- To:
- Subject: Re: Res: [cgal-discuss] testing for polygon containment
- Date: Wed, 25 Nov 2009 15:19:54 -0500
Sorry for the half-send...performance will depend on the nature of the dataset and what is desired. Random thoughts:
- True intersection is going to be expensive. For example, when you consider the effects of polygons that are disjoint except at edges/vertices, you might need a true polygon boolean intersection, which requires an exact numeric type.
- The intersection will be superior to the previous technique (containment tests on each edge) - intersection is O(N+MlogN+M) whereas the intersection test I think is O(NM).
- It might be possible to do sweeps on all vertices of the polygon at once, e.g. "which of this set of points are in the polygon" which would be faster than individual tests. I'm not sure what the best interface for that is...possibly to build an arrangement off of the polygon using accelerated insertions, then do a bulk point locate on the arrangement (which sweeps).
- A filtered or lazy adapter might speed gmp up, especially if your input numbers are IEEE doubles.
- The only CGAL tools that will work reliably with IEEE doubles that are applicable that I know of are:
1. Bbox2 for a quick check - if most polygons don't contain each other, a few fast bbox tests might save you a lot of time.
2. You can do a do_intersect on line segments on the union of all edges of both polygons, even with an exact-predicate inexact construction kernel, which will be faster. But you'd have to be careful about how exactly overlapping polygons are handled.
cheers
ben
Marcos R. P. wrote:
Try this:
Test if there are intersection between polygons and test if a point of one is an interior point of other.
Marcos
*De:* Cristiano Nattero
*Para:*
*Enviadas:* Quarta-feira, 25 de Novembro de 2009 8:14:19
*Assunto:* [cgal-discuss] testing for polygon containment
Hello everybody,
how would you test if a polygon is contained inside another?
I used the condition that a polygon A is contained in a polygon B
iff all the edges of A are contained in B.
Unfortunately - and it might be a problem of my implementation: I
use Polygon_2 with Gmpq point coordinates - I am not satisfied with
its speed. Can you think of a quicker way?
Thank you very much.
Ciao,
Cristiano
http://cristianonattero.com/blog
MSN messenger:
<mailto:>
yahoo IM: cristiano.nattero
jabber/GoogleTalk: <mailto:>
AIM:
<mailto:>
skype: cristianonattero
SIP:
<mailto:>
Linux User #368283
http://counter.li.org/
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/> - Celebridades <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/celebridades/> - Música <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/m%C3%BAsica/> - Esportes <http://br.rd.yahoo.com/mail/taglines/mail/*http://br.maisbuscados.yahoo.com/esportes/>
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] testing for polygon containment, Cristiano Nattero, 11/25/2009
- Res: [cgal-discuss] testing for polygon containment, Marcos R. P., 11/25/2009
- Re: Res: [cgal-discuss] testing for polygon containment, Ben Supnik, 11/25/2009
