cgal-discuss - Re: [cgal-discuss] about nearest_neighbor_searching
  • To:
  • Subject: Re: [cgal-discuss] about nearest_neighbor_searching
  • Date: Thu, 12 Nov 2009 14:29:44 +0100
Flaminigo schrieb:
Hi, I am using CGAL nearest_neighbor_searching to find the nearest neighbor of a given point.
However, the search function only return the coordinates of the nearest point. If i want to mark the original point set for querying. What should I do? I want the search function not only return the coordinates, but also return the id of this point.
I had the same problem several years ago. I don't know if there
is a clean solution in the current version, but my solutions then
were:
a) Using an additional STL-map
b) Add getIndex() / setIndex()-functions to CGAL's Point_2. I did
it like this, but the solution is dirty as the code is then bound
to the modified CGAL code.
c) Meantime I use http://github.com/jmhodges/kdtree2, which is
faster and returns the index of the point.
Best
Bernhard
