- To:
- Subject: [cgal-discuss] Check if a point inside of a polygon_with_hole or a polygon_set
- Date: Tue, 5 Jan 2010 11:32:18 +0800 (CST)
I fide a function to check if a point inside a polygon. Are there some functions working for a polygon_with_hole or a polygon_set in CGAL?
Thank in advance
- [cgal-discuss] Customizing CGAL::Qt_widget_standard_toolbar, eduriol, 01/04/2010
- Re: [cgal-discuss] Customizing CGAL::Qt_widget_standard_toolbar, Andreas Fabri, 01/04/2010
- [cgal-discuss] Check if a point inside of a polygon_with_hole or a polygon_set, Mumu, 01/05/2010
