- To:
- Subject: Re: [cgal-discuss] Creating a CAD model from a polygon
- Date: Wed, 4 Nov 2009 09:17:02 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:reply-to:in-reply-to:references:date:message-id :subject:from:to:content-type; b=AjC789d70+nXeWkFwsr4Loril4ZP9fv4nGOr7rJFcgFvRdzYY30OdnVgfboTOS808l 8R7zhYl5M2uRjmCQVTGx/fnGnt6ZQPiiwNJAWfv/QJmPP8QgZRoXaCrTVXhII+Vyh2Yl Fpd0VkB82xS47xm3tnWvRsMbQt/Dne/SyCc7A=
OpenCasCade / (Python)OCC could help you, and is basically the only option if you're keen on developing your application with Open Source code.
See opencascade.org (or pythonocc.org if you're familiar with Python).
The methods you're looking for are BRepBuilderAPI_MakePolygon to construct the faces, and BRepBuilderAPI_Sewing to join the faces into a solid. Alternatively you could use BRepBuilderAPI_Shell to create a shell from the faces, and create a Solid with BRepBuilderAPI_Solid to build the solid. OCC reads / writes IGES & STEP.
Hope this helps.
Best,
-jelle
On Wed, Nov 4, 2009 at 8:53 AM, Martin Baeker <> wrote:
Does anybody know of a simple way to create a solid model usable in a
CAE program from a polygon? I would need one of the following file
formats:
3Dxml
ACIS (.sat)
IGES
STEP
Parasolid
Thanks for any help,
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
e-mail <>
- [cgal-discuss] Creating a CAD model from a polygon, Martin Baeker, 11/04/2009
- Re: [cgal-discuss] Creating a CAD model from a polygon, jelle feringa, 11/04/2009
