- To:
- Subject: Re: [cgal-discuss] Delaunay_triangulation_3: all finite facets
- Date: Fri, 30 Oct 2009 17:45:43 +0100
On Friday 30 October 2009 17:40:43 chris wrote:
> Hello,
> I wonder if iterating over all finite facets of a Delaunay_triangulation_3
> via Finite_facets_iterator should be same as iterating all of these facets
> using something like:
> Facet(c,i) for all finite cells and i in [0,1,2,3]
> I noticed that the first approach, i.e. using Finite_facets_iterator, gives
> less facets and also gives facets whose cell is infinite.
In a 3D triangulation, all facets have to incident cells. To iterate over all
finite facets, you need to choose which representation of the facet, among
the
two.
If you iterate over all finite cells and i in [0,1,2,3], then Facet(c,i)
will
iterate twice on all finite facets, but facets on the convex hull, which be
seen only once (because you do not iterate over infinite cells).
Laurent Rineau, PhD
- [cgal-discuss] Delaunay_triangulation_3: all finite facets, chris, 10/30/2009
- Re: [cgal-discuss] Delaunay_triangulation_3: all finite facets, Sylvain Pion, 10/30/2009
- Re: [cgal-discuss] Delaunay_triangulation_3: all finite facets, Laurent Rineau (GeometryFactory), 10/30/2009
