- To:
- Subject: Re: [cgal-discuss] Error when calling linear_least_squares_fitting_2
- Date: Tue, 17 Nov 2009 21:33:58 +0100
- Organization: INRIA
dear Genis, can you dump your point coordinates to the console and then to your email? I could take a look at your problem. thank you, Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 Genís a écrit : I read carefully the documentation and I understood that error launches when all lines going through the centroid of the cloud of points fit. The problem is that the program crashes when that happens. Is there any way I could check that before calling linear_least_squares_fitting_2? or, better, any way I could handle that exception avoiding that crash? (sorry for my poor english). Genís wrote:Hello, I often get the following error when calling linear_least_squares_fitting_2: main: /usr/include/CGAL/eigen_2.h:69: void CGAL::CGALi::eigen_symmetric_2(const typename K::FT*, std::pair<typename K::Vector_2, typename K::Vector_2>&, std::pair<typename K::FT, typename K::FT>&) [with K = CGAL::Cartesian<double>]: Assertion `a == 0 || c == 0.0' failed. I imagine that it is caused because I don't use an exact predicates kernel, could it be that? The problem is that when I try to use a kernel as Cartesian<CGAL::Gmpq> I get a long compilation error. Ciao |
- [cgal-discuss] Error when calling linear_least_squares_fitting_2, Genís, 11/17/2009
- Re: [cgal-discuss] Error when calling linear_least_squares_fitting_2, Genís, 11/17/2009
- Re: [cgal-discuss] Error when calling linear_least_squares_fitting_2, Pierre Alliez, 11/17/2009
- Re: [cgal-discuss] Error when calling linear_least_squares_fitting_2, Genís, 11/18/2009
