cgal-discuss - Re: [cgal-discuss] can not build the example in the chapter Surface reconstruction from point set
  • To:
  • Subject: Re: [cgal-discuss] can not build the example in the chapter Surface reconstruction from point set
  • Date: Tue, 3 Nov 2009 00:31:35 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=AhWXQhPHp8QIYVn3IeaaTiLNzt0B+A+k4pIGfejzQGbLR6ZQll4upzctWRBgikAdEL y3AufJYGH/f1JyiilSVj+D/Xk/iiB4+Aq7MJDekTqb0wPxG0Ysc9NGwC3PiOhgNxD4tQ nBMS4wz1hz0hOsT1Stbuqx6vCT3E2bC20NKXc=
Hello,
have you tried adding the following ?
#pragma comment(lib,"psapi.lib")
http://www.codeguru.com/forum/archive/index.php/t-107351.html
On Tue, Nov 3, 2009 at 12:13 AM, <> wrote:
when I build the example program "poisson_reconstruction_example.c" in the
chapter Surface reconstrution from point set in CGAL 3.5, I encountered a
problem.I failed to  build it.error messages like this:(By the way I builded it
with Release Mode)
Linking...
poisson_reconstruction_example.obj : error LNK2001: one cannot recognize
external  symbol _GetProcessMemoryInfo@12
D:\My Documents\Visual Studio
2005\Projects\Surface_reconstruction_points_3\Release\Surface_reconstruction_points_3.exe
: fatal error LNK1120: one cannot recognize external  symbol
Build log was saved at "file://d:\My Documents\Visual Studio
2005\Projects\Surface_reconstruction_points_3\Surface_reconstruction_points_3\Release\BuildLog.htm"
Surface_reconstruction_points_3 - 2 error(s), 36 warning(s)
Omar
