cgal-discuss - Re: [cgal-discuss] Segmentation fault when removing vertices from a Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] Segmentation fault when removing vertices from a Delaunay triangulation
  • Date: Fri, 06 Nov 2009 16:21:40 +0100
  • Organization: INRIA
Josip Dzolonga wrote:
Here is the problematic code:
for(std::list<Facet>::iterator iter = grown->facets->begin();
iter != grown->facets->end(); ++iter) {
Cell_handle c = (*iter).first;
int index = (*iter).second;
T.remove(c->vertex((index+1)%4));
T.remove(c->vertex((index+2)%4));
T.remove(c->vertex((index+3)%4));
Basically, I have a set of facets that I have extracted from the triangulation and I want to remove them along with their points. But, the T.remove lines cause segmentation faults, where T is of type CGAL::Triangulation_hierarchy_3<Dt>. I get no precondition errors, just a segfault.
When you remove() the first vertex, then the Cell c becomes invalid.
Then, everything can happen. You need to memorize the Vertex_handles
first, and then remove them without refering to Cells or Facets that
may become invalid.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
