- To:
- Subject: Re: [cgal-discuss] Convert CGAL::Lazy_exact_nt<CGAL::Gmpq> to Double
- Date: Wed, 21 Oct 2009 09:41:03 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=jUEElcB4OCMiXMMJMeF97yS+DE5lmVbACNhVbbZYaQbvpR77o8P7yjlIm+PJtFWl60 AWyUaMt45yE50GXcsgBna8bZyoFk6nzdk2/YBNNKV3gknr1IpvUGmCNspw6YEFQf+RRY 2jXqv24y4HI0dRVOG5DnERCh0s5/boBlax8XI=
Ah, perfect! Thank you.
On Wed, Oct 21, 2009 at 9:33 AM, Laurent Rineau (GeometryFactory) <> wrote:
On Wednesday 21 October 2009 15:11:47 Matthew Denno wrote:As for that question, use CGAL::to_double
> 1) Is there a way to convert a CGAL::Lazy_exact_nt<CGAL::Gmpq> value to
> double precision so that I can write to results out to a shapefile?
http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Algebraic_foundations_ref/Function_to_double.html
Laurent Rineau, PhD
- [cgal-discuss] Convert CGAL::Lazy_exact_nt<CGAL::Gmpq> to Double, Matthew Denno, 10/21/2009
- Re: [cgal-discuss] Convert CGAL::Lazy_exact_nt<CGAL::Gmpq> to Double, Laurent Rineau (GeometryFactory), 10/21/2009
- Re: [cgal-discuss] Convert CGAL::Lazy_exact_nt<CGAL::Gmpq> to Double, Matthew Denno, 10/21/2009
- Re: [cgal-discuss] Convert CGAL::Lazy_exact_nt<CGAL::Gmpq> to Double, Andreas Fabri, 10/21/2009
