cgal-discuss - [cgal-discuss] failed to start the examples programs
  • To:
  • Subject: [cgal-discuss] failed to start the examples programs
  • Date: Wed, 25 Nov 2009 01:31:58 +0100 (CET)
hello,
I installed the last version of CGAL, 3.5 (with QT 4.5.3 and Boost 1.40).
All the libraries of CGAL compile correctly. My problem starts when I want to
execute the examples or the demos.
The compilation of the examples/demos are correct, but when I try to execute,
I
always get an error. The error is distinct if I compile in debug or release
mode. If I try to execute the example in Debug mode, I always get the next
error: Can't initialice the application because his configuration is incorrect
(traduce from my spanish windows)
If I try with the executable from the release mode, I always get an error that
says that the application can't start correctly. When I use this mode, the
information in Visual Studio is the next:
'prueba_CGAL.exe': se cargó 'C:\Documents and Settings\anhurt\Mis
documentos\Visual Studio 2005\Projects\prueba_CGAL\release\prueba_CGAL.exe',
Símbolos cargados.
'prueba_CGAL.exe': se cargó 'C:\WINDOWS\system32\ntdll.dll', No se cargaron
símbolos.
'prueba_CGAL.exe': se cargó 'C:\WINDOWS\system32\kernel32.dll', No se cargaron
símbolos.
'C:\WINDOWS\WinSxS\x86_Microsoft.VC80.DebugCRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_f75eb16c\msvcp80d.dll',
Símbolos cargados.
'C:\WINDOWS\WinSxS\x86_Microsoft.VC80.DebugCRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_f75eb16c\msvcr80d.dll',
Símbolos cargados.
'prueba_CGAL.exe': se cargó 'C:\WINDOWS\system32\msvcrt.dll', No se cargaron
símbolos.
'C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc80-mt-gd.dll', Símbolos cargados.
LDR: LdrpWalkImportDescriptor() failed to probe
C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc80-mt-gd.dll for its manifest,
ntstatus 0xc0150002
Depurador:: excepción no controlada y no continuada durante la carga del
proceso
El programa '[10388] prueba_CGAL.exe: Nativo' terminó con código -1072365566
(0xc0150002).
Obviously, the problem comes with: "LdrpWalkImportDescriptor() failed to probe
C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc80-mt-gd.dll for its manifest"
So...I don't know how can I fix it. I'll try to do an search over the web, but
I can't find anything that fix it.
My OS is Windows XP Sp3. I use Visual Studio 2005, and I suppose that all the
directories and dependencies are correct, because the compilation of CGAL and
all of the examples and demos is well done.
Thank you very much in advance for your ideas/answers.
Antonio H.
