- To:
- Subject: Re: [cgal-discuss] Voronoi diagram - Could some one explain me this output?
- Date: Sat, 02 Jan 2010 11:02:13 +0100
Hi Ben,
Your 4 points are the vertices of a square, which is a degenerate case since the 4 points are cocircular.
The triangulation consists in two triangles, both having the center of the square, ie the origin, as circumcenter.
So, the dual segment to the common edge of these two triangles (a diagonal of the square) has the origin as its two equal endpoints.
Best,
Monique Teillaud
Ben Strasser wrote:
Hello,
I'm trying to iterator over the boundaries of the facets of a Voronoi
diagram and have run into a CGAL behavior I can not explain. I build the
diagram of the points (1, 1), (-1, 1), (-1, -1) and (1, -1). Then I just
print out what objects CGAL gives me.
seg:-0 -0 -0 -0
ray:-0 -0 4 -0
ray:-0 -0 -0 4
--- ray:-0 -0 -4 -0
ray:-0 -0 -0 4
--- ray:-0 -0 -0 -4
seg:-0 -0 -0 -0
ray:-0 -0 -4 -0
--- ray:-0 -0 -0 -4
ray:-0 -0 4 -0
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] Voronoi diagram - Could some one explain me this output?, Ben Strasser, 01/02/2010
- Re: [cgal-discuss] Voronoi diagram - Could some one explain me this output?, Monique Teillaud, 01/02/2010
