- To:
- Subject: [cgal-discuss] problem using CGAL on Mac OS X 10.5 with boost 1.4
- Date: Tue, 3 Nov 2009 17:01:14 +0100
Hi all,
I have successfully installed CGAL 3.5 on a Mac OS.
The problem is that my code, which is working on linux with boost 1.37 and CGAL 3.5, doesn't work on Mac.
Mac version is 10.5.8, the version of boost on Mac is 1.40 and gcc is 4.0.1 darwin flavour.
I have attached here a log of the errors. It seems to be that the boost function CGAL is pointing to doesn't exist anymore or at least its header is not fulfilled.
In file included from /usr/local/include/CGAL/property_map.h:24,
from /usr/local/include/CGAL/pca_estimate_normals.h:26,
from include/meshing.hpp:9,
from src/meshing.cpp:1:
/usr/local/include/boost/property_map.hpp:15:4: warning: #warning "This
header is deprecated. Please use: boost/property_map/property_map.hpp"
In file included from /usr/local/include/CGAL/Index_property_map.h:24,
from /usr/local/include/CGAL/mst_orient_normals.h:26,
from include/meshing.hpp:10,
In file included from /usr/local/include/CGAL/mst_orient_normals.h:38,
/usr/include/boost-sandbox/boost/graph/properties.hpp:31,
from /usr/local/include/boost/graph/adjacency_list.hpp:50,
from /usr/local/include/CGAL/mst_orient_normals.h:39,
In file included from /usr/local/include/CGAL/IO/read_xyz_points.h:26,
from include/meshing.hpp:12,
In file included from /usr/local/include/CGAL/Point_with_normal_3.h:28,
from
/usr/local/include/CGAL/Reconstruction_triangulation_3.h:24,
from
/usr/local/include/CGAL/Poisson_reconstruction_function.h:27,
from include/meshing.hpp:18,
/usr/local/include/boost/graph/named_graph.hpp:187: error: 'vertex_bundle_t'
was not declared in this scope
/usr/local/include/boost/graph/named_graph.hpp:187: error: template argument
1 is invalid
1 is invalid
/usr/local/include/boost/graph/detail/adjacency_list.hpp: In function
'typename Config::vertex_descriptor boost::add_vertex(const typename
Config::vertex_property_type&, boost::adj_list_impl<Derived, Config, Base>&)':
/usr/local/include/boost/graph/detail/adjacency_list.hpp:1925: error:
'vertex_bundle' was not declared in this scope
Config::vertex_property_type&, boost::vec_adj_list_impl<G, C, B>&)':
/usr/local/include/boost/graph/detail/adjacency_list.hpp:2201: error:
/usr/local/include/boost/graph/adjacency_list.hpp: At global scope:
/usr/local/include/boost/graph/adjacency_list.hpp:366: error:
'vertex_bundle_t' was not declared in this scope
/usr/local/include/boost/graph/adjacency_list.hpp:367: error: template
argument 1 is invalid
/usr/local/include/boost/graph/adjacency_list.hpp:368: error: 'edge_bundle_t'
/usr/local/include/boost/graph/adjacency_list.hpp:368: error: template
/usr/local/include/boost/graph/adjacency_list.hpp:372: error: template
argument 5 is invalid
argument 6 is invalid
/usr/local/include/boost/graph/adjacency_list.hpp:372: error: expected `{'
before 'type'
/usr/local/include/boost/graph/adjacency_list.hpp:372: error: invalid type in
declaration before ',' token
declaration of 'int boost::type'
/usr/local/include/boost/graph/named_function_params.hpp:130: error:
'edge_centrality_t' was not declared in this scope
/usr/local/include/boost/graph/named_function_params.hpp:130: error: template
argument 2 is invalid
'vertex_centrality_t' was not declared in this scope
'vertex_lowpoint_t' was not declared in this scope
/usr/local/include/boost/graph/named_function_params.hpp: In member function
'int boost::bgl_named_params<T, Tag, Base>::edge_centrality_map(const PType&)
const':
/usr/local/include/boost/graph/named_function_params.hpp:130: error: invalid
type in declaration before ';' token
'int boost::bgl_named_params<T, Tag, Base>::centrality_map(const PType&)
const':
'int boost::bgl_named_params<T, Tag, Base>::lowpoint_map(const PType&) const':
/usr/local/include/boost/graph/named_function_params.hpp: At global scope:
/usr/local/include/boost/graph/named_function_params.hpp:157: error:
/usr/local/include/boost/graph/named_function_params.hpp:157: error: template
/usr/local/include/boost/graph/named_function_params.hpp: In function 'int
boost::edge_centrality_map(const PType&)':
/usr/local/include/boost/graph/named_function_params.hpp:157: error: invalid
boost::centrality_map(const PType&)':
boost::lowpoint_map(const PType&)':
/usr/local/include/boost/graph/named_function_params.hpp:335: error:
/usr/local/include/boost/graph/named_function_params.hpp:335: error: template
/usr/local/include/boost/graph/named_function_params.hpp:335: error: explicit
specialization of non-template '<type error>'
/usr/local/include/CGAL/mst_orient_normals.h: In instantiation of
'CGAL::CGALi::Riemannian_graph<std::_List_iterator<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, CGAL::Vector_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >
/usr/local/include/CGAL/mst_orient_normals.h:572: instantiated from
'ForwardIterator CGAL::mst_orient_normals(ForwardIterator, ForwardIterator,
PointPMap, NormalPMap, unsigned int, const Kernel&) [with ForwardIterator =
> >, PointPMap =
CGAL::First_of_pair_property_map<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, NormalPMap =
CGAL::Second_of_pair_property_map<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, Kernel = CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >]'
/usr/local/include/CGAL/mst_orient_normals.h:643: instantiated from
PointPMap, NormalPMap, unsigned int) [with ForwardIterator =
> >, PointPMap =
> >, NormalPMap =
src/meshing.cpp:39: instantiated from here
/usr/local/include/CGAL/mst_orient_normals.h:82: error: invalid use of
undefined type 'class boost::adjacency_list<boost::vecS, boost::vecS,
boost::undirectedS,
CGAL::CGALi::Riemannian_graph_vertex_properties<std::_List_iterator<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > >, boost::property<boost::edge_weight_t, float, boost::no_property>,
boost::no_property, boost::listS>'
/usr/local/include/boost/graph/adjacency_list.hpp:360: error: declaration of
'class boost::adjacency_list<boost::vecS, boost::vecS, boost::undirectedS,
'CGAL::CGALi::MST_graph<std::_List_iterator<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >':
/usr/local/include/CGAL/mst_orient_normals.h:579: instantiated from
> >, PointPMap =
> >, NormalPMap =
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:107: error: invalid use of
boost::directedS,
CGAL::CGALi::MST_graph_vertex_properties<std::_List_iterator<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > >, boost::no_property, boost::no_property, boost::listS>'
'class boost::adjacency_list<boost::vecS, boost::vecS, boost::directedS,
/usr/local/include/CGAL/mst_orient_normals.h: In function 'ForwardIterator
CGAL::mst_orient_normals(ForwardIterator, ForwardIterator, PointPMap,
> >, PointPMap =
> >, NormalPMap =
> >, Kernel = CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >]':
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:592: error: no matching function
for call to 'vertex(unsigned int&,
> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >&)'
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:601: error: no type named
'vertex_descriptor' in 'class
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:614: warning: format '%u'
expects type 'unsigned int', but argument 2 has type 'size_t'
/usr/include/boost-sandbox/boost/graph/properties.hpp: At global scope:
/usr/include/boost-sandbox/boost/graph/properties.hpp: In instantiation of
'boost::detail::edge_property_map<CGAL::CGALi::Riemannian_graph<std::_List_iterator<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > >, boost::edge_weight_t>':
/usr/include/boost-sandbox/boost/graph/properties.hpp:211: instantiated
from
'boost::property_map<CGAL::CGALi::Riemannian_graph<std::_List_iterator<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
/usr/local/include/CGAL/mst_orient_normals.h:286: instantiated from
'CGAL::CGALi::Riemannian_graph<ForwardIterator>
CGAL::CGALi::create_riemannian_graph(ForwardIterator, ForwardIterator,
PointPMap, NormalPMap, IndexPMap, unsigned int, const Kernel&) [with
ForwardIterator =
> >, PointPMap =
> >, NormalPMap =
> >, IndexPMap =
CGAL::Index_property_map<std::_List_iterator<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, std::bidirectional_iterator_tag>, Kernel =
/usr/local/include/CGAL/mst_orient_normals.h:576: instantiated from
> >, PointPMap =
> >, NormalPMap =
> >, PointPMap =
> >, NormalPMap =
/usr/include/boost-sandbox/boost/graph/properties.hpp:152: error: no type
named 'edge_property_type' in 'class
/usr/include/boost-sandbox/boost/graph/properties.hpp:153: error: no type
named 'graph_tag' in 'class
/usr/include/boost-sandbox/boost/graph/properties.hpp:154: error: no type
/usr/include/boost-sandbox/boost/graph/properties.hpp:156: error: no type
/usr/include/boost-sandbox/boost/graph/properties.hpp:157: error: no type
/usr/include/boost-sandbox/boost/graph/properties.hpp:158: error: no type
ForwardIterator =
> >, PointPMap =
> >, NormalPMap =
> >, IndexPMap =
> >, PointPMap =
> >, NormalPMap =
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:328: error: no type named
/usr/local/include/boost/graph/graph_traits.hpp: At global scope:
/usr/local/include/boost/graph/graph_traits.hpp: In instantiation of
'boost::graph_traits<CGAL::CGALi::Riemannian_graph<std::_List_iterator<std::pair<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
/usr/local/include/CGAL/mst_orient_normals.h:358: instantiated from
ForwardIterator =
> >, PointPMap =
> >, NormalPMap =
> >, IndexPMap =
> >, PointPMap =
> >, NormalPMap =
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/boost/graph/graph_traits.hpp:29: error: no type named
/usr/local/include/boost/graph/graph_traits.hpp:30: error: no type named
'edge_descriptor' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:31: error: no type named
'adjacency_iterator' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:32: error: no type named
'out_edge_iterator' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:33: error: no type named
'in_edge_iterator' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:34: error: no type named
'vertex_iterator' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:35: error: no type named
'edge_iterator' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:37: error: no type named
'directed_category' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:38: error: no type named
'edge_parallel_category' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:39: error: no type named
'traversal_category' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:41: error: no type named
'vertices_size_type' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:42: error: no type named
'edges_size_type' in 'class
/usr/local/include/boost/graph/graph_traits.hpp:43: error: no type named
'degree_size_type' in 'class
ForwardIterator =
> >, PointPMap =
> >, NormalPMap =
> >, IndexPMap =
> >, PointPMap =
> >, NormalPMap =
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:360: error: no matching function
'CGAL::CGALi::MST_graph<ForwardIterator, NormalPMap, Kernel>
CGAL::CGALi::create_mst_graph(ForwardIterator, ForwardIterator, PointPMap,
NormalPMap, IndexPMap, unsigned int, const Kernel&, const
CGAL::CGALi::Riemannian_graph<ForwardIterator>&, ForwardIterator) [with
ForwardIterator =
> >, PointPMap =
> >, NormalPMap =
> >, IndexPMap =
/usr/local/include/CGAL/mst_orient_normals.h:584: instantiated from
> >, PointPMap =
> >, NormalPMap =
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:434: error: no matching function
for call to 'num_vertices(const
/usr/local/include/CGAL/mst_orient_normals.h:442: error: no type named
/usr/local/include/CGAL/mst_orient_normals.h:443: error: no type named
/usr/local/include/CGAL/mst_orient_normals.h:441: error: 'weight_map' was not
/usr/local/include/CGAL/mst_orient_normals.h:441: error: no matching function
for call to 'vertex(unsigned int&, const
> >, PointPMap =
> >, NormalPMap =
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:460: error: no type named
> >, PointPMap =
> >, NormalPMap =
> >, PointPMap =
> >, NormalPMap =
/usr/local/include/CGAL/mst_orient_normals.h:443: error: no matching function
make: *** [objs/i686-darwin9.8.0/meshing.lo] Error 1
Nizar SALLEM
Robotics and Artificial Intelligence PhD student
LAAS-CNRS
7, Avenue Colonel Roche
31077 Toulouse CEDEX 4
FRANCE
- [cgal-discuss] problem using CGAL on Mac OS X 10.5 with boost 1.4, Nizar Khalifa Sallem, 11/03/2009
- Re: [cgal-discuss] problem using CGAL on Mac OS X 10.5 with boost 1.4, Ben Supnik, 11/03/2009
