- To:
- Subject: Re: Re: [cgal-discuss] Inserting vertices into Voronoi Diagram
- Date: Mon, 23 Nov 2009 13:13:14 +0100 (CET)
Hello,
your help actually cleared the fog in my head for a second and i changed the
code like that:
virtual void get_next_diagram(){
typedef std::vector<Point_2> Point_vector;
Point_vector pv;
Vertex_iterator vit;
Point_2 p;
for (vit = this->vertices_begin(); vit != this->vertices_end(); ++vit) {
p = Point_2((*vit).point().x(), (*vit).point().y());
pv.push_back(p);
this->clear();
for (unsigned int i = 0; i < pv.size(); i++) {
this->insert(pv[i]);
It works perfectly. The clear-Function seems have invalidated the vertices
indeed. So i used a point vector instead, saving the points instead of the
vertex references. Like both of you suggested. Thank you very much. I guess i
should have asked the mailing list much earlier.
Good day,
Artyom
- [cgal-discuss] Inserting vertices into Voronoi Diagram, chernysh, 11/23/2009
- Re: [cgal-discuss] Inserting vertices into Voronoi Diagram, chernysh, 11/23/2009
- Re: [cgal-discuss] Inserting vertices into Voronoi Diagram, Daniel Duque, 11/23/2009
- Re: [cgal-discuss] Inserting vertices into Voronoi Diagram, Bernd Gaertner, 11/23/2009
- Re: Re: [cgal-discuss] Inserting vertices into Voronoi Diagram, chernysh, 11/23/2009
- Re: [cgal-discuss] Inserting vertices into Voronoi Diagram, Sylvain Pion, 11/23/2009
