- To:
- Subject: Re: [cgal-discuss] example in Surface_mesher
- Date: Thu, 5 Nov 2009 10:41:25 +0100
On Wednesday 04 November 2009 09:35:54
wrote:
> The version of the CGAL I use is 3.5 and the CMake 2.6.4
Well, I am not sure but it might be related to a bug I found out in CMake,
during the "make install" part: the binaries are stripped and, apparently, it
lead to binary corruption of libCGAL_ImageIO.
Can you try the following? Copy lib/libCGAL_ImageIO.so.4 from the compile
tree
of CGAL, to the directory where you installed CGAL, to replace the
libCGAL_ImageIO.so.4 which was installed (and stripped) by CMake. It may
solve
your problem.
Laurent Rineau, PhD
- [cgal-discuss] example in Surface_mesher, zengdeshou, 11/04/2009
- Re: [cgal-discuss] example in Surface_mesher, Laurent Rineau (GeometryFactory), 11/04/2009
- Re: Re: [cgal-discuss] example in Surface_mesher, zengdeshou, 11/04/2009
- Re: [cgal-discuss] example in Surface_mesher, Laurent Rineau (GeometryFactory), 11/05/2009
- Re: Re: [cgal-discuss] example in Surface_mesher, zengdeshou, 11/07/2009
