cgal-discuss - [cgal-discuss] Meshing a (Nef-)Polyhedron - which kernel will work?
  • To: CGAL Mailinglist <>
  • Subject: [cgal-discuss] Meshing a (Nef-)Polyhedron - which kernel will work?
  • Date: Wed, 28 Oct 2009 13:52:12 +0100 (CET)
  • Organization: Institut fuer Werkstoffe TU Braunschweig
Dear all,
I am facing a problem which is probably due to the fact that i do not
sufficiently understand how the template-kernels really work.
The problem is the following:
I am operating on a Nef-Polyhedron and convert this to a Polyhedron.
The next step would be to create a Mesh on this polyhedron, but I
cannot get this to run because it seems that the Mesh_3-stuff and the
Nef-Polyhedron cannot work with the same kernel. (I found that my
Nef-calculation only works with exact_predicates_exact_constructions,
but Mesh_3 seems not to work with this?)
When compiling the program, I get (depending on my compiler version)
either a segmentation fault of gcc or a compiler error. (Example error
»CGAL::Lazy_exact_nt<CGAL::Gmpq>« kann nicht nach »double« in return
umgewandelt werden -- meaning canno convert
CGAL::Lazy_exact_nt<CGAL::Gmpq> to double in return)
Here is an excerpt from the program (full program below). It is based
on the examples polygon_prog_cut_cube and mesh_polyhedral_domain:
//Typedefs
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Mesh_3::Robust_intersection_traits_3<Kernel> Geom_traits;
typedef CGAL::Polyhedron_3<Geom_traits> Polyhedron;
typedef CGAL::SNC_indexed_items Items;
typedef CGAL::Nef_polyhedron_3<Kernel, Items> Nef_polyhedron;
typedef Kernel::Vector_3 Vector_3;
typedef Kernel::Aff_transformation_3 Aff_transformation_3;
typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, Geom_traits> Mesh_domain;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
// Mesh Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
typedef Mesh_criteria::Facet_criteria Facet_criteria;
typedef Mesh_criteria::Cell_criteria Cell_criteria;
...excerpt from main:
Polyhedron P;
Halfedge_handle h = make_cube_3( P);
Polyhedron Q=P;
Nef_polyhedron N1(P);
Nef_polyhedron N2(Q);
... some operations on N1 and N2
N2.convert_to_Polyhedron(P);
Mesh_domain domain(P);
Facet_criteria facet_criteria(25, 0.15, 0.008); // angle, size,
approximation
Cell_criteria cell_criteria(4, 0.2); // radius-edge ratio, size
Mesh_criteria criteria(facet_criteria, cell_criteria);
// Mesh generation --- the next command seems to be the troublesome one
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
So how can I create a mesh on a polyhedron that is made froma
Nef_Polyhedron? is it possible?
Any help would be appreciated,
Martin.
PS: Here is the full program:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/Nef_3/SNC_indexed_items.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
#include <CGAL/polyhedron_cut_plane_3.h>
#include <CGAL/IO/Polyhedron_geomview_ostream.h>
#include <iostream>
#include <CGAL/AABB_intersections.h>
#include <CGAL/Mesh_3/Robust_intersection_traits_3.h>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Polyhedral_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/refine_mesh_3.h>
typedef Kernel::Point_3 Point;
typedef Kernel::Plane_3 Plane;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
typedef Polyhedron::Halfedge_iterator
Halfedge_iterator;
// Triangulation
// Mesh Criteria
template <class Poly>
typename Poly::Halfedge_handle make_cube_3( Poly& P) {
// appends a cube of size [0,1]^3 to the polyhedron P.
CGAL_precondition( P.is_valid());
typedef typename Poly::Point_3 Point;
typedef typename Poly::Plane_3 Plane;
typedef typename Poly::Halfedge_handle Halfedge_handle;
Halfedge_handle h = P.make_tetrahedron( Point( 1, 0, 0),
Point( 0, 0, 1),
Point( 0, 0, 0),
Point( 0, 1, 0));
Halfedge_handle g = h->next()->opposite()->next();
P.split_edge( h->next());
P.split_edge( g->next());
P.split_edge( g);
h->next()->vertex()->point() = Point( 1, 0, 1);
g->next()->vertex()->point() = Point( 0, 1, 1);
g->opposite()->vertex()->point() = Point( 1, 1, 0);
Halfedge_handle f = P.split_facet( g->next(), g->next()->next()->next());
Halfedge_handle e = P.split_edge( f);
e->vertex()->point() = Point( 1, 1, 1);
P.split_facet( e, f->next()->next());
CGAL_postcondition( P.is_valid());
g = h;
g->facet()->plane() = Plane( g->vertex()->point(),
g->next()->vertex()->point(),
g->next()->next()->vertex()->point());
g = h->opposite();
g = h->next()->opposite();
g = h->next()->next()->opposite();
g = h->next()->next()->next()->opposite();
g = g->next()->next()->opposite();
return h;
int main() {
CGAL::set_pretty_mode( std::cout);
Polyhedron P;
std::cout << "Before" << P;
// Plane pl = Plane( Point( 0.5, 0.0, 0.0),
// Point( 1, 0.0, 1),
// Point( 1, 1, 1.));
// Simple cut in the middle
Point( 0.5, 0.0, 0.5),
Point( 0.5, 0.5, 0.));
//!!! It seems that the first point of the plane must be on the
//correct handle of the polygon!!??
Polyhedron Q=P;
// Find the corresponding handle to h on Q
Halfedge_handle hq;
for (Halfedge_iterator it=Q.halfedges_begin(); it != Q.halfedges_end();
++it)
if ((it->facet()->plane() == h->facet()->plane()) &&
(it->vertex()->point() == h->vertex()->point()))
hq = it;
std::cout << "Hit!\n";
break;
std::cout << pl << std::endl;
CGAL::polyhedron_cut_plane_3( P, h, pl);
CGAL::polyhedron_cut_plane_3( Q, hq->opposite(), pl.opposite());
std::cout << P << Q;
Aff_transformation_3 aff(CGAL::TRANSLATION, Vector_3(0,0,0.5));
N2.transform(aff);
// Now we would need to join N1 and N2 somehow
N2=(N1+N2) ;
Polyhedron Res;
if (N2.is_simple())
N2.convert_to_Polyhedron(Res);
std::cout << "N2 is simple!!!" << Res;
CGAL::Geomview_stream geo;
geo << CGAL::GREEN << Res;
// wait for a mouse click.
Point click;
geo >> click;
else
std::cout << "N2 is not simple!!" << N2;
// // Set mesh criteria
approximation
// Mesh generation
// // Output
// std::ofstream medit_file("out.mesh");
// c3t3.output_to_medit(medit_file);
// medit_file.close();
return 0;
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
e-mail
  • [cgal-discuss] Meshing a (Nef-)Polyhedron - which kernel will work?, Martin Baeker, 10/28/2009
