cgal-discuss - [cgal-discuss] installing taucs on snow leopard
  • To:
  • Subject: [cgal-discuss] installing taucs on snow leopard
  • Date: Sat, 28 Nov 2009 23:26:44 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=from:content-type:content-transfer-encoding:subject:date:message-id :to:mime-version:x-mailer; b=RiS3DZvL6UluVNJW86azHRtNJeIX3k79qvKi6tO6t60fQSRTHSKP8CnWliK6vHeIxi /mYUNFXliwzp6r4fCIVc8SFXOVTxm9uVKN8D5+ckDWgBFTNaIA+fi9Z6ncIggj6CMkDl H8ZqBDv4NRJCee66vtXM1mLlae63Ujvye+ltI=
hi,
I want to use the Poisson Surface Reconstruction so I need taucs. There are
some installation tutorials for windows, but with unix it says only that you
have to compile it yourself. I'm quite new to writing stuff into makefiles
because I use cmake-gui and macports. Please tell me if you need additional
information about my system. Any help is appreciated.
Here is what I have done so far:
in the taucs_full dir I type:
$ sudo ./configurator/configurator
error: the environment variable OSTYPE is not set
$ echo $OSTYPE
darwin10.0
$ export OSTYPE=darwin_intel
$ echo $OSTYPE
darwin_intel
also this does not work
$ sudo ./configure
cc -o configurator/configurator configurator/taucs_config.c
rm -rf lib/darwin_intel/*
rm -rf obj/darwin_intel/*
rm -rf bin/darwin_intel/*
rm -rf lib/darwin_intel/*.*
rm -rf obj/darwin_intel/*.*
rm -rf bin/darwin_intel/*.*
rm -rf build/darwin_intel/taucs_config_tests.h
rmdir obj/darwin_intel/
rmdir: obj/darwin_intel/: No such file or directory
make: [clean] Error 1 (ignored)
rmdir bin/darwin_intel/
rmdir: bin/darwin_intel/: No such file or directory
rmdir lib/darwin_intel/
rmdir: lib/darwin_intel/: No such file or directory
and this gives
$ sudo ./make
ld: warning: in external/lib/darwin_intel/libmetis.a, file is not of required
architecture
ld: warning: in external/lib/darwin_intel/libf2c.a, file is not of required
architecture
ld: symbol(s) not found
collect2: ld returned 1 exit status
thanks, yuri
