cgal-discuss - Re: [cgal-discuss] Jagged boundaries in segmented 3D mesh generation
  • To:
  • Subject: Re: [cgal-discuss] Jagged boundaries in segmented 3D mesh generation
  • Date: Fri, 08 Jan 2010 14:34:47 +0100
wrote:
I get the attached effect. The boundaries between the colors are straight and
smooth, as the function goes, but the meshing is rather jagged. Is that what
you mean by not preserving features just yet?
Thanks, Amir.
Yes, for example the edge between red and orange will be jagged without edge preservation. Our current mesh generation process only provides garantees about surface facets and tetrahedra of the mesh.
As I'm not sure to fully understand your problem, let me add this:
concerning the surfaces, did you try to play with the distance bound parameter, which controls the approximation error from mesh surface facets to the surface of the domain you are meshing ?
Quoting Stephane Tayeb
Amir Vaxman wrote:
Hello,
My input is a volumetric subdivision of the space to which I apply the 3D
mesh generation package. Even if my implicit oracle function (of what
point
has what volume index) is smooth, I still get jagged boundaries between
the
volumes, even for rather fine tet sizes. Is it inevitable, or is there a
fix
to it?
Thanks, Amir.
Hi,
Do you mean that the edges or the surfaces between the subdomains are not smooth ? The surfaces should be smooth, the edges are not. The current release of CGAL 3D Mesh Generator is designed for smooth surfaces only, i.e. it does not preserve sharp features (FYI we plan to release feature preservation later on, maybe in 3.7).
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
Stephane Tayeb
