- To:
- Subject: Re: [cgal-discuss] problem with read a txt file to cgal!
- Date: Tue, 20 Oct 2009 21:31:39 -0600
Guang,
Its weird. Could you give more information on your build process and execution of your code. Do mention the OS and the environment for your development.
Rahul Kavalapara
On Tue, Oct 20, 2009 at 9:06 PM, Zheng,Guang <> wrote:
HI, Rahul:Thanks so much for your reply!Acutally I did successfully build the project, when I run the code, what i thought it should ouput the result in a few seconds, but my CPU usage goes up to 100% and takes more than a couple minutes and get nothing.the txt file I tried to read is:0 ,0
10,0
10,10
6 ,5
4 ,1but I can successfully run the corresponding example without modification.Thanks againGuang--On Tue, Oct 20, 2009 at 7:23 PM, Rahul Kavalapara <> wrote:
Hi Guang,
I tried to execute your code, and it works fine. I replaced 1.txt with another text file.
I am not sure where exactly your having trouble with ?
Rahul Kavalapara
On Tue, Oct 20, 2009 at 6:57 PM, Zheng,Guang <> wrote:
Hi, all:I'm pretty new to cgal, and studying some example recently. I tried to modified a little bit of the example code in order to read a txt file to STL vector structure, but it doen't work.Could someone help me ? here is the code:#include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
#include <CGAL/convex_hull_2.h>#include <vector>
#include <iostream>
#include <fstream>
#include <iomanip>using namespace std;typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_2 Point_2;
typedef std::vector<Point_2> Points;int main()
{Points points, result;ifstream file_to_read("1.txt");double x,y;
while(!file_to_read.eof())
{CGAL::set_ascii_mode( file_to_read );
file_to_read>>x;
file_to_read.ignore(1);
file_to_read>>y;
file_to_read.ignore(1);points.push_back(Point_2(x,y));
/*points.push_back(Point_2(0,0));
points.push_back(Point_2(10,0));
points.push_back(Point_2(10,10));
points.push_back(Point_2(6,5));
points.push_back(Point_2(4,1));
*/CGAL::convex_hull_2( points.begin(), points.end(), std::back_inserter(result) );
std::cout << result.size() << " points on the convex hull" << std::endl;return 0;
}Thanks very much!
Guang Zheng
Guang Zheng
- [cgal-discuss] problem with read a txt file to cgal!, Zheng,Guang, 10/21/2009
- Re: [cgal-discuss] problem with read a txt file to cgal!, Rahul Kavalapara, 10/21/2009
- Re: [cgal-discuss] problem with read a txt file to cgal!, Zheng,Guang, 10/21/2009
