Re: [cgal-discuss] VS 2010 : Has anybody succeeded to build CGAL 3.5 on VS2010 ?
- To:
- Subject: Re: [cgal-discuss] VS 2010 : Has anybody succeeded to build CGAL 3.5 on VS2010 ?
- Date: Sat, 19 Dec 2009 12:53:38 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type; b=rQvGYV3KHGqfyriKIG/ZsI74eH86D3MdXX2/pKh7Moeou/FSSHJ9CuuLtRPKsdZXM5 tVU85fh25iDvFQe3MeIZBUqY6WsvGji0R2KfoWFTrQWRlVIOeZvKI97QD1jPuBLOPqUN NPMXTX1D7CBN0d/frrIfN1LWObSxWmyCkR8y0=
I think it wants the Boost thread library. Have you tried compiling the
boost thread library and making a variable in Cmake that points to that
location? /Priyank Gasnier wrote: I have been using CGAL with VS2005 and VS2008 but until now I have failed to compile CGAL 3.5 with VS2010 beta 2. I successfully compiled boot 1.41.0 but I am still blocked with cmake-gui (2.9) failing to configure because of missing boost_thread library. CMake output looks familiar since it appears in numerous posts in this forum dealing with compilation with previous versions of Visual Studio. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< CMake Error at cmake/modules/FindBoost.cmake:885 (message): Unable to find the requested Boost libraries. Boost version: 1.41.0 Boost include path: C:/Program Files/Boost/boost_1_41_0 The following Boost libraries could not be found: boost_thread No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the directory containing Boost libraries or BOOST_ROOT to the location of Boost. Call Stack (most recent call first): cmake/modules/CGAL_SetupBoost.cmake:12 (find_package) cmake/modules/CGAL_SetupDependencies.cmake:17 (include) CMakeLists.txt:220 (include)If you ever succeeded to compile CGAL 3.5 with VS2010, please share your ynowledge. Thanks in advance. |
- [cgal-discuss] VS 2010 : Has anybody succeeded to build CGAL 3.5 on VS2010 ?, Gasnier, 12/19/2009
- Re: [cgal-discuss] VS 2010 : Has anybody succeeded to build CGAL 3.5 on VS2010 ?, Priyank Jain, 12/19/2009
- Re: [cgal-discuss] VS 2010 : Has anybody succeeded to build CGAL 3.5 on VS2010 ?, Bo Zhou, 12/20/2009
- Re: Re: [cgal-discuss] VS 2010 : Has anybody succeeded to build CGAL 3.5 on VS2010 ?, Gasnier, 12/21/2009
