- To:
- Subject: Re: [cgal-discuss] Delauney graph constrained by outline
- Date: Tue, 17 Nov 2009 10:55:09 +0100
James Le Cuirot wrote:
On Tue, 17 Nov 2009 10:33:54 +0100, "Andreas Fabri"
Hello,Hello James,
Before I start, please excuse my lack of mathematical knowledge in this
area. I need to create a Delaunay graph to generate a Vonoroi diagram from.
The examples are very helpful but I need to add one extra constraint. The
graph will be built from geographical points across the UK but I don't want
edges to cross over the water, at least not by a large amount. If I have an
outline of the UK as a polygon, can I somehow use this to constrain the
resulting graph? I know about the constrained triangulations mentioned in
the manual but I don't think they will work. Any help would be much
appreciated. :)
Cheers,
James
You mean you want to clip Voronoi cells at borders ?
andreas
I understand that Voronoi cells extend to infinity around the outside so
yes but not only that. Where parts of the UK are concave (e.g. between
Wales and South-West England), the cells will cross over the water here
too. Now you mention the word "clip" though, I guess I could just clip
the resulting Voronoi afterwards? I think I was thinking about this too
hard. :)
Clipping is not the only thing you need here. When you have a point in
South-West England then you don't want it to have any Voronoi cell in
Wales. There is a prototype floating around that does what you want to do,
but I am not sure that it has an API stable enough to be distributed.
andreas
- [cgal-discuss] Delauney graph constrained by outline, James Le Cuirot, 11/17/2009
- Re: [cgal-discuss] Delauney graph constrained by outline, Olivier Devillers, 11/17/2009
- Re: [cgal-discuss] Delauney graph constrained by outline, James Le Cuirot, 11/17/2009
- Re: [cgal-discuss] Delauney graph constrained by outline, Andreas Fabri, 11/17/2009
