- To:
- Subject: [cgal-discuss] single Demo build:
- Date: Wed, 21 Oct 2009 23:51:46 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=zIKbgaw4bIBZEPyYIpel7NBqmVh8cLneKCMW1SmIQx6ppYgjI20erdCm7669gnW3L6SoUCNr9ylxf3c4IdLnse9UCdsdUjZS4dPir9ocpP7C6O6VspRrlO0EXXBQlv1VlKvkn8/TS7jcoAgP8Ps2l5DsyMT1N3XxCDr+Q/+KrXg=;
I'm pretty sure I was able to reset the environment variable for Visual Studuio 2008 (as demonstrated in the upper portion of the following). But I can't figure out why this is failing on this Demo build:
C:\Program Files\Microsoft Visual Studio 9.0\vc\bin>"C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools\vsvars32.bat" Setting environment for using Microsoft Visual Studio 2008 x86 tools. C:\Program Files\Microsoft Visual Studio 9.0\vc\bin>cd "C:\Program Files\Microso
ft Visual Studio 9.0\Common7\Tools" C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools>vcvars32.bat
C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools>"C:\Program Files\Mic
rosoft Visual Studio 9.0\Common7\Tools\vsvars32.bat" Setting environment for using Microsoft Visual Studio 2008 x86 tools. C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools>cd "C:\Program Files\
CGAL-3.5\demo\Alpha_shapes_2" C:\Program Files\CGAL-3.5\demo\Alpha_shapes_2>cmake -DCGAL_DIR=$HOME/CGAL-3.5
-- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/VC98/B in/CL.EXE -- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/VC98/B in/CL.EXE -- broken CMake Error at C:/Program Files/CMake 2.6/share/cmake-2.6/Modules/CMakeTestCComp iler.cmake:32 (MESSAGE): The C compiler "C:/Program Files/Microsoft Visual Studio/VC98/Bin/CL.EXE" is not able to compile a simple test program. It fails with the following output:
Change Dir: C:/Program Files/CGAL-3.5/demo/Alpha_shapes_2/CMakeFiles/CMakeTmp
Run Build Command:C:\PROGRA~1\MICROS~4\COMMON\MSDev98\Bin\MSDEV.COM CMAKE_TRY_COMPILE.dsw /MAKE "cmTryCompileExec - Debug" /BUILD --------------------Configuration: cmTryCompileExec - Win32
Debug-------------------- Compiling...
Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 12.00.8168 for
80x86 Copyright (C) Microsoft Corp 1984-1998. All rights reserved.
cl /MDd /W3 /Zi /Od /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_WINDOWS" /D
"_MBCS" /D CMAKE_INTDIR=\"Debug\" /Fo"Debug/" /Fd"Debug/" /FD /GZ /Zm1000 /GZ /TC /c "C:\Program Files\CGAL-3.5\demo\Alpha_shapes_2\CMakeFiles\CMakeTmp\testCCom
piler.c" testCCompiler.c
Linking...
Microsoft (R) Incremental Linker Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib
shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /version:0.0 /stack:0x989680 /subsystem:console /incremental:yes "/pdb:C:\Program Files\CGAL-3.5\demo\Alpha_shapes_2\CMakeFiles\CMakeTmp\Debug/cmTryCompileExec. pdb" /debug /machine:I386 "/out:C:\Program Files\CGAL-3.5\demo\Alpha_shapes_2\CMakeFiles\CMakeTmp\Debug/cmTryCompileExec. exe" "/implib:C:\Program Files\CGAL-3.5\demo\Alpha_shapes_2\CMakeFiles\CMakeTmp\Debug\cmTryCompileExec. lib" /pdbtype:sept /IGNORE:4089 ".\Debug\testCCompiler.obj"
LINK : fatal error LNK1104: cannot open file "C:\Program
Files\CGAL-3.5\demo\Alpha_shapes_2\CMakeFiles\CMakeTmp\Debug/cmTryCompileExec. exe" Error executing link.exe. cmTryCompileExec.exe - 1 error(s), 0 warning(s)
CMake will not be able to correctly generate this project.
Call Stack (most recent call first): CMakeLists.txt:3 (project) -- Configuring incomplete, errors occurred! C:\Program Files\CGAL-3.5\demo\Alpha_shapes_2> |
- [cgal-discuss] single Demo build:, A S, 10/22/2009
