- To:
- Subject: Re: [cgal-discuss] This happens on attempt to run demo arrangement_2:
- Date: Mon, 26 Oct 2009 10:58:08 +0200
On Monday 26 October 2009 03:29:27 A S wrote:
> Windows Dialog Box: "The program can't start because gmp-vc90-mt-gd.dll is
> missing from your comuter. Try reinstalling the program to fix this
> problem."
> This machine is swimming in gmp-vc90-mt-gd.dll files. There's even one
> inside C:\System32\. I also placed one in the same directory as
> arrangement_2.exe.
Maybe the dependencies of gmp-vc90-mt-gd.dll itself are not found on that
computer. Use depends.exe (from the Visual Studio suite) to find out what
dependency you may have forget. Anyway, distributing a debug version of a dll
is a strange way of doing. You should refrain from doing that.
And multiple copies of a dll will never help. It can become a nightmare if
you
have *different* copies of the same dll in the system.
Laurent Rineau, PhD
- [cgal-discuss] This happens on attempt to run demo arrangement_2:, A S, 10/26/2009
- Re: [cgal-discuss] This happens on attempt to run demo arrangement_2:, Laurent Rineau (GeometryFactory), 10/26/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] This happens on attempt to run demo arrangement_2:, A S, 10/26/2009
