cgal-discuss - [cgal-discuss] how to solve this error
  • To:
  • Subject: [cgal-discuss] how to solve this error
  • Date: Wed, 28 Oct 2009 04:24:22 -0700 (PDT)
Hi ,
I am trying to run one simple program, i got the following error :
Compiling...
stdafx.cpp
Compiling...
ex1.cpp
d:\cgalcode\polyhedronification\ex1\ex1.cpp(106) : error C2664:
'std::vector<_Ty>::push_back' : cannot convert parameter 1 from
'CGAL::Triangle_3' to 'const CGAL::CGALi::CC_iterator &'
with
_Ty=CGAL::CGALi::CC_iterator>>,false>
and
R_=CGAL::Filtered_kernel>
and
DSC=CGAL::Compact_container>>,
Const=false
Reason: cannot convert from 'CGAL::Triangle_3' to 'const
CGAL::CGALi::CC_iterator'
with
and
Const=false
No user-defined-conversion operator available that can perform this
conversion, or the operator cannot be called
My program code is :
include "stdafx.h"
#include <cassert>
#include <vector>
#include <fstream>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_hierarchy_3.h>
#include <CGAL/IO/Geomview_stream.h>
typedef CGAL::Simple_cartesian<double> CK;
typedef CGAL::Filtered_kernel<CK> K;
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::FT NT;
typedef CGAL::Triangulation_vertex_base_3<K> Vb;
typedef CGAL::Triangulation_hierarchy_vertex_base_3<Vb> Vbh;
typedef CGAL::Triangulation_data_structure_3<Vbh> Tds;
typedef CGAL::Delaunay_triangulation_3<K,Tds> Dt;
typedef CGAL::Triangulation_hierarchy_3<Dt> Dh;
typedef Dh::Vertex_iterator Vertex_iterator;
typedef Dh::Vertex_handle Vertex_handle;
typedef Dh::Cell_handle Cell_handle;
typedef Dh::Point Point;
//bool is_alpha(const Dh & T, const Dh::Facet & f, NT alpha) { }
assert( alpha > 0 ); assert( ! T.is_infinite( f ) );
Cell_handle c = f.first; int ic = f.second;
Cell_handle n = c->neighbor(ic);
Point p1, p2, p3;
if ( ic%2 == 1 ) {
p1 = c->vertex((ic+1)&3)->point(); // &3 in place of %4
p2 = c->vertex((ic+2)&3)->point();
p3 = c->vertex((ic+3)&3)->point(); }
else {
p1 = c->vertex((ic+2)&3)->point();
p2 = c->vertex((ic+1)&3)->point();
if ( T.is_infinite(n) ) {
Point Oc = CGAL::circumcenter( c->vertex(0)->point(),
c->vertex(1)->point(), c->vertex(2)->point(), c->vertex(3)->point() );
if ( orientation(p1, p2, p3, Oc) == CGAL::POSITIVE )
return alpha > CGAL::squared_distance( p1,
circumcenter( p1, p2, p3 ) );
else
return alpha > CGAL::squared_distance( Oc, p1 );
if ( T.is_infinite(c) ) {
Point On = CGAL::circumcenter( n->vertex(0)->point(),
n->vertex(1)->point(), n->vertex(2)->point(), n->vertex(3)->point() );
if ( orientation(p1, p2, p3, On) == CGAL::NEGATIVE )
else
return alpha > CGAL::squared_distance( On, p1 );
} // now both c and n are finite Point
NT R2c = CGAL::squared_distance( Oc, p1 );
NT R2n = CGAL::squared_distance( On, p1 );
if ( orientation( p1,p2,p3,Oc ) != orientation( p1,p2,p3,On ) )
return alpha < CGAL::max( R2c, R2n ) && alpha >
p1, circumcenter( p1,p2,p3 ) );
else
return alpha < CGAL::max( R2c, R2n ) && alpha > CGAL::min(
R2c, R2n );
int main(int argc, char* argv[]) {
CGAL::Geomview_stream gv(CGAL::Bbox_3(0,0,0, 5, 5, 5));
gv.set_bg_color(CGAL::Color(0, 200, 200));
gv.clear();
Dh T;
std::cout << "--- Reading file and computing Delaunay... " <<
std::endl;
std::ifstream iFile(argv[1], std::ios::in);
Point p;
int nbpts = 0;
while ( iFile >> p ) {
++nbpts;
T.insert( p );
std::cout << nbpts << " read points" << std::endl;
std::cout << T.number_of_vertices() << " vertices" << std::endl;
std::cout << T.number_of_finite_facets() << " facets in Delaunay" <<
std::endl << std::endl;
bool again = true;
double alpha;
while (again) {
std::cout << "alpha ? ";
std::cin >> alpha;
std::cout << std::endl;
int nb_facets=0;
std::cout << "--- computation of the alpha facets and
display... " <<
std::endl;
std::vector<Cell_handle> tris;
Dh::Finite_facets_iterator tit = T.finite_facets_begin();
for ( ; tit != T.finite_facets_end() ; ++tit ) {
if ( is_alpha( T, *tit, alpha ) ) {
++nb_facets; // gv << T.triangle(*tit);
tris.push_back(T.triangle(*tit));
gv.clear();
gv.draw_triangles(tris.begin(), tris.end());
std::cout << nb_facets << " alpha facets" << std::endl;
std::cout << "continue ? yes : 1 / no : 0 ? ";
std::cin >> again;
return 0;
as a beginner , i tried alot but i couldnot define the appropriate Vector
type to run this program.
Could you please help me in this situation.
Thank you in advance.
Regards,
Arun K Pratihast
View this message in context:
http://www.nabble.com/how-to-solve-this-error-tp26092986p26092986.html
