5213 5219 5215
3 3757 3806 3756
3 3757 3756 2136
3 3806 3754 3756
3 3758 3757 2136
3 3758 2136 3759
3 3806 5210 3754
3 5201 5210 3806
3 4432 4014 4015
3 4431 4432 4015
3 4423 4431 4015
3 4014 4013 4015
3 4419 4431 4423
3 4414 4022 4417
3 4440 4022 4414
3 4434 4432 4419
3 4396 4434 4419
3 4396 4419 4417
3 4419 4432 4431
3 4413 4396 4417
3 4017 4413 4417
3 4022 4017 4417
3 4397 4022 4440
3 5615 4397 1493
3 1493 4397 4399
3 4397 4017 4022
3 1493 4399 4403
3 4406 1493 4403
3 4406 4403 4407
3 4406 4407 5612
3 1582 4406 5612
3 5907 1582 5612
3 5907 5612 5135
3 1579 1582 5907
3 5611 1579 5907
3 1558 1561 5611
3 1365 1558 5611
3 1333 1365 5611
3 1333 5611 639
3 1561 1579 5611
3 4663 1333 639
3 838 4663 639
3 5911 1397 838
3 355 5911 838
3 355 838 4108
3 838 1397 4663
3 4110 355 4108
3 4110 4108 16
3 16 4108 159
3 159 4108 164
3 159 164 161
3 168 161 167
3 166 159 161
3 166 161 4070
3 4070 161 168
3 2398 4869 4870
3 2398 4870 2403
3 4033 4069 4869
3 2398 4033 4869
3 2402 4070 4109
3 2402 4109 4112
3 4112 4109 4069
3 4033 4112 4069
3 4071 166 4070
3 4071 4070 2402
3 170 2398 2403
3 4043 2397 2300
3 4040 4038 2397
3 4043 4040 2397
3 390 4043 2300
3 390 2300 4048
3 4068 170 4067
3 4067 170 4038
3 4068 2398 170
3 391 4067 4038
3 391 4038 4040
3 4388 4390 4391
3 4388 4391 4446
3 4446 4391 404
3 4444 4386 4390
3 387 4045 4386
3 341 387 4386
3 552 341 4386
3 552 4386 4444
3 4444 4390 4388
3 4044 4047 4041
3 4121 4044 4041
3 4045 4121 4041
3 387 4121 4045
3 5140 396 5097
3 5140 5097 394
3 5097 336 394
3 394 336 370
3 403 404 396
3 4446 404 403
3 403 396 5140
3 375 394 370
3 371 394 375
3 369 371 375
3 4137 4123 4047
3 4044 4137 4047
3 4047 2298 390
3 4123 2298 4047
3 2298 4043 390
3 364 4094 4145
3 4150 364 4145
3 4151 4150 4145
3 4151 4145 4084
3 4153 4084 4149
3 4153 4151 4084
3 4152 4149 4077
3 4077 4149 2116
3 4152 4153 4149
3 4077 2116 4148
3 364 4099 4094
3 5212 5216 5211
3 5195 4148 5216
3 5195 5216 5212
3 4077 4148 5195
3 4392 371 369
3 366 4392 368
3 4392 394 371
3 4392 332 394
3 328 332 4392
3 366 328 4392
3 367 366 368
3 4099 366 367
3 256 366 4099
3 257 256 4099
3 365 257 4099
3 364 365 4099
3 5192 5211 5199
3 5212 5192 5199
3 5197 5212 5199
3 5185 5197 5199
3 3748 5185 5199
3 3748 5199 3946
3 5212 5211 5192
3 5828 5810 3759
3 5206 5828 3759
3 5810 3758 3759
3 5828 5206 5834
3 5823 5828 5834
3 5823 5834 3948
3 3948 5834 5829
3 3948 5829 5817
3 3753 5823 3948
3 5811 3753 3948
3 3936 5811 3948
3 5801 3936 3948
3 5801 3948 3949
3 3950 5801 3949
3 3716 3950 5816
3 3715 5801 3950
3 3715 3950 3716
3 5662 5664 5663
3 5662 5645 5664
3 5664 5645 5646
3 5645 5642 5646
3 5645 5655 5642
3 5642 5647 5646
3 5647 1607 5665
3 5647 5145 1607
3 5646 5647 5665
3 1607 5145 5660
3 5145 5657 5660
3 5657 5648 5660
3 5669 5648 5657
3 5648 5669 5622
3 5669 5658 5622
3 5658 5841 5622
3 5622 5841 5950
3 5841 5152 5950
3 5841 5150 5152
3 5841 5151 5150
3 5151 1150 1160
3 5151 1157 1150
3 5150 5151 5837
3 5837 5151 1160
3 1157 5928 1150
3 5928 5937 5938
3 5924 5937 5928
3 5928 5938 1150
3 5924 5843 5937
3 5633 5942 5843
3 5935 5633 5843
3 5843 5936 5937
3 5843 5942 5936
3 5942 1169 5953
3 5936 5942 5929
3 5942 5844 5929
3 5844 5942 5922
3 5942 5953 5922
3 1169 1602 5953
3 1169 5940 1602
3 1602 5940 5939
3 5940 5941 5939
3 5939 5941 1163
3 5941 1138 1163
3 1138 1140 1163
3 1140 1138 1139
3 1140 1139 698
3 698 1139 699
3 1139 458 699
3 458 1139 425
3 458 425 424
3 425 423 424
3 425 431 423
3 431 1345 423
3 1345 5899 423
3 1345 406 5899
3 423 5899 5900
3 424 423 5900
3 1459 424 5900
3 1459 5900 1521
3 4396 4509 4434
3 4412 4503 4413
3 4503 4396 4413
3 1459 1521 457
3 457 1521 1517
3 1521 1589 1517
3 1517 1589 1519
3 1519 1589 1523
3 1519 1523 5897
3 1515 1519 5897
3 1515 5897 1512
3 1515 1512 1526
3 1512 1524 1526
3 1526 1524 5895
3 1501 5896 1481
3 1482 1501 1481
3 1482 1481 1514
3 1482 1514 1504
3 1504 1514 1505
3 1505 1514 1585
3 1505 1585 1584
3 1584 1585 1586
3 1585 1583 1586
3 5895 5896 1501
3 1526 5895 1482
3 5895 1501 1482
3 1586 1587 1569
3 1584 1586 1567
3 1567 1586 1569
3 1567 1569 5901
3 5901 1569 1508
3 1508 1569 1507
3 1507 1569 5910
3 1569 1594 5910
3 5910 1597 5613
3 1507 5910 1565
3 1565 5910 5675
3 5675 5910 5909
3 5910 5613 5909
3 5613 5614 5909
3 5909 5614 5615
3 1593 5909 5615
3 1593 5615 5674
3 5674 5615 1493
3 4434 4438 4436
3 4434 4436 4432
3 6107 4439 4438
3 4438 4437 4436
3 4436 4437 4432
3 4437 4014 4432
3 932 752 753
3 932 857 751
3 932 753 857
3 920 2091 1849
3 1856 2091 920
3 758 1856 920
3 920 1849 926
3 758 757 1856
3 757 1859 1862
3 1866 1859 757
3 885 1866 757
3 757 1862 1856
3 885 1864 1866
3 1866 1864 1859
3 1864 1863 1859
3 1063 1865 1863
3 1081 1063 1863
3 1863 1083 1859
3 1863 1865 1083
3 1063 2093 1865
3 1063 1840 2093
3 1273 1840 1063
3 891 1273 1063
3 891 1102 1273
3 891 967 1102
3 1062 859 967
3 860 859 1062
3 751 860 1062
3 967 1094 1102
3 967 569 1094
3 859 569 967
3 954 971 986
3 971 970 986
3 969 970 971
3 969 1067 970
3 897 1067 969
3 1066 897 969
3 1066 926 897
3 926 1849 898
3 926 898 897
3 751 857 860
3 2140 1279 1261
3 1261 1279 6015
3 2140 863 1279
3 1244 863 2140
3 1244 846 863
3 735 846 1244
3 735 853 846
3 219 853 735
3 219 4341 853
3 4341 734 853
3 734 1750 853
3 734 733 1750
3 733 5701 1750
3 752 855 753
3 1259 855 752
3 848 1259 752
3 854 1278 848
3 848 1278 1259
3 1780 6017 6018
3 1780 6016 6017
3 6015 6016 1780
3 854 1780 1278
3 1278 1780 1783
3 1780 1781 1783
3 1780 6018 1781
3 6015 1279 6016
3 853 1750 1770
3 1750 5858 1770
3 1750 1771 5858
3 1750 1243 1771
3 1750 5700 1243
3 5700 5695 1243
3 5700 1249 5695
3 1249 6001 5695
3 492 6001 1249
3 508 1238 492
3 492 1238 6001
3 508 1225 1238
3 508 1121 1225
3 1120 1121 508
3 1121 4490 1225
3 1121 4487 4490
3 4487 485 4490
3 4487 497 485
3 4479 497 4487
3 497 4651 1234
3 497 1234 485
3 1187 496 4650
3 496 1187 499
3 1187 1413 499
3 1187 1193 1413
3 1192 1193 1187
3 1194 1192 1187
3 1194 598 1192
3 1234 4651 503
3 4651 487 503
3 4651 4650 487
3 4650 1188 487
3 4650 494 1188
3 4650 496 494
3 598 599 1192
3 1192 599 5677
3 5677 599 5683
3 5683 599 619
3 599 620 619
3 599 611 620
3 602 611 599
3 614 602 599
3 611 602 613
3 5663 1171 613
3 611 613 620
3 613 612 620
3 612 613 4657
3 4657 613 600
3 613 596 600
3 613 1171 596
3 5663 5664 1171
3 3913 3715 3716
3 3740 3715 3913
3 3715 3936 5801
3 3713 3936 3715
3 3713 132 3936
3 132 3934 3935
3 3723 3934 132
3 132 3935 3936
3 3933 3934 3723
3 3724 3933 3723
3 3724 3931 3933
3 4361 3931 3724
3 4361 4462 3931
3 3929 4462 4361
3 574 3929 4361
3 1049 1036 574
3 783 3929 574
3 1036 783 574
3 1050 1036 1049
3 1051 1050 1049
3 6054 1966 1042
3 6026 6054 1042
3 2088 1050 1051
3 6054 1836 2088
3 6054 2088 1966
3 1836 1050 2088
3 2089 6054 6026
3 2012 2089 6026
3 6053 2089 2012
3 2013 6053 2012
3 1965 2013 2012
3 1061 2013 1965
3 1061 1834 2013
3 2011 1834 1061
3 1963 2011 1061
3 1059 1963 1061
3 1964 1963 1059
3 1425 1963 1964
3 1284 1425 1964
3 1284 1964 1428
3 1426 1284 1428
3 1427 1426 1428
3 1285 1427 1428
3 1426 895 1284
3 1833 895 1426
3 1407 6046 1833
3 1889 6046 1407
3 1833 1405 895
3 6046 1405 1833
3 6035 1890 1889
3 1889 1890 6046
3 6035 1832 1890
3 1820 1832 6035
3 6031 6034 1820
3 1820 1900 1832
3 1820 6034 1900
3 6031 2086 6034
3 6032 2086 6031
3 6033 6032 6031
3 1899 6032 6033
3 1899 1885 6032
3 1878 1815 1813
3 6032 1885 2086
3 1885 1882 2086
3 1882 1894 2086
3 1894 2053 2086
3 1895 2053 1894
3 1879 1408 1895
3 1895 1408 2053
3 1879 1877 1408
3 1815 1877 1879
3 1880 6041 1815
3 1878 1880 1815
3 1815 6041 1877
3 5592 1880 1878
3 787 1880 5592
3 787 788 1880
3 970 1068 986
3 788 986 893
3 986 1068 893
3 788 893 1880
3 5177 5213 5202
3 2139 5177 5202
3 2139 5202 5814
3 5814 5202 5176
3 5814 5176 5812
3 5812 5176 5201
3 5812 5201 5815
3 5815 5201 2135
3 2135 5201 3806
3 3943 3748 3946
3 3742 3748 3943
3 3747 3742 3943
3 3938 3747 3943
3 3743 3747 3938
3 3937 3743 3938
3 3937 3938 5177
3 3824 3937 5177
3 3824 5177 2139
3 2135 3806 3757
3 2135 3757 3807
3 3807 3757 3758
3 5810 3807 3758
3 5674 1493 1598
3 1598 1493 4406
3 5676 4406 1582
3 5676 1598 4406
3 1580 5676 1582
3 1125 1580 1582
3 1125 1582 1579
3 1561 1125 1579
3 1558 1494 1561
3 1561 5906 1125
3 1494 5906 1561
3 1492 1494 1558
3 1365 1492 1558
3 645 1492 1365
3 1366 645 1365
3 1333 1366 1365
3 4663 1397 1333
3 1364 1366 1333
3 1397 1364 1333
3 1395 1364 1397
3 1367 1395 1397
3 5912 1367 1397
3 5911 5912 1397
3 355 5912 5911
3 842 355 837
3 837 355 4110
3 839 5912 355
3 839 355 842
3 4110 16 339
3 837 4110 339
3 339 16 4071
3 16 159 4071
3 159 166 4071
3 4115 4033 2398
3 4115 2398 4068
3 4032 4112 4033
3 4083 4032 4033
3 4083 4033 4113
3 4113 4033 4115
3 169 2402 4032
3 4032 2402 4112
3 169 4071 2402
3 339 4071 169
3 4123 4126 4043
3 4123 4043 2298
3 4126 4040 4043
3 4126 391 4040
3 391 4068 4067
3 4115 4068 391
3 4042 391 4126
3 4118 4115 391
3 4042 4118 391
3 385 4388 4451
3 4451 4388 4445
3 4445 4388 4446
3 385 4444 4388
3 4445 4446 403
3 4443 4444 385
3 334 552 4444
3 4443 334 4444
3 4560 401 387
3 388 4560 387
3 388 387 341
3 401 4121 387
3 4394 388 341
3 4394 341 552
3 554 552 334
3 554 4394 552
3 4125 4137 4044
3 401 4125 4044
3 4121 401 4044
3 4449 403 5140
3 1031 4449 5140
3 1031 5140 327
3 327 5140 394
3 332 327 394
3 4449 4445 403
3 4123 4042 4126
3 4039 4042 4123
3 4122 4039 4123
3 4122 4123 4137
3 4125 4122 4137
3 253 365 364
3 4150 253 364
3 358 4150 4155
3 4155 4150 4151
3 358 253 4150
3 4155 4151 305
3 305 4151 4153
3 305 4153 4152
3 4154 4152 4077
3 4154 4077 131
3 131 4077 5195
3 4160 4152 4154
3 4158 305 4152
3 4158 4152 4160
3 131 5195 5212
3 3940 131 5212
3 5197 3940 5212
3 366 326 328
3 256 326 366
3 324 327 332
3 316 324 332
3 325 316 332
3 325 332 328
3 326 325 328
3 256 363 326
3 363 256 365
3 365 256 257
3 361 363 365
3 317 361 365
3 360 317 365
3 252 360 365
3 253 252 365
3 3941 3940 5197
3 3941 5197 5185
3 3820 3941 5185
3 3939 3820 5185
3 3939 5185 3742
3 3742 5185 3748
3 5823 5810 5828
3 2135 3807 5810
3 5820 2135 5810
3 5809 5820 5810
3 3753 5809 5810
3 3753 5810 5823
3 5818 5809 3753
3 3755 5818 3753
3 3755 3753 5811
3 3935 3755 5811
3 3936 3935 5811
3 1171 5664 600
3 5664 608 600
3 5664 5646 608
3 5646 609 608
3 5646 5665 609
3 609 5665 5651
3 5665 1607 5651
3 1607 5660 5651
3 5660 1610 5649
3 5660 5622 1610
3 5648 5622 5660
3 5651 5660 5649
3 5622 5950 1610
3 5950 5152 5955
3 1610 5950 1613
3 5950 5955 1613
3 5152 1159 5955
3 1159 5152 1172
3 5152 1158 1172
3 5152 5150 1158
3 5150 5837 1158
3 1150 5932 1160
3 5837 1160 5840
3 1160 5933 5840
3 1160 5932 5933
3 1150 5938 5932
3 1158 5837 1611
3 1611 5837 5838
3 5837 5840 5838
3 5932 5938 5927
3 5938 5925 5927
3 5937 5925 5938
3 5937 5936 5925
3 5936 5929 5925
3 5953 1602 5922
3 5929 5923 5925
3 5929 5844 5923
3 5844 5922 5923
3 5923 5922 5842
3 5922 1166 5842
3 5922 5939 1166
3 1602 5939 5922
3 1166 5939 1163
3 1166 1163 5842
3 5842 1163 1145
3 1163 1143 1145
3 1163 426 1143
3 1163 1140 426
3 426 1140 1141
3 1140 698 1141
3 1141 698 433
3 698 699 433
3 699 429 1459
3 458 429 699
3 433 699 1480
3 699 1459 1480
3 429 458 424
3 429 424 1459
3 1480 1459 457
3 1480 457 456
3 456 457 460
3 460 457 1517
3 460 1517 1509
3 1517 1519 1509
3 1509 1519 1515
3 1483 1515 1525
3 1525 1515 1526
3 1509 1515 1483
3 1526 1482 1557
3 1478 1525 1526
3 439 1478 1526
3 1477 439 1526
3 1477 1526 1479
3 1479 1526 1557
3 1557 1482 1500
3 1482 1504 1500
3 1504 1505 1500
3 1500 1505 1499
3 1499 1505 1584
3 1499 1584 1475
3 1475 1584 1567
3 1475 1567 5902
3 5902 1567 1502
3 1567 5901 1502
3 5901 1508 1502
3 1508 1507 1502
3 1502 1507 1565
3 1565 5675 638
3 640 1502 1565
3 640 1565 638
3 5675 5909 1593
3 638 5675 1566
3 1566 5675 1593
3 1563 1566 1593
3 1563 1593 1599
3 1599 1593 5674
3 1599 5674 1598
3 753 1807 1806
3 855 1807 753
3 857 753 768
3 753 1794 768
3 753 1806 1794
3 857 768 860
3 1849 2091 1850
3 1849 1850 898
3 2091 2092 1850
3 1856 2092 2091
3 1856 1855 2092
3 1862 1855 1856
3 1862 1859 1855
3 1859 1083 1855
3 1083 1865 6068
3 1865 2093 6068
3 1083 6068 1855
3 2093 1845 6068
3 2093 1860 1845
3 1840 1860 2093
3 1840 1861 1860
3 1840 1805 1861
3 1273 1805 1840
3 1273 1102 1805
3 1095 1828 1102
3 1094 1095 1102
3 1102 1828 1805
3 859 860 569
3 860 768 569
3 569 1095 1094
3 1794 769 569
3 768 1794 569
3 569 858 1095
3 569 769 858
3 970 1914 1809
3 970 1067 1914
3 1068 970 1809
3 1067 1841 1914
3 897 1841 1067
3 897 898 1841
3 1841 898 6045
3 898 1065 6045
3 898 1850 1065
3 1279 1260 1779
3 863 1260 1279
3 1279 1779 6016
3 863 846 1260
3 846 1245 847
3 846 230 1245
3 853 230 846
3 1260 846 847
3 853 1770 230
3 855 6023 1807
3 1782 6023 855
3 1783 1782 855
3 1259 1783 855
3 1278 1783 1259
3 6018 1096 6019
3 6018 6017 1096
3 1781 6018 856
3 6018 6019 856
3 6017 1778 1096
3 1779 1778 6017
3 6016 1779 6017
3 1781 856 1783
3 1783 1808 1782
3 1783 856 1808
3 230 1770 1245
3 1245 1770 1745
3 1770 5702 1745
3 1770 5858 5702
3 5858 6012 5859
3 6012 5858 6013
3 5858 1771 6013
3 5702 5858 5859
3 1771 1748 6011
3 1771 1243 1748
3 1771 1246 6013
3 1246 1771 6011
3 6000 1243 1119
3 1243 5695 1119
3 1748 1243 1749
3 1749 1243 1229
3 1243 6000 1229
3 5695 6001 1230
3 1119 5695 1230
3 1230 6001 242
3 6001 1237 242
3 6001 1238 1237
3 1238 1225 1237
3 1225 1236 1237
3 1225 506 1236
3 1225 4490 506
3 506 4490 1235
3 1235 4490 507
3 4490 485 507
3 485 1115 507
3 485 1234 1115
3 1115 1234 503
3 496 499 494
3 499 1413 495
3 494 499 495
3 1413 1186 4355
3 1186 1413 1412
3 1413 1192 1412
3 1193 1192 1413
3 495 1413 4354
3 1413 4355 4354
3 1192 1186 1412
3 1192 5677 1186
3 1115 503 1233
3 1233 503 4467
3 503 504 4467
3 503 505 504
3 503 487 505
3 487 232 505
3 487 243 232
3 1188 243 487
3 1188 495 243
3 494 495 1188
3 5677 5683 1186
3 5683 619 5684
3 1186 5683 5684
3 619 5678 5684
3 619 620 5678
3 620 5603 618
3 620 4657 5603
3 620 612 4657
3 5678 620 618
3 596 1171 600
3 5603 4657 621
3 4657 600 621
3 600 5643 621
3 600 608 5643
3 3934 3755 3935
3 3934 3932 3755
3 3751 3932 3934
3 3933 3751 3934
3 3931 3751 3933
3 3931 3749 3750
3 4462 3749 3931
3 3751 3931 3752
3 3931 3750 3752
3 3929 4461 4462
3 4462 4356 3749
3 4461 4356 4462
3 783 265 3929
3 3927 4461 3929
3 782 3927 3929
3 265 782 3929
3 1050 982 1036
3 982 783 1036
3 984 265 783
3 983 984 783
3 982 983 783
3 1836 982 1050
3 1960 1836 6054
3 2001 1960 6054
3 1041 2001 6054
3 2089 1041 6054
3 1836 896 982
3 2000 896 1836
3 1960 2000 1836
3 2089 6050 1041
3 6053 6050 2089
3 2009 6050 6053
3 2009 6053 2013
3 2007 2009 2013
3 1834 2007 2013
3 2011 2007 1834
3 1425 2008 2011
3 1425 2011 1963
3 2008 2007 2011
3 1881 2008 1425
3 1881 1425 1284
3 895 1902 1284
3 1902 1881 1284
3 1405 1902 895
3 1890 1903 6046
3 6046 1903 1405
3 1405 1903 1874
3 1405 1874 1902
3 1890 1873 1903
3 1888 1873 1890
3 1832 1888 1890
3 1832 1900 1888
3 6034 1887 1900
3 2086 1887 6034
3 1888 1900 1873
3 1900 2087 1873
3 1887 2087 1900
3 2086 1897 1887
3 2053 1897 2086
3 2053 6057 1897
3 2053 2054 6057
3 6064 2054 2053
3 2057 6064 2053
3 1408 2057 2053
3 1408 1406 2057
3 1877 1406 1408
3 1877 6030 1406
3 6041 6030 1877
3 6041 1810 6030
3 894 1810 6041
3 1880 894 6041
3 893 894 1880
3 1068 6029 893
3 6029 1068 1809
3 893 6029 894
3 3750 2139 5814
3 3750 3824 2139
3 3750 5814 3752
3 3752 5814 5812
3 3752 5812 5815
3 5819 3752 5815
3 5819 5815 5820
3 5820 5815 2135
3 3939 3742 3747
3 3743 3939 3747
3 3823 3939 3743
3 3744 3823 3743
3 3925 3744 3743
3 3925 3743 4356
3 4356 3743 3824
3 3743 3937 3824
3 4356 3824 3750
3 1503 1599 1598
3 1495 1503 1598
3 1559 1495 1598
3 1559 1598 5676
3 5906 1559 5676
3 1580 5906 5676
3 5906 1580 1125
3 1494 1559 5906
3 1560 1559 1494
3 1492 1560 1494
3 645 1560 1492
3 1487 5891 645
3 1488 1487 645
3 1366 1488 645
3 645 1496 1560
3 1497 1496 645
3 5891 1497 645
3 1364 1488 1366
3 1364 1363 1488
3 1364 1396 1363
3 1395 1396 1364
3 1367 1396 1395
3 1362 1396 1367
3 1484 1362 1367
3 5912 1484 1367
3 1361 1484 5912
3 5913 1361 5912
3 1394 5913 5912
3 1355 1394 5912
3 1355 5912 839
3 842 837 832
3 832 837 5131
3 837 172 5131
3 172 837 339
3 833 839 842
3 845 833 842
3 845 842 832
3 834 1355 839
3 834 839 833
3 172 339 4111
3 4111 339 169
3 4113 4115 4118
3 169 4032 4083
3 4082 4083 4113
3 4081 169 4083
3 4037 4081 4083
3 4037 4083 4082
3 4082 4113 4120
3 4120 4113 4118
3 4034 4111 169
3 4034 169 4081
3 4039 4118 4042
3 4039 4120 4118
3 4451 4445 4449
3 4452 385 4451
3 803 4452 4451
3 331 803 4451
3 321 331 4451
3 321 4451 1032
3 1032 4451 4449
3 4452 4443 385
3 335 334 4443
3 4458 335 4443
3 4452 4458 4443
3 335 554 334
3 4036 4125 401
3 4560 4036 401
3 4559 4036 4560
3 399 4559 4560
3 400 399 4560
3 400 4560 388
3 389 400 388
3 555 389 388
3 555 388 4394
3 4376 555 4394
3 4376 4394 554
3 554 335 4458
3 553 4376 554
3 719 553 554
3 719 554 4458
3 4125 4039 4122
3 4119 4039 4125
3 4124 4119 4125
3 4117 4124 4125
3 4036 4117 4125
3 1032 4449 1030
3 1030 4449 1031
3 323 1031 327
3 1030 1031 323
3 324 323 327
3 4114 4120 4039
3 4119 4114 4039
3 362 252 253
3 362 253 358
3 4156 4155 4158
3 4155 305 4158
3 308 358 4155
3 308 4155 4156
3 307 362 358
3 372 307 358
3 372 358 308
3 4157 4154 3940
3 4154 131 3940
3 4160 4154 4157
3 4162 4160 359
3 359 4160 4157
3 4162 4158 4160
3 4161 4156 4158
3 4161 4158 4163
3 4163 4158 4162
3 4157 3940 4159
3 4159 3940 3941
3 363 325 326
3 282 324 316
3 282 323 324
3 319 282 316
3 325 319 316
3 315 319 325
3 363 315 325
3 717 311 363
3 361 717 363
3 363 311 315
3 717 361 317
3 313 717 317
3 314 313 317
3 360 314 317
3 320 314 360
3 320 360 252
3 320 252 362
3 3820 4159 3941
3 3745 3820 3939
3 3745 4159 3820
3 3744 3745 3939
3 3823 3744 3939
3 5819 5820 5809
3 5818 5819 5809
3 3932 5819 5818
3 3932 5818 3755
3 5641 608 597
3 597 608 5652
3 608 609 5652
3 5643 608 5641
3 609 5651 5652
3 5651 5650 5652
3 5651 5649 5650
3 5649 1610 5951
3 5650 5649 5951
3 5951 1610 1323
3 1323 1610 1612
3 1610 1155 1612
3 1610 1613 1155
3 5955 1159 1156
3 1613 5955 1156
3 1613 1156 1155
3 1159 1172 1156
3 1172 1161 1156
3 1172 1611 1161
3 1172 1158 1611
3 5932 5943 5933
3 5932 5927 5943
3 5838 5840 1153
3 1153 5840 1151
3 5840 5626 1151
3 5840 5933 5626
3 5933 432 5626
3 5933 586 432
3 5943 586 5933
3 1161 1611 1124
3 1611 5838 1124
3 1124 5838 1153
3 5925 5926 5927
3 5943 5927 586
3 5927 455 586
3 5927 448 455
3 5927 5926 448
3 5925 1164 5926
3 5925 5923 1164
3 5923 5842 1164
3 5842 1145 1164
3 1145 1143 434
3 1164 1145 5944
3 5944 1145 1147
3 1145 438 1147
3 1145 1146 438
3 1145 434 1146
3 1143 436 434
3 1143 435 436
3 1143 426 435
3 426 1141 435
3 1141 433 1142
3 1141 1142 435
3 1142 433 1480
3 1142 1480 456
3 1346 456 1509
3 456 460 1509
3 435 1142 456
3 436 435 456
3 436 456 1346
3 1346 1509 1478
3 1478 1509 1483
3 1478 1483 1525
3 1485 1557 1542
3 1542 1557 1551
3 1557 1500 1551
3 1479 1557 1485
3 1346 1478 437
3 437 1478 439
3 437 439 1477
3 1474 437 1477
3 1474 1477 1466
3 1466 1477 1491
3 1491 1477 1479
3 1534 1491 1479
3 1534 1479 1468
3 1468 1479 1533
3 1533 1479 1485
3 1500 1499 1556
3 1500 1556 1551
3 1556 1499 1475
3 1556 1475 1535
3 1535 1475 5902
3 1535 5902 1506
3 1506 5902 1502
3 1506 1502 640
3 641 640 638
3 641 638 1562
3 1562 638 1566
3 1506 640 641
3 1564 1566 1563
3 1562 1566 1564
3 1564 1563 1498
3 1498 1563 1503
3 1503 1563 1599
3 1794 1806 769
3 1806 1804 769
3 6022 1804 1806
3 1807 6022 1806
3 1807 6023 6022
3 2092 2090 1850
3 1850 1825 1065
3 1850 1851 1825
3 2090 1851 1850
3 1854 2090 2092
3 1855 1854 2092
3 1855 1084 1854
3 6068 1084 1855
3 6068 1845 1084
3 1845 1837 1084
3 1845 1838 1837
3 1860 1838 1845
3 1860 1861 1838
3 1861 1839 1838
3 1861 1829 1839
3 1805 1829 1861
3 1805 1828 5862
3 1805 5862 1829
3 1828 1800 5862
3 1828 6024 1800
3 858 6024 1828
3 1095 858 1828
3 769 770 858
3 769 1804 770
3 770 6024 858
3 6029 1809 1868
3 1868 1809 1915
3 1915 1809 1916
3 1809 1914 1916
3 1914 1918 1916
3 1914 1852 1918
3 6045 1852 1914
3 1841 6045 1914
3 6045 1065 2094
3 6045 2094 1852
3 1065 1913 2094
3 1065 1853 1913
3 1065 1825 1853
3 1779 1260 1778
3 1260 847 1778
3 847 1756 1778
3 847 1747 1756
3 1745 1747 847
3 1245 1745 847
3 6022 6023 1804
3 6023 1808 1804
3 1782 1808 6023
3 856 6019 1808
3 6019 1277 1808
3 1277 6019 1274
3 6019 1785 1274
3 6019 1093 1785
3 1096 1093 6019
3 1778 1093 1096
3 1778 1744 1093
3 1756 1744 1778
3 1808 1277 1803
3 1808 1803 1804
3 1745 1769 6008
3 5702 1769 1745
3 1745 6008 1747
3 5702 5859 1769
3 1769 5859 6008
3 5859 6009 6008
3 5859 6012 6009
3 6012 6013 6009
3 6013 1246 6011
3 6009 6013 6010
3 6013 6011 6010
3 6011 1742 6010
3 6011 1229 1742
3 6011 1749 1229
3 1748 1749 6011
3 1242 6000 1119
3 1242 1119 1227
3 1227 1119 233
3 233 1119 1768
3 1119 221 1768
3 1119 1230 221
3 6000 1242 1229
3 1742 1229 1760
3 1229 1262 1760
3 1229 233 1262
3 1229 1227 233
3 1242 1227 1229
3 221 1230 1757
3 1230 242 1757
3 1757 242 5857
3 242 5693 5857
3 242 5694 5693
3 242 488 5694
3 1237 488 242
3 1237 1236 489
3 1237 489 488
3 1236 1235 489
3 506 1235 1236
3 1235 507 489
3 507 1233 489
3 507 1115 1233
3 243 495 4353
3 495 4354 4353
3 4354 4355 231
3 4355 1415 231
3 4355 1185 1415
3 4355 2108 1185
3 4355 1186 2108
3 1186 5684 2108
3 4353 4354 498
3 498 4354 4351
3 4354 231 4351
3 489 1233 4467
3 489 4467 1224
3 4467 1114 1224
3 4467 504 1114
3 504 4347 1114
3 504 505 4347
3 505 247 4347
3 505 232 247
3 232 4353 247
3 232 243 4353
3 5684 5678 5685
3 5684 5685 2108
3 5678 618 5685
3 618 1199 6073
3 618 5603 1199
3 5685 618 6073
3 1199 5603 6102
3 5603 621 6102
3 5643 5641 621
3 6102 621 462
3 621 5641 462
3 3932 5813 5819
3 3932 3751 5813
3 3751 3752 5813
3 3749 4356 3750
3 5813 3752 5819
3 4461 3928 4356
3 3927 3928 4461
3 3930 3925 4356
3 3928 3930 4356
3 265 4362 782
3 984 4362 265
3 3927 782 3928
3 4362 3926 782
3 782 3926 3928
3 896 983 982
3 1961 953 984
3 1961 984 896
3 896 984 983
3 953 4362 984
3 1997 1960 2001
3 1960 1961 2000
3 1994 1961 1960
3 1997 1994 1960
3 6103 1997 2001
3 1046 6103 2001
3 1046 2001 1041
3 6050 1046 1041
3 2000 1961 896
3 2009 2010 6050
3 2010 1046 6050
3 6052 2010 2009
3 6104 6052 2009
3 2007 6104 2009
3 1901 2026 2007
3 2008 1901 2007
3 2007 2026 6104
3 1962 1901 2008
3 6047 1962 2008
3 1835 6047 2008
3 1835 2008 1881
3 1902 1874 1881
3 1874 1835 1881
3 1903 1873 1874
3 6047 1835 1874
3 1873 6047 1874
3 1873 2087 6047
3 1897 1955 1887
3 1887 1954 2087
3 1887 1955 1954
3 2087 1956 6047
3 1956 2087 2056
3 2087 1954 2056
3 1897 1989 1955
3 6065 1989 1897
3 6057 6065 1897
3 2054 1876 6057
3 1876 6065 6057
3 6064 1876 2054
3 1424 1876 6064
3 1875 1424 6064
3 2057 1875 6064
3 1816 1875 2057
3 1406 1816 2057
3 1406 6030 1816
3 6030 1424 1875
3 6030 1872 1424
3 1810 1872 6030
3 6030 1875 1816
3 1810 1811 1872
3 1915 1811 1810
3 1868 1915 1810
3 894 1868 1810
3 6029 1868 894
3 3922 3821 3744
3 3922 3744 3925
3 3822 3745 3744
3 3821 3822 3744
3 3924 3922 3925
3 3924 3925 3930
3 5903 1498 1503
3 5903 1503 1495
3 1496 1495 1559
3 1496 5903 1495
3 1560 1496 1559
3 5891 5893 1497
3 1554 5893 5891
3 1554 5891 5888
3 5888 5891 1487
3 5892 5888 1487
3 1486 5892 1487
3 1489 1486 1487
3 1489 1487 1488
3 1363 1489 1488
3 1497 5903 1496
3 1497 1498 5903
3 1497 1564 1498
3 1497 1562 1564
3 641 1562 1497
3 5893 641 1497
3 1467 5919 1363
3 1396 1467 1363
3 5919 1489 1363
3 1361 5920 1396
3 1362 1361 1396
3 1544 1467 1396
3 5920 1544 1396
3 1361 1362 1484
3 1393 5920 1361
3 1393 1361 5913
3 1393 5913 1394
3 1184 1393 1394
3 1184 1394 1355
3 834 1184 1355
3 831 845 832
3 831 832 825
3 825 832 5131
3 827 825 5131
3 827 5131 5142
3 5142 5131 5099
3 5131 5673 5099
3 5673 5131 4034
3 5131 4111 4034
3 5131 172 4111
3 834 833 845
3 1337 834 845
3 1337 845 5853
3 5853 845 1173
3 1173 845 831
3 5885 1184 834
3 1341 5885 834
3 1341 834 844
3 844 834 1337
3 4114 4082 4120
3 4035 4037 4082
3 4035 4082 4114
3 5100 4034 4081
3 4037 5100 4081
3 5100 4037 4393
3 4037 840 4393
3 840 4037 4035
3 5100 5673 4034
3 807 4458 4452
3 329 807 4452
3 329 4452 803
3 329 803 331
3 329 331 330
3 330 331 321
3 330 321 322
3 322 321 1030
3 321 1032 1030
3 281 719 4458
3 806 281 4458
3 807 806 4458
3 4116 4117 4036
3 4559 4116 4036
3 399 4116 4559
3 399 4558 4116
3 398 4558 399
3 398 399 558
3 558 399 400
3 558 400 342
3 342 400 389
3 4447 389 4376
3 389 555 4376
3 4447 342 389
3 294 4375 4376
3 294 4376 553
3 556 4447 4376
3 4375 556 4376
3 294 553 719
3 287 294 719
3 287 719 281
3 4035 4114 4119
3 4124 4035 4119
3 4393 4035 4124
3 4557 4393 4124
3 4557 4124 4558
3 4558 4124 4117
3 4116 4558 4117
3 322 1030 323
3 282 322 323
3 1033 320 362
3 307 1033 362
3 308 4156 4165
3 4165 4156 4161
3 4459 308 4170
3 308 4166 4170
3 4166 308 4165
3 1034 372 308
3 4459 1034 308
3 251 1033 307
3 306 251 307
3 372 306 307
3 1034 707 372
3 707 306 372
3 359 4157 4159
3 4169 359 4164
3 4164 359 4159
3 4169 4162 359
3 4168 4162 4169
3 4168 4163 4162
3 4165 4161 4163
3 4168 4165 4163
3 4164 4159 3745
3 720 322 282
3 720 282 319
3 311 720 319
3 311 319 315
3 717 720 311
3 312 720 717
3 313 312 717
3 312 313 1035
3 1035 313 314
3 1035 314 320
3 1033 251 320
3 523 1035 320
3 251 523 320
3 3822 4164 3745
3 5641 597 462
3 462 597 607
3 597 5948 607
3 597 5652 5948
3 5948 5652 5945
3 5652 605 5945
3 5652 5650 605
3 5650 5951 5661
3 605 5650 5661
3 5661 5951 1605
3 1605 5951 1323
3 1605 1323 631
3 631 1323 1609
3 1323 1612 1609
3 1155 1608 1612
3 1609 1612 5956
3 5956 1612 1348
3 1612 1154 1348
3 1608 1154 1612
3 1155 1156 1608
3 1156 589 1608
3 1156 1161 589
3 589 1161 1124
3 1124 1153 1152
3 1152 1153 461
3 1153 413 461
3 1153 1151 413
3 1151 590 413
3 1151 588 590
3 5626 588 1151
3 5626 587 588
3 5626 432 587
3 432 1123 587
3 432 1122 1123
3 586 1122 432
3 586 463 1122
3 586 455 463
3 589 1124 812
3 812 1124 1152
3 5926 5944 448
3 1164 5944 5926
3 463 455 582
3 455 453 582
3 455 585 453
3 448 585 455
3 585 448 445
3 448 5944 445
3 1146 434 1346
3 434 436 1346
3 5944 1147 445
3 445 1147 446
3 446 1147 1474
3 1147 440 1474
3 438 440 1147
3 440 438 437
3 438 1146 437
3 1146 1346 437
3 1485 1542 1548
3 1542 1555 1548
3 1542 1551 1555
3 1533 1485 1527
3 1527 1485 1552
3 1552 1485 1549
3 1485 1548 1549
3 1555 1551 1553
3 1551 1490 1553
3 1551 1535 1490
3 1556 1535 1551
3 440 437 1474
3 446 1474 1466
3 408 446 1466
3 408 1466 1183
3 1183 1466 1491
3 1491 1534 444
3 442 1183 1491
3 442 1491 444
3 1465 1534 1468
3 444 1534 1465
3 1465 1468 1464
3 1464 1468 1533
3 1464 1533 1529
3 1529 1533 1527
3 1490 1535 1506
3 1490 1506 642
3 642 1506 641
3 5893 642 641
3 1804 1801 770
3 1804 1803 1801
3 2090 1848 1851
3 2090 1843 1848
3 1854 1843 2090
3 1825 1851 1842
3 1825 1842 1853
3 1851 1822 1842
3 1848 1822 1851
3 1854 1858 1843
3 1084 1858 1854
3 1084 1857 1858
3 1837 1857 1084
3 1838 1839 1837
3 1837 1827 1857
3 1837 1839 1827
3 1839 2068 1827
3 1829 2068 1839
3 2068 1829 1846
3 1829 5862 1846
3 5862 6025 1846
3 5862 1799 6025
3 1800 1799 5862
3 1800 1097 1799
3 1087 1097 1800
3 6024 1087 1800
3 1802 1087 6024
3 1801 1802 6024
3 770 1801 6024
3 1811 1915 1872
3 1915 1916 1872
3 1918 2085 1916
3 1916 2085 1872
3 1918 1871 2085
3 1852 1871 1918
3 1852 2094 1871
3 1871 2094 6043
3 2094 1913 6043
3 1913 6044 6043
3 1913 1853 6044
3 1853 6063 6044
3 1853 1842 6063
3 1756 1228 1744
3 1756 6007 1228
3 1762 6007 1756
3 1743 1762 1756
3 1747 1743 1756
3 1747 6008 1743
3 1277 1276 1803
3 1277 1274 1276
3 1276 1274 6020
3 1274 1787 6020
3 1274 1785 1787
3 1785 6014 1787
3 1785 5856 6014
3 1093 5856 1785
3 1093 1740 5856
3 1752 1740 1093
3 1744 1752 1093
3 1744 1258 1752
3 1744 1247 1258
3 1746 1247 1744
3 1228 1746 1744
3 1276 1772 1803
3 1803 1795 1801
3 1803 1772 1795
3 1743 6008 1762
3 6008 6010 1762
3 6009 6010 6008
3 1762 6010 1746
3 1746 6010 1753
3 6010 1763 1753
3 6010 1741 1763
3 6010 1742 1741
3 1741 1742 1760
3 1262 233 1766
3 1766 233 1768
3 1266 1768 1751
3 1768 1757 1751
3 1768 221 1757
3 1766 1768 1266
3 1763 1760 1753
3 1753 1760 6002
3 6002 1760 1765
3 1760 1766 1765
3 1760 1262 1766
3 1763 1741 1760
3 1751 1757 1263
3 1757 1264 1263
3 1264 1757 5692
3 5692 1757 5857
3 5857 5693 1271
3 5692 5857 5860
3 5860 5857 1271
3 5693 240 1271
3 5693 268 240
3 5693 5694 268
3 5694 5696 273
3 1226 5696 5694
3 488 1226 5694
3 5694 273 268
3 488 5696 1226
3 488 489 5696
3 5696 489 1224
3 4353 498 247
3 4351 231 246
3 231 1415 246
3 4368 1415 5682
3 1415 2105 5682
3 1415 1203 2105
3 1415 1411 1203
3 1185 1411 1415
3 246 1415 5681
3 5681 1415 4368
3 6073 6071 1185
3 2110 6073 1185
3 2108 2110 1185
3 1411 1185 6070
3 1185 6071 6070
3 5685 2109 2108
3 2109 2110 2108
3 247 498 4346
3 498 4352 4346
3 498 4351 4352
3 4351 246 5681
3 4351 5681 4352
3 5696 1224 1232
3 1224 1105 1232
3 1224 4343 1105
3 1104 4343 1224
3 1114 1104 1224
3 1114 1113 1104
3 1114 4345 1113
3 1114 4347 4345
3 4347 5686 4345
3 4347 247 5686
3 247 4346 5686
3 5685 6073 2109
3 6073 1199 6071
3 2109 6073 2110
3 1199 5602 6071
3 1199 6102 5602
3 6102 5946 5947
3 6102 462 5946
3 5602 6102 5947
3 462 607 5946
3 3926 3930 3928
3 4363 3923 3930
3 3926 4363 3930
3 3923 3924 3930
3 4362 4363 3926
3 4362 4364 4363
3 4362 779 4364
3 3921 779 4362
3 777 3921 4362
3 4365 777 4362
3 985 4365 4362
3 985 4362 953
3 1998 985 953
3 952 1998 953
3 952 953 1961
3 1994 952 1961
3 2015 1994 1997
3 2014 2015 1997
3 6103 2014 1997
3 2015 6027 1994
3 6027 952 1994
3 1993 2014 6103
3 2038 1993 6103
3 1999 2038 6103
3 6051 1999 6103
3 6051 6103 1046
3 2003 6051 1046
3 2004 2003 1046
3 2002 2004 1046
3 2002 1046 6052
3 6052 1046 2010
3 2026 2002 6052
3 2026 6052 6104
3 2026 2004 2002
3 2026 1996 2004
3 2056 1996 2026
3 1901 2056 2026
3 1962 2056 1901
3 1956 2056 1962
3 1956 1962 6047
3 1954 1955 2006
3 1955 1989 2006
3 1954 2006 2056
3 2055 1996 2056
3 2006 2055 2056
3 6065 2052 1989
3 1989 1995 2006
3 1989 1986 1995
3 2052 1986 1989
3 6065 1934 2052
3 1898 1934 6065
3 1876 1898 6065
3 1424 1898 1876
3 1424 6042 1898
3 1872 6042 1424
3 1872 2085 6042
3 4463 3822 3821
3 4357 4463 3821
3 4357 3821 3922
3 3746 3922 3924
3 4357 3922 3746
3 3822 4169 4164
3 4463 4169 3822
3 779 3746 3924
3 4364 779 3924
3 3923 4364 3924
3 1490 642 5893
3 5894 1490 5893
3 1553 5894 5893
3 1553 5893 1554
3 1548 1553 1554
3 1549 1548 1554
3 1549 1554 5888
3 1549 5888 1486
3 1486 5888 5892
3 5889 1486 1489
3 1550 1549 1486
3 5889 1550 1486
3 5919 5889 1489
3 1550 5889 5919
3 5890 1550 5919
3 1467 5890 5919
3 1544 1546 1467
3 1546 5890 1467
3 1531 1543 5920
3 443 1531 5920
3 1354 443 5920
3 1340 1354 5920
3 1393 1340 5920
3 5920 1543 1544
3 1543 1546 1544
3 5885 1340 1393
3 5885 1393 1184
3 1330 1173 831
3 1330 831 841
3 841 831 825
3 841 825 827
3 5143 827 5099
3 827 5142 5099
3 821 841 827
3 821 827 5143
3 4387 5143 5099
3 4556 4387 5099
3 4556 5099 4389
3 5099 5100 4389
3 5673 5100 5099
3 1391 844 1337
3 843 1391 1337
3 843 1337 1332
3 1332 1337 5853
3 416 414 5853
3 415 416 5853
3 1338 415 5853
3 1338 5853 1181
3 1181 5853 1330
3 5853 1173 1330
3 1331 1332 5853
3 414 1331 5853
3 5904 1340 5885
3 5904 5885 1341
3 1392 1341 844
3 1392 5904 1341
3 1391 1392 844
3 4393 840 4035
3 4389 5100 4393
3 343 4393 4558
3 4393 4557 4558
3 397 4389 4393
3 397 4393 346
3 346 4393 343
3 285 806 807
3 285 807 329
3 4370 285 329
3 804 4370 329
3 804 329 330
3 1029 330 322
3 1029 804 330
3 1029 322 720
3 291 287 281
3 1672 291 281
3 280 1672 281
3 280 281 806
3 4369 280 806
3 4369 806 285
3 398 343 4558
3 4374 398 558
3 4373 343 398
3 4374 4373 398
3 4374 558 4447
3 4447 558 342
3 559 4447 556
3 288 4374 4447
3 559 288 4447
3 295 556 4375
3 295 4375 294
3 287 295 294
3 295 559 556
3 557 295 287
3 293 557 287
3 296 293 287
3 291 296 287
3 4166 4165 4168
3 4460 4170 4173
3 4173 4170 4167
3 4170 4166 4167
3 4460 4459 4170
3 4466 4459 4464
3 4464 4459 4172
3 4459 4460 4172
3 4372 1034 4459
3 4358 4372 4459
3 4466 4358 4459
3 4167 4166 4168
3 303 707 1034
3 4372 303 1034
3 251 278 523
3 278 251 306
3 303 306 707
3 303 278 306
3 4171 4169 4463
3 4167 4168 4169
3 4171 4167 4169
3 312 1029 720
3 722 1029 312
3 711 722 312
3 711 312 278
3 278 312 523
3 523 312 1035
3 607 5948 5945
3 5946 607 5945
3 5946 5945 5947
3 5947 5945 1605
3 5945 5661 1605
3 605 5661 5945
3 5947 1605 624
3 1605 606 624
3 606 1605 1604
3 1604 1605 1606
3 1606 1605 631
3 632 631 1609
3 1606 631 630
3 630 631 632
3 632 1609 1349
3 1609 5956 1349
3 1608 812 1154
3 1608 589 812
3 5956 1348 1349
3 1349 1348 1322
3 1348 814 1322
3 1348 1154 814
3 1154 813 814
3 1154 1321 813
3 1154 1327 1321
3 1154 812 1327
3 1327 1152 461
3 812 1152 1327
3 1327 461 418
3 461 413 418
3 418 413 1180
3 413 835 1180
3 413 407 835
3 413 590 407
3 590 4564 407
3 410 4564 590
3 588 410 590
3 588 587 410
3 587 450 410
3 587 1123 450
3 1123 1122 454
3 1123 454 450
3 1122 582 454
3 1122 463 582
3 582 584 454
3 582 583 584
3 453 583 582
3 453 408 441
3 453 441 583
3 445 408 453
3 585 445 453
3 445 446 408
3 1548 1555 1553
3 5887 1527 1552
3 1528 1529 1527
3 1528 1527 1530
3 1530 1527 5887
3 5887 1552 1543
3 1543 1552 1546
3 1552 1545 1546
3 1545 1552 1549
3 1545 1549 1547
3 1547 1549 1550
3 1490 5894 1553
3 441 408 1183
3 441 1183 442
3 444 1465 1473
3 5921 442 444
3 5921 444 1470
3 1470 444 409
3 409 444 1473
3 583 441 442
3 583 442 5921
3 1465 1476 1473
3 1465 1464 1476
3 1476 1464 1529
3 1476 1529 1528
3 1801 1795 1802
3 1848 1085 1822
3 1843 1085 1848
3 1858 1085 1843
3 1842 1844 6063
3 1822 1844 1842
3 1822 6059 1844
3 1085 6059 1822
3 1858 2069 1085
3 1857 2069 1858
3 1857 1827 2069
3 2068 1826 1827
3 1827 1826 2069
3 1826 2068 924
3 2068 1846 924
3 1846 1272 1830
3 1846 6025 1272
3 924 1846 1830
3 1272 6025 1416
3 6025 1418 1416
3 1799 1418 6025
3 1097 1847 1799
3 1847 1418 1799
3 1097 1796 1847
3 1798 1796 1097
3 1087 1798 1097
3 1802 1798 1087
3 1802 1795 1798
3 2085 6043 6042
3 1871 6043 2085
3 6063 1949 6043
3 6044 6063 6043
3 6043 1917 6042
3 6043 1980 1917
3 6043 1978 1980
3 1949 1978 6043
3 6063 2064 1949
3 6063 2065 2064
3 6063 2067 2065
3 1844 2067 6063
3 1762 1746 1228
3 6007 1762 1228
3 1772 1276 1784
3 1276 1786 1784
3 1276 6020 1786
3 6020 1787 1786
3 1787 1789 1786
3 1787 6014 1789
3 5855 5854 6014
3 5856 5855 6014
3 6014 1398 1789
3 6014 5854 1398
3 5856 6003 5855
3 1740 6003 5856
3 1740 6004 6003
3 1764 6004 1740
3 1752 1764 1740
3 1258 6006 1752
3 6005 1764 1752
3 6006 6005 1752
3 1258 6002 6006
3 1248 6002 1258
3 1247 1248 1258
3 1746 1248 1247
3 1746 1753 1248
3 1795 1772 1793
3 1772 6021 1793
3 1772 1784 6021
3 1795 1793 1798
3 1753 6002 1248
3 1766 1266 1765
3 1266 1751 1767
3 1767 1751 1263
3 1765 1266 1767
3 6002 1761 6006
3 1761 6002 6005
3 6002 1765 6005
3 6005 1765 1263
3 1765 1767 1263
3 6005 1263 1759
3 1759 1263 1755
3 1263 1264 1755
3 1264 5692 1758
3 1264 1758 1755
3 1758 5692 5860
3 5854 1269 1271
3 5854 1271 1398
3 1398 1271 1788
3 1788 1271 1098
3 1098 1271 1268
3 1271 1270 1268
3 240 1270 1271
3 1269 5860 1271
3 1758 5860 1269
3 240 272 1270
3 240 239 272
3 268 239 240
3 268 273 239
3 273 1231 239
3 273 5696 1231
3 5696 267 1231
3 5696 1232 267
3 4352 4368 5682
3 4346 4352 5682
3 4346 5682 5691
3 5682 1648 5691
3 5682 1195 1648
3 2105 1195 5682
3 4352 5681 4368
3 1203 1414 2105
3 2105 1414 1195
3 1411 6070 1203
3 1203 6070 1414
3 6071 2106 6070
3 2106 6071 1205
3 6071 2107 1205
3 6071 1198 2107
3 5602 1198 6071
3 1414 6070 6072
3 6070 1205 6072
3 6070 2106 1205
3 5686 4346 1223
3 4346 5691 1223
3 1232 1109 5127
3 1109 1232 543
3 1232 1110 543
3 1232 1105 1110
3 267 1232 5127
3 1105 5689 1110
3 1105 4343 5689
3 4343 1104 5689
3 1104 1113 4348
3 1104 4348 5689
3 1113 4344 245
3 1113 4345 4344
3 4348 1113 245
3 4345 5686 4344
3 4344 5686 1223
3 1198 5602 1197
3 1197 5602 1189
3 1189 5602 1191
3 1191 5602 1190
3 5602 5947 1190
3 5947 5601 1190
3 5947 624 5601
3 4364 3923 4363
3 3921 3746 779
3 777 4366 3921
3 3921 4357 3746
3 4366 4357 3921
3 755 4366 777
3 988 755 777
3 988 777 987
3 987 777 4365
3 987 4365 985
3 1927 987 985
3 1930 1927 985
3 1930 985 1998
3 6049 1930 1998
3 2035 6049 1998
3 6027 2035 1998
3 6027 1998 952
3 2035 6027 2015
3 2014 2035 2015
3 1993 2037 2014
3 2014 2036 2035
3 2016 2036 2014
3 2037 2016 2014
3 2039 2040 1993
3 2038 2039 1993
3 1993 2040 2037
3 1056 2046 2038
3 1056 2038 1999
3 1952 2039 2038
3 2046 1952 2038
3 780 1056 1999
3 1996 780 1999
3 1996 1999 2005
3 2005 1999 6051
3 2005 6051 2003
3 2004 2005 2003
3 1996 2005 2004
3 1932 780 1996
3 2055 1932 1996
3 2006 785 1990
3 1995 785 2006
3 2006 1990 2055
3 2055 1931 1932
3 784 1931 2055
3 1990 784 2055
3 2052 1991 1986
3 1957 1991 2052
3 1934 1957 2052
3 1995 784 785
3 1995 1959 784
3 1986 1959 1995
3 1986 1953 1959
3 1986 1933 1953
3 1958 1933 1986
3 1991 1958 1986
3 1957 1934 1958
3 1934 1982 1958
3 1917 1982 1934
3 6042 1917 1934
3 1898 6042 1934
3 4179 4178 4463
3 4179 4463 4357
3 4465 4171 4463
3 4176 4465 4463
3 4178 4176 4463
3 4177 4179 4357
3 4366 4177 4357
3 5890 1547 1550
3 1546 1547 5890
3 1545 1547 1546
3 1174 5887 1543
3 1531 1174 1543
3 443 1174 1531
3 1532 1174 443
3 1354 1532 443
3 1472 1532 1354
3 1182 1472 1354
3 1340 1182 1354
3 1356 1340 5904
3 449 1182 1340
3 1353 449 1340
3 1356 1353 1340
3 1181 1330 841
3 1181 841 821
3 5141 5143 4387
3 822 821 5143
3 730 822 5143
3 730 5143 5141
3 826 1181 821
3 826 821 822
3 5141 4387 351
3 351 4387 4556
3 351 4556 4389
3 351 4389 349
3 349 4389 397
3 843 5884 1391
3 5884 1392 1391
3 5884 843 1331
3 1331 843 1332
3 414 5884 1331
3 5850 5884 414
3 5850 414 416
3 5850 416 415
3 1179 1390 415
3 1179 415 1338
3 1390 5850 415
3 1389 1338 1328
3 1328 1338 1181
3 1389 1179 1338
3 1328 1181 826
3 1356 5904 1392
3 1357 1356 1392
3 1357 1392 5884
3 289 346 343
3 348 289 343
3 4373 348 343
3 349 397 5098
3 5098 397 348
3 348 397 289
3 397 346 289
3 1700 4369 285
3 805 1700 285
3 4370 805 285
3 5993 5989 4370
3 1688 5993 4370
3 718 1688 4370
3 718 4370 804
3 5989 805 4370
3 318 718 804
3 716 318 804
3 716 804 1029
3 722 716 1029
3 1681 296 291
3 1680 1681 291
3 1680 291 1672
3 1699 1680 1672
3 1699 1672 277
3 277 1672 280
3 276 277 280
3 4369 276 280
3 5994 276 4369
3 5994 4369 1700
3 348 4373 4374
3 347 348 4374
3 347 4374 288
3 4570 4448 559
3 4570 559 295
3 4450 288 559
3 4448 4450 559
3 4450 347 288
3 557 4570 295
3 557 4569 4570
3 4648 4569 557
3 577 4648 557
3 290 577 557
3 290 557 292
3 292 557 293
3 1697 292 293
3 1697 293 704
3 704 293 296
3 704 296 1681
3 4172 4173 4175
3 4175 4173 4465
3 4465 4173 4171
3 4173 4167 4171
3 4172 4460 4173
3 761 4466 4464
3 761 4464 250
3 250 4464 4172
3 304 4358 4466
3 274 304 4466
3 274 4466 1658
3 1658 4466 761
3 250 4172 4175
3 4372 727 303
3 4372 705 727
3 705 4372 4358
3 304 705 4358
3 249 278 303
3 727 249 303
3 249 711 278
3 721 716 722
3 310 721 722
3 711 310 722
3 724 310 711
3 710 724 711
3 710 711 249
3 624 606 5601
3 606 1604 5601
3 5601 1604 630
3 1604 595 630
3 1604 1606 595
3 595 1606 630
3 632 1617 5957
3 632 815 1617
3 632 1349 815
3 630 632 5957
3 625 630 5957
3 5601 630 625
3 815 1349 1351
3 1351 1349 1350
3 1349 1322 1350
3 1350 1322 1335
3 1322 1409 1335
3 1322 1326 1409
3 814 1326 1322
3 1326 814 1360
3 814 1325 1360
3 1321 1325 814
3 813 1321 814
3 1321 418 1325
3 1321 1327 418
3 1325 418 1360
3 418 1180 1360
3 1360 1180 1469
3 1180 835 1469
3 835 836 1469
3 835 5886 836
3 407 5886 835
3 407 1537 5886
3 407 1536 1537
3 407 1463 1536
3 4564 1463 407
3 4564 451 1463
3 410 451 4564
3 450 451 410
3 450 452 451
3 454 452 450
3 454 447 452
3 454 584 447
3 584 583 5921
3 447 584 1470
3 584 5921 1470
3 1530 5887 1532
3 1532 5887 1174
3 1473 1476 1528
3 1352 1473 1528
3 1352 1528 1353
3 1528 449 1353
3 449 1528 1182
3 1528 1530 1182
3 1530 1472 1182
3 1472 1530 1532
3 1359 1473 1540
3 1540 1473 1352
3 1471 409 1473
3 1471 1473 1359
3 452 447 1470
3 451 452 1470
3 451 1470 1463
3 1463 1470 409
3 1463 409 1471
3 1085 2069 6059
3 1844 6059 2067
3 6059 2079 2067
3 6059 1826 2079
3 2069 1826 6059
3 1826 924 2079
3 924 1830 2079
3 1830 1272 2077
3 1830 2077 2079
3 1272 2080 2077
3 1272 1422 2080
3 1272 1416 1422
3 1416 1417 1422
3 1418 1417 1416
3 1418 1101 1417
3 1418 1400 1101
3 1267 1400 1418
3 1847 1267 1418
3 1775 1267 1847
3 1797 1775 1847
3 1796 1797 1847
3 1796 1793 1797
3 1798 1793 1796
3 1978 1949 2084
3 1949 2064 2084
3 1917 1946 1982
3 1980 1946 1917
3 1980 1978 1946
3 1978 2084 1979
3 1978 1981 1946
3 1981 1978 1979
3 2066 1947 2064
3 2065 2066 2064
3 2064 2070 2084
3 2064 1947 2070
3 2067 2066 2065
3 2066 2067 1086
3 2067 2079 1086
3 6021 1784 1792
3 1784 1774 1792
3 1784 1404 1774
3 1786 1404 1784
3 1786 1403 1404
3 1786 1789 1403
3 1789 1398 1403
3 1754 1269 5854
3 5855 1754 5854
3 1755 1754 5855
3 6003 1755 5855
3 1398 1788 1403
3 6004 1759 6003
3 1759 1755 6003
3 6005 1759 6004
3 1764 6005 6004
3 1761 6005 6006
3 1793 6021 1792
3 1793 1792 1797
3 1755 1758 1754
3 1754 1758 1269
3 1403 1788 1404
3 1788 1098 1404
3 1404 1098 1773
3 1098 1790 1773
3 1098 1268 1790
3 1790 1268 1399
3 1268 1270 1399
3 1270 237 1399
3 1270 271 237
3 1270 272 271
3 272 270 269
3 239 270 272
3 272 535 271
3 272 269 535
3 239 5127 270
3 239 1231 5127
3 1231 267 5127
3 5691 1204 5680
3 5691 1648 1204
3 5691 5680 1223
3 1204 1648 1196
3 1648 1195 1196
3 1195 1206 1196
3 1414 1206 1195
3 1414 6072 1206
3 6072 1205 1207
3 1205 2107 1207
3 2107 1189 1207
3 1197 1189 2107
3 1198 1197 2107
3 1208 6072 1202
3 1202 6072 1210
3 6072 5962 1210
3 6072 1207 5962
3 1206 6072 1208
3 1223 5690 1652
3 5690 1223 1254
3 1223 5679 1254
3 5680 5679 1223
3 4344 1223 245
3 245 1223 1652
3 533 5127 534
3 5127 1111 534
3 5127 1109 1111
3 270 5127 533
3 1109 543 1111
3 1110 1108 543
3 1111 543 4350
3 543 1654 4350
3 543 4349 1654
3 1108 4349 543
3 1110 5689 1108
3 5689 4348 1108
3 4348 245 1108
3 1108 245 4349
3 245 1652 4349
3 1189 1191 1207
3 1191 626 5961
3 626 1191 1190
3 1207 1191 5961
3 626 1190 629
3 629 1190 702
3 1190 625 702
3 1190 5601 625
3 755 4177 4366
3 755 260 4177
3 258 260 755
3 258 755 989
3 989 755 988
3 989 988 2018
3 2018 988 987
3 2018 987 1927
3 6048 2034 1927
3 6028 6048 1927
3 6028 1927 1930
3 2017 2018 1927
3 2034 2017 1927
3 6049 6028 1930
3 6048 6028 6049
3 2036 6048 6049
3 2036 6049 2035
3 2040 2016 2037
3 2036 2034 6048
3 2036 2030 2034
3 2032 2030 2036
3 2032 2036 2016
3 2029 2032 2016
3 2041 2029 2016
3 2041 2016 2040
3 2039 2041 2040
3 2045 2041 2039
3 1952 2045 2039
3 2046 2045 1952
3 2044 2045 2046
3 6055 2044 2046
3 1992 6055 2046
3 1992 2046 780
3 780 2046 1056
3 1931 1992 780
3 1932 1931 780
3 785 784 1990
3 1931 6055 1992
3 2051 6055 1931
3 784 2051 1931
3 1953 2051 784
3 1959 1953 784
3 1957 1958 1991
3 1988 2051 1953
3 1933 1988 1953
3 1958 1988 1933
3 1958 1985 1988
3 1982 1985 1958
3 1982 1977 1983
3 1946 1977 1982
3 1982 1983 1985
3 264 4176 4178
3 264 4178 4177
3 4177 4178 4179
3 4175 4465 4176
3 4174 4175 4176
3 4174 4176 264
3 4174 264 4177
3 259 4174 4177
3 260 259 4177
3 1358 1353 1356
3 1358 1356 1357
3 1352 1353 1358
3 730 5141 412
3 412 5141 4555
3 4555 5141 351
3 593 828 822
3 593 822 730
3 828 826 822
3 592 593 730
3 592 730 412
3 828 1328 826
3 4377 4555 351
3 4377 351 4442
3 4442 351 349
3 4442 349 4441
3 4441 349 348
3 349 5098 348
3 5905 1357 5884
3 5905 5884 5850
3 5849 5905 5850
3 5849 5850 1389
3 5850 1390 1389
3 1389 1390 1179
3 1336 1389 1328
3 810 1336 1328
3 1178 810 1328
3 1178 1328 830
3 830 1328 828
3 1324 5849 1389
3 1336 1324 1389
3 1462 1358 1357
3 5847 1462 1357
3 5847 1357 1388
3 1388 1357 5905
3 4441 348 344
3 344 348 347
3 805 5994 1700
3 5989 5994 805
3 5989 1696 5994
3 5988 1696 5989
3 1694 5988 5989
3 1695 1694 5989
3 5993 1695 5989
3 1687 1695 5993
3 5992 1687 5993
3 5992 5993 1688
3 5992 1688 718
3 318 5992 718
3 1730 5992 318
3 721 1730 318
3 721 318 716
3 1702 704 1681
3 1701 1702 1681
3 1701 1681 1680
3 1679 1701 1680
3 1698 1679 1680
3 1698 1680 1699
3 276 1699 277
3 1696 1698 1699
3 1696 1699 5994
3 1699 276 5994
3 344 347 4450
3 4569 4448 4570
3 4569 4450 4448
3 5136 560 4450
3 5136 4450 4569
3 560 344 4450
3 4648 5136 4569
3 4371 4647 4648
3 284 4371 4648
3 284 4648 577
3 4648 4568 5136
3 4647 4568 4648
3 283 577 290
3 283 284 577
3 1703 290 1697
3 1697 290 292
3 1703 283 290
3 1685 1697 1702
3 1702 1697 704
3 1703 1697 1685
3 250 4175 4174
3 1658 761 254
3 254 761 255
3 255 761 5128
3 761 250 5128
3 5128 250 4174
3 705 304 727
3 304 275 727
3 274 275 304
3 274 726 275
3 274 248 726
3 524 248 274
3 524 274 227
3 227 274 1658
3 774 1658 254
3 744 227 1658
3 744 1658 774
3 275 249 727
3 726 249 275
3 706 710 249
3 248 706 249
3 248 249 726
3 723 1734 721
3 723 721 310
3 1734 1730 721
3 712 723 310
3 724 712 310
3 236 709 724
3 236 724 725
3 724 710 725
3 709 712 724
3 725 710 706
3 5965 625 5957
3 5965 5957 1620
3 1620 5957 1618
3 5957 627 1618
3 5957 1617 627
3 1617 628 627
3 1617 1339 628
3 1339 1617 1336
3 1617 815 1336
3 815 1350 1336
3 815 1351 1350
3 702 625 5999
3 5999 625 5965
3 1336 1350 1335
3 1336 1335 1324
3 1335 1334 1324
3 1409 1334 1335
3 1409 1360 1469
3 1326 1360 1409
3 1409 1469 1334
3 1469 1541 1334
3 1469 1540 1541
3 836 1540 1469
3 1539 1540 836
3 5886 1539 836
3 5886 1540 1539
3 5886 1537 1540
3 1537 1359 1540
3 1536 1359 1537
3 1536 1471 1359
3 1463 1471 1536
3 1540 1352 1538
3 1538 1352 1358
3 1540 1538 5847
3 1540 5847 1541
3 2079 1943 1086
3 2079 2077 1943
3 2077 1945 1943
3 2077 2080 1945
3 2080 1080 1945
3 2080 2078 1080
3 2080 1831 2078
3 1422 1831 2080
3 1422 1417 1831
3 1417 1101 5861
3 1417 5861 1831
3 1101 767 5861
3 1400 767 1101
3 1400 1103 767
3 1275 1103 1400
3 1776 1275 1400
3 1267 1776 1400
3 1402 1776 1267
3 1791 1402 1267
3 1791 1267 1775
3 1774 1791 1775
3 1792 1774 1775
3 1792 1775 1797
3 1979 2084 1948
3 2084 1944 1948
3 1944 2084 6066
3 2084 2070 6066
3 1981 1977 1946
3 1981 1979 1977
3 1977 1979 1974
3 1979 1948 1974
3 1947 1086 2070
3 2066 1086 1947
3 2070 2071 6066
3 2070 6058 2071
3 1086 6058 2070
3 6058 1086 2060
3 1086 1943 2060
3 1774 1773 1791
3 1404 1773 1774
3 1773 1790 1791
3 1791 1790 1402
3 1790 1265 1402
3 1790 1399 1265
3 1399 568 1401
3 1399 266 568
3 237 266 1399
3 1265 1399 1401
3 237 271 266
3 271 537 266
3 271 535 537
3 269 533 535
3 269 270 533
3 537 535 536
3 535 533 536
3 5680 1196 5679
3 1204 1196 5680
3 1196 1107 5679
3 1196 1200 1107
3 1202 1200 1196
3 1206 1202 1196
3 1206 1208 1202
3 1207 5961 5962
3 1202 1210 1200
3 1200 1210 1107
3 1210 5962 1107
3 5962 1211 1107
3 5962 5961 1211
3 4349 1652 1654
3 1654 1652 5998
3 1652 5967 5998
3 1652 5970 5967
3 1652 1649 5970
3 5690 1649 1652
3 1649 5690 5970
3 5690 1650 5970
3 5690 1254 1650
3 1254 5959 1375
3 5679 5959 1254
3 1254 1375 1650
3 5679 1209 5959
3 1107 1209 5679
3 533 534 5688
3 5688 534 5875
3 534 241 5875
3 534 539 241
3 534 6101 539
3 534 4350 6101
3 1111 4350 534
3 536 533 5688
3 6101 4350 542
3 4350 234 542
3 4350 1654 234
3 234 1654 5996
3 1654 1253 5996
3 1654 1662 1253
3 1662 1654 5998
3 5961 626 5960
3 1211 5961 1222
3 5961 5960 1222
3 626 629 5960
3 5960 629 1614
3 629 702 1614
3 702 5999 1614
3 4367 259 260
3 258 4367 260
3 2022 4367 258
3 1869 2022 258
3 1869 258 1926
3 1926 258 989
3 1926 989 2018
3 1867 2018 2017
3 1867 1926 2018
3 2033 2017 2034
3 2030 2033 2034
3 2033 1867 2017
3 2030 2031 2033
3 1935 2031 2030
3 2032 1935 2030
3 2029 1935 2032
3 2042 1935 2029
3 2028 2042 2029
3 2028 2029 2041
3 2045 2028 2041
3 2045 2042 2028
3 2044 2042 2045
3 1970 2048 2044
3 2043 1970 2044
3 2043 2044 1987
3 2044 6055 1987
3 2044 2048 2042
3 6055 1971 1987
3 1984 1971 6055
3 2051 1984 6055
3 1988 1984 2051
3 1985 1984 1988
3 1985 2050 1984
3 1985 1983 2050
3 2050 1983 1976
3 1983 1975 1976
3 1977 1975 1983
3 1977 1974 1975
3 756 5128 4174
3 2023 756 4174
3 261 2023 4174
3 261 4174 259
3 2022 259 4367
3 2022 261 259
3 1462 1538 1358
3 352 592 412
3 350 352 412
3 564 350 412
3 564 412 4555
3 563 564 4555
3 563 4555 4377
3 824 830 828
3 820 824 828
3 820 828 593
3 633 820 593
3 353 633 593
3 353 593 352
3 352 593 592
3 563 4377 4453
3 4453 4377 4378
3 4378 4377 4442
3 4378 4442 344
3 4442 4441 344
3 1541 1388 5905
3 1329 1541 5905
3 1329 5905 5849
3 1334 1329 5849
3 1324 1334 5849
3 1339 1336 5848
3 5848 1336 810
3 729 5848 810
3 729 810 819
3 819 810 823
3 823 810 1178
3 823 1178 830
3 823 830 824
3 5847 1538 1462
3 1541 5847 1388
3 4453 4378 344
3 345 4453 344
3 560 345 344
3 1684 1698 1696
3 1693 1684 1696
3 5988 1693 1696
3 703 1693 5988
3 1694 703 5988
3 1686 703 1694
3 5975 1686 1694
3 5975 1694 1695
3 1092 5975 1695
3 1092 1695 1687
3 1383 1092 1687
3 1383 1687 5992
3 715 1383 5992
3 1730 715 5992
3 1729 715 1730
3 1734 1729 1730
3 1685 1702 1701
3 1685 1701 1678
3 1678 1701 1679
3 1678 1679 1698
3 1678 1698 1684
3 4567 4455 560
3 4647 4567 560
3 4647 560 4568
3 4568 560 5136
3 4455 345 560
3 4371 4567 4647
3 4371 548 4567
3 549 548 4371
3 4382 549 4371
3 298 4382 4371
3 299 298 4371
3 4385 299 4371
3 4385 4371 579
3 579 4371 284
3 579 284 286
3 286 284 283
3 286 283 1703
3 1252 286 1703
3 545 1252 1703
3 545 1703 1685
3 1675 545 1685
3 1675 1685 1693
3 1693 1685 1678
3 760 774 254
3 6067 760 254
3 6067 254 255
3 6067 255 2025
3 2025 255 5128
3 2025 5128 756
3 524 706 248
3 5971 524 227
3 279 706 524
3 5971 279 524
3 309 5971 227
3 773 309 227
3 5129 773 227
3 5129 227 744
3 531 744 774
3 5870 531 774
3 5870 774 759
3 759 774 760
3 6062 5129 744
3 6062 744 6061
3 6061 744 531
3 279 725 706
3 1733 1735 1734
3 1736 1733 1734
3 1736 1734 723
3 1735 1729 1734
3 712 1736 723
3 709 1736 712
3 5977 1736 709
3 5978 5977 709
3 708 5978 709
3 236 708 709
3 1660 772 236
3 1660 236 713
3 713 236 725
3 1723 708 236
3 1725 1723 236
3 772 1725 236
3 4359 713 725
3 279 4359 725
3 5999 5965 1621
3 1621 5965 701
3 701 5965 1619
3 1619 5965 1620
3 1619 1620 1615
3 1615 1620 1217
3 1217 1620 1218
3 1620 1618 1218
3 1618 816 1218
3 627 816 1618
3 627 628 816
3 628 728 816
3 628 1339 728
3 728 1339 729
3 1339 5848 729
3 1614 5999 1219
3 1219 5999 1616
3 1616 5999 1621
3 1334 1541 1329
3 1943 1824 2060
3 1943 1823 1824
3 1943 1945 1823
3 1945 1080 1823
3 1080 2076 1823
3 1080 2059 2076
3 1080 2078 2059
3 2078 2083 2059
3 2078 1100 2083
3 1099 1100 2078
3 1421 1099 2078
3 1831 1421 2078
3 1831 1423 1421
3 1831 5861 1423
3 5861 1448 1423
3 767 1448 5861
3 767 881 1448
3 767 1079 881
3 1076 1079 767
3 1103 1076 767
3 1275 1401 1103
3 1103 540 1076
3 1103 1401 540
3 1265 1401 1275
3 1265 1275 1776
3 1402 1265 1776
3 1974 1948 1919
3 1948 1944 1919
3 1944 6066 1919
3 1939 6066 2062
3 6066 2071 2062
3 6066 1939 1919
3 1974 1919 1975
3 2071 2072 2062
3 2071 2073 2072
3 2071 2063 2073
3 6058 2063 2071
3 6058 2060 2073
3 2063 6058 2073
3 2060 2074 2073
3 2061 2074 2060
3 1824 2061 2060
3 1401 541 540
3 235 541 1401
3 538 235 1401
3 266 538 1401
3 568 266 1401
3 266 537 538
3 537 536 538
3 538 536 235
3 235 536 5688
3 1107 1211 1209
3 1211 1626 1209
3 1626 1211 1212
3 1211 1222 1212
3 5998 5995 1720
3 5995 5998 1712
3 5998 1651 1712
3 5998 5967 1651
3 1662 5998 1634
3 1634 5998 1671
3 1671 5998 1720
3 5967 1633 1651
3 1636 1633 5967
3 5970 1636 5967
3 5970 1650 1636
3 1636 1650 1633
3 1650 1635 1633
3 1650 1375 1635
3 5959 5968 1375
3 1635 1375 1106
3 1375 1627 1106
3 5968 1627 1375
3 5959 1637 5968
3 5959 1628 1637
3 5963 1628 5959
3 1213 5963 5959
3 5958 1213 5959
3 1209 5958 5959
3 1626 5958 1209
3 541 235 5688
3 541 5688 5875
3 541 5875 5879
3 5879 5875 5876
3 5876 5875 5877
3 5875 771 5877
3 5875 241 771
3 241 238 771
3 241 1657 238
3 241 542 1657
3 539 542 241
3 6101 542 539
3 542 1656 1657
3 542 1655 1656
3 542 5996 1655
3 234 5996 542
3 5996 1253 5997
3 5996 5997 1655
3 1253 1706 5997
3 1253 1653 1706
3 1253 1670 1653
3 1662 1670 1253
3 1670 1662 1671
3 1662 1634 1671
3 5960 1614 1222
3 1212 1222 5964
3 1222 1625 5964
3 1219 1625 1222
3 1614 1219 1222
3 1921 261 2022
3 532 1921 2022
3 532 2022 1869
3 2020 532 1869
3 2020 1869 2019
3 2019 1869 1867
3 1869 1926 1867
3 991 2019 1867
3 991 1867 2033
3 2031 991 2033
3 2021 991 2031
3 1938 2021 2031
3 1937 1938 2031
3 1935 1937 2031
3 2027 1937 1935
3 2042 2027 1935
3 2048 6056 2042
3 6056 2027 2042
3 2047 2048 1970
3 2048 1972 6056
3 1951 1972 2048
3 1951 2048 2047
3 2049 2047 1970
3 1976 2049 1970
3 1976 1970 1971
3 1970 1969 1971
3 1969 1970 2043
3 1969 2043 1987
3 1971 1969 1987
3 1984 1976 1971
3 2050 1976 1984
3 1976 1975 2049
3 1975 1950 2049
3 1975 1973 1950
3 1919 1973 1975
3 1921 756 2023
3 2025 756 1921
3 1921 2023 261
3 353 352 5138
3 5138 352 564
3 352 350 564
3 5137 5138 564
3 5137 564 563
3 4383 5137 563
3 4383 563 562
3 562 563 4453
3 829 823 824
3 829 824 820
3 5139 829 820
3 5139 820 633
3 591 5139 633
3 591 633 353
3 591 353 5138
3 4456 4453 345
3 551 562 4453
3 551 4453 550
3 550 4453 4456
3 728 729 811
3 811 729 809
3 729 819 809
3 809 819 731
3 731 819 5139
3 819 829 5139
3 819 823 829
3 4454 4456 345
3 4454 345 4455
3 1693 1678 1684
3 703 1675 1693
3 1704 1692 703
3 1704 703 1686
3 1692 1675 703
3 1721 1686 5975
3 1704 1686 1721
3 1721 5975 1092
3 5991 1092 1383
3 1721 1092 5991
3 715 5991 1383
3 1729 5991 715
3 5976 5991 1729
3 1735 5976 1729
3 4454 4455 4567
3 4457 4454 4567
3 548 4457 4567
3 4381 4456 548
3 549 4381 548
3 4457 548 4454
3 548 4456 4454
3 4382 4566 549
3 549 550 4381
3 4566 550 549
3 300 4566 4382
3 301 300 4382
3 301 4382 298
3 182 301 298
3 182 298 299
3 182 299 4385
3 1379 4385 1255
3 1255 4385 1256
3 4385 579 1256
3 1369 182 4385
3 1369 4385 1379
3 1256 579 286
3 1252 1256 286
3 544 1255 1252
3 544 1252 545
3 1255 1256 1252
3 1674 1673 545
3 1674 545 1675
3 1673 544 545
3 1692 1676 1675
3 1676 1674 1675
3 5870 760 6067
3 5870 759 760
3 5870 6067 5871
3 5871 6067 2025
3 5871 2025 2024
3 2024 2025 1921
3 1661 279 5971
3 1661 5971 309
3 1661 4359 279
3 773 1661 309
3 2081 773 2082
3 2082 773 5129
3 525 1661 773
3 2081 525 773
3 2082 5129 6062
3 6061 531 5870
3 6061 5870 1941
3 1941 5870 5871
3 2083 2082 6062
3 2083 6062 6060
3 6060 6062 5869
3 5869 6062 6061
3 5869 6061 1941
3 1733 5976 1735
3 5978 1733 1736
3 5976 1733 5978
3 5977 5978 1736
3 1728 5976 5978
3 1737 1728 5978
3 1723 1737 5978
3 1723 5978 708
3 5852 1112 772
3 566 5852 772
3 1659 566 772
3 1659 772 1660
3 1386 1725 772
3 1112 1386 772
3 1659 1660 1661
3 1660 4360 1661
3 4360 1660 713
3 4360 713 4359
3 5972 1737 1723
3 5972 1723 1725
3 1386 5972 1725
3 1661 4360 4359
3 1219 1616 1621
3 1219 1621 1625
3 1625 1621 1221
3 1621 701 1221
3 1221 701 1615
3 701 1619 1615
3 1221 1615 1623
3 1623 1615 1622
3 1622 1615 1215
3 1615 1217 1215
3 1217 1218 1215
3 1215 1218 622
3 1218 817 622
3 1218 1410 817
3 816 1410 1218
3 816 811 1410
3 816 728 811
3 1824 5869 2061
3 1824 1823 5869
3 1823 2075 5869
3 2076 2075 1823
3 2076 6060 2075
3 2076 2059 6060
3 2059 2083 6060
3 2058 2082 2083
3 1100 2058 2083
3 1099 1423 1100
3 1420 2058 1100
3 1448 1420 1100
3 1423 1448 1100
3 1421 1423 1099
3 1448 1419 1420
3 881 1419 1448
3 881 5874 1419
3 881 5878 5874
3 1079 5878 881
3 1079 1076 5878
3 1076 5876 1078
3 1076 1077 5876
3 540 1077 1076
3 1076 1078 5878
3 540 5879 1077
3 540 541 5879
3 1973 1919 1950
3 1950 1919 1951
3 1919 1972 1951
3 1919 990 1972
3 1919 1939 990
3 1939 2062 990
3 2062 1940 990
3 2062 1922 1940
3 1942 1922 2062
3 2072 1942 2062
3 2073 1942 2072
3 2073 2074 1942
3 2074 1941 1942
3 2074 2061 1941
3 2061 5869 1941
3 1626 1212 5958
3 5958 1212 1213
3 1212 5964 1213
3 5979 1671 1720
3 1732 5979 1720
3 1719 1732 1720
3 1719 1720 1682
3 1682 1720 1667
3 1667 1720 1715
3 1715 1720 1711
3 1720 5973 1711
3 1720 1666 5973
3 1720 5983 1666
3 1720 1731 5983
3 5995 1731 1720
3 5995 5980 1731
3 5995 5982 5980
3 5995 1712 5982
3 5982 1712 1709
3 1712 1643 1709
3 1712 1651 1643
3 1651 5966 1643
3 1633 5966 1651
3 1670 1671 1664
3 1664 1671 1663
3 1663 1671 5979
3 1633 1632 5966
3 1635 1632 1633
3 1635 1201 1632
3 1635 1106 1201
3 5968 1637 1627
3 1201 1106 1738
3 1106 1644 1738
3 1106 1627 1644
3 1627 1631 1644
3 1627 1216 1631
3 1637 1216 1627
3 1637 1628 1216
3 1216 1628 1629
3 1628 1368 1629
3 1368 1628 1215
3 1628 1622 1215
3 1623 1622 1628
3 1624 1623 1628
3 5963 1624 1628
3 5963 5964 1624
3 1213 5964 5963
3 1077 5879 5876
3 5876 5877 5878
3 1078 5876 5878
3 5878 5877 1450
3 5877 5687 1450
3 5877 771 5687
3 771 567 5687
3 771 238 567
3 238 1657 567
3 567 1657 566
3 1657 1656 566
3 1656 1112 566
3 1656 575 1112
3 1656 1655 575
3 1655 5997 575
3 5997 1718 575
3 5997 1669 1718
3 5997 1706 1669
3 1706 1732 1669
3 1706 1653 1732
3 1653 1663 1732
3 1653 1670 1663
3 1670 1664 1663
3 5964 1220 1624
3 1625 1220 5964
3 1625 1221 1220
3 2024 1921 532
3 1923 2024 532
3 1923 532 2020
3 1923 2020 1925
3 1925 2020 2021
3 2021 2020 2019
3 2021 2019 991
3 1936 1925 2021
3 1938 1936 2021
3 1936 1938 1937
3 2027 1936 1937
3 6056 1928 2027
3 1928 1936 2027
3 1968 1928 6056
3 1972 1968 6056
3 1950 1951 2047
3 2049 1950 2047
3 1972 990 1968
3 591 5138 5137
3 591 5137 561
3 5137 4383 561
3 561 4383 562
3 561 562 551
3 731 5139 591
3 340 731 591
3 340 591 4384
3 4384 591 297
3 297 591 561
3 4381 550 4456
3 4566 561 551
3 4566 551 550
3 1410 811 818
3 811 809 818
3 818 809 731
3 1410 818 731
3 817 1410 731
3 817 731 340
3 1692 1677 1676
3 5987 1677 1692
3 5984 5987 1692
3 5985 5984 1692
3 5985 1692 5973
3 5973 1692 1704
3 5973 1704 1721
3 1711 5973 1721
3 1711 1721 5974
3 5974 1721 5991
3 5976 5974 5991
3 5974 5976 1728
3 297 561 4566
3 594 297 4566
3 300 594 4566
3 594 300 301
3 4565 594 301
3 4565 301 182
3 1369 4565 182
3 1376 1255 1673
3 1673 1255 544
3 1377 1379 1255
3 1376 1377 1255
3 1372 1369 1379
3 1372 1379 1377
3 1372 4565 1369
3 1376 1673 1677
3 1677 1673 1674
3 1676 1677 1674
3 1922 1941 5871
3 1922 5871 5872
3 5872 5871 1920
3 1920 5871 2024
3 1920 2024 1923
3 1451 1450 1661
3 525 1451 1661
3 566 1659 1661
3 5687 566 1661
3 1450 5687 1661
3 2058 2081 2082
3 1420 2081 2058
3 1451 525 2081
3 5873 1451 2081
3 5873 2081 1420
3 1941 1922 1942
3 2075 6060 5869
3 714 1724 1728
3 1385 714 1728
3 1722 1385 1728
3 1737 1722 1728
3 1724 5974 1728
3 1384 1722 1737
3 5972 1384 1737
3 1112 1384 1386
3 1112 1387 1384
3 575 1387 1112
3 1112 5852 566
3 567 566 5687
3 1386 1384 5972
3 1220 1221 1623
3 1220 1623 1624
3 1368 1215 1370
3 1370 1215 5851
3 1215 700 5851
3 1215 622 700
3 622 623 1374
3 622 817 623
3 700 622 1372
3 622 1374 1372
3 623 817 340
3 1419 5873 1420
3 5874 5873 1419
3 5874 5878 5873
3 5878 1450 5873
3 990 1929 1968
3 1929 990 1924
3 990 1940 1924
3 1940 1922 1924
3 1922 5872 1924
3 1732 1663 5979
3 1732 1665 1669
3 1732 1719 1665
3 1665 1719 1667
3 1719 1682 1667
3 1668 1665 1667
3 1668 1667 1715
3 1713 1715 1690
3 1690 1715 1711
3 1717 1668 1715
3 1717 1715 1713
3 1690 1711 1250
3 1250 1711 5974
3 5990 5985 5973
3 5986 5990 5973
3 1666 5986 5973
3 5983 5981 1666
3 1666 1705 5986
3 5981 1705 1666
3 1714 5981 5983
3 1731 1714 5983
3 5980 1714 1731
3 5980 5981 1714
3 5980 5982 5981
3 5982 1739 5981
3 1739 5982 1710
3 5982 1709 1710
3 1709 1707 1710
3 1707 1709 1691
3 1691 1709 5984
3 1709 578 5984
3 1709 1643 578
3 5966 1738 1643
3 1643 1378 578
3 1643 1251 1378
3 1738 1251 1643
3 1201 1738 5966
3 1632 1201 5966
3 1738 1644 1251
3 1644 1631 1630
3 1644 1630 1251
3 1631 1216 1630
3 1216 1629 1630
3 1368 5969 1629
3 1629 1371 1630
3 1629 5969 1371
3 1368 1638 5969
3 1638 1368 1370
3 5873 1450 1449
3 1449 1450 1451
3 575 1718 1726
3 575 1726 1387
3 1718 1717 1726
3 1718 1669 1717
3 1669 1668 1717
3 1669 1665 1668
3 1924 1920 1923
3 1870 1924 1923
3 1870 1923 1925
3 1936 1870 1925
3 1924 1870 1936
3 1968 1924 1936
3 1968 1936 1928
3 1968 1929 1924
3 623 340 808
3 808 340 4384
3 808 4384 594
3 4384 297 594
3 5987 1376 1677
3 5987 578 1376
3 5984 578 5987
3 1691 5984 1683
3 1683 5984 5985
3 5990 1683 5985
3 1724 1250 5974
3 1214 808 594
3 4565 1214 594
3 4655 1214 4565
3 1372 4655 4565
3 1382 1377 1376
3 578 1382 1376
3 1645 1373 1377
3 1380 1645 1377
3 1641 1380 1377
3 1642 1641 1377
3 1382 1642 1377
3 1373 1372 1377
3 1374 4655 1372
3 1373 700 1372
3 5872 1920 1924
3 5873 1449 1451
3 714 1250 1724
3 714 1690 1250
3 1689 1690 714
3 1716 1689 714
3 1727 1716 714
3 1727 714 1385
3 1384 1385 1722
3 576 1727 1385
3 576 1385 1384
3 1387 576 1384
3 1387 1726 576
3 1640 1370 5851
3 1638 1370 1640
3 1640 5851 1373
3 5851 700 1373
3 1374 623 4655
3 623 808 4655
3 1689 1713 1690
3 1716 1713 1689
3 1717 1713 1716
3 1726 1717 1716
3 1710 1683 5990
3 5986 1710 5990
3 1705 1710 5986
3 5981 1708 1705
3 5981 1739 1708
3 1708 1710 1705
3 1708 1739 1710
3 1710 1707 1683
3 1707 1691 1683
3 578 1378 1382
3 1382 1378 1641
3 1378 1381 1641
3 1378 1646 1381
3 1251 1646 1378
3 1630 1371 1251
3 1646 1251 1647
3 1251 1371 1647
3 5969 1640 1371
3 5969 1638 1640
3 1371 1640 1647
3 1726 1727 576
3 1726 1716 1727
3 808 1214 4655
3 1642 1382 1641
3 1640 1373 1645
3 1640 1645 1647
3 1647 1645 1639
3 1639 1645 1380
3 1641 1639 1380
3 1381 1639 1641
3 1647 1639 1381
3 1646 1647 1381
B1.off
OFF
840 1676 0
12659 10971 1700
12659 10993 1700
12664 11014 1700
12674 11034 1700
13227 11917 1700
13238 11932 1700
13252 11944 1700
13267 11953 1700
13284 11960 1700
14448 12304 1700
14466 12307 1700
14486 12307 1700
14504 12304 1700
15090 12131 1700
15110 12122 1700
15127 12110 1700
15142 12095 1700
15641 11432 1700
15651 11417 1700
15657 11401 1700
15661 11384 1700
15769 10460 1700
15770 10441 1700
15767 10422 1700
15760 10405 1700
15750 10388 1700
15244 9714 1700
15231 9700 1700
15217 9689 1700
15200 9681 1700
15182 9676 1700
13668 9394 1700
13649 9392 1700
13631 9394 1700
13613 9399 1700
13597 9407 1700
13582 9418 1700
12769 10150 1700
12756 10163 1700
12747 10179 1700
12740 10196 1700
12736 10214 1700
12604 10965 1850
12605 10999 1850
12612 11032 1850
12627 11063 1850
13181 11946 1850
13198 11968 1850
13219 11987 1850
13242 12002 1850
13268 12012 1850
14432 12356 1850
14461 12362 1850
14491 12362 1850
14520 12356 1850
15106 12183 1850
15136 12170 1850
15163 12152 1850
15185 12128 1850
15685 11465 1850
15699 11442 1850
15709 11417 1850
15715 11390 1850
15824 10466 1850
15824 10437 1850
15819 10408 1850
15809 10381 1850
15794 10356 1850
15287 9681 1850
15268 9660 1850
15245 9643 1850
15220 9630 1850
15192 9622 1850
13678 9340 1850
13649 9338 1850
13621 9340 1850
13594 9348 1850
13569 9360 1850
13546 9377 1850
12732 10109 1850
12713 10130 1850
12698 10154 1850
12688 10180 1850
12682 10208 1850
12505 10955 1850
12505 11011 1850
12518 11065 1850
12543 11116 1850
13096 11999 1850
13124 12036 1850
13158 12067 1850
13197 12091 1850
13240 12108 1850
14404 12452 1850
14452 12461 1850
14500 12461 1850
14548 12452 1850
15134 12279 1850
15184 12258 1850
15228 12227 1850
15265 12188 1850
15765 11525 1850
15789 11487 1850
15805 11446 1850
15814 11402 1850
15923 10478 1850
15924 10430 1850
15916 10382 1850
15899 10337 1850
15874 10295 1850
15367 9621 1850
15336 9586 1850
15298 9558 1850
15256 9537 1850
15210 9524 1850
13696 9242 1850
13649 9238 1850
13603 9242 1850
13558 9254 1850
13516 9275 1850
13479 9303 1850
12666 10035 1850
12634 10069 1850
12609 10109 1850
12592 10152 1850
12583 10198 1850
12451 10949 2000
12451 11017 2000
12467 11084 2000
12496 11145 2000
13050 12028 2000
13084 12073 2000
13125 12110 2000
13172 12140 2000
13224 12161 2000
14388 12504 2000
14446 12516 2000
14506 12516 2000
14564 12504 2000
15149 12331 2000
15210 12306 2000
15264 12269 2000
15309 12221 2000
15808 11558 2000
15837 11512 2000
15857 11461 2000
15869 11408 2000
15977 10484 2000
15979 10426 2000
15969 10368 2000
15948 10313 2000
15917 10263 2000
15411 9588 2000
15373 9546 2000
15327 9511 2000
15276 9486 2000
15220 9470 2000
13706 9188 2000
13649 9183 2000
13593 9188 2000
13539 9203 2000
13488 9228 2000
13442 9262 2000
12629 9994 2000
12590 10036 2000
12560 10084 2000
12539 10137 2000
12528 10192 2000
12351 10939 2000
12352 11029 2000
12372 11117 2000
12412 11198 2000
12965 12081 2000
13010 12140 2000
13065 12190 2000
13127 12229 2000
13196 12256 2000
14360 12600 2000
14437 12615 2000
14515 12615 2000
14592 12600 2000
15178 12427 2000
15258 12394 2000
15329 12344 2000
15388 12281 2000
15888 11618 2000
15926 11557 2000
15953 11490 2000
15968 11420 2000
16077 10496 2000
16078 10418 2000
16065 10342 2000
16038 10269 2000
15997 10203 2000
15491 9528 2000
15440 9472 2000
15380 9426 2000
15312 9393 2000
15239 9372 2000
13724 9090 2000
13650 9083 2000
13575 9090 2000
13503 9110 2000
13436 9143 2000
13376 9188 2000
12562 9920 2000
12511 9975 2000
12471 10038 2000
12443 10108 2000
12429 10182 2000
12297 10933 2150
12298 11036 2150
12321 11135 2150
12365 11227 2150
12919 12110 2150
12970 12177 2150
13032 12233 2150
13103 12278 2150
13181 12309 2150
14345 12653 2150
14432 12670 2150
14520 12670 2150
14608 12653 2150
15193 12479 2150
15284 12442 2150
15365 12386 2150
15432 12314 2150
15932 11651 2150
15975 11582 2150
16005 11506 2150
16022 11426 2150
16131 10503 2150
16133 10414 2150
16118 10328 2150
16087 10245 2150
16041 10170 2150
15535 9496 2150
15477 9432 2150
15408 9380 2150
15331 9342 2150
15249 9318 2150
13734 9036 2150
13650 9028 2150
13565 9036 2150
13483 9059 2150
13407 9097 2150
13339 9147 2150
12526 9879 2150
12468 9942 2150
12422 10014 2150
12391 10093 2150
12374 10177 2150
12197 10923 2150
12198 11047 2150
12227 11168 2150
12281 11280 2150
12834 12163 2150
12896 12245 2150
12971 12313 2150
13058 12367 2150
13152 12405 2150
14316 12749 2150
14422 12769 2150
14530 12769 2150
14636 12749 2150
15222 12575 2150
15332 12529 2150
15430 12461 2150
15512 12374 2150
16012 11711 2150
16064 11627 2150
16101 11535 2150
16121 11438 2150
16230 10514 2150
16232 10407 2150
16214 10301 2150
16177 10201 2150
16121 10110 2150
15615 9436 2150
15544 9358 2150
15461 9295 2150
15368 9248 2150
15267 9220 2150
13752 8938 2150
13650 8928 2150
13547 8938 2150
13448 8966 2150
13355 9011 2150
13272 9073 2150
12459 9805 2150
12388 9881 2150
12333 9968 2150
12295 10065 2150
12275 10166 2150
12143 10918 2300
12144 11054 2300
12175 11187 2300
12234 11309 2300
12788 12192 2300
12856 12281 2300
12938 12357 2300
13033 12416 2300
13137 12457 2300
14301 12801 2300
14417 12823 2300
14535 12823 2300
14651 12801 2300
15237 12628 2300
15358 12577 2300
15466 12503 2300
15555 12407 2300
16055 11744 2300
16113 11652 2300
16153 11551 2300
16176 11444 2300
16284 10521 2300
16287 10403 2300
16267 10287 2300
16226 10177 2300
16165 10077 2300
15658 9403 2300
15581 9318 2300
15490 9249 2300
15387 9198 2300
15277 9166 2300
13762 8884 2300
13650 8874 2300
13537 8884 2300
13428 8915 2300
13326 8965 2300
13236 9032 2300
12422 9764 2300
12345 9848 2300
12285 9944 2300
12243 10049 2300
12221 10161 2300
12044 10908 2300
12045 11066 2300
12081 11220 2300
12150 11362 2300
12703 12246 2300
12782 12349 2300
12878 12436 2300
12988 12505 2300
13108 12553 2300
14272 12897 2300
14407 12923 2300
14545 12923 2300
14680 12897 2300
15265 12724 2300
15406 12665 2300
15531 12578 2300
15635 12467 2300
16135 11804 2300
16202 11697 2300
16249 11580 2300
16275 11456 2300
16384 10532 2300
16387 10396 2300
16364 10261 2300
16316 10133 2300
16245 10017 2300
15738 9343 2300
15649 9244 2300
15543 9164 2300
15423 9104 2300
15295 9068 2300
13781 8786 2300
13650 8774 2300
13519 8786 2300
13392 8821 2300
13274 8879 2300
13169 8958 2300
12355 9690 2300
12266 9787 2300
12195 9898 2300
12147 10021 2300
12121 10151 2300
11989 10902 2450
11991 11072 2450
12029 11238 2450
12103 11391 2450
12657 12275 2450
12742 12386 2450
12845 12480 2450
12963 12554 2450
13093 12605 2450
14257 12949 2450
14402 12977 2450
14550 12977 2450
14695 12949 2450
15281 12776 2450
15432 12713 2450
15567 12620 2450
15679 12500 2450
16179 11837 2450
16251 11722 2450
16301 11595 2450
16329 11462 2450
16438 10539 2450
16441 10392 2450
16416 10247 2450
16365 10109 2450
16288 9984 2450
15782 9310 2450
15686 9204 2450
15571 9117 2450
15443 9053 2450
15305 9014 2450
13791 8732 2450
13650 8719 2450
13509 8732 2450
13373 8770 2450
13246 8833 2450
13132 8918 2450
12319 9649 2450
12222 9753 2450
12147 9874 2450
12094 10006 2450
12067 10145 2450
11890 10892 2450
11891 11084 2450
11935 11271 2450
12019 11444 2450
12572 12328 2450
12668 12453 2450
12784 12559 2450
12918 12643 2450
13065 12701 2450
14229 13045 2450
14393 13077 2450
14560 13077 2450
14724 13045 2450
15309 12872 2450
15480 12801 2450
15632 12695 2450
15759 12560 2450
16259 11898 2450
16340 11767 2450
16397 11624 2450
16428 11474 2450
16537 10550 2450
16541 10384 2450
16513 10221 2450
16455 10066 2450
16368 9924 2450
15862 9250 2450
15753 9130 2450
15624 9032 2450
15479 8960 2450
15324 8916 2450
13809 8634 2450
13650 8619 2450
13491 8634 2450
13337 8677 2450
13194 8748 2450
13065 8843 2450
12252 9575 2450
12143 9693 2450
12058 9828 2450
11998 9977 2450
11967 10135 2450
11836 10886 2600
11837 11090 2600
11884 11289 2600
11972 11473 2600
12526 12357 2600
12628 12490 2600
12751 12603 2600
12893 12692 2600
13049 12754 2600
14213 13097 2600
14387 13131 2600
14565 13131 2600
14739 13097 2600
15325 12924 2600
15506 12849 2600
15668 12737 2600
15802 12593 2600
16302 11930 2600
16389 11792 2600
16449 11640 2600
16483 11480 2600
16591 10557 2600
16595 10381 2600
16566 10207 2600
16504 10042 2600
16412 9891 2600
15905 9217 2600
15790 9090 2600
15653 8986 2600
15499 8909 2600
15334 8862 2600
13819 8580 2600
13650 8565 2600
13481 8580 2600
13317 8626 2600
13165 8701 2600
13029 8803 2600
12216 9534 2600
12100 9659 2600
12009 9804 2600
11946 9962 2600
11913 10129 2600
11736 10876 2600
11738 11102 2600
11789 11323 2600
11888 11527 2600
12441 12410 2600
12554 12558 2600
12691 12683 2600
12848 12781 2600
13021 12849 2600
14185 13193 2600
14378 13231 2600
14574 13231 2600
14767 13193 2600
15353 13020 2600
15554 12936 2600
15733 12812 2600
15882 12653 2600
16382 11991 2600
16478 11837 2600
16545 11669 2600
16582 11492 2600
16691 10568 2600
16695 10373 2600
16662 10181 2600
16594 9998 2600
16492 9831 2600
15985 9157 2600
15857 9016 2600
15706 8901 2600
15535 8816 2600
15352 8764 2600
13837 8482 2600
13650 8465 2600
13463 8482 2600
13282 8533 2600
13113 8616 2600
12962 8728 2600
12149 9460 2600
12020 9599 2600
11920 9758 2600
11850 9934 2600
11814 10119 2600
11682 10870 2750
11684 11109 2750
11738 11341 2750
11841 11556 2750
12395 12439 2750
12513 12594 2750
12658 12726 2750
12824 12830 2750
13005 12902 2750
14169 13246 2750
14373 13285 2750
14580 13285 2750
14783 13246 2750
15369 13072 2750
15580 12984 2750
15769 12854 2750
15926 12686 2750
16426 12023 2750
16526 11862 2750
16597 11685 2750
16636 11498 2750
16745 10575 2750
16749 10369 2750
16715 10166 2750
16643 9974 2750
16535 9798 2750
16029 9124 2750
15894 8976 2750
15734 8855 2750
15555 8765 2750
15362 8710 2750
13847 8428 2750
13650 8410 2750
13453 8428 2750
13262 8482 2750
13084 8569 2750
12926 8688 2750
12112 9419 2750
11977 9565 2750
11871 9734 2750
11798 9918 2750
11759 10114 2750
11582 10860 2750
11584 11121 2750
11643 11374 2750
11757 11609 2750
12310 12492 2750
12440 12662 2750
12597 12806 2750
12779 12919 2750
12977 12998 2750
14141 13342 2750
14363 13385 2750
14589 13385 2750
14811 13342 2750
15397 13168 2750
15628 13072 2750
15834 12929 2750
16006 12746 2750
16505 12084 2750
16616 11907 2750
16693 11714 2750
16736 11510 2750
16844 10586 2750
16849 10362 2750
16812 10140 2750
16733 9930 2750
16615 9738 2750
16109 9064 2750
15962 8902 2750
15787 8770 2750
15591 8672 2750
15380 8612 2750
13866 8330 2750
13650 8310 2750
13435 8330 2750
13226 8388 2750
13032 8484 2750
12859 8613 2750
12045 9345 2750
11898 9504 2750
11782 9688 2750
11702 9890 2750
11660 10103 2750
11528 10855 2900
11530 11127 2900
11592 11392 2900
11710 11638 2900
12264 12521 2900
12399 12699 2900
12564 12849 2900
12754 12968 2900
12962 13050 2900
14126 13394 2900
14358 13439 2900
14595 13439 2900
14827 13394 2900
15413 13221 2900
15655 13120 2900
15870 12971 2900
16049 12779 2900
16549 12117 2900
16664 11932 2900
16745 11730 2900
16790 11516 2900
16898 10593 2900
16904 10358 2900
16864 10126 2900
16782 9906 2900
16659 9706 2900
16153 9031 2900
15999 8862 2900
15816 8723 2900
15611 8621 2900
15390 8558 2900
13876 8276 2900
13650 8255 2900
13425 8276 2900
13207 8337 2900
13004 8437 2900
12822 8573 2900
12009 9304 2900
11854 9471 2900
11733 9664 2900
11649 9875 2900
11606 10098 2900
11428 10844 2900
11431 11139 2900
11498 11426 2900
11626 11691 2900
12179 12574 2900
12326 12766 2900
12504 12929 2900
12709 13057 2900
12933 13146 2900
14097 13490 2900
14348 13539 2900
14604 13539 2900
14855 13490 2900
15441 13317 2900
15703 13208 2900
15935 13046 2900
16129 12840 2900
16629 12177 2900
16753 11977 2900
16841 11759 2900
16889 11528 2900
16998 10605 2900
17003 10351 2900
16961 10100 2900
16872 9862 2900
16739 9646 2900
16233 8971 2900
16066 8788 2900
15869 8638 2900
15647 8528 2900
15408 8460 2900
13894 8178 2900
13650 8155 2900
13406 8178 2900
13171 8244 2900
12951 8352 2900
12755 8498 2900
11942 9230 2900
11775 9410 2900
11644 9618 2900
11553 9847 2900
11506 10088 2900
11374 10839 3050
11377 11145 3050
11446 11444 3050
11579 11720 3050
12133 12603 3050
12285 12803 3050
12471 12972 3050
12684 13106 3050
12918 13198 3050
14082 13542 3050
14343 13593 3050
14609 13593 3050
14871 13542 3050
15456 13369 3050
15729 13256 3050
15971 13088 3050
16173 12872 3050
16672 12210 3050
16802 12002 3050
16893 11774 3050
16943 11534 3050
17052 10611 3050
17058 10347 3050
17013 10086 3050
16921 9838 3050
16783 9613 3050
16276 8939 3050
16103 8748 3050
15897 8592 3050
15667 8477 3050
15418 8406 3050
13904 8124 3050
13650 8101 3050
13397 8124 3050
13151 8193 3050
12923 8305 3050
12719 8458 3050
11905 9189 3050
11732 9377 3050
11595 9594 3050
11501 9831 3050
11452 10082 3050
11275 10829 3050
11277 11157 3050
11352 11477 3050
11495 11773 3050
12048 12656 3050
12212 12871 3050
12411 13052 3050
12639 13195 3050
12889 13294 3050
14053 13638 3050
14334 13692 3050
14619 13692 3050
14899 13638 3050
15485 13465 3050
15777 13343 3050
16036 13163 3050
16252 12933 3050
16752 12270 3050
16891 12047 3050
16989 11803 3050
17043 11546 3050
17151 10623 3050
17158 10339 3050
17110 10060 3050
17011 9795 3050
16863 9553 3050
16356 8879 3050
16170 8674 3050
15950 8507 3050
15703 8384 3050
15437 8308 3050
13922 8026 3050
13650 8001 3050
13378 8026 3050
13116 8100 3050
12871 8220 3050
12652 8383 3050
11838 9115 3050
11652 9316 3050
11506 9548 3050
11405 9803 3050
11352 10072 3050
11220 10823 3200
11223 11164 3200
11300 11495 3200
11448 11802 3200
12002 12685 3200
12171 12907 3200
12378 13096 3200
12614 13244 3200
12874 13347 3200
14038 13691 3200
14328 13747 3200
14624 13747 3200
14915 13690 3200
15500 13517 3200
15803 13391 3200
16072 13205 3200
16296 12965 3200
16796 12303 3200
16940 12072 3200
17041 11819 3200
17097 11553 3200
17206 10629 3200
17212 10335 3200
17163 10046 3200
17060 9771 3200
16906 9520 3200
16400 8846 3200
16207 8634 3200
15979 8461 3200
15722 8333 3200
15447 8254 3200
13932 7972 3200
13650 7946 3200
13369 7972 3200
13096 8049 3200
12842 8174 3200
12615 8343 3200
11802 9074 3200
11609 9283 3200
11458 9523 3200
11353 9788 3200
11298 10066 3200
3 1 0 42
3 0 41 42
3 2 0 1
3 2 3 0
3 3 4 0
3 4 5 0
3 5 6 0
3 6 7 0
3 7 8 0
3 8 9 0
3 9 10 0
3 10 11 0
3 11 12 0
3 12 13 0
3 13 14 0
3 14 15 0
3 15 16 0
3 16 17 0
3 17 18 0
3 18 19 0
3 19 20 0
3 20 21 0
3 21 22 0
3 22 23 0
3 23 24 0
3 24 25 0
3 25 26 0
3 26 27 0
3 27 28 0
3 28 29 0
3 29 30 0
3 30 31 0
3 31 32 0
3 32 33 0
3 33 34 0
3 34 35 0
3 35 36 0
3 36 37 0
3 37 38 0
3 38 39 0
3 39 40 0
3 40 41 0
3 86 84 85
3 86 87 84
3 87 88 84
3 88 89 84
3 89 90 84
3 90 91 84
3 91 92 84
3 92 93 50
3 96 97 54
3 94 95 50
3 98 99 55
3 99 100 57
3 100 101 58
3 107 66 65
3 102 103 60
3 103 104 62
3 105 106 63
3 106 107 65
3 107 108 66
3 108 109 67
3 109 110 68
3 110 111 70
3 111 112 72
3 114 115 73
3 115 116 77
3 116 117 78
3 120 79 78
3 119 120 78
3 118 119 78
3 120 121 79
3 121 122 84
3 122 123 84
3 123 124 84
3 124 125 84
3 84 42 83
3 117 118 78
3 83 121 84
3 82 121 83
3 81 121 82
3 80 121 81
3 79 121 80
3 115 77 76
3 115 76 75
3 73 115 74
3 111 72 71
3 110 70 69
3 106 65 64
3 103 62 61
3 96 51 50
3 105 63 62
3 104 105 62
3 102 60 59
3 106 64 63
3 99 57 56
3 99 56 55
3 98 55 54
3 95 96 50
3 97 98 54
3 96 54 53
3 93 94 50
3 96 53 52
3 96 52 51
3 92 50 49
3 84 46 45
3 92 49 48
3 92 48 47
3 92 47 46
3 92 46 84
3 84 45 44
3 84 44 43
3 108 67 66
3 84 43 42
3 100 58 57
3 101 102 58
3 102 59 58
3 103 61 60
3 109 68 67
3 110 69 68
3 111 71 70
3 112 113 72
3 113 114 72
3 116 78 77
3 115 75 74
3 114 73 72
3 41 83 42
3 43 1 42
3 44 1 43
3 2 1 44
3 41 40 83
3 40 82 83
3 40 39 82
3 39 81 82
3 39 38 81
3 38 80 81
3 38 79 80
3 38 37 79
3 37 78 79
3 36 78 37
3 36 77 78
3 36 35 77
3 35 76 77
3 35 34 76
3 34 75 76
3 33 75 34
3 33 74 75
3 32 74 33
3 32 73 74
3 31 73 32
3 30 72 31
3 31 72 73
3 71 72 30
3 29 71 30
3 28 71 29
3 70 71 28
3 27 70 28
3 69 70 27
3 68 69 27
3 26 68 27
3 67 68 26
3 25 67 26
3 24 67 25
3 66 67 24
3 65 66 24
3 23 65 24
3 64 65 23
3 22 64 23
3 63 64 22
3 63 22 21
3 63 21 20
3 62 63 20
3 62 20 19
3 61 62 19
3 60 61 19
3 60 19 18
3 60 18 17
3 59 60 17
3 59 17 16
3 58 59 16
3 58 16 15
3 57 58 15
3 56 57 15
3 56 15 14
3 56 14 13
3 55 56 13
3 55 12 54
3 55 13 12
3 54 12 11
3 53 54 11
3 11 52 53
3 11 10 52
3 52 10 9
3 52 9 51
3 9 50 51
3 9 8 50
3 50 8 49
3 8 7 49
3 7 6 49
3 49 6 48
3 6 5 48
3 48 5 47
3 5 4 47
3 46 4 45
3 4 3 45
3 47 4 46
3 3 2 45
3 45 2 44
3 85 126 127
3 85 84 126
3 84 125 126
3 125 166 167
3 125 124 166
3 125 167 126
3 124 123 166
3 123 165 166
3 122 165 123
3 122 164 165
3 122 121 164
3 121 163 164
3 121 120 163
3 163 120 162
3 120 119 162
3 119 161 162
3 119 118 161
3 118 160 161
3 118 117 160
3 117 159 160
3 117 116 159
3 116 158 159
3 116 115 158
3 115 157 158
3 114 156 115
3 115 156 157
3 155 156 114
3 113 155 114
3 154 155 113
3 112 154 113
3 111 154 112
3 111 153 154
3 152 153 111
3 110 152 111
3 151 152 110
3 109 151 110
3 108 151 109
3 150 151 108
3 149 150 108
3 107 149 108
3 148 149 107
3 106 148 107
3 148 106 105
3 147 148 105
3 147 105 146
3 146 105 104
3 146 104 103
3 145 146 103
3 144 145 103
3 144 103 102
3 144 102 101
3 143 144 101
3 143 101 100
3 142 143 100
3 142 100 99
3 141 142 99
3 141 99 98
3 140 141 98
3 140 98 139
3 139 98 97
3 139 97 138
3 138 97 96
3 138 96 137
3 137 96 95
3 95 136 137
3 95 94 136
3 136 94 93
3 136 93 135
3 135 93 134
3 93 92 134
3 134 92 133
3 92 91 133
3 133 91 132
3 91 90 132
3 132 90 131
3 90 89 131
3 89 88 130
3 131 89 130
3 130 88 129
3 88 87 129
3 87 86 129
3 129 86 128
3 128 86 127
3 86 85 127
3 170 168 169
3 170 171 168
3 171 172 168
3 172 173 168
3 173 174 168
3 174 175 168
3 175 176 168
3 176 177 134
3 179 180 136
3 180 181 138
3 182 183 140
3 183 184 141
3 184 185 142
3 185 186 143
3 186 187 144
3 187 188 146
3 189 190 147
3 190 191 149
3 191 192 150
3 192 193 151
3 193 194 152
3 194 195 153
3 195 196 155
3 196 197 156
3 198 199 157
3 199 200 159
3 200 201 161
3 201 202 162
3 204 163 162
3 203 204 162
3 204 205 164
3 205 206 168
3 206 207 168
3 207 208 168
3 208 209 168
3 168 126 167
3 202 203 162
3 167 205 168
3 166 205 167
3 165 205 166
3 204 164 163
3 164 205 165
3 200 161 160
3 199 159 158
3 195 155 154
3 190 149 148
3 187 146 145
3 189 147 146
3 188 189 146
3 190 148 147
3 191 150 149
3 192 151 150
3 193 152 151
3 182 140 139
3 194 153 152
3 180 138 137
3 195 154 153
3 196 156 155
3 179 136 135
3 197 198 156
3 176 134 133
3 168 130 129
3 176 133 132
3 176 132 131
3 176 131 130
3 176 130 168
3 168 129 128
3 198 157 156
3 168 127 126
3 177 178 134
3 178 179 134
3 180 137 136
3 179 135 134
3 181 182 138
3 182 139 138
3 183 141 140
3 184 142 141
3 185 143 142
3 186 144 143
3 187 145 144
3 199 158 157
3 201 162 161
3 200 160 159
3 168 128 127
3 169 168 211
3 211 168 210
3 168 209 210
3 209 250 251
3 209 208 250
3 209 251 210
3 208 207 250
3 207 249 250
3 207 248 249
3 207 206 248
3 206 247 248
3 205 247 206
3 205 246 247
3 204 246 205
3 204 245 246
3 203 245 204
3 203 244 245
3 202 244 203
3 202 243 244
3 201 243 202
3 201 200 243
3 200 242 243
3 200 199 242
3 199 241 242
3 198 240 199
3 199 240 241
3 239 240 198
3 197 239 198
3 238 239 197
3 196 238 197
3 237 238 196
3 195 237 196
3 236 237 195
3 194 236 195
3 235 236 194
3 193 235 194
3 234 235 193
3 192 234 193
3 191 234 192
3 233 234 191
3 190 233 191
3 232 233 190
3 232 190 189
3 231 232 189
3 231 189 188
3 230 231 188
3 230 188 187
3 229 230 187
3 228 229 187
3 228 187 186
3 228 186 185
3 227 228 185
3 226 227 184
3 184 227 185
3 226 184 183
3 225 226 183
3 225 183 224
3 224 183 182
3 224 182 223
3 223 182 181
3 223 181 222
3 222 181 180
3 222 180 179
3 221 222 179
3 179 220 221
3 179 178 220
3 220 178 177
3 220 177 219
3 177 218 219
3 177 176 218
3 218 176 175
3 218 175 217
3 217 175 174
3 217 174 216
3 216 174 173
3 215 173 172
3 216 173 215
3 215 172 214
3 214 172 171
3 214 171 213
3 171 170 213
3 213 170 212
3 170 169 212
3 212 169 211
3 254 252 253
3 254 255 252
3 255 256 252
3 256 257 252
3 257 258 213
3 259 260 216
3 260 261 218
3 283 242 241
3 262 263 219
3 263 264 221
3 264 265 222
3 265 266 223
3 266 267 224
3 267 268 225
3 268 269 226
3 269 270 227
3 270 271 228
3 271 272 230
3 273 274 231
3 274 275 233
3 275 276 234
3 276 277 235
3 277 278 236
3 278 279 237
3 279 280 238
3 280 281 240
3 282 283 241
3 283 284 242
3 284 285 244
3 285 286 246
3 288 247 246
3 288 289 247
3 289 290 250
3 290 291 252
3 291 292 252
3 292 293 252
3 252 210 251
3 252 251 250
3 289 250 249
3 250 290 252
3 252 213 212
3 287 288 246
3 248 289 249
3 247 289 248
3 285 246 245
3 284 244 243
3 280 240 239
3 274 233 232
3 271 230 229
3 273 231 230
3 272 273 230
3 274 232 231
3 275 234 233
3 276 235 234
3 277 236 235
3 278 237 236
3 279 238 237
3 263 221 220
3 280 239 238
3 282 241 240
3 281 282 240
3 260 218 217
3 260 217 216
3 259 214 213
3 259 216 215
3 258 259 213
3 259 215 214
3 257 213 252
3 252 212 211
3 252 211 210
3 261 262 218
3 262 219 218
3 263 220 219
3 264 222 221
3 265 223 222
3 266 224 223
3 267 225 224
3 268 226 225
3 269 227 226
3 270 228 227
3 271 229 228
3 284 243 242
3 286 287 246
3 285 245 244
3 253 252 294
3 293 294 252
3 293 335 294
3 293 292 335
3 292 334 335
3 292 291 334
3 291 333 334
3 291 290 333
3 290 332 333
3 290 289 332
3 289 331 332
3 289 288 331
3 288 330 331
3 288 287 330
3 287 329 330
3 287 328 329
3 286 328 287
3 286 285 328
3 285 327 328
3 285 284 327
3 284 326 327
3 284 283 326
3 283 325 326
3 282 324 283
3 283 324 325
3 323 324 282
3 281 323 282
3 280 323 281
3 280 322 323
3 321 322 280
3 279 321 280
3 320 321 279
3 278 320 279
3 319 320 278
3 277 319 278
3 318 319 277
3 276 318 277
3 275 318 276
3 317 318 275
3 316 317 275
3 274 316 275
3 316 274 273
3 315 316 273
3 315 273 272
3 314 315 272
3 313 314 272
3 313 272 271
3 312 313 271
3 312 271 270
3 312 270 311
3 311 270 269
3 310 311 268
3 268 311 269
3 310 268 267
3 309 310 267
3 309 267 266
3 308 309 266
3 308 266 307
3 307 266 265
3 307 265 306
3 306 265 264
3 306 264 305
3 305 264 263
3 263 304 305
3 263 262 304
3 304 262 303
3 262 261 303
3 261 302 303
3 261 260 302
3 302 260 259
3 302 259 301
3 301 259 258
3 301 258 300
3 300 258 299
3 258 257 299
3 257 256 298
3 299 257 298
3 298 256 297
3 256 255 297
3 297 255 296
3 255 254 296
3 296 254 295
3 254 253 295
3 295 253 294
3 338 336 337
3 338 339 336
3 339 340 297
3 342 343 298
3 343 344 300
3 344 345 302
3 367 326 325
3 346 347 304
3 347 348 305
3 348 349 306
3 349 350 307
3 350 351 308
3 351 352 309
3 352 353 310
3 353 354 311
3 354 355 312
3 355 356 314
3 357 358 315
3 358 359 317
3 359 360 318
3 360 361 319
3 361 362 320
3 362 363 321
3 363 364 322
3 364 365 323
3 365 366 324
3 366 367 325
3 367 368 326
3 368 369 327
3 369 370 329
3 370 371 330
3 372 373 331
3 373 374 334
3 374 375 336
3 375 376 336
3 376 377 336
3 336 294 335
3 373 333 332
3 335 374 336
3 334 374 335
3 373 334 333
3 331 373 332
3 369 329 328
3 358 317 316
3 355 314 313
3 357 315 314
3 356 357 314
3 358 316 315
3 359 318 317
3 360 319 318
3 361 320 319
3 362 321 320
3 363 322 321
3 364 323 322
3 365 324 323
3 346 304 303
3 366 325 324
3 344 302 301
3 343 300 299
3 343 299 298
3 341 342 297
3 340 341 297
3 339 297 296
3 336 296 295
3 339 296 336
3 368 327 326
3 336 295 294
3 344 301 300
3 342 298 297
3 347 305 304
3 345 346 302
3 346 303 302
3 348 306 305
3 349 307 306
3 350 308 307
3 351 309 308
3 352 310 309
3 353 311 310
3 354 312 311
3 355 313 312
3 369 328 327
3 370 330 329
3 371 372 330
3 372 331 330
3 336 419 378
3 377 419 336
3 337 336 378
3 377 418 419
3 377 376 418
3 376 417 418
3 376 375 417
3 375 374 417
3 374 416 417
3 374 415 416
3 373 415 374
3 373 414 415
3 372 414 373
3 372 413 414
3 371 413 372
3 371 412 413
3 370 412 371
3 370 411 412
3 369 411 370
3 369 368 411
3 368 410 411
3 368 367 410
3 367 409 410
3 366 408 367
3 367 408 409
3 365 408 366
3 365 407 408
3 364 406 365
3 365 406 407
3 363 406 364
3 363 405 406
3 362 405 363
3 362 404 405
3 403 404 362
3 361 403 362
3 360 403 361
3 360 402 403
3 359 402 360
3 401 402 359
3 400 401 359
3 358 400 359
3 399 400 358
3 399 358 357
3 399 357 398
3 398 357 356
3 397 398 356
3 397 356 355
3 396 397 355
3 396 355 354
3 396 354 395
3 395 354 353
3 394 395 352
3 352 395 353
3 394 352 393
3 393 352 351
3 393 351 392
3 392 351 350
3 392 350 391
3 391 350 349
3 391 349 390
3 390 349 348
3 390 348 389
3 389 348 347
3 347 388 389
3 347 346 388
3 388 346 345
3 388 345 387
3 345 386 387
3 345 344 386
3 386 344 343
3 386 343 385
3 385 343 342
3 385 342 384
3 384 342 383
3 342 341 383
3 341 340 382
3 383 341 382
3 382 340 381
3 340 339 381
3 381 339 380
3 339 338 380
3 380 338 379
3 338 337 379
3 379 337 378
3 422 420 421
3 422 423 420
3 423 424 381
3 426 427 383
3 427 428 385
3 428 429 386
3 451 410 409
3 430 431 388
3 431 432 389
3 432 433 390
3 433 434 391
3 434 435 392
3 435 436 393
3 436 437 394
3 437 438 395
3 438 439 396
3 439 440 398
3 441 442 399
3 442 443 401
3 443 444 402
3 444 445 403
3 445 446 404
3 446 447 405
3 447 448 406
3 448 449 407
3 449 450 408
3 450 451 409
3 451 452 410
3 452 453 411
3 453 454 413
3 454 455 414
3 456 457 416
3 457 458 418
3 458 459 420
3 459 460 420
3 460 461 420
3 420 378 419
3 457 417 416
3 419 458 420
3 457 418 417
3 418 458 419
3 456 416 415
3 453 413 412
3 442 401 400
3 439 398 397
3 441 399 398
3 440 441 398
3 442 400 399
3 443 402 401
3 444 403 402
3 445 404 403
3 446 405 404
3 447 406 405
3 448 407 406
3 449 408 407
3 430 388 387
3 450 409 408
3 452 411 410
3 427 385 384
3 453 412 411
3 426 383 382
3 423 381 380
3 420 380 379
3 423 380 420
3 454 414 413
3 420 379 378
3 424 425 381
3 425 426 381
3 427 384 383
3 428 386 385
3 426 382 381
3 429 430 386
3 430 387 386
3 431 389 388
3 432 390 389
3 433 391 390
3 434 392 391
3 435 393 392
3 436 394 393
3 437 395 394
3 438 396 395
3 439 397 396
3 455 456 414
3 456 415 414
3 421 420 462
3 461 462 420
3 461 503 462
3 461 502 503
3 461 460 502
3 460 501 502
3 459 501 460
3 459 458 501
3 457 499 458
3 458 500 501
3 458 499 500
3 457 498 499
3 456 498 457
3 456 497 498
3 455 497 456
3 455 454 497
3 454 496 497
3 454 453 496
3 453 495 496
3 453 452 495
3 452 494 495
3 452 451 494
3 451 493 494
3 450 492 451
3 451 492 493
3 449 492 450
3 449 491 492
3 448 491 449
3 448 490 491
3 447 490 448
3 447 489 490
3 446 489 447
3 446 488 489
3 445 488 446
3 445 487 488
3 444 487 445
3 444 486 487
3 443 486 444
3 443 485 486
3 442 485 443
3 484 485 442
3 484 442 441
3 483 484 441
3 483 441 440
3 482 483 440
3 482 440 439
3 481 482 439
3 481 439 480
3 480 439 438
3 480 438 479
3 479 438 437
3 479 437 478
3 478 437 436
3 478 436 477
3 477 436 435
3 477 435 476
3 476 435 434
3 476 434 433
3 475 476 433
3 475 433 432
3 474 475 432
3 474 432 431
3 473 474 431
3 431 472 473
3 431 430 472
3 472 430 471
3 430 429 471
3 471 429 470
3 429 428 470
3 470 428 469
3 428 427 469
3 469 427 468
3 427 426 468
3 468 426 425
3 425 424 466
3 468 425 467
3 467 425 466
3 466 424 465
3 424 423 465
3 465 423 464
3 423 422 464
3 464 422 463
3 422 421 463
3 463 421 462
3 506 504 505
3 506 507 504
3 507 508 465
3 510 511 467
3 511 512 469
3 512 513 470
3 513 514 471
3 514 515 472
3 515 516 473
3 516 517 474
3 517 518 475
3 518 519 476
3 519 520 477
3 520 521 478
3 521 522 479
3 522 523 480
3 523 524 482
3 525 526 483
3 526 527 485
3 527 528 486
3 528 529 487
3 529 530 488
3 530 531 489
3 531 532 490
3 532 533 491
3 533 534 492
3 534 535 493
3 535 536 494
3 536 537 495
3 537 538 496
3 538 539 498
3 540 541 500
3 541 542 501
3 542 543 504
3 543 544 504
3 544 545 504
3 504 462 503
3 542 502 501
3 503 502 504
3 502 542 504
3 540 499 498
3 541 501 500
3 540 500 499
3 538 498 497
3 526 485 484
3 523 482 481
3 510 466 465
3 525 483 482
3 524 525 482
3 526 484 483
3 527 486 485
3 528 487 486
3 529 488 487
3 530 489 488
3 531 490 489
3 532 491 490
3 533 492 491
3 534 493 492
3 535 494 493
3 536 495 494
3 511 469 468
3 537 496 495
3 510 467 466
3 538 497 496
3 507 465 464
3 504 464 463
3 507 464 504
3 504 463 462
3 508 509 465
3 509 510 465
3 511 468 467
3 512 470 469
3 513 471 470
3 514 472 471
3 515 473 472
3 516 474 473
3 517 475 474
3 518 476 475
3 519 477 476
3 520 478 477
3 521 479 478
3 522 480 479
3 523 481 480
3 539 540 498
3 505 504 546
3 504 545 546
3 545 544 587
3 545 587 546
3 544 586 587
3 544 543 586
3 543 585 586
3 543 584 585
3 542 584 543
3 541 583 542
3 542 583 584
3 541 582 583
3 540 582 541
3 540 581 582
3 539 581 540
3 539 538 581
3 538 580 581
3 538 537 580
3 537 579 580
3 537 536 579
3 536 578 579
3 536 535 578
3 535 577 578
3 534 576 535
3 535 576 577
3 533 576 534
3 533 575 576
3 532 575 533
3 532 574 575
3 531 574 532
3 531 573 574
3 530 573 531
3 530 572 573
3 571 572 530
3 529 571 530
3 570 571 529
3 528 570 529
3 569 570 528
3 527 569 528
3 526 569 527
3 568 569 526
3 568 526 525
3 567 568 525
3 567 525 566
3 566 525 524
3 566 524 523
3 565 566 523
3 565 523 522
3 564 565 522
3 564 522 521
3 563 564 521
3 563 521 520
3 562 563 520
3 562 520 519
3 561 562 519
3 561 519 518
3 560 561 518
3 560 518 517
3 559 560 517
3 559 517 516
3 558 559 516
3 558 516 515
3 557 558 515
3 515 556 557
3 515 514 556
3 556 514 513
3 556 513 555
3 513 554 555
3 513 512 554
3 554 512 511
3 554 511 553
3 553 511 510
3 553 510 552
3 552 510 509
3 551 509 508
3 552 509 551
3 551 508 550
3 550 508 507
3 550 507 549
3 549 507 506
3 549 506 548
3 548 506 505
3 548 505 547
3 547 505 546
3 590 588 589
3 590 591 588
3 591 592 549
3 623 624 582
3 593 594 550
3 594 595 552
3 595 596 553
3 596 597 554
3 597 598 555
3 598 599 556
3 599 600 557
3 600 601 558
3 601 602 559
3 602 603 560
3 603 604 561
3 604 605 562
3 605 606 563
3 606 607 564
3 607 608 566
3 609 610 567
3 610 611 569
3 611 612 570
3 612 613 571
3 613 614 572
3 614 615 573
3 615 616 574
3 616 617 575
3 617 618 576
3 618 619 577
3 619 620 578
3 620 621 579
3 621 622 580
3 622 623 582
3 624 625 583
3 625 626 585
3 626 627 586
3 627 628 588
3 628 629 588
3 588 546 587
3 625 584 583
3 626 586 585
3 586 627 588
3 625 585 584
3 588 587 586
3 622 582 581
3 610 569 568
3 607 566 565
3 609 567 566
3 608 609 566
3 610 568 567
3 611 570 569
3 612 571 570
3 613 572 571
3 614 573 572
3 615 574 573
3 616 575 574
3 617 576 575
3 618 577 576
3 619 578 577
3 620 579 578
3 621 580 579
3 594 552 551
3 622 581 580
3 591 549 548
3 588 548 547
3 591 548 588
3 624 583 582
3 588 547 546
3 592 593 549
3 593 550 549
3 594 551 550
3 595 553 552
3 596 554 553
3 597 555 554
3 598 556 555
3 599 557 556
3 600 558 557
3 601 559 558
3 602 560 559
3 603 561 560
3 604 562 561
3 605 563 562
3 606 564 563
3 607 565 564
3 589 588 631
3 631 588 630
3 629 630 588
3 629 671 630
3 629 628 671
3 628 670 671
3 628 669 670
3 627 669 628
3 627 668 669
3 626 668 627
3 625 667 626
3 626 667 668
3 625 666 667
3 624 666 625
3 624 665 666
3 623 665 624
3 623 664 665
3 622 664 623
3 622 663 664
3 621 663 622
3 621 662 663
3 620 662 621
3 620 661 662
3 619 661 620
3 618 660 619
3 619 660 661
3 617 660 618
3 617 659 660
3 616 659 617
3 616 658 659
3 657 658 616
3 615 657 616
3 656 657 615
3 614 656 615
3 655 656 614
3 613 655 614
3 612 655 613
3 612 654 655
3 653 654 612
3 611 653 612
3 652 653 611
3 610 652 611
3 651 652 610
3 651 610 609
3 651 609 650
3 650 609 608
3 649 650 608
3 649 608 607
3 649 607 648
3 648 607 606
3 648 606 605
3 647 648 605
3 647 605 604
3 646 647 604
3 646 604 603
3 645 646 603
3 645 603 602
3 644 645 602
3 644 602 601
3 643 644 601
3 643 601 600
3 642 643 600
3 642 600 599
3 641 642 599
3 599 640 641
3 599 598 640
3 640 598 597
3 640 597 639
3 597 638 639
3 597 596 638
3 638 596 637
3 596 595 637
3 637 595 636
3 595 594 636
3 636 594 593
3 635 593 592
3 636 593 635
3 635 592 634
3 634 592 633
3 592 591 633
3 633 591 590
3 633 590 632
3 632 590 589
3 632 589 631
3 674 672 673
3 674 675 672
3 675 676 633
3 708 667 666
3 677 678 634
3 678 679 636
3 679 680 637
3 680 681 638
3 681 682 639
3 682 683 640
3 683 684 641
3 684 685 642
3 685 686 643
3 686 687 644
3 687 688 645
3 688 689 646
3 689 690 647
3 690 691 648
3 691 692 650
3 693 694 651
3 694 695 653
3 695 696 654
3 696 697 655
3 697 698 656
3 698 699 657
3 699 700 658
3 700 701 659
3 701 702 660
3 702 703 661
3 703 704 662
3 704 705 663
3 705 706 664
3 706 707 666
3 708 709 667
3 709 710 669
3 710 711 670
3 711 712 672
3 712 713 672
3 672 630 671
3 710 670 669
3 671 711 672
3 670 711 671
3 709 669 668
3 706 666 665
3 694 653 652
3 691 650 649
3 693 651 650
3 692 693 650
3 694 652 651
3 695 654 653
3 696 655 654
3 697 656 655
3 698 657 656
3 699 658 657
3 700 659 658
3 701 660 659
3 702 661 660
3 703 662 661
3 704 663 662
3 705 664 663
3 678 636 635
3 707 708 666
3 706 665 664
3 675 633 632
3 672 632 631
3 675 632 672
3 672 631 630
3 676 677 633
3 677 634 633
3 678 635 634
3 679 637 636
3 680 638 637
3 681 639 638
3 682 640 639
3 683 641 640
3 684 642 641
3 685 643 642
3 686 644 643
3 687 645 644
3 688 646 645
3 689 647 646
3 690 648 647
3 691 649 648
3 709 668 667
3 673 672 715
3 715 672 714
3 672 713 714
3 713 755 714
3 713 712 755
3 712 754 755
3 712 711 754
3 711 753 754
3 711 710 753
3 710 709 752
3 710 752 753
3 709 751 752
3 709 708 751
3 708 750 751
3 708 707 750
3 707 749 750
3 707 748 749
3 706 748 707
3 706 705 748
3 705 747 748
3 705 704 747
3 704 746 747
3 704 745 746
3 703 745 704
3 702 744 703
3 703 744 745
3 701 744 702
3 701 743 744
3 700 743 701
3 700 742 743
3 741 742 700
3 699 741 700
3 740 741 699
3 698 740 699
3 739 740 698
3 697 739 698
3 696 739 697
3 696 738 739
3 737 738 696
3 695 737 696
3 736 737 695
3 694 736 695
3 736 694 693
3 735 736 693
3 734 735 692
3 692 735 693
3 734 692 691
3 733 734 691
3 733 691 690
3 732 733 690
3 732 690 689
3 731 732 689
3 731 689 688
3 730 731 688
3 730 688 687
3 729 730 687
3 729 687 728
3 728 687 686
3 728 686 685
3 727 728 685
3 727 685 684
3 726 727 684
3 726 684 683
3 725 726 683
3 683 724 725
3 683 682 724
3 724 682 681
3 724 681 723
3 681 722 723
3 681 680 722
3 722 680 679
3 722 679 721
3 721 679 678
3 721 678 720
3 720 678 677
3 677 676 718
3 720 677 719
3 719 677 718
3 718 676 717
3 676 675 717
3 675 674 716
3 717 675 716
3 716 674 715
3 674 673 715
3 758 756 757
3 758 759 756
3 759 760 717
3 792 751 750
3 761 762 718
3 762 763 720
3 763 764 721
3 764 765 722
3 765 766 723
3 766 767 724
3 767 768 725
3 768 769 726
3 769 770 727
3 770 771 728
3 771 772 729
3 772 773 730
3 773 774 731
3 774 775 732
3 775 776 734
3 777 778 735
3 778 779 737
3 779 780 738
3 780 781 739
3 781 782 740
3 782 783 741
3 783 784 742
3 784 785 743
3 785 786 744
3 786 787 745
3 787 788 746
3 788 789 747
3 789 790 748
3 790 791 749
3 791 792 750
3 792 793 751
3 793 794 753
3 794 795 754
3 795 796 756
3 796 797 756
3 756 714 755
3 794 754 753
3 755 795 756
3 754 795 755
3 793 753 752
3 778 737 736
3 775 734 733
3 777 735 734
3 776 777 734
3 778 736 735
3 779 738 737
3 780 739 738
3 781 740 739
3 782 741 740
3 783 742 741
3 784 743 742
3 785 744 743
3 786 745 744
3 787 746 745
3 788 747 746
3 789 748 747
3 762 720 719
3 790 749 748
3 791 750 749
3 759 717 716
3 759 716 756
3 716 715 756
3 756 715 714
3 760 761 717
3 761 718 717
3 762 719 718
3 763 721 720
3 764 722 721
3 765 723 722
3 766 724 723
3 767 725 724
3 768 726 725
3 769 727 726
3 770 728 727
3 771 729 728
3 772 730 729
3 773 731 730
3 774 732 731
3 775 733 732
3 793 752 751
3 757 756 798
3 756 797 798
3 797 839 798
3 797 796 839
3 796 838 839
3 796 837 838
3 795 837 796
3 795 836 837
3 794 836 795
3 793 835 794
3 794 835 836
3 793 834 835
3 792 834 793
3 792 833 834
3 791 833 792
3 791 832 833
3 790 832 791
3 790 831 832
3 789 831 790
3 789 830 831
3 788 830 789
3 788 829 830
3 787 829 788
3 786 828 787
3 787 828 829
3 827 828 786
3 785 827 786
3 826 827 785
3 784 826 785
3 825 826 784
3 783 825 784
3 824 825 783
3 782 824 783
3 823 824 782
3 781 823 782
3 780 823 781
3 780 822 823
3 821 822 780
3 779 821 780
3 820 821 779
3 778 820 779
3 819 820 778
3 819 778 777
3 819 777 818
3 818 777 776
3 818 776 817
3 817 776 775
3 817 775 816
3 816 775 774
3 816 774 815
3 815 774 773
3 815 773 814
3 814 773 772
3 814 772 813
3 813 772 771
3 813 771 770
3 812 813 770
3 812 770 811
3 811 770 769
3 811 769 810
3 810 769 768
3 810 768 809
3 809 768 767
3 767 808 809
3 767 766 808
3 808 766 807
3 766 765 807
3 765 806 807
3 765 764 806
3 806 764 805
3 764 763 805
3 805 763 804
3 763 762 804
3 804 762 803
3 762 761 803
3 761 760 802
3 803 761 802
3 802 760 801
3 760 759 801
3 759 758 800
3 801 759 800
3 800 758 799
3 758 757 799
3 799 757 798
3 839 838 798
3 798 837 836
3 798 838 837
3 798 836 835
3 798 835 834
3 798 834 833
3 798 833 832
3 798 832 831
3 798 831 830
3 798 830 829
3 798 829 828
3 798 828 827
3 798 827 826
3 798 826 825
3 798 825 824
3 798 824 823
3 798 823 822
3 798 822 821
3 798 821 820
3 798 820 819
3 798 819 818
3 798 818 817
3 798 817 816
3 798 816 815
3 798 815 814
3 798 814 813
3 798 813 812
3 798 812 811
3 798 811 810
3 798 810 809
3 798 809 808
3 798 808 807
3 798 807 806
3 798 806 805
3 798 805 804
3 798 804 803
3 798 803 802
3 798 802 801
3 798 801 800
3 798 800 799
B2.off
OFF
840 1676 0
12669 10971 1700
12669 10993 1700
12674 11014 1700
12684 11034 1700
13237 11917 1700
13248 11932 1700
13262 11944 1700
13277 11953 1700
13294 11960 1700
14458 12304 1700
14476 12307 1700
14496 12307 1700
14514 12304 1700
15100 12131 1700
15120 12122 1700
15137 12110 1700
15152 12095 1700
15651 11432 1700
15661 11417 1700
15667 11401 1700
15671 11384 1700
15779 10460 1700
15780 10441 1700
15777 10422 1700
15770 10405 1700
15760 10388 1700
15254 9714 1700
15241 9700 1700
15227 9689 1700
15210 9681 1700
15192 9676 1700
13678 9394 1700
13659 9392 1700
13641 9394 1700
13623 9399 1700
13607 9407 1700
13592 9418 1700
12779 10150 1700
12766 10163 1700
12757 10179 1700
12750 10196 1700
12746 10214 1700
12614 10965 1850
12615 10999 1850
12622 11032 1850
12637 11063 1850
13191 11946 1850
13208 11968 1850
13229 11987 1850
13252 12002 1850
13278 12012 1850
14442 12356 1850
14471 12362 1850
14501 12362 1850
14530 12356 1850
15116 12183 1850
15146 12170 1850
15173 12152 1850
15195 12128 1850
15695 11465 1850
15709 11442 1850
15719 11417 1850
15725 11390 1850
15834 10466 1850
15834 10437 1850
15829 10408 1850
15819 10381 1850
15804 10356 1850
15297 9681 1850
15278 9660 1850
15255 9643 1850
15230 9630 1850
15202 9622 1850
13688 9340 1850
13659 9338 1850
13631 9340 1850
13604 9348 1850
13579 9360 1850
13556 9377 1850
12742 10109 1850
12723 10130 1850
12708 10154 1850
12698 10180 1850
12692 10208 1850
12515 10955 1850
12515 11011 1850
12528 11065 1850
12553 11116 1850
13106 11999 1850
13134 12036 1850
13168 12067 1850
13207 12091 1850
13250 12108 1850
14414 12452 1850
14462 12461 1850
14510 12461 1850
14558 12452 1850
15144 12279 1850
15194 12258 1850
15238 12227 1850
15275 12188 1850
15775 11525 1850
15799 11487 1850
15815 11446 1850
15824 11402 1850
15933 10478 1850
15934 10430 1850
15926 10382 1850
15909 10337 1850
15884 10295 1850
15377 9621 1850
15346 9586 1850
15308 9558 1850
15266 9537 1850
15220 9524 1850
13706 9242 1850
13659 9238 1850
13613 9242 1850
13568 9254 1850
13526 9275 1850
13489 9303 1850
12676 10035 1850
12644 10069 1850
12619 10109 1850
12602 10152 1850
12593 10198 1850
12461 10949 2000
12461 11017 2000
12477 11084 2000
12506 11145 2000
13060 12028 2000
13094 12073 2000
13135 12110 2000
13182 12140 2000
13234 12161 2000
14398 12504 2000
14456 12516 2000
14516 12516 2000
14574 12504 2000
15159 12331 2000
15220 12306 2000
15274 12269 2000
15319 12221 2000
15818 11558 2000
15847 11512 2000
15867 11461 2000
15879 11408 2000
15987 10484 2000
15989 10426 2000
15979 10368 2000
15958 10313 2000
15927 10263 2000
15421 9588 2000
15383 9546 2000
15337 9511 2000
15286 9486 2000
15230 9470 2000
13716 9188 2000
13659 9183 2000
13603 9188 2000
13549 9203 2000
13498 9228 2000
13452 9262 2000
12639 9994 2000
12600 10036 2000
12570 10084 2000
12549 10137 2000
12538 10192 2000
12361 10939 2000
12362 11029 2000
12382 11117 2000
12422 11198 2000
12975 12081 2000
13020 12140 2000
13075 12190 2000
13137 12229 2000
13206 12256 2000
14370 12600 2000
14447 12615 2000
14525 12615 2000
14602 12600 2000
15188 12427 2000
15268 12394 2000
15339 12344 2000
15398 12281 2000
15898 11618 2000
15936 11557 2000
15963 11490 2000
15978 11420 2000
16087 10496 2000
16088 10418 2000
16075 10342 2000
16048 10269 2000
16007 10203 2000
15501 9528 2000
15450 9472 2000
15390 9426 2000
15322 9393 2000
15249 9372 2000
13734 9090 2000
13660 9083 2000
13585 9090 2000
13513 9110 2000
13446 9143 2000
13386 9188 2000
12572 9920 2000
12521 9975 2000
12481 10038 2000
12453 10108 2000
12439 10182 2000
12307 10933 2150
12308 11036 2150
12331 11135 2150
12375 11227 2150
12929 12110 2150
12980 12177 2150
13042 12233 2150
13113 12278 2150
13191 12309 2150
14355 12653 2150
14442 12670 2150
14530 12670 2150
14618 12653 2150
15203 12479 2150
15294 12442 2150
15375 12386 2150
15442 12314 2150
15942 11651 2150
15985 11582 2150
16015 11506 2150
16032 11426 2150
16141 10503 2150
16143 10414 2150
16128 10328 2150
16097 10245 2150
16051 10170 2150
15545 9496 2150
15487 9432 2150
15418 9380 2150
15341 9342 2150
15259 9318 2150
13744 9036 2150
13660 9028 2150
13575 9036 2150
13493 9059 2150
13417 9097 2150
13349 9147 2150
12536 9879 2150
12478 9942 2150
12432 10014 2150
12401 10093 2150
12384 10177 2150
12207 10923 2150
12208 11047 2150
12237 11168 2150
12291 11280 2150
12844 12163 2150
12906 12245 2150
12981 12313 2150
13068 12367 2150
13162 12405 2150
14326 12749 2150
14432 12769 2150
14540 12769 2150
14646 12749 2150
15232 12575 2150
15342 12529 2150
15440 12461 2150
15522 12374 2150
16022 11711 2150
16074 11627 2150
16111 11535 2150
16131 11438 2150
16240 10514 2150
16242 10407 2150
16224 10301 2150
16187 10201 2150
16131 10110 2150
15625 9436 2150
15554 9358 2150
15471 9295 2150
15378 9248 2150
15277 9220 2150
13762 8938 2150
13660 8928 2150
13557 8938 2150
13458 8966 2150
13365 9011 2150
13282 9073 2150
12469 9805 2150
12398 9881 2150
12343 9968 2150
12305 10065 2150
12285 10166 2150
12153 10918 2300
12154 11054 2300
12185 11187 2300
12244 11309 2300
12798 12192 2300
12866 12281 2300
12948 12357 2300
13043 12416 2300
13147 12457 2300
14311 12801 2300
14427 12823 2300
14545 12823 2300
14661 12801 2300
15247 12628 2300
15368 12577 2300
15476 12503 2300
15565 12407 2300
16065 11744 2300
16123 11652 2300
16163 11551 2300
16186 11444 2300
16294 10521 2300
16297 10403 2300
16277 10287 2300
16236 10177 2300
16175 10077 2300
15668 9403 2300
15591 9318 2300
15500 9249 2300
15397 9198 2300
15287 9166 2300
13772 8884 2300
13660 8874 2300
13547 8884 2300
13438 8915 2300
13336 8965 2300
13246 9032 2300
12432 9764 2300
12355 9848 2300
12295 9944 2300
12253 10049 2300
12231 10161 2300
12054 10908 2300
12055 11066 2300
12091 11220 2300
12160 11362 2300
12713 12246 2300
12792 12349 2300
12888 12436 2300
12998 12505 2300
13118 12553 2300
14282 12897 2300
14417 12923 2300
14555 12923 2300
14690 12897 2300
15275 12724 2300
15416 12665 2300
15541 12578 2300
15645 12467 2300
16145 11804 2300
16212 11697 2300
16259 11580 2300
16285 11456 2300
16394 10532 2300
16397 10396 2300
16374 10261 2300
16326 10133 2300
16255 10017 2300
15748 9343 2300
15659 9244 2300
15553 9164 2300
15433 9104 2300
15305 9068 2300
13791 8786 2300
13660 8774 2300
13529 8786 2300
13402 8821 2300
13284 8879 2300
13179 8958 2300
12365 9690 2300
12276 9787 2300
12205 9898 2300
12157 10021 2300
12131 10151 2300
11999 10902 2450
12001 11072 2450
12039 11238 2450
12113 11391 2450
12667 12275 2450
12752 12386 2450
12855 12480 2450
12973 12554 2450
13103 12605 2450
14267 12949 2450
14412 12977 2450
14560 12977 2450
14705 12949 2450
15291 12776 2450
15442 12713 2450
15577 12620 2450
15689 12500 2450
16189 11837 2450
16261 11722 2450
16311 11595 2450
16339 11462 2450
16448 10539 2450
16451 10392 2450
16426 10247 2450
16375 10109 2450
16298 9984 2450
15792 9310 2450
15696 9204 2450
15581 9117 2450
15453 9053 2450
15315 9014 2450
13801 8732 2450
13660 8719 2450
13519 8732 2450
13383 8770 2450
13256 8833 2450
13142 8918 2450
12329 9649 2450
12232 9753 2450
12157 9874 2450
12104 10006 2450
12077 10145 2450
11900 10892 2450
11901 11084 2450
11945 11271 2450
12029 11444 2450
12582 12328 2450
12678 12453 2450
12794 12559 2450
12928 12643 2450
13075 12701 2450
14239 13045 2450
14403 13077 2450
14570 13077 2450
14734 13045 2450
15319 12872 2450
15490 12801 2450
15642 12695 2450
15769 12560 2450
16269 11898 2450
16350 11767 2450
16407 11624 2450
16438 11474 2450
16547 10550 2450
16551 10384 2450
16523 10221 2450
16465 10066 2450
16378 9924 2450
15872 9250 2450
15763 9130 2450
15634 9032 2450
15489 8960 2450
15334 8916 2450
13819 8634 2450
13660 8619 2450
13501 8634 2450
13347 8677 2450
13204 8748 2450
13075 8843 2450
12262 9575 2450
12153 9693 2450
12068 9828 2450
12008 9977 2450
11977 10135 2450
11846 10886 2600
11847 11090 2600
11894 11289 2600
11982 11473 2600
12536 12357 2600
12638 12490 2600
12761 12603 2600
12903 12692 2600
13059 12754 2600
14223 13097 2600
14397 13131 2600
14575 13131 2600
14749 13097 2600
15335 12924 2600
15516 12849 2600
15678 12737 2600
15812 12593 2600
16312 11930 2600
16399 11792 2600
16459 11640 2600
16493 11480 2600
16601 10557 2600
16605 10381 2600
16576 10207 2600
16514 10042 2600
16422 9891 2600
15915 9217 2600
15800 9090 2600
15663 8986 2600
15509 8909 2600
15344 8862 2600
13829 8580 2600
13660 8565 2600
13491 8580 2600
13327 8626 2600
13175 8701 2600
13039 8803 2600
12226 9534 2600
12110 9659 2600
12019 9804 2600
11956 9962 2600
11923 10129 2600
11746 10876 2600
11748 11102 2600
11799 11323 2600
11898 11527 2600
12451 12410 2600
12564 12558 2600
12701 12683 2600
12858 12781 2600
13031 12849 2600
14195 13193 2600
14388 13231 2600
14584 13231 2600
14777 13193 2600
15363 13020 2600
15564 12936 2600
15743 12812 2600
15892 12653 2600
16392 11991 2600
16488 11837 2600
16555 11669 2600
16592 11492 2600
16701 10568 2600
16705 10373 2600
16672 10181 2600
16604 9998 2600
16502 9831 2600
15995 9157 2600
15867 9016 2600
15716 8901 2600
15545 8816 2600
15362 8764 2600
13847 8482 2600
13660 8465 2600
13473 8482 2600
13292 8533 2600
13123 8616 2600
12972 8728 2600
12159 9460 2600
12030 9599 2600
11930 9758 2600
11860 9934 2600
11824 10119 2600
11692 10870 2750
11694 11109 2750
11748 11341 2750
11851 11556 2750
12405 12439 2750
12523 12594 2750
12668 12726 2750
12834 12830 2750
13015 12902 2750
14179 13246 2750
14383 13285 2750
14590 13285 2750
14793 13246 2750
15379 13072 2750
15590 12984 2750
15779 12854 2750
15936 12686 2750
16436 12023 2750
16536 11862 2750
16607 11685 2750
16646 11498 2750
16755 10575 2750
16759 10369 2750
16725 10166 2750
16653 9974 2750
16545 9798 2750
16039 9124 2750
15904 8976 2750
15744 8855 2750
15565 8765 2750
15372 8710 2750
13857 8428 2750
13660 8410 2750
13463 8428 2750
13272 8482 2750
13094 8569 2750
12936 8688 2750
12122 9419 2750
11987 9565 2750
11881 9734 2750
11808 9918 2750
11769 10114 2750
11592 10860 2750
11594 11121 2750
11653 11374 2750
11767 11609 2750
12320 12492 2750
12450 12662 2750
12607 12806 2750
12789 12919 2750
12987 12998 2750
14151 13342 2750
14373 13385 2750
14599 13385 2750
14821 13342 2750
15407 13168 2750
15638 13072 2750
15844 12929 2750
16016 12746 2750
16515 12084 2750
16626 11907 2750
16703 11714 2750
16746 11510 2750
16854 10586 2750
16859 10362 2750
16822 10140 2750
16743 9930 2750
16625 9738 2750
16119 9064 2750
15972 8902 2750
15797 8770 2750
15601 8672 2750
15390 8612 2750
13876 8330 2750
13660 8310 2750
13445 8330 2750
13236 8388 2750
13042 8484 2750
12869 8613 2750
12055 9345 2750
11908 9504 2750
11792 9688 2750
11712 9890 2750
11670 10103 2750
11538 10855 2900
11540 11127 2900
11602 11392 2900
11720 11638 2900
12274 12521 2900
12409 12699 2900
12574 12849 2900
12764 12968 2900
12972 13050 2900
14136 13394 2900
14368 13439 2900
14605 13439 2900
14837 13394 2900
15423 13221 2900
15665 13120 2900
15880 12971 2900
16059 12779 2900
16559 12117 2900
16674 11932 2900
16755 11730 2900
16800 11516 2900
16908 10593 2900
16914 10358 2900
16874 10126 2900
16792 9906 2900
16669 9706 2900
16163 9031 2900
16009 8862 2900
15826 8723 2900
15621 8621 2900
15400 8558 2900
13886 8276 2900
13660 8255 2900
13435 8276 2900
13217 8337 2900
13014 8437 2900
12832 8573 2900
12019 9304 2900
11864 9471 2900
11743 9664 2900
11659 9875 2900
11616 10098 2900
11438 10844 2900
11441 11139 2900
11508 11426 2900
11636 11691 2900
12189 12574 2900
12336 12766 2900
12514 12929 2900
12719 13057 2900
12943 13146 2900
14107 13490 2900
14358 13539 2900
14614 13539 2900
14865 13490 2900
15451 13317 2900
15713 13208 2900
15945 13046 2900
16139 12840 2900
16639 12177 2900
16763 11977 2900
16851 11759 2900
16899 11528 2900
17008 10605 2900
17013 10351 2900
16971 10100 2900
16882 9862 2900
16749 9646 2900
16243 8971 2900
16076 8788 2900
15879 8638 2900
15657 8528 2900
15418 8460 2900
13904 8178 2900
13660 8155 2900
13416 8178 2900
13181 8244 2900
12961 8352 2900
12765 8498 2900
11952 9230 2900
11785 9410 2900
11654 9618 2900
11563 9847 2900
11516 10088 2900
11384 10839 3050
11387 11145 3050
11456 11444 3050
11589 11720 3050
12143 12603 3050
12295 12803 3050
12481 12972 3050
12694 13106 3050
12928 13198 3050
14092 13542 3050
14353 13593 3050
14619 13593 3050
14881 13542 3050
15466 13369 3050
15739 13256 3050
15981 13088 3050
16183 12872 3050
16682 12210 3050
16812 12002 3050
16903 11774 3050
16953 11534 3050
17062 10611 3050
17068 10347 3050
17023 10086 3050
16931 9838 3050
16793 9613 3050
16286 8939 3050
16113 8748 3050
15907 8592 3050
15677 8477 3050
15428 8406 3050
13914 8124 3050
13660 8101 3050
13407 8124 3050
13161 8193 3050
12933 8305 3050
12729 8458 3050
11915 9189 3050
11742 9377 3050
11605 9594 3050
11511 9831 3050
11462 10082 3050
11285 10829 3050
11287 11157 3050
11362 11477 3050
11505 11773 3050
12058 12656 3050
12222 12871 3050
12421 13052 3050
12649 13195 3050
12899 13294 3050
14063 13638 3050
14344 13692 3050
14629 13692 3050
14909 13638 3050
15495 13465 3050
15787 13343 3050
16046 13163 3050
16262 12933 3050
16762 12270 3050
16901 12047 3050
16999 11803 3050
17053 11546 3050
17161 10623 3050
17168 10339 3050
17120 10060 3050
17021 9795 3050
16873 9553 3050
16366 8879 3050
16180 8674 3050
15960 8507 3050
15713 8384 3050
15447 8308 3050
13932 8026 3050
13660 8001 3050
13388 8026 3050
13126 8100 3050
12881 8220 3050
12662 8383 3050
11848 9115 3050
11662 9316 3050
11516 9548 3050
11415 9803 3050
11362 10072 3050
11230 10823 3200
11233 11164 3200
11310 11495 3200
11458 11802 3200
12012 12685 3200
12181 12907 3200
12388 13096 3200
12624 13244 3200
12884 13347 3200
14048 13691 3200
14338 13747 3200
14634 13747 3200
14925 13690 3200
15510 13517 3200
15813 13391 3200
16082 13205 3200
16306 12965 3200
16806 12303 3200
16950 12072 3200
17051 11819 3200
17107 11553 3200
17216 10629 3200
17222 10335 3200
17173 10046 3200
17070 9771 3200
16916 9520 3200
16410 8846 3200
16217 8634 3200
15989 8461 3200
15732 8333 3200
15457 8254 3200
13942 7972 3200
13660 7946 3200
13379 7972 3200
13106 8049 3200
12852 8174 3200
12625 8343 3200
11812 9074 3200
11619 9283 3200
11468 9523 3200
11363 9788 3200
11308 10066 3200
3 1 0 42
3 0 41 42
3 2 0 1
3 2 3 0
3 3 4 0
3 4 5 0
3 5 6 0
3 6 7 0
3 7 8 0
3 8 9 0
3 9 10 0
3 10 11 0
3 11 12 0
3 12 13 0
3 13 14 0
3 14 15 0
3 15 16 0
3 16 17 0
3 17 18 0
3 18 19 0
3 19 20 0
3 20 21 0
3 21 22 0
3 22 23 0
3 23 24 0
3 24 25 0
3 25 26 0
3 26 27 0
3 27 28 0
3 28 29 0
3 29 30 0
3 30 31 0
3 31 32 0
3 32 33 0
3 33 34 0
3 34 35 0
3 35 36 0
3 36 37 0
3 37 38 0
3 38 39 0
3 39 40 0
3 40 41 0
3 86 84 85
3 86 87 84
3 87 88 84
3 88 89 84
3 89 90 84
3 90 91 84
3 91 92 84
3 92 93 50
3 96 97 54
3 94 95 50
3 98 99 55
3 99 100 57
3 100 101 58
3 107 66 65
3 102 103 60
3 103 104 62
3 105 106 63
3 106 107 65
3 107 108 66
3 108 109 67
3 109 110 68
3 110 111 70
3 111 112 72
3 114 115 73
3 115 116 77
3 116 117 78
3 120 79 78
3 119 120 78
3 118 119 78
3 120 121 79
3 121 122 84
3 122 123 84
3 123 124 84
3 124 125 84
3 84 42 83
3 117 118 78
3 83 121 84
3 82 121 83
3 81 121 82
3 80 121 81
3 79 121 80
3 115 77 76
3 115 76 75
3 73 115 74
3 111 72 71
3 110 70 69
3 106 65 64
3 103 62 61
3 96 51 50
3 105 63 62
3 104 105 62
3 102 60 59
3 106 64 63
3 99 57 56
3 99 56 55
3 98 55 54
3 95 96 50
3 97 98 54
3 96 54 53
3 93 94 50
3 96 53 52
3 96 52 51
3 92 50 49
3 84 46 45
3 92 49 48
3 92 48 47
3 92 47 46
3 92 46 84
3 84 45 44
3 84 44 43
3 108 67 66
3 84 43 42
3 100 58 57
3 101 102 58
3 102 59 58
3 103 61 60
3 109 68 67
3 110 69 68
3 111 71 70
3 112 113 72
3 113 114 72
3 116 78 77
3 115 75 74
3 114 73 72
3 41 83 42
3 43 1 42
3 44 1 43
3 2 1 44
3 41 40 83
3 40 82 83
3 40 39 82
3 39 81 82
3 39 38 81
3 38 80 81
3 38 79 80
3 38 37 79
3 37 78 79
3 36 78 37
3 36 77 78
3 36 35 77
3 35 76 77
3 35 34 76
3 34 75 76
3 33 75 34
3 33 74 75
3 32 74 33
3 32 73 74
3 31 73 32
3 30 72 31
3 31 72 73
3 71 72 30
3 29 71 30
3 28 71 29
3 70 71 28
3 27 70 28
3 69 70 27
3 68 69 27
3 26 68 27
3 67 68 26
3 25 67 26
3 24 67 25
3 66 67 24
3 65 66 24
3 23 65 24
3 64 65 23
3 22 64 23
3 63 64 22
3 63 22 21
3 63 21 20
3 62 63 20
3 62 20 19
3 61 62 19
3 60 61 19
3 60 19 18
3 60 18 17
3 59 60 17
3 59 17 16
3 58 59 16
3 58 16 15
3 57 58 15
3 56 57 15
3 56 15 14
3 56 14 13
3 55 56 13
3 55 12 54
3 55 13 12
3 54 12 11
3 53 54 11
3 11 52 53
3 11 10 52
3 52 10 9
3 52 9 51
3 9 50 51
3 9 8 50
3 50 8 49
3 8 7 49
3 7 6 49
3 49 6 48
3 6 5 48
3 48 5 47
3 5 4 47
3 46 4 45
3 4 3 45
3 47 4 46
3 3 2 45
3 45 2 44
3 85 126 127
3 85 84 126
3 84 125 126
3 125 166 167
3 125 124 166
3 125 167 126
3 124 123 166
3 123 165 166
3 122 165 123
3 122 164 165
3 122 121 164
3 121 163 164
3 121 120 163
3 163 120 162
3 120 119 162
3 119 161 162
3 119 118 161
3 118 160 161
3 118 117 160
3 117 159 160
3 117 116 159
3 116 158 159
3 116 115 158
3 115 157 158
3 114 156 115
3 115 156 157
3 155 156 114
3 113 155 114
3 154 155 113
3 112 154 113
3 111 154 112
3 111 153 154
3 152 153 111
3 110 152 111
3 151 152 110
3 109 151 110
3 108 151 109
3 150 151 108
3 149 150 108
3 107 149 108
3 148 149 107
3 106 148 107
3 148 106 105
3 147 148 105
3 147 105 146
3 146 105 104
3 146 104 103
3 145 146 103
3 144 145 103
3 144 103 102
3 144 102 101
3 143 144 101
3 143 101 100
3 142 143 100
3 142 100 99
3 141 142 99
3 141 99 98
3 140 141 98
3 140 98 139
3 139 98 97
3 139 97 138
3 138 97 96
3 138 96 137
3 137 96 95
3 95 136 137
3 95 94 136
3 136 94 93
3 136 93 135
3 135 93 134
3 93 92 134
3 134 92 133
3 92 91 133
3 133 91 132
3 91 90 132
3 132 90 131
3 90 89 131
3 89 88 130
3 131 89 130
3 130 88 129
3 88 87 129
3 87 86 129
3 129 86 128
3 128 86 127
3 86 85 127
3 170 168 169
3 170 171 168
3 171 172 168
3 172 173 168
3 173 174 168
3 174 175 168
3 175 176 168
3 176 177 134
3 179 180 136
3 180 181 138
3 182 183 140
3 183 184 141
3 184 185 142
3 185 186 143
3 186 187 144
3 187 188 146
3 189 190 147
3 190 191 149
3 191 192 150
3 192 193 151
3 193 194 152
3 194 195 153
3 195 196 155
3 196 197 156
3 198 199 157
3 199 200 159
3 200 201 161
3 201 202 162
3 204 163 162
3 203 204 162
3 204 205 164
3 205 206 168
3 206 207 168
3 207 208 168
3 208 209 168
3 168 126 167
3 202 203 162
3 167 205 168
3 166 205 167
3 165 205 166
3 204 164 163
3 164 205 165
3 200 161 160
3 199 159 158
3 195 155 154
3 190 149 148
3 187 146 145
3 189 147 146
3 188 189 146
3 190 148 147
3 191 150 149
3 192 151 150
3 193 152 151
3 182 140 139
3 194 153 152
3 180 138 137
3 195 154 153
3 196 156 155
3 179 136 135
3 197 198 156
3 176 134 133
3 168 130 129
3 176 133 132
3 176 132 131
3 176 131 130
3 176 130 168
3 168 129 128
3 198 157 156
3 168 127 126
3 177 178 134
3 178 179 134
3 180 137 136
3 179 135 134
3 181 182 138
3 182 139 138
3 183 141 140
3 184 142 141
3 185 143 142
3 186 144 143
3 187 145 144
3 199 158 157
3 201 162 161
3 200 160 159
3 168 128 127
3 169 168 211
3 211 168 210
3 168 209 210
3 209 250 251
3 209 208 250
3 209 251 210
3 208 207 250
3 207 249 250
3 207 248 249
3 207 206 248
3 206 247 248
3 205 247 206
3 205 246 247
3 204 246 205
3 204 245 246
3 203 245 204
3 203 244 245
3 202 244 203
3 202 243 244
3 201 243 202
3 201 200 243
3 200 242 243
3 200 199 242
3 199 241 242
3 198 240 199
3 199 240 241
3 239 240 198
3 197 239 198
3 238 239 197
3 196 238 197
3 237 238 196
3 195 237 196
3 236 237 195
3 194 236 195
3 235 236 194
3 193 235 194
3 234 235 193
3 192 234 193
3 191 234 192
3 233 234 191
3 190 233 191
3 232 233 190
3 232 190 189
3 231 232 189
3 231 189 188
3 230 231 188
3 230 188 187
3 229 230 187
3 228 229 187
3 228 187 186
3 228 186 185
3 227 228 185
3 226 227 184
3 184 227 185
3 226 184 183
3 225 226 183
3 225 183 224
3 224 183 182
3 224 182 223
3 223 182 181
3 223 181 222
3 222 181 180
3 222 180 179
3 221 222 179
3 179 220 221
3 179 178 220
3 220 178 177
3 220 177 219
3 177 218 219
3 177 176 218
3 218 176 175
3 218 175 217
3 217 175 174
3 217 174 216
3 216 174 173
3 215 173 172
3 216 173 215
3 215 172 214
3 214 172 171
3 214 171 213
3 171 170 213
3 213 170 212
3 170 169 212
3 212 169 211
3 254 252 253
3 254 255 252
3 255 256 252
3 256 257 252
3 257 258 213
3 259 260 216
3 260 261 218
3 283 242 241
3 262 263 219
3 263 264 221
3 264 265 222
3 265 266 223
3 266 267 224
3 267 268 225
3 268 269 226
3 269 270 227
3 270 271 228
3 271 272 230
3 273 274 231
3 274 275 233
3 275 276 234
3 276 277 235
3 277 278 236
3 278 279 237
3 279 280 238
3 280 281 240
3 282 283 241
3 283 284 242
3 284 285 244
3 285 286 246
3 288 247 246
3 288 289 247
3 289 290 250
3 290 291 252
3 291 292 252
3 292 293 252
3 252 210 251
3 252 251 250
3 289 250 249
3 250 290 252
3 252 213 212
3 287 288 246
3 248 289 249
3 247 289 248
3 285 246 245
3 284 244 243
3 280 240 239
3 274 233 232
3 271 230 229
3 273 231 230
3 272 273 230
3 274 232 231
3 275 234 233
3 276 235 234
3 277 236 235
3 278 237 236
3 279 238 237
3 263 221 220
3 280 239 238
3 282 241 240
3 281 282 240
3 260 218 217
3 260 217 216
3 259 214 213
3 259 216 215
3 258 259 213
3 259 215 214
3 257 213 252
3 252 212 211
3 252 211 210
3 261 262 218
3 262 219 218
3 263 220 219
3 264 222 221
3 265 223 222
3 266 224 223
3 267 225 224
3 268 226 225
3 269 227 226
3 270 228 227
3 271 229 228
3 284 243 242
3 286 287 246
3 285 245 244
3 253 252 294
3 293 294 252
3 293 335 294
3 293 292 335
3 292 334 335
3 292 291 334
3 291 333 334
3 291 290 333
3 290 332 333
3 290 289 332
3 289 331 332
3 289 288 331
3 288 330 331
3 288 287 330
3 287 329 330
3 287 328 329
3 286 328 287
3 286 285 328
3 285 327 328
3 285 284 327
3 284 326 327
3 284 283 326
3 283 325 326
3 282 324 283
3 283 324 325
3 323 324 282
3 281 323 282
3 280 323 281
3 280 322 323
3 321 322 280
3 279 321 280
3 320 321 279
3 278 320 279
3 319 320 278
3 277 319 278
3 318 319 277
3 276 318 277
3 275 318 276
3 317 318 275
3 316 317 275
3 274 316 275
3 316 274 273
3 315 316 273
3 315 273 272
3 314 315 272
3 313 314 272
3 313 272 271
3 312 313 271
3 312 271 270
3 312 270 311
3 311 270 269
3 310 311 268
3 268 311 269
3 310 268 267
3 309 310 267
3 309 267 266
3 308 309 266
3 308 266 307
3 307 266 265
3 307 265 306
3 306 265 264
3 306 264 305
3 305 264 263
3 263 304 305
3 263 262 304
3 304 262 303
3 262 261 303
3 261 302 303
3 261 260 302
3 302 260 259
3 302 259 301
3 301 259 258
3 301 258 300
3 300 258 299
3 258 257 299
3 257 256 298
3 299 257 298
3 298 256 297
3 256 255 297
3 297 255 296
3 255 254 296
3 296 254 295
3 254 253 295
3 295 253 294
3 338 336 337
3 338 339 336
3 339 340 297
3 342 343 298
3 343 344 300
3 344 345 302
3 367 326 325
3 346 347 304
3 347 348 305
3 348 349 306
3 349 350 307
3 350 351 308
3 351 352 309
3 352 353 310
3 353 354 311
3 354 355 312
3 355 356 314
3 357 358 315
3 358 359 317
3 359 360 318
3 360 361 319
3 361 362 320
3 362 363 321
3 363 364 322
3 364 365 323
3 365 366 324
3 366 367 325
3 367 368 326
3 368 369 327
3 369 370 329
3 370 371 330
3 372 373 331
3 373 374 334
3 374 375 336
3 375 376 336
3 376 377 336
3 336 294 335
3 373 333 332
3 335 374 336
3 334 374 335
3 373 334 333
3 331 373 332
3 369 329 328
3 358 317 316
3 355 314 313
3 357 315 314
3 356 357 314
3 358 316 315
3 359 318 317
3 360 319 318
3 361 320 319
3 362 321 320
3 363 322 321
3 364 323 322
3 365 324 323
3 346 304 303
3 366 325 324
3 344 302 301
3 343 300 299
3 343 299 298
3 341 342 297
3 340 341 297
3 339 297 296
3 336 296 295
3 339 296 336
3 368 327 326
3 336 295 294
3 344 301 300
3 342 298 297
3 347 305 304
3 345 346 302
3 346 303 302
3 348 306 305
3 349 307 306
3 350 308 307
3 351 309 308
3 352 310 309
3 353 311 310
3 354 312 311
3 355 313 312
3 369 328 327
3 370 330 329
3 371 372 330
3 372 331 330
3 336 419 378
3 377 419 336
3 337 336 378
3 377 418 419
3 377 376 418
3 376 417 418
3 376 375 417
3 375 374 417
3 374 416 417
3 374 415 416
3 373 415 374
3 373 414 415
3 372 414 373
3 372 413 414
3 371 413 372
3 371 412 413
3 370 412 371
3 370 411 412
3 369 411 370
3 369 368 411
3 368 410 411
3 368 367 410
3 367 409 410
3 366 408 367
3 367 408 409
3 365 408 366
3 365 407 408
3 364 406 365
3 365 406 407
3 363 406 364
3 363 405 406
3 362 405 363
3 362 404 405
3 403 404 362
3 361 403 362
3 360 403 361
3 360 402 403
3 359 402 360
3 401 402 359
3 400 401 359
3 358 400 359
3 399 400 358
3 399 358 357
3 399 357 398
3 398 357 356
3 397 398 356
3 397 356 355
3 396 397 355
3 396 355 354
3 396 354 395
3 395 354 353
3 394 395 352
3 352 395 353
3 394 352 393
3 393 352 351
3 393 351 392
3 392 351 350
3 392 350 391
3 391 350 349
3 391 349 390
3 390 349 348
3 390 348 389
3 389 348 347
3 347 388 389
3 347 346 388
3 388 346 345
3 388 345 387
3 345 386 387
3 345 344 386
3 386 344 343
3 386 343 385
3 385 343 342
3 385 342 384
3 384 342 383
3 342 341 383
3 341 340 382
3 383 341 382
3 382 340 381
3 340 339 381
3 381 339 380
3 339 338 380
3 380 338 379
3 338 337 379
3 379 337 378
3 422 420 421
3 422 423 420
3 423 424 381
3 426 427 383
3 427 428 385
3 428 429 386
3 451 410 409
3 430 431 388
3 431 432 389
3 432 433 390
3 433 434 391
3 434 435 392
3 435 436 393
3 436 437 394
3 437 438 395
3 438 439 396
3 439 440 398
3 441 442 399
3 442 443 401
3 443 444 402
3 444 445 403
3 445 446 404
3 446 447 405
3 447 448 406
3 448 449 407
3 449 450 408
3 450 451 409
3 451 452 410
3 452 453 411
3 453 454 413
3 454 455 414
3 456 457 416
3 457 458 418
3 458 459 420
3 459 460 420
3 460 461 420
3 420 378 419
3 457 417 416
3 419 458 420
3 457 418 417
3 418 458 419
3 456 416 415
3 453 413 412
3 442 401 400
3 439 398 397
3 441 399 398
3 440 441 398
3 442 400 399
3 443 402 401
3 444 403 402
3 445 404 403
3 446 405 404
3 447 406 405
3 448 407 406
3 449 408 407
3 430 388 387
3 450 409 408
3 452 411 410
3 427 385 384
3 453 412 411
3 426 383 382
3 423 381 380
3 420 380 379
3 423 380 420
3 454 414 413
3 420 379 378
3 424 425 381
3 425 426 381
3 427 384 383
3 428 386 385
3 426 382 381
3 429 430 386
3 430 387 386
3 431 389 388
3 432 390 389
3 433 391 390
3 434 392 391
3 435 393 392
3 436 394 393
3 437 395 394
3 438 396 395
3 439 397 396
3 455 456 414
3 456 415 414
3 421 420 462
3 461 462 420
3 461 503 462
3 461 502 503
3 461 460 502
3 460 501 502
3 459 501 460
3 459 458 501
3 457 499 458
3 458 500 501
3 458 499 500
3 457 498 499
3 456 498 457
3 456 497 498
3 455 497 456
3 455 454 497
3 454 496 497
3 454 453 496
3 453 495 496
3 453 452 495
3 452 494 495
3 452 451 494
3 451 493 494
3 450 492 451
3 451 492 493
3 449 492 450
3 449 491 492
3 448 491 449
3 448 490 491
3 447 490 448
3 447 489 490
3 446 489 447
3 446 488 489
3 445 488 446
3 445 487 488
3 444 487 445
3 444 486 487
3 443 486 444
3 443 485 486
3 442 485 443
3 484 485 442
3 484 442 441
3 483 484 441
3 483 441 440
3 482 483 440
3 482 440 439
3 481 482 439
3 481 439 480
3 480 439 438
3 480 438 479
3 479 438 437
3 479 437 478
3 478 437 436
3 478 436 477
3 477 436 435
3 477 435 476
3 476 435 434
3 476 434 433
3 475 476 433
3 475 433 432
3 474 475 432
3 474 432 431
3 473 474 431
3 431 472 473
3 431 430 472
3 472 430 471
3 430 429 471
3 471 429 470
3 429 428 470
3 470 428 469
3 428 427 469
3 469 427 468
3 427 426 468
3 468 426 425
3 425 424 466
3 468 425 467
3 467 425 466
3 466 424 465
3 424 423 465
3 465 423 464
3 423 422 464
3 464 422 463
3 422 421 463
3 463 421 462
3 506 504 505
3 506 507 504
3 507 508 465
3 510 511 467
3 511 512 469
3 512 513 470
3 513 514 471
3 514 515 472
3 515 516 473
3 516 517 474
3 517 518 475
3 518 519 476
3 519 520 477
3 520 521 478
3 521 522 479
3 522 523 480
3 523 524 482
3 525 526 483
3 526 527 485
3 527 528 486
3 528 529 487
3 529 530 488
3 530 531 489
3 531 532 490
3 532 533 491
3 533 534 492
3 534 535 493
3 535 536 494
3 536 537 495
3 537 538 496
3 538 539 498
3 540 541 500
3 541 542 501
3 542 543 504
3 543 544 504
3 544 545 504
3 504 462 503
3 542 502 501
3 503 502 504
3 502 542 504
3 540 499 498
3 541 501 500
3 540 500 499
3 538 498 497
3 526 485 484
3 523 482 481
3 510 466 465
3 525 483 482
3 524 525 482
3 526 484 483
3 527 486 485
3 528 487 486
3 529 488 487
3 530 489 488
3 531 490 489
3 532 491 490
3 533 492 491
3 534 493 492
3 535 494 493
3 536 495 494
3 511 469 468
3 537 496 495
3 510 467 466
3 538 497 496
3 507 465 464
3 504 464 463
3 507 464 504
3 504 463 462
3 508 509 465
3 509 510 465
3 511 468 467
3 512 470 469
3 513 471 470
3 514 472 471
3 515 473 472
3 516 474 473
3 517 475 474
3 518 476 475
3 519 477 476
3 520 478 477
3 521 479 478
3 522 480 479
3 523 481 480
3 539 540 498
3 505 504 546
3 504 545 546
3 545 544 587
3 545 587 546
3 544 586 587
3 544 543 586
3 543 585 586
3 543 584 585
3 542 584 543
3 541 583 542
3 542 583 584
3 541 582 583
3 540 582 541
3 540 581 582
3 539 581 540
3 539 538 581
3 538 580 581
3 538 537 580
3 537 579 580
3 537 536 579
3 536 578 579
3 536 535 578
3 535 577 578
3 534 576 535
3 535 576 577
3 533 576 534
3 533 575 576
3 532 575 533
3 532 574 575
3 531 574 532
3 531 573 574
3 530 573 531
3 530 572 573
3 571 572 530
3 529 571 530
3 570 571 529
3 528 570 529
3 569 570 528
3 527 569 528
3 526 569 527
3 568 569 526
3 568 526 525
3 567 568 525
3 567 525 566
3 566 525 524
3 566 524 523
3 565 566 523
3 565 523 522
3 564 565 522
3 564 522 521
3 563 564 521
3 563 521 520
3 562 563 520
3 562 520 519
3 561 562 519
3 561 519 518
3 560 561 518
3 560 518 517
3 559 560 517
3 559 517 516
3 558 559 516
3 558 516 515
3 557 558 515
3 515 556 557
3 515 514 556
3 556 514 513
3 556 513 555
3 513 554 555
3 513 512 554
3 554 512 511
3 554 511 553
3 553 511 510
3 553 510 552
3 552 510 509
3 551 509 508
3 552 509 551
3 551 508 550
3 550 508 507
3 550 507 549
3 549 507 506
3 549 506 548
3 548 506 505
3 548 505 547
3 547 505 546
3 590 588 589
3 590 591 588
3 591 592 549
3 623 624 582
3 593 594 550
3 594 595 552
3 595 596 553
3 596 597 554
3 597 598 555
3 598 599 556
3 599 600 557
3 600 601 558
3 601 602 559
3 602 603 560
3 603 604 561
3 604 605 562
3 605 606 563
3 606 607 564
3 607 608 566
3 609 610 567
3 610 611 569
3 611 612 570
3 612 613 571
3 613 614 572
3 614 615 573
3 615 616 574
3 616 617 575
3 617 618 576
3 618 619 577
3 619 620 578
3 620 621 579
3 621 622 580
3 622 623 582
3 624 625 583
3 625 626 585
3 626 627 586
3 627 628 588
3 628 629 588
3 588 546 587
3 625 584 583
3 626 586 585
3 586 627 588
3 625 585 584
3 588 587 586
3 622 582 581
3 610 569 568
3 607 566 565
3 609 567 566
3 608 609 566
3 610 568 567
3 611 570 569
3 612 571 570
3 613 572 571
3 614 573 572
3 615 574 573
3 616 575 574
3 617 576 575
3 618 577 576
3 619 578 577
3 620 579 578
3 621 580 579
3 594 552 551
3 622 581 580
3 591 549 548
3 588 548 547
3 591 548 588
3 624 583 582
3 588 547 546
3 592 593 549
3 593 550 549
3 594 551 550
3 595 553 552
3 596 554 553
3 597 555 554
3 598 556 555
3 599 557 556
3 600 558 557
3 601 559 558
3 602 560 559
3 603 561 560
3 604 562 561
3 605 563 562
3 606 564 563
3 607 565 564
3 589 588 631
3 631 588 630
3 629 630 588
3 629 671 630
3 629 628 671
3 628 670 671
3 628 669 670
3 627 669 628
3 627 668 669
3 626 668 627
3 625 667 626
3 626 667 668
3 625 666 667
3 624 666 625
3 624 665 666
3 623 665 624
3 623 664 665
3 622 664 623
3 622 663 664
3 621 663 622
3 621 662 663
3 620 662 621
3 620 661 662
3 619 661 620
3 618 660 619
3 619 660 661
3 617 660 618
3 617 659 660
3 616 659 617
3 616 658 659
3 657 658 616
3 615 657 616
3 656 657 615
3 614 656 615
3 655 656 614
3 613 655 614
3 612 655 613
3 612 654 655
3 653 654 612
3 611 653 612
3 652 653 611
3 610 652 611
3 651 652 610
3 651 610 609
3 651 609 650
3 650 609 608
3 649 650 608
3 649 608 607
3 649 607 648
3 648 607 606
3 648 606 605
3 647 648 605
3 647 605 604
3 646 647 604
3 646 604 603
3 645 646 603
3 645 603 602
3 644 645 602
3 644 602 601
3 643 644 601
3 643 601 600
3 642 643 600
3 642 600 599
3 641 642 599
3 599 640 641
3 599 598 640
3 640 598 597
3 640 597 639
3 597 638 639
3 597 596 638
3 638 596 637
3 596 595 637
3 637 595 636
3 595 594 636
3 636 594 593
3 635 593 592
3 636 593 635
3 635 592 634
3 634 592 633
3 592 591 633
3 633 591 590
3 633 590 632
3 632 590 589
3 632 589 631
3 674 672 673
3 674 675 672
3 675 676 633
3 708 667 666
3 677 678 634
3 678 679 636
3 679 680 637
3 680 681 638
3 681 682 639
3 682 683 640
3 683 684 641
3 684 685 642
3 685 686 643
3 686 687 644
3 687 688 645
3 688 689 646
3 689 690 647
3 690 691 648
3 691 692 650
3 693 694 651
3 694 695 653
3 695 696 654
3 696 697 655
3 697 698 656
3 698 699 657
3 699 700 658
3 700 701 659
3 701 702 660
3 702 703 661
3 703 704 662
3 704 705 663
3 705 706 664
3 706 707 666
3 708 709 667
3 709 710 669
3 710 711 670
3 711 712 672
3 712 713 672
3 672 630 671
3 710 670 669
3 671 711 672
3 670 711 671
3 709 669 668
3 706 666 665
3 694 653 652
3 691 650 649
3 693 651 650
3 692 693 650
3 694 652 651
3 695 654 653
3 696 655 654
3 697 656 655
3 698 657 656
3 699 658 657
3 700 659 658
3 701 660 659
3 702 661 660
3 703 662 661
3 704 663 662
3 705 664 663
3 678 636 635
3 707 708 666
3 706 665 664
3 675 633 632
3 672 632 631
3 675 632 672
3 672 631 630
3 676 677 633
3 677 634 633
3 678 635 634
3 679 637 636
3 680 638 637
3 681 639 638
3 682 640 639
3 683 641 640
3 684 642 641
3 685 643 642
3 686 644 643
3 687 645 644
3 688 646 645
3 689 647 646
3 690 648 647
3 691 649 648
3 709 668 667
3 673 672 715
3 715 672 714
3 672 713 714
3 713 755 714
3 713 712 755
3 712 754 755
3 712 711 754
3 711 753 754
3 711 710 753
3 710 709 752
3 710 752 753
3 709 751 752
3 709 708 751
3 708 750 751
3 708 707 750
3 707 749 750
3 707 748 749
3 706 748 707
3 706 705 748
3 705 747 748
3 705 704 747
3 704 746 747
3 704 745 746
3 703 745 704
3 702 744 703
3 703 744 745
3 701 744 702
3 701 743 744
3 700 743 701
3 700 742 743
3 741 742 700
3 699 741 700
3 740 741 699
3 698 740 699
3 739 740 698
3 697 739 698
3 696 739 697
3 696 738 739
3 737 738 696
3 695 737 696
3 736 737 695
3 694 736 695
3 736 694 693
3 735 736 693
3 734 735 692
3 692 735 693
3 734 692 691
3 733 734 691
3 733 691 690
3 732 733 690
3 732 690 689
3 731 732 689
3 731 689 688
3 730 731 688
3 730 688 687
3 729 730 687
3 729 687 728
3 728 687 686
3 728 686 685
3 727 728 685
3 727 685 684
3 726 727 684
3 726 684 683
3 725 726 683
3 683 724 725
3 683 682 724
3 724 682 681
3 724 681 723
3 681 722 723
3 681 680 722
3 722 680 679
3 722 679 721
3 721 679 678
3 721 678 720
3 720 678 677
3 677 676 718
3 720 677 719
3 719 677 718
3 718 676 717
3 676 675 717
3 675 674 716
3 717 675 716
3 716 674 715
3 674 673 715
3 758 756 757
3 758 759 756
3 759 760 717
3 792 751 750
3 761 762 718
3 762 763 720
3 763 764 721
3 764 765 722
3 765 766 723
3 766 767 724
3 767 768 725
3 768 769 726
3 769 770 727
3 770 771 728
3 771 772 729
3 772 773 730
3 773 774 731
3 774 775 732
3 775 776 734
3 777 778 735
3 778 779 737
3 779 780 738
3 780 781 739
3 781 782 740
3 782 783 741
3 783 784 742
3 784 785 743
3 785 786 744
3 786 787 745
3 787 788 746
3 788 789 747
3 789 790 748
3 790 791 749
3 791 792 750
3 792 793 751
3 793 794 753
3 794 795 754
3 795 796 756
3 796 797 756
3 756 714 755
3 794 754 753
3 755 795 756
3 754 795 755
3 793 753 752
3 778 737 736
3 775 734 733
3 777 735 734
3 776 777 734
3 778 736 735
3 779 738 737
3 780 739 738
3 781 740 739
3 782 741 740
3 783 742 741
3 784 743 742
3 785 744 743
3 786 745 744
3 787 746 745
3 788 747 746
3 789 748 747
3 762 720 719
3 790 749 748
3 791 750 749
3 759 717 716
3 759 716 756
3 716 715 756
3 756 715 714
3 760 761 717
3 761 718 717
3 762 719 718
3 763 721 720
3 764 722 721
3 765 723 722
3 766 724 723
3 767 725 724
3 768 726 725
3 769 727 726
3 770 728 727
3 771 729 728
3 772 730 729
3 773 731 730
3 774 732 731
3 775 733 732
3 793 752 751
3 757 756 798
3 756 797 798
3 797 839 798
3 797 796 839
3 796 838 839
3 796 837 838
3 795 837 796
3 795 836 837
3 794 836 795
3 793 835 794
3 794 835 836
3 793 834 835
3 792 834 793
3 792 833 834
3 791 833 792
3 791 832 833
3 790 832 791
3 790 831 832
3 789 831 790
3 789 830 831
3 788 830 789
3 788 829 830
3 787 829 788
3 786 828 787
3 787 828 829
3 827 828 786
3 785 827 786
3 826 827 785
3 784 826 785
3 825 826 784
3 783 825 784
3 824 825 783
3 782 824 783
3 823 824 782
3 781 823 782
3 780 823 781
3 780 822 823
3 821 822 780
3 779 821 780
3 820 821 779
3 778 820 779
3 819 820 778
3 819 778 777
3 819 777 818
3 818 777 776
3 818 776 817
3 817 776 775
3 817 775 816
3 816 775 774
3 816 774 815
3 815 774 773
3 815 773 814
3 814 773 772
3 814 772 813
3 813 772 771
3 813 771 770
3 812 813 770
3 812 770 811
3 811 770 769
3 811 769 810
3 810 769 768
3 810 768 809
3 809 768 767
3 767 808 809
3 767 766 808
3 808 766 807
3 766 765 807
3 765 806 807
3 765 764 806
3 806 764 805
3 764 763 805
3 805 763 804
3 763 762 804
3 804 762 803
3 762 761 803
3 761 760 802
3 803 761 802
3 802 760 801
3 760 759 801
3 759 758 800
3 801 759 800
3 800 758 799
3 758 757 799
3 799 757 798
3 839 838 798
3 798 837 836
3 798 838 837
3 798 836 835
3 798 835 834
3 798 834 833
3 798 833 832
3 798 832 831
3 798 831 830
3 798 830 829
3 798 829 828
3 798 828 827
3 798 827 826
3 798 826 825
3 798 825 824
3 798 824 823
3 798 823 822
3 798 822 821
3 798 821 820
3 798 820 819
3 798 819 818
3 798 818 817
3 798 817 816
3 798 816 815
3 798 815 814
3 798 814 813
3 798 813 812
3 798 812 811
3 798 811 810
3 798 810 809
3 798 809 808
3 798 808 807
3 798 807 806
3 798 806 805
3 798 805 804
3 798 804 803
3 798 803 802
3 798 802 801
3 798 801 800
3 798 800 799
  • [cgal-discuss] Error on 3D boolean difference operation on Nef Polyhedra, pascale.bergeret, 10/19/2009
