- To:
- Subject: Re: [cgal-discuss] insert_curve problem
- Date: Mon, 26 Oct 2009 08:41:19 +0100
Eric Berberich wrote:
Ben Strasser wrote:
Thanks,
#include <CGAL/Cartesian.h>
#include <CGAL/MP_Float.h>
#include <CGAL/Quotient.h>
typedef CGAL::Quotient<CGAL::MP_Float> Number_type;
typedef CGAL::Cartesian<Number_type> Kernel;
did the trick :)
This is not a trick - it's essential for reliable geometric computing. 'doubles' are evil for that. See the other mail I just sent a few seconds ago.
eriC
The maybe better trick would be to use
CGAL::Exact_predicates_exact_constructions_kernel
because this should be faster than using an arbitrary precision number type
all the time.
andreas
- [cgal-discuss] insert_curve problem, Ben Strasser, 10/25/2009
- Re: [cgal-discuss] insert_curve problem, Ben Supnik, 10/25/2009
- Re: [cgal-discuss] insert_curve problem, Ben Strasser, 10/25/2009
- Re: [cgal-discuss] insert_curve problem, Eric Berberich, 10/26/2009
- Re: [cgal-discuss] insert_curve problem, Andreas Fabri, 10/26/2009
