cgal-discuss - Re: [cgal-discuss] Problems with CGAL 3.5
  • To:
  • Subject: Re: [cgal-discuss] Problems with CGAL 3.5
  • Date: Sun, 06 Dec 2009 21:55:04 +0100
Hi,
i assume some libraries are missing.
i experienced similar problems lately when i reinstalled CGAL and tried to use my old code which required CGAL and Qt3 ONLY.
So I installed on Windows XP: Visual Studio 2005+SDK, Cmake2.6, boost, free version of qt3 and CGAL 3.5. But i recieved the same message when executing my code. So i installed Qt4 AND went through the configure+nmake procedure (which takes several hours). My code worked afterwards.
I guess CGAL is being compiled properly without some components, but still those components are essential when executing your code.
I'm new to CGAL, so i guess you listen to other opinions on this matter.
Bye,
Artyom
Am 06.12.2009, 20:31 Uhr, schrieb Pinto
Hi all,
I'm having problems when I run my code: at the moment of compilation, no error
is reported but when I try to execute, I'm having the following message: "The
application failed to initialize properly (0xc000007b)"
I am using CGAL 3.5 and .NET libraries. I must use the \clr:oldsyntax option to
compile it (I had problems with the commands like
#using <mscorlib.dll>
#using <System.xml.dll>
Does anyone already had this problem or know how to solve it?
Thanks in advance,
Telmo Pinto
Erstellt mit Operas revolutionärem E-Mail-Modul: http://www.opera.com/mail/
