cgal-discuss - Re: [cgal-discuss] Accessing facet from facet iterator
  • To:
  • Subject: Re: [cgal-discuss] Accessing facet from facet iterator
  • Date: Thu, 22 Oct 2009 13:40:35 +0200
On Thursday 22 October 2009 13:13:59
wrote:
> for( Surface::Facet_iterator fb = surface.facets_begin()
> , fe = surface.facets_end()
> ; fb != fe
> ; ++ fb
> HF_circulator h = fb->facet_begin();
> std::size_t order = 0;
> do{
> ++order;
> }while( ++h != fb->facet_begin());
> if( order == 3)
> std::cout << cont << " -TRIANGULAR ->" << order << "\n";
> else{
> std::cout << cont << " -NÃO TRIANGULAR ->" << order << "\n";
> break;
> cont++;
; fb != fe
; ++ fb
if( fb->is_triangle())
else{
break;
cont++;
fb is of type Surface::Facet_iterator. An iterator behaves approximately like
pointers. The value type of that iterator type is facet. It means that you
can
do:
Facet f = (*fe); // you need to _dereference_ "fe" with, "*"
or directly call Facet methods using:
fb->method(...)
Laurent Rineau, PhD
