- To:
- Subject: [cgal-discuss] Problem using incremental_builder_3.
- Date: Sat, 21 Nov 2009 09:24:42 +0100 (CET)
Hello CGALer,
(Sorry) I'm still a newbee in CGAL and I have this following problem :
Trying to build a simple prism (with a triangle base) and I get this error
when
I try to build a facet sharing points with another one :
lookup_halfedge(): input error: facet 2 shares a halfedge from vertex 0 to
vertex 1 with facet 0.
My code is :
B.begin_surface(6,3,0);
//upper vertices
B.add_vertex( Point_3(-1,0,0));
B.add_vertex( Point_3(1,0,0));
B.add_vertex( Point_3(0,1,0));
//lower vertices
B.add_vertex( Point_3(-1,0,-1));
B.add_vertex( Point_3(1,0,-1));
B.add_vertex( Point_3(0,1,-1));
//upper-facet
B.begin_facet();
B.add_vertex_to_facet(0);
B.add_vertex_to_facet(1);
B.add_vertex_to_facet(2);
B.end_facet();
//bottom-facet
B.begin_facet();
B.add_vertex_to_facet(3);
B.add_vertex_to_facet(4);
B.add_vertex_to_facet(5);
B.end_facet();
// side-facet 1 of 3 (doing this make problem)
B.begin_facet();
B.end_facet();
B.end_surface();
What's wrong ?
Gilles
- [cgal-discuss] Problem using incremental_builder_3., Gilles, 11/21/2009
- Re: [cgal-discuss] Problem using incremental_builder_3., Nico Kruithof, 11/21/2009
- Re: [cgal-discuss] Problem using incremental_builder_3., Gilles Kneuss, 11/21/2009
