cgal-discuss - Re:Re: [cgal-discuss] Configure error with Cmake for boost library
  • To:
  • Subject: Re:Re: [cgal-discuss] Configure error with Cmake for boost library
  • Date: Thu, 14 Jan 2010 17:09:05 +0800 (CST)
Thank you very much :) The issue is solved with someone's help. Yes, the building process is beyond complicate for the beginner. Maybe someone can improve it so as to absorb more guys to join in.
在2010-01-14 16:57:21,Remi <> 写道:
>Using CMake to find Boost is a joke. The file FindBoost.cmake is a
>joke. The result would be the same if you simply included what needed
>from CGAL into your project and compile it the way you want. Your
>compiler would point it out to you that it cannot find Boost headers
>also but you wouldn't be so confused as to how to fix that. Open
>source libraries shouldn't enforce a build system on the user
>(especially if it gets so convulted as in this case). Nor should they
>use CMake (or any other build system) to magically plow through your
>PC and based on some rules (contained in 500K lines of CMake scripts)
>GENERATE ACTUAL SOURCE CODE. It just feels so wrong to let the build
>tool generate source code. Don't even get me started on that.
>BTW GGAL is no exception here. I think this is a widespread trend to
>make the build super complicated for no good reason.
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
