cgal-discuss - [cgal-discuss] Surface mesh simplification
  • To:
  • Subject: [cgal-discuss] Surface mesh simplification
  • Date: Thu, 12 Nov 2009 23:01:10 -1000
Hi all,
I'm running into a couple of problems (bugs?) in the surface mesh
simplification package in CGAL 3.5.
The first is an issue with visitors that was reported here in CGAL
3.5-beta:
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2009-09/msg00123.html
It still seems to exist in the released version of 3.5. I can work
around this using member references in the visitor class, so it's not a
big deal.
Second, I'm trying to simplify a mesh by just collapsing all edges
shorter than some amount. I find that many qualifying edges remain
after edge_collapse has done its thing. Attached is a small example
that illustrates this. Has anyone else encountered this? Any
suggestions?
Cheers,
Brandoch
Attachment: remove_short_edges.cpp
Description: Binary data
Attachment: poly.off
  • [cgal-discuss] Surface mesh simplification, Brandoch Calef, 11/13/2009
