cgal-discuss - Re: [cgal-discuss] Error compiling with LEDA window stream
  • To:
  • Subject: Re: [cgal-discuss] Error compiling with LEDA window stream
  • Date: Thu, 29 Oct 2009 11:35:21 +0100
This is rather outdated, so you are better off using Qt4 and the
GraphicsView framework.
andreas
Sterpa wrote:
I need to visualize Polygon_2, and since Geomview doesn't support this I'm
trying to use LEDA Window_stream. I've installed the library on Ubuntu, and
added the flags specified by the Readme.txt of LEDA to the compiler, but I
still got these errors:
CGAL/IO/Window_stream.h: No such file or directory
CGAL/IO/cgal_window_redefine.h: No such file or directory
