cgal-discuss - Res: Res: [cgal-discuss] CGAL::Intersection
  • To:
  • Subject: Res: Res: [cgal-discuss] CGAL::Intersection
  • Date: Thu, 29 Oct 2009 12:18:07 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=sNXT6HliMnMQ+JXhDbI3JBCIJnbc+DLI74eMq2xrjjpd8x74qN81bOdh3BP4/j5PsTic4dMO6TTnYRWqTx5GlHPwRTJTL8XfERRPyD3SZJum7gRets/71iAH62L3tHzxhW+/0cwTIkkXMoMrewmUiWB7NuwIatiuipIKcDse3pA=;
Hi Supnik.
The operations in this manual will work in beta version? I use the beta version and, because a lot of problems throughout the installation, I don't want try a new installation.
Thank you very much!
mrp
De: Ben Supnik <>
Para:
Enviadas: Quarta-feira, 28 de Outubro de 2009 16:37:54
Assunto: Re: Res: [cgal-discuss] CGAL::Intersection
Hi Marcos,
Marcos R. P. wrote:
> Somebody could give me a good idea to get a intersection between two polygons that it have more than four vertices?
Look at this
http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Boolean_set_operations_2/Chapter_main.html
it is what you want.  For polygons of line segments, there are premade traits to have line segments for edges.  The code works fine for non-convex polygons.
I will warn you now - you MUST use an exact number type!  Do not use cartesian<double> or this package will fail. :-)
cheers
Ben
>  Please, who knows, if there are no way, warn me.
> MRP
> *De:* Marcos R. P. <>
> *Para:* cgal discuss <>
> *Enviadas:* Quinta-feira, 8 de Outubro de 2009 8:30:41
> *Assunto:* [cgal-discuss] CGAL::Intersection
> Hi, everybody!
>  I am reading the cgal_manual.pdf in order to try to solve my problem, i.e.,  to calculate the average rainfall by the Thiessen Method.
>  I have just seen on pages 608 and 609 a table with avaiable intersection types and realized that there is no intersection for polygon, which I assume is what I need.
>  In any case, the problem is I need to compute the intersection area between a Voronoi cell and a polygon. How could I do it?
>  Any hints?
>  Marcos
> Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/> - Celebridades <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/celebridades/> - Música <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/m%C3%BAsica/> - Esportes <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/esportes/>
-- Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
-- You are currently subscribed to cgal-discuss.
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
