- To:
- Subject: Re: [cgal-discuss] Qt4 for CGAL Installation
- Date: Wed, 21 Oct 2009 21:23:45 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=QrLvva2CG+vVpGDmJUhIfub9X28IbmBJ7LsiiS6ZuagmbfxuXzI1eAPBXPM2WMyhluCoS8b7w9T1Nno00cdXY47nw5DLmw6Y+OFCLgo5/hwPtDhlhDqYMIYv27/pB5pfdeFGKgBOVyprVfvC9iWh++fa/f7cUr1GV0oWwk5bpCE=;
Excellent!! That worked! I cleared the entire cache except for the two recently entered ZLIB line items, and then made a manual cache entry for Qt4 (for Visual Studio 2008). I later downloaded an old free Qt3 setup distro, and added the appropriate entries for Qt3 (for MSVC 6.0) to the cache. Altogether, the addenda look like this:
QTDIR C:/Program Files/qt-win-free-msvc-3.3.3/lib
QT3_INCLUDE_DIR C:/Program Files/qt-win-free-msvc-3.3.3/include
QT3_QT_LIBRARY C:/Program Files/qt-win-free-msvc-3.3.3/lib/qt-mt3.lib
QT3_QTMAIN_LIBRARY C:/Program Files/qt-win-free-msvc-3.3.3/lib/qtmain.lib
QT3_QASSISTANTCLIENT_LIBRARY C:/Program Files/qt-win-free-msvc-3.3.3/lib/qassistantclient.lib
QT3_MOC_LIBRARY C:/Program Files/qt-win-free-msvc-3.3.3/bin/moc.exe
QT3_UIC_LIBRARY C:/Program Files/qt-win-free-msvc-3.3.3/bin/uic.exe
QT_QMAKE_EXECUTABLE C:/Qt/2009.04/qt/qmake/qmake.exe
ZLIB_INCLUDE_DIR C:/ZLIB/include
ZLIB_LIBRARY C:/ZLIB/lib/zlib.lib
Then I ran <Configure>, then <Generate> The output follows:
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=5 CGAL_BUILD_VERSION= CGAL_SONAME_VERSION=4 CGAL_SOVERSION =4.0.0 CGAL_REFERENCE_CACHE_DIR= Building static libraries Targetting Visual Studio 9 2008 Target build enviroment supports auto-linking Using VC90 compiler. Generator uses intermediate configuration directory: $(OutDir) USING CMake version: 2.6.4 System: Windows Build type: Release USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG' USING LDFLAGS = ' ' GMP include: C:/Program Files/CGAL-3.5/auxiliary/gmp/include GMP libraries: GMP definitions: USING GMP_VERSION = '4.2.4' MPFR include: C:/Program Files/CGAL-3.5/auxiliary/gmp/include MPFR libraries: MPFR definitions: USING MPFR_VERSION = '2.3.2' Boost include: C:/Program Files/boost/boost_1_39 Boost libraries: optimized;C:/Program Files/boost/boost_1_39/lib/libboost_thread-vc90-mt-1_39.lib;debug;C:/Program Files/boost/boost_1_39/lib/libboost_thread-vc90-mt-gd-1_39.lib Boost definitions: USING BOOST_VERSION = '1.39.0' CMAKE_INSTALL_PREFIX=C:/Program Files/CGAL OpenGL include: OpenGL libraries: glu32;opengl32 USING ZLIB_VERSION = '1.2.3' ZLib include: C:/ZLIB/include ZLib libraries: C:/ZLIB/lib/zlib.lib USING OPENGL_VERSION = '1.1' USING QT_VERSION = '3.3.3' OpenGL include: OpenGL include: OpenGL libraries: glu32;opengl32 OpenGL definitions: Qt3 include: C:/Program Files/qt-win-free-msvc-3.3.3/include Qt3 libraries: imm32.lib;ws2_32.lib;C:/Program Files/qt-win-free-msvc-3.3.3/lib/qt-mt3.lib Qt3 definitions: moc executable: QT3_MOC_EXECUTABLE-NOTFOUND uic executable: QT3_UIC_EXECUTABLE-NOTFOUND USING QT4_VERSION = '4.5.3' OpenGL include: OpenGL libraries: glu32;opengl32 OpenGL definitions: Qt4 include: C:/Qt/2009.04/qt/include Qt4 libraries: optimized;C:/Qt/2009.04/qt/lib/qtmain.lib;debug;C:/Qt/2009.04/qt/lib/qtmaind.lib;optimized;C:/Qt/2009.04/qt/lib/QtOpenGL4.lib;debug;C:/Qt/2009.04/qt/lib/QtOpenGLd4.lib;opengl32.lib glu32.lib gdi32.lib user32.lib delayimp.lib;optimized;C:/Qt/2009.04/qt/lib/QtGui4.lib;debug;C:/Qt/2009.04/qt/lib/QtGuid4.lib;imm32;winmm;optimized;C:/Qt/2009.04/qt/lib/QtCore4.lib;debug;C:/Qt/2009.04/qt/lib/QtCored4.lib;ws2_32 Qt4 definitions: -DQT_DLL moc executable: C:/Qt/2009.04/qt/bin/moc.exe uic executable: C:/Qt/2009.04/qt/bin/uic.exe Configuring done Generating done Not sure what I should do next. (One of my next questions is how do I eliminate the instructions which instruct the 'upper pane' to produce lines like this:
uic executable: QT3_UIC_EXECUTABLE-NOTFOUND ... [etc.]
...(when I've already directed CMake to their locations))?
Given what's seen in the output, what should I do next?
I can't thank you enough for your generous assistance with all of this so far. |
- [cgal-discuss] Qt4 for CGAL Installation, A S, 10/21/2009
- Re: [cgal-discuss] Qt4 for CGAL Installation, Laurent Rineau (GeometryFactory), 10/21/2009
- Re: [cgal-discuss] Qt4 for CGAL Installation, A S, 10/21/2009
- Re: [cgal-discuss] Qt4 for CGAL Installation, A S, 10/22/2009
