cgal-discuss - Re: [cgal-discuss] Combining Triangulation_euclidean_traits_xy_3 with Constrained_Delaunay_triangulation_2
  • To:
  • Subject: Re: [cgal-discuss] Combining Triangulation_euclidean_traits_xy_3 with Constrained_Delaunay_triangulation_2
  • Date: Wed, 16 Dec 2009 15:36:04 -0700
Am 16.12.2009 um 15:28 schrieb Laurent Rineau (GeometryFactory):
> Le mercredi 16 décembre 2009 19:32:44, Ole Rehmsen a écrit :
>> Hey everyone,
>> I could not find an answer in the FAQ, the documentation or the mailing
>> list archives. I am using the CDT to triangulate a set of points lying in
>> the x-y-plane, but later would like to elevate these points (in z
>> direction). I stumbled across Triangulation_euclidean_traits_xy_3 which
>> basically allows just that, only for the non-constraint Delaunay
>> triangulation. Is it somehow possible to use 3D points for a CDT that
>> simply ignores the z coordinate?
> Do your constraints intersect, or might intersect? Because, in case of an
> intersection, the difficulty is choose a z coordinate for the intersection.
No, the constraints form a simple, not necessarily convex polygon. For my
application, it would be fine if the triangulation would completely ignore
the z-values. The only reason I want them there is that I will afterwards do
some processing that will involve finding the desired z values. The other
approach for me would be to convert the whole triangulation into a data
structure that allows 3-D points by simply choosing z=0, which is also
possible, but not very efficient. That's why I thought there might be a
better way (as there is one for non-constrained Delaunay triangulations).
Attachment: smime.p7s
Description: S/MIME cryptographic signature
