cgal-discuss - Re: [cgal-discuss] Precondition_exception with Minkowsi sum - inexact constructions kernel
  • To:
  • Cc:
  • Subject: Re: [cgal-discuss] Precondition_exception with Minkowsi sum - inexact constructions kernel
  • Date: Mon, 19 Oct 2009 13:36:13 +0200
Hi!
Thanks for replying! =)
I would very much appreciate if you could explain in more detail...
I don't understand why the kernel must be exact, even if new points are created. Is this a specifically introduced limitation in CGAL or is it that the use of inexact kernel causes errors due to floating point representation which makes the algorithm throw exceptions.
In my specific case, I would be satisfied if the precision of the Point_2 is around 1E-9 which is very "dull" compared to the smallest double. Is it possible to do this in CGAL? or do I need a new type of Kernel. What I mean is, in my case, I can consider values to be the same if the difference is "small". Is there a Kernel for this? "epsilon_Kernel" =)
I realize I should read more about Kernels... but in the mean time... =)
Regards,
Jim
Efraim Fogel wrote:
During the computation of Minkowski sums new points might be
constructed. These points are used as operands of predicates. Thus, you
need an exact-construction kernel (as well as an exact-predicate
kernel). I didn't understand the second question.
jim.wilenius wrote:
Hi!
I am using the CGAL lib in OSX 10.6. (freshly compiled, I followed the
instructions carefully)
I am using the CGAL::Exact_predicates_inexact_constructions_kernel and when
running minkowski sum I get:
terminate called after throwing an instance of
'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: cv.is_in_x_range (p)
File: /usr/local/include/CGAL/Arr_segment_traits_2.h
Line: 486
I get the error given the following two polygons (in order):
P:
4
0.0 0.0
29.809108311772626 0.0
29.809108311772626 29.809108311772626
0.0 29.809108311772626
Q:
7
99.10004234616522 202.2922116762398
168.16528534816382 202.2922116762398
168.16528534816382 271.3574546782384
154.3522367477641 271.3574546782384
140.53918814736437 243.73135747743896
126.72613954696467 229.91830887703924
99.10004234616522 216.1052602766395
I am not sure exactly what the error means? Is it supposed to give an error?
If I use CGAL::Exact_predicates_exact_constructions_kernel then I do not get
the error.
using exact constructions is extremely slow for my application, so I would
really like to use inexact.
by the way, how inexact is the inexact kernel? Any pointers to useful info
is welcome.
Regards,
Jim
Jim Wilenius
